RC212-0.5-10M
RC212-0.5-10M
    SCHAFFNER(夏弗纳)
    DIP4
    10 mH @ 10 kHz 2 线路共模扼流圈 通孔 500mA DCR 1 欧姆
RC212-0.5-10M 数据手册
DATA SHEET Common Mode Chokes RC series Current-compensated Chokes Rated currents from 0.25 to 0.7 A Approvals & Compliances DC to 400 Hz frequency 100 kHz to 3 MHz common-mode resonance frequency Dual-choke configurations Multiple PCB-mounting options RC chokes are attenuating common-mode or asymmetric (P/N –> E) interference signals, by being connected in series with the phase and neutral lines of an AC powerline input. Symmetrical components of the noise are also attenuated by the leakage inductance (stray inductance) of the windings. These chokes are typically used in conjunction with suppression capacitors. Features and Benefits Performance indicators Inductance value [mH] 0 20 40 4.7 60 80 100 3 Through hole pin connections Dual-choke configuration 47 Small compact design Rated current [A] 0 High saturation resistance and excellent thermal behavior 6 9 12 0.25 0.7 15 Multiple housing options Custom-specific versions are available on request Environmental friendly open design Typical Applications Switch-mode power applications Technical Specifications DC/DC converters HVAC, typically in EMI input filter for ventilation Rated operating voltage 250 VAC LED driver circuit Operating frequency DC to 400 Hz Rated currents 0.25 to 0.7 A @ rated ambient temperature For suppression-equipment with no earth connection, e.g. medical Rated inductance 4.7 to 47 mH Stray inductance Typically 1% of LN Inductance reduction (DC bias with IN) Less than 10% (25°C) High potential test voltage winding-towinding @ 25°C 1500 VAC, 60 sec, guaranteed 1500 VAC, 2 sec, factory test Winding-to-housing @ 25°C 4000 VAC, 60 sec, guaranteed Surge current @ 10 msec 20 x IN @ 25°C Temperature range (operation and storage) -40°C to 125°C (40/125/56) acc. IEC 60068-1 Flammability corresponding to UL 94V-0 Design corresponding to IEC/EN 60938-2 MTBF @ Rated amb. Temp./Voltage (MilHB-217F) > 5,000,000 hours Phase-angle control circuits in combination with saturating chokes Consumer electronics, EDP, test equipment, electronic ballasts in lamps etc. Applicable for low frequency signaling effective from 10kHz to 30MHz Typical electrical schematic 2 Common Mode Chokes Schaffner Group DATA SHEET 05. Jul 2022 Choke Selection Table Choke Buy Current @ Ambient Resistance Pin 1-2** (lN) Temperature* (LN) [A] [°C] [mH] (LS) (RDC) (Pin 3-4) [mH] [mOhm] 0.25 40 47.0 RC112-0.3-30M 0.3 40 30.0 0.6 0.5 RC112-0.35-22M 0.35 40 22.0 RC112-0.4-15M 0.4 RC112-0.5-10M 0.5 40 40 RC112-0.6-6M8 0.6 40 0.7 40 RC112-0.7-4M7 0.25 RC212-0.3-30M RC212-0.35-22M RC112-0.25-47M RC212-0.25-47M Inductance Stray Inductance Pin 1-3 Height Weight [mm] [mm] [mm] (g) 2400 10 15 8 3 2200 10 15 8 3 0.4 1900 10 15 8 3 15.0 0.25 1350 10 15 8 3 10.0 0.17 1000 10 15 8 3 6.8 0.12 630 10 15 8 3 4.7 0.075 440 10 15 8 3 40 47.0 0.6 2400 5.08 (2.54) 12.7 17.6 3 0.3 40 30.0 0.5 2200 5.08 (2.54) 12.7 17.6 3 0.35 40 22.0 0.4 1900 5.08 (2.54) 12.7 17.6 3 RC212-0.4-15M 0.4 40 15.0 0.25 1350 5.08 (2.54) 12.7 17.6 3 RC212-0.5-10M 0.5 40 10.0 0.17 1000 5.08 (2.54) 12.7 17.6 3 RC212-0.6-6M8 0.6 40 6.8 0.12 630 5.08 (2.54) 12.7 17.6 3 RC212-0.7-4M7 0.7 40 4.7 0.075 440 5.08 (2.54) 12.7 17.6 3 Test conditions: Measuring frequency: 10 kHz; 50 mV; Inductance tolerance: +50%, -30%; Resistance tolerance: ±15% @ 25°C; Electrical characteristics @ 25°C: ±2°C * Rated ambient temperature according to approval. For other ambient temperatures, please make use of the derating graph below ** Values in brackets show the pin-out distance between pin 3 and 4. Symmetrical pin-out on request Product selector Thermal Derating If higher ambient temperatures than the specified apply, the nominal current needs to be reduced according to the graph below. 3 Common Mode Chokes Schaffner Group Typical Attenuation/Resonance Frequency Characteristics Per CISPR 17; 50 Ω/50 Ω RC112, RC212 common mode RC112, RC212 differential mode Mechanical Data RC112 For dimensions [mm] without tolerances: ISO 2768-m/ EN 22768-m applies Pin material: Steel (base), Cu (under plating), Sn (final plating 6µm) RC212 DATA SHEET 05. Jul 2022 4 Common Mode Chokes Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 05. Jul 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
RC212-0.5-10M 价格&库存
很抱歉,暂时无法提供与“RC212-0.5-10M”相匹配的价格&库存,您可以联系我们找货
RC212-0.5-10M
    • 1+4.75200
    • 200+1.83600
    • 500+1.77120
    • 800+1.74960
