KLDX-SMT-0202-BP
KLDX-SMT-0202-BP
    KYCON
    SMD
    套管 - 电源连接器 插孔 2.50mm 内径(0.098"),5.50mm 外径(0.217") 表面贴装,直角,通孔
KLDX-SMT-0202-BP 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KLDX-SMT-0202-AP Part Number Builder R E 140125 LR78160 KLDX-SMT-0202 DC POWER CONNECTORS: KLDX-SMT Series Series A P Diameter Peg Option Hybrid DC Power Jack Packaging Option Series KLDX-SMT-0202 - Hybrid Mount DC Power Jack Product Features 2.0mm and 2.5mm Built-In DC On/Off Switch Laptop and Palm Computer, Portable Modems, Radar Detectors, and Other Portable Device Applications High Temperature Material For Reflow Compatibility Packaged in Tubes for Automated Assembly Optional Center Peg Available CSA/NRTL Certified File No. LR78160 UL File No. E140125 Performance Specifications Center Peg Option Blank - No Peg P - With Peg Packaging Option Blank - Bulk TR - Tape and Reel Contact Kycon for Other Options KLDX-SMT Series Dimensions in mm 9.0 3.5 14.6 Ø2.0±0.05 (A) Ø2.5±0.05 (B) Mechanical Characteristics Ø6.3 2 1.85 t 0.25 0.15 1.4 Contact Resistance Before Durability Test Between Terminals: 30 milliohms Max. Plug to Contacts: 50 milliohms Max. After Durability Test Between Terminals: 60 milliohms Max. Plug to Contacts: 100 milliohms Max. Rated Voltage: 24V DC Rated Current: 3.5A Insulation Resistance: 100 Megohms Min. at 500V DC Dielectric Withstanding Voltage: 500V AC RMS for 1 Minute 6.5 Electrical Characteristics 2.5 10.9 Materials and Finish Plastic Housing: High Temperature Thermoplastic, UL 94V-0 Rated, Black Color Center Pin: Copper Alloy, Nickel Plated Contact #1: and #3: Brass, Silver Plated Contact #2: Phosphor Bronze, Silver Plated Diameter A - 2.0mm Center Pin Diameter B - 2.5mm Center Pin Diameter 3 1 2.9 1.9 t 0.4 (2x) 9.8 Ø1.7 KLDX-SMT-0202-AP and -BP only (Optional) 1 3 2 Schematic Durability Test: 5000 Cycles Insertion Force: 0.3kg - 2.0kg Extraction Force: 0.3kg - 2.0kg Operating Temperature: -25˚C to +85˚C Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013 3.5 9.35 10.1 11.85 13.5 15.4
KLDX-SMT-0202-BP 价格&库存
很抱歉,暂时无法提供与“KLDX-SMT-0202-BP”相匹配的价格&库存,您可以联系我们找货
KLDX-SMT-0202-BP
  • 1+18.685841+2.33834
  • 10+15.8471210+1.98310
  • 40+14.3650240+1.79763
  • 80+13.6778880+1.71165
  • 120+13.29158120+1.66330
  • 280+12.51959280+1.56670
  • 520+11.98443520+1.49973
  • 1000+11.444051000+1.43211
  • 2520+10.721952520+1.34174
库存:248
