TL50GRQ
TL50GRQ
    BANNER(邦纳)
    Module
    堆叠灯 全套装置 绿色,红色 LED 导线引线
TL50GRQ 数据手册
TL50 Tower Light Datasheet Multi-Color General-Purpose or Audible Indicators • • • • • • • • • Rugged, cost-effective, and easy-to-install multi-segment indicators Illuminated segments provide easy-to-see operator guidance and indication of equipment status Up to 7 stacked colors available Available in black or light gray housing Audible models available with standard, sealed, or omni-directional audible element Compact devices are completely self-contained, no controller needed Models with 1 to 5 segments, 18 V dc to 30 V dc or 24 V ac operation Models with 6 to 7 segments, 12 V dc to 30 V dc or 24 V ac operation No assembly required Non-Audible Models Model 1 # of LED Colors TL50RQ 1 Red TL50GRQ 2 Green, Red TL50GYRQ 3 Green, Yellow, Red TL50BGYRQ 4 Blue, Green, Yellow, Red Integral 5-pin M12/Euro-style quick disconnect TL50WBGYRQ 5 White, Blue, Green, Yellow, Red Integral 8-pin M12/Euro-style quick disconnect LED Colors 2 Connection3 Inputs Integral 4-pin M12/Euro-style quick disconnect Bimodal (NPN or PNP) Audible Models Standard Audible Model1 # of LED Colors LED Colors 2 TL50RAQ 1 Red TL50GRAQ 2 Green, Red TL50GYRAQ 3 Green, Yellow, Red TL50BGYRAQ 4 Blue, Green, Yellow, Red TL50WBGYRAQ 5 White, Blue, Green, Yellow, Red Pulsed at 1.6 Hz Inputs Integral 4-pin M12/Euro-style quick disconnect Sealed Audible Model1 Continuous Connection 3 Staccato Integral 5-pin M12/Euro-style quick disconnect Bimodal (NPN or PNP) Integral 8-pin M12/Euro-style quick disconnect # of LED Colors LED Colors 2 TL50RALSQ TL50RALS3Q TL50RALS4Q 1 Red TL50GRALSQ TL50GRALS3Q TL50GRALS4Q 2 Green, Red TL50GYRALSQ TL50GYRALS3Q TL50GYRALS4Q 3 Green, Yellow, Red TL50BGYRALSQ TL50BGYRALS3Q TL50BGYRALS4Q 4 Blue, Green, Yellow, Red TL50WBGYRALSQ TL50WBGYRALS3Q TL50WBGYRALS4Q 5 White, Blue, Green, Yellow, Red Connection 3 Inputs Integral 4-pin M12/Euro-style quick disconnect Integral 5-pin M12/Euro-style quick disconnect Integral 8-pin M12/Euro-style quick disconnect Bimodal (NPN or PNP) 1 Models with black housing are listed. For gray housing, add the suffix "C" at the end of the cabled model number or before the "Q" in quick disconnect model numbers. For example, TL50RAC or TL50RACQ. 2 The first color listed is the bottom color, going up in successive order. Other available colors include: Turquoise (T), Orange (O), Violet (V), Sky Blue (S) and Magenta (M). 3 • To order the 150 mm (6 in) PVC cable model with a M12/Euro-style quick disconnect, replace the suffix "Q" with "QP" in the model number. For example, TL50RAQP. • To order the 2 m (6.5 ft) PVC cable model, omit the suffix "Q" in the model number. For example, TL50RA. • Models with a quick disconnect require a mating cordset. Original Document 142406 Rev. R 6 May 2019 142406 TL50 Tower Light Omni-Directional4 Sealed Audible Model 1 Continuous Pulsed at 1.6 Hz # of LED Colors Staccato LED Colors 2 TL50RAOSQ TL50RAOS3Q TL50RAOS4Q 1 Red TL50GRAOSQ TL50GRAOS3Q TL50GRAOS4Q 2 Green, Red TL50GYRAOS3Q TL50GYRAOS4Q 3 Green, Yellow, Red TL50BGYRAOSQ TL50BGYRAOS3Q TL50BGYRAOS4Q 4 Blue, Green, Yellow, Red TL50WBGYRAOSQ TL50WBGYRAOS3Q TL50WBGYRAOS4Q 5 White, Blue, Green, Yellow, Red Continuous Pulsed at 1.6 Hz Staccato # of LED Colors Inputs Integral 4-pin M12/Euro-style quick disconnect TL50GYRAOSQ Omni-Directional4 Sealed Audible Model with Intensity Adjustment 1 Connection 3 Integral 5-pin M12/Euro-style quick disconnect Integral 8-pin M12/Euro-style quick disconnect LED Colors 2 TL50RAOSIQ TL50RAOS3IQ TL50RAOS4IQ 1 Red TL50GRAOSIQ TL50GRAOS3IQ TL50GRAOS4IQ 2 Green, Red TL50GYRAOSIQ TL50GYRAOS3IQ TL50GYRAOS4IQ 3 Green, Yellow, Red TL50BGYRAOSIQ TL50BGYRAOS3IQ TL50BGYRAOS4IQ 4 Blue, Green, Yellow, Red TL50WBGYRAOSIQ TL50WBGYRAOS3IQ TL50WBGYRAOS4IQ 5 White, Blue, Green, Yellow, Red Connection 3 Bimodal (NPN or PNP) Inputs Integral 4-pin M12/Euro-style quick disconnect Integral 5-pin M12/Euro-style quick disconnect Integral 8-pin M12/Euro-style quick disconnect Bimodal (NPN or PNP) Wiring Diagram — 4-Pin Models with 1 to 3 Segments PNP Input NPN Input 3 Indicator Color 18-30V dc 24V ac 4 C1 1 C2/A 3 Indicator Color 18-30V dc 24V ac 4 C1 1 = Brown 2 = White 3 = Blue 4 = Black C1 = Color 1 C2 = Color 2 C3 = Color 3 A = Audible 1 C2/A 2 C3/A Key: Pins 1 and 2 can activate the corresponding color or the audible function, if available. 2 C3/A Wiring Diagram – 5-Pin Models with 4 Segments PNP Input NPN Input Key: Indicator Color C1 3 4 18-30V dc 24V ac Indicator Color C1 4 18-30V dc 24V ac 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray C1 = Color 1 C2 = Color 2 C3 = Color 3 C4 = Color 4 A = Audible 1 1 C2 C2 2 C3 C4/A 3 5 2 C3 C4/A 5 Pin 5 can activate the corresponding color or the audible function, if available. 4 Sound exits at 45°. 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 142406 Rev. R TL50 Tower Light Wiring Diagram — 8-Pin Models with 5 Segments PNP Input NPN Input Key: Indicator Color 7 18-30V dc 24V ac 6 2 2 C2 C2 C4 C5/A 18-30V dc 24V ac 6 C1 C1 C3 Indicator Color 7 1 C3 5 C4 4 C5/A 1 1 = White 2 = Brown 3 = Green 4 = Yellow 5 = Gray 6 = Pink 7 = Blue 8 = Red C1 = Color 1 C2 = Color 2 C3 = Color 3 C4 = Color 4 C5 = Color 5 A = Audible 5 4 8 8 3 3 Pin 4 can activate the corresponding color or the audible function, if available. Pins 3 and 8 are not used. Wiring Diagram — 8-Pin Models with 6 to 7 Segments PNP Input NPN Input Key: Indicator Color C1 7 6 12-30V dc 24V ac Indicator Color C1 2 C2 C3 C4 C5 C6/A 7 6 12-30V dc 24V ac 2 C2 1 5 4 8 C3 C4 C5 C6/A 3 C7/A 1 1 = White 2 = Brown 3 = Green 4 = Yellow 5 = Gray 6 = Pink 7 = Blue 8 = Red C1 = Color 1 C2 = Color 2 C3 = Color 3 C4 = Color 4 C5 = Color 5 C6 = Color 6 C7 = Color 7 A = Audible 5 4 8 3 C7/A Pins 3 and 8 can activate the corresponding color or the audible function, if available. P/N 142406 Rev. R www.bannerengineering.com - Tel: + 1 888 373 6767 3 TL50 Tower Light Specifications Supply Voltage and Current Models with 1 to 5 segments: 18 V dc to 30 V dc; or 24 V ac (± 3 V) at 50 Hz to 60 Hz (both lights and audible alarms are counted as segments) Indicators—maximum current per LED color: 45 mA at 18 V to 30 V dc