RP1D
RP1D
1-phase PCB mount DC switching solid state relays
Main features
DC Solid State Relay for PCB mounting
Rated operational current: Up to 8 ADC
Rated operational voltage: Up to 350 VDC
Surface mount technology
Flexible encapsulation for extended life
Control voltage: 4.25 to 32 VDC
Isolation (Input to Output): 4000 VACrms
Description
The DC switching relay for PCB mounting is used in
applications where there is a need for fast switching of
small DC loads with a high input/output insulation of
more than 4000 VACrms.
The DC switching relay always switches on and off in
accordance with the applied control voltage.
Applications
These relays can be used to switch heaters, motors, valves or solenoids
Main functions
• DC switching
• Ratings up to 8 ADC / 60 VDC, 1 ADC / 350 VDC
• DC control voltage
30/08/21
RP1D DS ENG
Carlo Gavazzi Ltd.
1
RP1D
Order code
RP1D
D
Enter the code entering the corresponding option instead of
Code
R
P
1
D
Option
060
350
1
4
8
D
Mx
Description
Comments
Solid State Relay (PCB) with DC switching
Number of poles
Switching mode: DC switching
Rated voltage: 60 VDC
Rated voltage: 350 VDC
Control voltage: 4.25-32 VDC
Rated current: 1 ADC
Rated current: 4 ADC
Rated current: 8 ADC
M1 = Mounting on DIN EN adaptor RPM1
M2 = Mounting on DIN EN adaptor RPM2
Up to 250 V
Up to 600 V
Selection guide
Max. rated
voltage
60 VDC
350 VDC
Control
voltage
4.25 - 32 VDC
Rated operational current @ 40oC
1 ADC
4 ADC
8 ADC
RP1D060D4
RP1D060D8
RP1D350D1
Selection guide (mounted on DIN EN adaptor)
Max. rated
voltage
60 VDC
350 VDC
Control
voltage
6.25 - 34 VDC
1 ADC
4 ADC
8 ADC
RP1D060D4M1
RP1D060D8M1
RP1D350D1M2
Carlo Gavazzi compatible components
Description
Component code Notes
DIN rail adaptor
RPM1
DIN adaptor 250 V with LED
DIN rail adaptor
RPM1P
DIN adaptor 250 V with pins for removal of RP
DIN rail adaptor
RPM1PD
DIN adaptor 250 V with pins for removal of RP and LED
DIN rail adaptor
RPM2
DIN adaptor 600 V
30/08/21
RP1D DS ENG
Carlo Gavazzi Ltd.
2
RP1D
Features
General data
Material
Potting compound
Weight
Isolation
PBT, RAL7035
Flame-retardant flexible silicone rubber
Approx. 20 g
Input to Output: 4000 VACrms
Dimensions
11M
M = 1/10” = 2.54 mm
9M
4M
1M
10.5**
3M
25.4*
43*
2
+3
4
6**
+1
4 x ø1
30/08/21
RP1D DS ENG
* = ± 0.2 mm
** = ± 0.5 mm
Carlo Gavazzi Ltd.
3
RP1D
Performance
Mains supply
Operational voltage range
Blocking voltage
RP1D060...
RP1D350...
1 - 60 VDC
1 - 350 VDC
60 VDC
350 VDC
Outputs
RP1D350D1
RP1D060D4
RP1D060D8
DC1
DC5
DC13
Min. operational load current
1 ADC
1 ADC
1 ADC
4 ADC
4 ADC
4 ADC
1 mADC
8 ADC
8 ADC
8 ADC
Rep. overload current t=1 s
20 ADC
15 ADC
60 ADC
@ Ta=40°C
Off-state leakage current @
rated voltage
On-state voltage drop @ rated
current
< 0.01 mADC
< 0.5 VDC
< 0.5 VDC
< 1.0 VDC
Inputs
Control voltage range (Uc)
Pick-up voltage @ Ta = 25oC
Drop-out voltage
Reverse voltage
Switching frequency
Response time pick-up @ Vin ≥
5 VDC
Response time drop-out @ Vin
≤ 24 VDC max.
Input current
30/08/21
RP1D DS ENG
4.25 - 32 VDC
3.3 VDC
1 VDC
32 VDC
< 100 Hz
< 100 μs
< 250 μs
15 mA
Carlo Gavazzi Ltd.
4
RP1D
Derating curve
10
9
8
Load current (ADC)
7
6
5
RP1D060D8
4
3
RP1D060D4
2
1
RP1D350D1
RP1D DS ENG
10
40
50
60
Surrounding ambient temperature (°C)
70
80
Carlo Gavazzi Ltd.
