KUSBX-SMT2AP1S-B
KUSBX-SMT2AP1S-B
    KYCON
    SMD
    USB连接器 4P SMD 端口数:1 额定电流:1A 额定电压:30V 工作温度:-55℃~+85℃
KUSBX-SMT2AP1S-B 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBX-SMT2AP1S-B Part Number Builder LR78160 KUSBX UNIVERSAL SERIAL BUS: KUSBX-SMT2 Series SMT USB A Type Plug SMT2AP1S B Style Insulator Color Plating Option Series KUSBX- Universal Serial Bus Product Features Surface Mount 4 Pin Plug Available with 0.9mm Plastic Posts Designed for Use in Dongles and Adapters CSA/NRTL/US Certified File No. LR78160 UL File No. E134345 Performance Specifications Materials and Finish Insulator PA6T Thermoplastic, UL94V-0 Rated, Black or White Color Contacts Phosphor Bronze Shell Steel, Nickel Plated Electrical Characteristics Series Style SMT2-AP1S - SMT Plug with 0.90mm Plastic Posts Insulator Color Option B - Black W - White Plating Option Blank - Gold Flash 30 - 30µ" Gold Plating Contact Kycon for more options KUSBX-SMT2-AP1S Series Dimensions in mm Rated Voltage 30V AC (RMS) Rated Current 1A Contact Resistance 30 milliohms Max. Insulation Resistance 1000 Megohms Min. Dielectric Withstanding Voltage 500V AC OperatingTemperature See Drawing Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
KUSBX-SMT2AP1S-B 价格&库存
很抱歉,暂时无法提供与“KUSBX-SMT2AP1S-B”相匹配的价格&库存,您可以联系我们找货
