DATA SHEET
Common Mode Chokes RT series
Current-compensated Chokes
Rated currents from 6 to 63 A
Approvals & Compliances
Up to 600 VAC and VDC
2- and 3-wire configurations
Horizontal and vertical PCB mounting types
Ruggedized saturation and thermal behavior
Open construction for forced and convection
cooling
Straightforward pin-out for easy PCB design
Performance indicators
Inductance value [mH]
EIS applicable for currents > 20A
RT common-mode chokes are mainly used to filter
EMI noise on AC power lines up to 600 VAC. EMI
noise of electronic equipment can go to the power
lines and disturb the proper function of other
devices like communication devices or control
logic of robotics. Thus noise generated by the
equipment from switched power electronics or by
high slew rates of controllers needs to be filtered.
RT common-mode chokes are used to suppress
EMI noise in PCB integrated filter designs with line
bypass capacitors or in combination with single
phase filters for extra low leakage filter designs.
Features and Benefits
0.3 - 10
Cost-effective PCB designs for up to 100 A with
forced cooling *
Rated current [A]
EIS (elektrical insulation system E332676) for
currents > 20A acc. to UL 1446
63
Compact size and light weight
Low magnetic leakage flux
Excellent winding insulation
Standardized foot print
Technical Specifications
Broad range of inductance ratings
Custom-specific versions on request
Rated currents
6 to 63 A @ 60°C
Rated inductance
0.3 to 6 mH (3-line)
0.5 to 10 mH (2-line)
Stray inductance
Max. 1% of rated inductance (@ 100 kHz 1 V, 0 A)
High potential test voltage
3 kV DC 3s (coil to coil)
Repetition with max. 80% of the HV test voltage
AC and DC filtering for midsize power range
drives, photovoltaic inverters, fast chargers, EV
charging stations, UPS and switch mode power
supplies
Temperature range (operation and storage)
-40°C to +100°C (6 to 20 A) / -40°C to +125°C (25 to 63
A)
Filter with low leakage current noise or improved
immunity against grid disturbances
Climatic category
40/100/56 (acc. IEC 60068-1) (6 to 20 A) / 40/125/56
(acc. IEC 60068-1) (25 to 63 A)
Electronic devices, automation and (industrial)
LED lighting
Design corresponding to
UL/IEC 60938-1/-2
UL1446 (>20A)
Communication devices
Overvoltage category
III (acc. IEC 60664-1)
Creepage and clearance distances
Converters
Creepage & Clearance (2-line): ≥ 3.5 mm (Coil - Coil) / ≥
3.0 mm (Coil-Core)
Creepage & Clearance (3-line): ≥ 6.3 mm (Coil - Coil) / ≥
5.5 mm (Coil-Core)
Pollution degree
PD2 (acc. IEC60664-1)
Altitude
2000 m, current and voltage derating above
Vibration and shock
3M4 (according IEC 60721-3-3)
Flammability according to
UL 94 V0
MTBF
>2'000'000 h (MIL-HDBK-217)
Operating voltage
600 VAC (3-line)
300 VAC/425 VDC (2-line)
Operating frequency
DC to 400 Hz
Typical Applications
Medical and laboratory Equipment
Typical electrical schematic
RT8122 & RT8522
2x Lcm
1
2
3
4
RT8132 & RT8532
3x Lcm
1
2
3
4
5
6
2
Common Mode Chokes
Schaffner Group
DATA SHEET
06. Oct 2023
RT Series
Selection table
Buy
convection
*forced cooling
Inductance
Resistance
Choke
***Ø Pin
cooling nominal
3 m/s nominal
Ln @ 25˚C
R @ 25˚C
current @ 60˚C
current @ 60˚C
100kHz
[A]
[A]
[mH/path]
Weight
[mΩ/path]
[size]
ØP [mm]
[g]
±0.1
RT8122-6-10M0
6
9.5
10.0
33.0
1
1.1
80
RT8122-8-8M0
8
12.5
8.0
21.0
1
1.3
80
RT8122-10-6M0
10
16
6.0
16.0
1
1.4
80
RT8122-12-5M0
12
19
5.0
14.0
2
1.5
100
RT8122-16-4M0
16
27
4.0
10.0
2
1.8
110
RT8122-20-3M0
3.0
7.0
3
2
160
RT8122-32-1M5
32
51
1.5
3.4
13
2.36
200
