K202XHT-E9S-N30
K202XHT-E9S-N30
    KYCON
    SMD
    SMT D9 ULT SHRT RT< FML 2ND PCB-
K202XHT-E9S-N30 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Check Stock Request a Sample Certificate of Origin Send Us An Email Generated Part Number K202XHT-E15S-N Part Number Builder LR78160 D-SUBMINIATURE CONNECTORS: K202XHT Series Right Angle Surface Mount K202XHT Series E15 S N Shell Size Contact Contact Type Mounting Option Plating Option Series K202XHT - D-Subminiature Connector, Right Angle, Ultra Short Footprint, Surface Mount, Reflow Compatible K202XHT Series Dimensions Dimensions in mm Shell Size-Contact Option E - 9 Contacts B - 25 Contacts E - 15 Contacts, High Density (Socket only) C B A, A1 2.84 8.36 Plug Interior 7.90 Socket Exterior Contact Type P - Pin Contact (Plug) S - Socket Contact (Receptacle) 12.55 #4-40 UNC Threaded Inserts Mounting Option N - With Boardlocks and #4-40 UNC Threaded Inserts NJ - With Boardlocks and JSX-1055 Jackscrews Installed Plating Option Blank - Gold Flash 15 - 15µ” Gold 30 - 30µ” Gold D Contact Kycon for Tape and Reel and Other Options 6.1 Plug 5.8 Socket Shell Size In mm 9 (E) 15 (E) 25 (B) A ±.010 ±0.25 A1 ±.010 ±0.25 B ±.005 ±0.13 C ±.015 ±0.38 D ±.005 ±0.13 .643 16.33 .643 16.33 1.511 38.38 .666 16.92 .984 24.99 .984 24.99 1.852 47.04 1.213 30.81 1.213 30.81 2.088 53.04 .626 15.90 .609 15.46 1.498 38.06 N/A 1.534 38.96 A = Exterior of Female Shell (S) A1 = Interior of Male Shell (P) Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0318
K202XHT-E9S-N30 价格&库存
很抱歉,暂时无法提供与“K202XHT-E9S-N30”相匹配的价格&库存,您可以联系我们找货