Models with 6 to 7 segments: 12 V dc to 30 V dc or 24 V ac (± 3 V) at 50 Hz to 60 Hz (both lights and audible alarms are counted as segments) Indicators—maximum current per LED color: • 135 mA at 12 V dc • 45 mA at 30 V dc • 60 mA at 24 V ac Standard Audible Alarm: 25 mA maximum current Sealed Audible Alarm: 35 mA maximum current Omni-Directional Sealed Audible Alarm: 45 mA maximum current Indicators LEDs are independently selected; 1 to 7 colors depending on model Indicator Characteristics Color Coordinates5 Color Dominant Wavelength (nm) or Color Temperature (CCT) x y Lumen Output (Typical at 25 °C) Green 528 nm – – 23.0 Red 625 nm – – 7.5 Yellow 590 nm – – 5.0 Supply Protection Circuitry Protected against transient voltages Blue 470 nm – – 4.0 Orange 608 nm – – 15.5 Input Response Time Indicator On/Off: 10 milliseconds maximum White 6000 K – – 21.0 Turquoise – 0.19 0.37 5.5 Audible Alarm Standard Audible Alarm: 2.7 kHz ± 500 Hz oscillation frequency; maximum intensity 92 dB at 1 m (3.3 ft) (typical) Sealed Audible Alarm: 2.9 kHz ± 250 Hz oscillation frequency; maximum intensity 94 dB at 1 m (3.3 ft) (typical) Omni-Directional Sealed Audible Alarm: 2.1 kHz ± 250 Hz oscillation frequency; maximum intensity 99 dB at 1 m (3.3 ft) (typical) Omni-Directional Sealed Audible Alarm with Intensity Adjustment: 2.1 kHz ± 250 Hz oscillation frequency; maximum intensity 95 dB at 1 m (3.3 ft) (typical) Typical Reduction in Sound Intensity with Audible Adjustment (maximum to minimum) • Standard Audible: 30 dB • Sealed Audible: 20 dB • Omni-Directional Sealed Audible: 12 dB Violet – 0.20 0.08 2.5 Magenta – 0.35 0.15 3.0 Sky Blue – 0.19 0.26 12.0 Audible Adjustment Standard Audible Alarm: Unscrew the cover (up to 1.5 turns maximum) to adjust the audible intensity. (Do not exceed 1.5 turns or the cover may detach during operation.) For maximum intensity, rotate the center plug 180° counterclockwise to remove it. Sealed Audible Alarm and Omni-Directional Sealed Audible Alarm with Intensity Adjustment: Rotate the front cover until the desired intensity is reached. Omni-Directional Sealed Audible Alarm: No adjustment. Connections Integral 4-pin, 5-pin, or 8-pin M12/Euro-style quick disconnect, 150 mm (6 in) PVC cable with a M12/Euro-style quick disconnect, or 2 m (6.5 ft) integral PVC cable depending on model Models with a quick disconnect require a mating cordset Construction Bases and Covers: ABS Light Segment: Polycarbonate Vibration and Mechanical Shock Meets IEC 60068-2-6 requirements (Vibration: 10 Hz to 55 Hz, 1.0 mm amplitude, 5 minutes sweep, 30 minutes dwell) Meets IEC 60068-2-27 requirements (Shock: 30G 11 ms duration, half sine wave) Operating Conditions Non-Audible: –40 °C to +50 °C (–40 °F to +122 °F) Standard and Sealed Audible: –20 °C to +50 °C (–4 °F to +122 °F) 95% at +50 °C maximum relative humidity (non-condensing) Environmental Rating UL Type 4X Indoor and UL Type 13 Non-Audible and Sealed Audible: IEC IP67 Standard Audible: IEC IP50 Certifications Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 5 Refer to CIE 1931 chromaticity diagram or color chart, to show equivalent color with indicated color coordinates. 