RT8122-40-1M2
40
64
1.2
2.2
13
2.8
210
RT8122-50-1M0
50
80
1.0
1.7
14
2x2.2
270
RT8122-63-0M5
63
100
0.5
1.1
14
2x2.36
260
RT8522-6-10M0
6
9.5
10.0
33.0
4
1.1
70
RT8522-8-8M0
8
12.5
8.0
21.0
4
1.3
80
RT8522-10-6M0
10
16
6.0
16.0
4
1.4
80
RT8522-12-5M0
12
19
5.0
14.0
5
1.5
90
RT8522-16-4M0
16
27
4.0
10.0
5
1.8
110
RT8522-20-3M0
3.0
7.0
6
2.0
150
RT8522-32-1M5
32
51
1.5
3.4
15
2.36
210
RT8522-40-1M2
40
64
1.2
2.2
15
2.8
220
RT8522-50-1M0
50
80
1.0
1.7
16
2x2.2
280
RT8522-63-0M5
63
100
0.5
1.0
16
2x2.36
270
RT8132-6-6M0
6
9.5
6.0
27.0
7
1.1
80
RT8132-8-4M8
8
12.5
4.8
17.0
7
1.3
90
RT8132-10-4M0
10
16
4.0
15.0
8
1.5
110
RT8132-12-3M6
12
19
3.6
12.0
8
1.6
120
RT8132-16-3M0
16
27
3.0
8.0
9
1.8
170
RT8132-20-2M5
2.5
7.0
9
2.1
190
RT8132-25-1M5
25
40
1.5
3.5
17
2.4
240
RT8132-32-1M2
32
51
1.2
2.5
17
2.4
240
RT8132-40-0M7
40
64
0.7
1.9
18
2x1.9
270
RT8132-50-0M5
50
80
0.5
1.2
18
2x2.2
290
RT8132-63-0M3
63
100
0.3
0.7
18
2x2.6
300
RT8532-6-6M0
6
9.5
6.0
27.0
10
1.1
90
RT8532-8-4M8
8
12.5
4.8
17.0
10
1.3
90
RT8532-10-4M0
10
16
4.0
15.0
11
1.5
110
RT8532-12-3M6
12
19
3.6
12.0
11
1.6
120
RT8532-16-3M0
16
27
3.0
8.0
12
1.8
160
RT8532-20-2M5
2.5
7.0
12
2.1
190
RT8532-25-1M5
25
40
1.5
3.5
19
2.4
250
RT8532-32-1M2
32
51
1.2
2.5
19
2.4
250
RT8532-40-0M7
40
64
0.7
1.9
2x1.9
290
RT8532-50-0M5
50
80
0.5
1.2
2x2.2
290
RT8532-63-0M3
63
100
0.3
0.8
2x2.6
310
Test conditions: Inductance tolerance: +50%, –30%; Resistance tolerance: +15% @ 25°C; Electrical characteristics @ 25°C: ±2°C
* typical current for forced cooling with 3 m/s. Due to the possible turbulences and degradation of the air stream within an equipment please consider
thermal validation.
** typical stray inductance, max is 0.1% of Ln
*** Length of pin (Dimension P) is always 5.5 mm ± 1
3
Common Mode Chokes
Schaffner Group
Product selector
RT8xxx-xx-xMx
Inductance value (e.g. 1M2 = 1.2mH)
Nominal input current [A]
1: nanocrystalline core
2: ferrite core
2: 2–line choke
3: 3–line choke
1: Horizontal
5: Vertical
RT: Schaffner standard ring core choke series “RT”
Examples: RT8532-16-3M0: Vertical 3-line choke for 16 A, with 3 mH ; RT8122-20-3M0: Horizontal 2-line
choke for 20 A, with 3 mH
Distribution Inventory
Up-to-date inventory levels for global distributors is available at
https://products.schaffner.com/stock
DATA SHEET
06. Oct 2023
4
Common Mode Chokes
Schaffner Group
DATA SHEET
06. Oct 2023
Typical Choke Attenuation/Resonance Frequency Characteristics
Per CISPR 17; 50 Ω/50 Ω asym
RT 8122
RT 8132
RT 8522
RT 8532
RT 8122 and RT 8522 > 20 A
RT 8132 and RT 8532 > 20A
dB
dB
32 A
25 A
25
25
63 A
15
15
10
10
63 A
5
5
10k
100k
1M
10M
Hz
10k
100k
1M
10M
Hz
5
Common Mode Chokes
Schaffner Group
DATA SHEET
06. Oct 2023
Mechanical Data: Horizontal Chokes (2-line And 3-line Up To Size 12)
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Horizontal 2-line chokes (Size 1-3)
Horizontal 3-line chokes (Size 7-9)
Dimensions
A
B
ØD
H
ØD1
ØD2
ØD3
ØE
(±0.5)
(±0.5)
(max)
(max)
(±0.5)
Size1 (RT8122-6-10M0, RT8122-8-8M0, RT8122-10-6M0)
21
25
45
34
42
1.5
2.5
36
Size2 (RT8122-12-5M0, RT8122-16-4M0)
26
30
51
33
48
1.9
2.5
40
Size3 (RT8122-20-3M0)
32
36
57
37
54
2.1
2.5
43
Size 7 (RT8132-6-6M0, RT8132-8-4M8)
38
46
34
43
1.4
2.5
35
Size 8 (RT8132-10-4M0,RT8132-12-3M6)
44
51
33
48
1.7
2.5
40
Size 9 (RT8132-16-3M0, RT8132-20-2M5)
49
57
37
54
2.3
2.5
44
Pin material: Copper (base), Sn (final plating typical thickness 0.15 mm; composition: Sn-1.2AG-4Cu or SN-3Cu-0.25Ni)
Please visit www.schaffner.com to find more details on filter connections.
