T2314
T2314
    COMET
    SMD
    BAR. PRESS. TRANSMITTER,RS232
T2314 数据手册
Barometric pressure transmitter - RS232 output code: T2314 Atmospheric pressure transmitter. Outdoor, indoor use. Barometric pressure transmitter for outdoor and indoor use.Display reading and pressure output is user selectable in these units: hPa, kPa, mbar, mmHg, inHg, inH2O, PSI, oz/in2. Technical data ATMOSPHERIC PRESSURE SENSOR SENSOR Measuring range 600 to 1100 hPa Accuracy ±1.3 hPa at 23 °C from 800 to 1100 hPa Resolution 0.1 hPa GENERAL TECHNICAL DATA Operating temperature -30 to +80 °C Channels internal atmospheric pressure sensor Output RS232 Available pressure units hPa, kPa, mbar, mmHg, inHg, inH2O, PSI, oz/in2 Communication protocol ModBus RTU and Advantech ADAM compatible protocol 9 to 30 Vdc Power Protection class IP54 Dimensions 88,5 x 98 x 39,5 mm Weight approx. 150 g Warranty 3 years 1/1 Powered by TCPDF (www.tcpdf.org)
T2314 价格&库存
很抱歉,暂时无法提供与“T2314”相匹配的价格&库存,您可以联系我们找货