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 142406 Rev. R TL50 Tower Light Dimensions 50.0 [1.97"] Tower Height (H) # of Colors H M30 x 1.5 (mounting nut included) Internal Threads 1/2–14 NPSM Max Torque 2.25 Nm [20in–lbf] 19.0 [0.75"] Non-Audible Standard Audible* Sealed Audible Omni-Directional Sealed Audible 1 61.2 mm (2.4 in) 92.0 mm (3.6 in) 115.1 mm (4.5 in) 129.1 mm (5.1 in) 2 101.9 mm (4.0 in) 132.7 mm (5.2 in) 155.8 mm (6.1 in) 169.8 mm (6.7 in) 3 142.6 mm (5.6 in) 173.4 mm (6.8 in) 196.5 mm (7.7 in) 210.5 mm (8.3 in) 4 183.3 mm (7.2 in) 214.1 mm (8.4 in) 237.2 mm (9.3 in) 251.2 mm (9.9 in) 5 224.0 mm (8.8 in) 254.8 mm (10.0 in) 277.9 mm (10.9 in) 291.1 mm (11.5 in) 6 264.7 mm (10.4 in) 298.5 mm (11.8 in) 318.6 mm (12.5 in) 332.6 mm (13.1 in) 7 305.4 mm (12.0 in) – – – * Tower height (H) with top unscrewed approximately 3.5 mm (0.18 in) to allow sound to escape 8.3 [0.33"] All measurements are listed in millimeters [inches], unless noted otherwise. Accessories Cordsets 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) Style Dimensions Pinout (Female) 44 Typ. 3 4 Straight MQDC-450 2 1 M12 x 1 ø 14.5 15.2 m (50 ft) 1 = Brown 2 = White 3 = Blue 4 = Black 5-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model MQDC1-501.5 Length Style 0.50 m (1.5 ft) MQDC1-506 1.83 m (6 ft) MQDC1-515 4.57 m (15 ft) MQDC1-530 9.14 m (30 ft) MQDC1-506RA 1.83 m (6 ft) MQDC1-515RA 4.57 m (15 ft) Dimensions 44 Typ. Straight M12 x 1 ø 14.5 2 1 3 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC1-530RA Pinout (Female) 9.14 m (30 ft) 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray M12 x 1 ø 14.5 [0.57"] P/N 142406 Rev. R www.bannerengineering.com - Tel: + 1 888 373 6767 5 TL50 Tower Light 8-Pin Threaded M12/Euro-Style Cordsets with Open-Shield Model Length MQDC2S-806 1.83 m (6 ft) MQDC2S-815 4.57 m (15 ft) MQDC2S-830 9.14 m (30 ft) Style Dimensions Pinout (Female) 44 Typ. Straight MQDC2S-850 15.2 m (50 ft) MQDC2S-806RA 1.83 m (6 ft) MQDC2S-815RA 4.57 m (15 ft) MQDC2S-830RA 9.14 m (30 ft) 5 8 1 = White 2 = Brown 3 = Green 4 = Yellow 5 = Gray 6 = Pink 7 = Blue 8 = Red 30 Typ. [1.18"] 15.2 m (50 ft) 3 4 1 7 6 32 Typ. [1.26"] Right-Angle MQDC2S-850RA 2 M12 x 1 ø 14.5 M12 x 1 ø 14.5 [0.57"] Mounting Brackets All measurements are listed in millimeters [inches], unless noted otherwise. SMB30A • Right-angle bracket with curved slot for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor • 12-ga. stainless steel 45 C 61 B A 69 Hole center spacing: A to B=40 Hole size: A=ø 6.3, B= 27.1 x 6.3, C=ø 30.5 SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor SMB30FA • Swivel bracket with tilt and pan movement for precise adjustment • Mounting hole for 30 mm sensor • 12-ga. 304 stainless steel • Easy sensor mounting to extrude rail T-slot • Metric and inch size bolt available 83.2 36.3 68.9 B A Bolt thread: SMB30FA, A= 3/8 - 16 x 2 in; SMB30FAM10, A= M10 - 1.5 x 50 Hole size: B= ø 30.1 57 70 C 57 B SMBAMS30P • Flat SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. 