6
Common Mode Chokes
Schaffner Group
DATA SHEET
06. Oct 2023
Mechanical Data: Vertical Chokes (2-line And 3-line Up To Size 12)
Vertical 2-line chokes (Size 4-6)
Vertical 3-line chokes (Size 10-12)
Dimensions
A
A1
B
L
W
H
L1
L2
L3
W1
W2
ØD2
ØD3
X
Y
(±0.5)
(±0.5)
(±0.5)
(max)
(max)
(max)
(±0.5)
(±0.5)
(±0.5)
(±0.5)
Size 4 (RT8522-6-10M0, RT8522-8-8M0, RT 8522-10-6M0)
16
32
44
32
26
27.8
22
1.5
2.5
3
2.9
SIze 5 (RT8522-12-5M0, RT8522-16-4M0)
16
22
50
32
52
39
33
27
23
1.9
2.5
3
2
Size 6 (RT8522-20-3M0)
16
22
56
32
57
42
35
31.2
25
2.1
2.5
3.5
3.1
Size 10 (RT8532-6-6M0, RT8532-8-4M8)
36
18
24
44
32
47
41
27
9
29
1.4
1.4
2.5
2.5
Size 11 (RT8532-10-4M0,RT8532-12-3M6)
38
19
24
49
34
53
46
28.5
9.5
31
1.7
1.7
4
3.5
Size 12 (RT8532-16-3M0, RT8532-20-2M5)
46
23
29
56
37
60
53
34.5
11.5
34
2.2
2.2
3.5
2.5
7
Common Mode Chokes
Schaffner Group
DATA SHEET
06. Oct 2023
Mechanical Data: Vertical And Horizontal Chokes
Horizontal 2-line chokes (Size 13 & 14)
Horizontal 3-line chokes (Size 17 & 18)
Dimensions
øD
Н
G
øЕ
f
±0.2
(max)
±0.1
±0.2
±10°
Size 13 (RT8122-32-1M5, RT8122-40-1M2)
62
37
0.6
55.4
150°
Size 14 (RT8122-50-1M0, RT8122-63-0M5)
66
41
0.6
59.8
120°
Size 17 (RT8132-25-1M5, RT8132-32-1M2)
62
38
0.6
55.4
150°
Size 18 (RT8132-40-0M7, RT8132-40-0M5, RT8132-63-0M3)
66
42
0.6
59.8
120°
g
±10°
L
±0.5
ФР
ФР
ФР
ФР
ФР
(25A)
(32A)
(40A)
(50A)
(63A)
±0.1
±0.1
±0.1
±0.1
±0.1
2.4
2.8
2.2
2.2
2.2
2.6
5
220°
5
5
220°
5
2.4
2.4
1.9
Common Mode Chokes
Schaffner Group
DATA SHEET
06. Oct 2023
Vertical 2-line chokes (Size 15 & 16)
Vertical 3-line chokes (Size 19 & 20)
L
P
O
M
S
T
5
3
1
6
4
2
C
D
B
N
mark indicates PIN no. 1
Q
recommendad screw for fixation:
WN 1452 K35 x 8
tightening torque 1.0 Nm
M A X CO M P O N E NT
VOLUME
G
H max
P (25A / 32A)
R
8
P (40A / 50A / 63A)
Dimensions
H
G
±0.1
В
C
±0.2 ±0.4
D
L
±0.2 ±0.2
M
N
Ю
±0.4
1
Size 15 (RT8522-32-1M5, RT8522-40-1M2)
60
0.6
38
32
12
60
4
Size 16 (RT8522-50-1M0, RT8522-63-0M5)
64
0.6
42
36
18
64
4
Size 19 (RT8532-25-1M5, RT8532-32-1M2)
63
0.6
38
32
12
60
4
Size 20 (RT8532-40-0M7, RT8532-50-0M5,
RT8532-63-0M3)
67
0.6
42
36
18
64
4
5
5
O
P
±0.4 ±0.4
51
51
Q
S
±0,4 ±0.4
T
R
±0.2 ±0.5
52
46
5
56
56
5
52
46
56
56
30.5
26
5
25.5
5
øР
øР
øР
øР
øР
(25A)
(32A)
(40A)
(50A)
(63A)
±0.1
±0.1
±0.1
±0.1
±0.1
2.4
2.8
2.2
2.2
2.2
2.6
2.4
2.4
1.9
9
Common Mode Chokes
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Group
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Schaffner Group
Finland
Schaffner Oy
Lohjanharjuntie 1109
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC 22nd Floor Unit No 2238 Brigade
Gateway Campus 26/1 Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
© 2023 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tionsw are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
06. Oct 2023
Sales and Application
Centers
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
DATA SHEET
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2 No 97 Section 1 XinTai 5th Road
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
United Kingdom
Schaffner Ltd.
Suite 1 Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya
7F 1-32-12 Kamiuma Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1 #05-09 Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
很抱歉,暂时无法提供与“RT8522-20-3M0”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+186.630841+24.26141
- 10+153.4622110+19.94959
- 25+141.9934525+18.45869
- 80+128.6913480+16.72946
- 160+121.37944160+15.77894
- 320+117.29563320+15.24806
