RP1D060D8
RP1D060D8
    CARLOGAVAZZI
    SIP-4
    固态 SPST-NO(1 Form A) 4-SIP
RP1D060D8 数据手册
RP1D RP1D 1-phase PCB mount DC switching solid state relays Main features • • • • • • • DC Solid State Relay for PCB mounting Rated operational current: Up to 8 ADC Rated operational voltage: Up to 350 VDC Surface mount technology Flexible encapsulation for extended life Control voltage: 4.25 to 32 VDC Isolation (Input to Output): 4000 VACrms Description The DC switching relay for PCB mounting is used in applications where there is a need for fast switching of small DC loads with a high input/output insulation of more than 4000 VACrms. The DC switching relay always switches on and off in accordance with the applied control voltage. Applications These relays can be used to switch heaters, motors, valves or solenoids Main functions • DC switching • Ratings up to 8 ADC / 60 VDC, 1 ADC / 350 VDC • DC control voltage  30/08/21 RP1D DS ENG Carlo Gavazzi Ltd. 1 RP1D Order code RP1D D Enter the code entering the corresponding option instead of Code R P 1 D Option 060 350 1 4 8 D Mx Description Comments Solid State Relay (PCB) with DC switching Number of poles Switching mode: DC switching Rated voltage: 60 VDC Rated voltage: 350 VDC Control voltage: 4.25-32 VDC Rated current: 1 ADC Rated current: 4 ADC Rated current: 8 ADC M1 = Mounting on DIN EN adaptor RPM1 M2 = Mounting on DIN EN adaptor RPM2 Up to 250 V Up to 600 V Selection guide Max. rated voltage 60 VDC 350 VDC Control voltage 4.25 - 32 VDC Rated operational current @ 40oC 1 ADC 4 ADC 8 ADC - RP1D060D4 RP1D060D8 RP1D350D1 - - Selection guide (mounted on DIN EN adaptor) Max. rated voltage 60 VDC 350 VDC Control voltage 6.25 - 34 VDC Rated operational current @ 40oC 1 ADC 4 ADC 8 ADC - RP1D060D4M1 RP1D060D8M1 RP1D350D1M2 - - Carlo Gavazzi compatible components Description Component code Notes DIN rail adaptor RPM1 DIN adaptor 250 V with LED DIN rail adaptor RPM1P DIN adaptor 250 V with pins for removal of RP DIN rail adaptor RPM1PD DIN adaptor 250 V with pins for removal of RP and LED DIN rail adaptor RPM2 DIN adaptor 600 V  30/08/21 RP1D DS ENG Carlo Gavazzi Ltd. 2 RP1D Features General data Material Potting compound Weight Isolation PBT, RAL7035 Flame-retardant flexible silicone rubber Approx. 20 g Input to Output: 4000 VACrms Dimensions 11M M = 1/10” = 2.54 mm 9M 4M 1M 10.5** 3M 25.4* 43* 2 +3 4 6** +1 4 x ø1  30/08/21 RP1D DS ENG * = ± 0.2 mm ** = ± 0.5 mm Carlo Gavazzi Ltd. 3 RP1D Performance Mains supply Operational voltage range Blocking voltage RP1D060... RP1D350... 1 - 60 VDC 1 - 350 VDC 60 VDC 350 VDC Outputs RP1D350D1 RP1D060D4 RP1D060D8 DC1 DC5 DC13 Min. operational load current 1 ADC 1 ADC 1 ADC 4 ADC 4 ADC 4 ADC 1 mADC 8 ADC 8 ADC 8 ADC Rep. overload current t=1 s 20 ADC 15 ADC 60 ADC Rated operational current @ Ta=40°C Off-state leakage current @ rated voltage On-state voltage drop @ rated current < 0.01 mADC < 0.5 VDC < 0.5 VDC < 1.0 VDC Inputs Control voltage range (Uc) Pick-up voltage @ Ta = 25oC Drop-out voltage Reverse voltage Switching frequency Response time pick-up @ Vin ≥ 5 VDC Response time drop-out @ Vin ≤ 24 VDC max. Input current  30/08/21 RP1D DS ENG 4.25 - 32 VDC 3.3 VDC 1 VDC 32 VDC < 100 Hz < 100 μs < 250 μs 15 mA Carlo Gavazzi Ltd. 4 RP1D Derating curve 10 9 8 Load current (ADC) 7 6 5 RP1D060D8 4 3 RP1D060D4 2 1 0  30/08/21 RP1D350D1 0 