5
RP1D
Compatibility and conformance
Standards compliance
LVD: EN 60947-4-3 / EE: BS 60947-4-3
EMCD: EN 61000-6-2, EN 61000-6-4 / EMC: BS 61000-6-2, BS 61000-6-4
UL 508
C22.2 No. 14
Approvals
Electromagnetic compatibility (EMC) - Immunity
Electrostatic discharge (ESD)
EN/IEC 61000-4-2
8 kV air discharge, 4 kV contact (PC1)
Radiated radio frequency
EN/IEC 61000-4-3
10 V/m, from 80 MHz to 2700 MHz (PC1)2
Electrical fast transient (burst)
EN/IEC 61000-4-4
Output: 2 kV, 5 kHz (PC2)
Input: 1 kV, 5 kHz (PC2)
Conducted radio frequency
EN/IEC 61000-4-6
10V/m, from 0.15 to 80 MHz (PC1)2
Electrical surge
EN/IEC 61000-4-5
Line to earth: 500 V (PC2)
Line to line: 500 V (PC2)
Voltage dips, interrupts and
variations
EN 61000-4-29
0, 30, 40, 60, 70, 80, 120%
1, 3, 10, 30, 100, 300, 1000ms
(PC2)
Voltage interruptions
EN/IEC 61000-4-11
0% for 10 ms (PC2)
0% for 20 ms (PC2)
0% for 40 ms (PC2)
0% for 100 ms (PC2)
0% for 200 ms (PC2)
0% for 5000 ms (PC2)
Electromagnetic compatibility (EMC) - Emissions
Radio interference field
emission (radiated)
EN 55011
Class A1: from 30 to 1000 MHz
Radio interference voltage
emissions (conducted)
EN 55011
Class A1: from 0.15 to 30 MHz
30/08/21
RP1D DS ENG
Carlo Gavazzi Ltd.
6
RP1D
Environmental specifications
Operating temperature
-20° to +80°C (-4° to +176°F)
Storage temperature
-40° to +100°C (-40° to +212°F)
Pollution degree
2
EU RoHS compliant
Yes
25
China RoHS
The declaration in this section is prepared in compliance with People’s Republic of China Electronic Industry Standard SJ/
T11364-2014: Marking for the Restricted Use of Hazardous Substances in Electronic and Electrical Products.
Toxic or Harardous Substances and Elements
Part Name
Lead
(Pb)
Mercury
(Hg)
Cadmium
(Cd)
Hexavalent
Chromium
(Cr(Vl))
Polybrominated biphenyls
(PBB)
Polybrominated diphenyl
ethers (PBDE)
Power Unit
Assembly
x
O
O
O
O
O
O: Indicates that said hazardous substance contained in homogeneous materials fot this part are below the limit
requirement of GB/T 26572.
X: Indicates that said hazardous substance contained in one of the homogeneous materials used for this part is above
the limit requirement of GB/T 26572.
这份申明根据中华人民共和国电子工业标准
SJ/T11364-2014:标注在电子电气产品中限定使用的有害物质
有毒或有害物质与元素
零件名称
铅
(Pb)
汞
(Hg)
镉
(Cd)
六价铬
(Cr(Vl))
多溴化联苯
(PBB)
多溴联苯醚
(PBDE)
功率单元
x
O
O
O
O
O
O:此零件所有材料中含有的该有害物低于GB/T 26572的限定。
X: 此零件某种材料中含有的该有害物高于GB/T 26572的限定。
30/08/21
RP1D DS ENG
Carlo Gavazzi Ltd.
7
RP1D
Note:
1. A filter is required to meet the Class A limits of EN55011: A filter (capacitor or snubber) could be necessary from 60 / 350
VDC supply to chassis Ground. A filter (capacitor or snubber) could be necessary from 24 VDC input to chassis Ground.
Attention: This product has been designed for class A equipment. Use of the product in domestic environments may cause
radio interference, in which case the user may be required to employ additional mitigation methods.
2. It is recommended that the control input lines are installed together (i.e. a 2 core cable) to ensure acceptable
susceptability to RF (Radio Frequency) is maintained. The manufacturer has set a maximum allowable deviation when
under RF exposure of
很抱歉,暂时无法提供与“RP1D060D4”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+371.722271+48.31483
- 10+353.1372210+45.89923
- 50+334.5462050+43.48285
- 100+323.39464100+42.03342