300 series stainless steel 45 C A 93 B A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 SMBAMS30RA • Right-angle SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. (2.6 mm) cold-rolled steel Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 6 Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 45 C 53 A B 48 SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 142406 Rev. R TL50 Tower Light LMBE12RA35 55 35 • Direct mounting of stand-off pipe, with common bracket type • • • Mounting distance from the wall to the NPSM NUT center of the 1/2-14 NPSM nut is 35 mm LMBE12RA45 65 • Direct mounting of stand-off pipe, with common bracket type Zinc-plated steel • Zinc-plated steel 1/2-14 NPSM nut • 1/2-14 NPSM nut • Mounting distance from the wall to the center of the 1/2-14 NPSM nut is 45 mm 38.25 1/2 - 14 2X Ø9 Hole center spacing: 20.0 57 45 38.25 1/2 - 14 NPSM NUT 81 2X Ø11 Hole center spacing: 35.0 LMB Sealed Right-Angle Bracket Model Description Construction LMB30RA Black polycarbonate Direct-Mount Models: Bracket kit with base, 30 mm adapter, set screw, fasteners, O-rings, and gaskets. LMB30RAC LMBE12RA Gray polycarbonate Black polycarbonate Pipe-Mount Models: Bracket kit with base, ½-14 pipe adapter, set screw, fasteners, O-rings, and gaskets. For use with stand-off pipe (listed and sold separately). Gray polycarbonate LMBE12RAC Elevated Mount System Features Model SA-M30TE12 - Black Acetal SA-M30TE12C - White UHMW • Streamlined black acetal or white UHMW stand-off pipe adapter/cover • Connects between 30 mm light base and ½ in. NPSM/DN15 pipe • Mounting hardware included Elevated-use stand-off pipe (½ in. NPSM/DN15) Polished 304 stainless steel, black anodized aluminum, or clear anodized aluminum surface ½ in. NPT thread at both ends Compatible with most industrial environments Polished 304 Stainless Steel Black Anodized Aluminum Clear Anodized Aluminum SOP-E12-150SS 150 mm (6 in) long SOP-E12-150A 150 mm (6 in) long SOP-E12-150AC 150 mm (6 in) long • • SOP-E12-300SS 300 mm (12 in) long SOP-E12-300A 300 mm (12 in) long SOP-E12-300AC 300 mm (12 in) long • • SOP-E12-900SS 900 mm (36 in) long SOP-E12-900A 900 mm (36 in) long SOP-E12-900AC 900 mm (36 in) long SA-E12M30 - Black Acetal SA-E12M30C - White UHMW Components • Streamlined black acetal or white UHMW mounting base adapter/cover • Connects between ½ in. NPSM/DN15 pipe and 30 mm (1-3/16 in) drilled hole • Mounting hardware included Pipe Mounting Flange Pipe Mounting Flange Model Features • SA-F12 P/N 142406 Rev. R • Construction Elevated-use stand-off pipes (½ in, NPSM/DN15) Die-cast zinc base with M5 mounting hardware and nitrile gasket black paint included www.bannerengineering.com - Tel: + 1 888 373 6767 1/2-14 NPSM 4x ø5.5 10 ø70 54 ø28 7 TL50 Tower Light Pipe Mounting Flange Model SA-F12-3 Features Construction • Elevated-use stand-off pipes (½ in, NPSM/DN15) • M4 mounting hardware and nitrile blend gasket included ø40 1/2-14 NPSM Black Polycarbonate 2 x 120° 29 8.77 ø60 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
TL50GRQ 价格&库存
很抱歉,暂时无法提供与“TL50GRQ”相匹配的价格&库存,您可以联系我们找货