RP1D DS ENG 10 20 30 40 50 60 Surrounding ambient temperature (°C) 70 80 Carlo Gavazzi Ltd. 5 RP1D Compatibility and conformance Standards compliance LVD: EN 60947-4-3 / EE: BS 60947-4-3 EMCD: EN 61000-6-2, EN 61000-6-4 / EMC: BS 61000-6-2, BS 61000-6-4 UL 508 C22.2 No. 14 Approvals Electromagnetic compatibility (EMC) - Immunity Electrostatic discharge (ESD) EN/IEC 61000-4-2 8 kV air discharge, 4 kV contact (PC1) Radiated radio frequency EN/IEC 61000-4-3 10 V/m, from 80 MHz to 2700 MHz (PC1)2 Electrical fast transient (burst) EN/IEC 61000-4-4 Output: 2 kV, 5 kHz (PC2) Input: 1 kV, 5 kHz (PC2) Conducted radio frequency EN/IEC 61000-4-6 10V/m, from 0.15 to 80 MHz (PC1)2 Electrical surge EN/IEC 61000-4-5 Line to earth: 500 V (PC2) Line to line: 500 V (PC2) Voltage dips, interrupts and variations EN 61000-4-29 0, 30, 40, 60, 70, 80, 120% 1, 3, 10, 30, 100, 300, 1000ms (PC2) Voltage interruptions EN/IEC 61000-4-11 0% for 10 ms (PC2) 0% for 20 ms (PC2) 0% for 40 ms (PC2) 0% for 100 ms (PC2) 0% for 200 ms (PC2) 0% for 5000 ms (PC2) Electromagnetic compatibility (EMC) - Emissions Radio interference field emission (radiated) EN 55011 Class A1: from 30 to 1000 MHz Radio interference voltage emissions (conducted) EN 55011 Class A1: from 0.15 to 30 MHz  30/08/21 RP1D DS ENG Carlo Gavazzi Ltd. 6 RP1D Environmental specifications Operating temperature -20° to +80°C (-4° to +176°F) Storage temperature -40° to +100°C (-40° to +212°F) Pollution degree 2 EU RoHS compliant Yes 25 China RoHS The declaration in this section is prepared in compliance with People’s Republic of China Electronic Industry Standard SJ/ T11364-2014: Marking for the Restricted Use of Hazardous Substances in Electronic and Electrical Products. Toxic or Harardous Substances and Elements Part Name Lead (Pb) Mercury (Hg) Cadmium (Cd) Hexavalent Chromium (Cr(Vl)) Polybrominated biphenyls (PBB) Polybrominated diphenyl ethers (PBDE) Power Unit Assembly x O O O O O O: Indicates that said hazardous substance contained in homogeneous materials fot this part are below the limit requirement of GB/T 26572. X: Indicates that said hazardous substance contained in one of the homogeneous materials used for this part is above the limit requirement of GB/T 26572. 这份申明根据中华人民共和国电子工业标准 SJ/T11364-2014:标注在电子电气产品中限定使用的有害物质 有毒或有害物质与元素 零件名称 铅 (Pb) 汞 (Hg) 镉 (Cd) 六价铬 (Cr(Vl)) 多溴化联苯 (PBB) 多溴联苯醚 (PBDE) 功率单元 x O O O O O O:此零件所有材料中含有的该有害物低于GB/T 26572的限定。 X: 此零件某种材料中含有的该有害物高于GB/T 26572的限定。  30/08/21 RP1D DS ENG Carlo Gavazzi Ltd. 7 RP1D Note: 1. A filter is required to meet the Class A limits of EN55011: A filter (capacitor or snubber) could be necessary from 60 / 350 VDC supply to chassis Ground. A filter (capacitor or snubber) could be necessary from 24 VDC input to chassis Ground. Attention: This product has been designed for class A equipment. Use of the product in domestic environments may cause radio interference, in which case the user may be required to employ additional mitigation methods. 2. It is recommended that the control input lines are installed together (i.e. a 2 core cable) to ensure acceptable susceptability to RF (Radio Frequency) is maintained. The manufacturer has set a maximum allowable deviation when under RF exposure of
RP1D060D8 价格&库存
很抱歉,暂时无法提供与“RP1D060D8”相匹配的价格&库存,您可以联系我们找货
RP1D060D8
    • 1+820.55160
    • 200+327.41280
    • 500+316.47240
    • 1000+311.06160
