K50LGRY2NQ
K50LGRY2NQ
    BANNER(邦纳)
    Module
    堆叠灯 全套装置 绿色,红色,黄色 LED 连接器
K50LGRY2NQ 数据手册
EZ-LIGHT Indicators for 3-Color, 7-Function Datasheet DC-operated LED indicators with solid ON or flashing capability and an integral M12 quick-disconnect connector 1 Choose from red, yellow, or green ON, flashing, or rotating (depending on wiring) 2. To view or download the latest technical information about this product, including specifications, dimensions, accessories, and wiring, go to www.bannerengineering.com. WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or de-energized (off) output condition. Models Models Construction Inputs M18GRY2PQ PNP Nickel-plated brass housing, M18x1 thread; thermoplastic diffuser. Fully encapsulated; IP67. M18GRY2NQ NPN K50LGRY2PQ PNP 30 mm threaded polycarbonate base, translucent polycarbonate dome. Fully encapsulated; IP67, IP69K per DIN 40050-9. K50LGRY2NQ NPN K50FLGRY2PQ PNP Polycarbonate base, translucent polycarbonate dome. Fully encapsulated; IP67, IP69K per DIN 40050-9. K50FLGRY2NQ NPN K80LGRY2PQ 3 PNP ABS and polycarbonate base, translucent polycarbonate dome. Electronics fully encapsulated; IP67. K80LGRY2NQ NPN The following models are no longer available for order, but are still covered by the information in this document. Construction Models Inputs T30GRY2PQ PNP Thermoplastic polyester housing, thermoplastic diffuser. Fully encapsulated; IP67. T30GRY2NQ NPN Other Models: Standard integral quick-disconnect connector models are listed (mating cordset required). To order 2 m (6.5 ft) cabled models, omit suffix Q from model number (example, M18GRY2P). To order models with 150 mm (6 in) PVC-jacketed cable with 5-pin M12 quick-disconnect connector, replace suffix Q with QP (example, M18GRY2PQP). Wiring Table 1: Select from 7 operating schemes, depending on wiring LED Function PNP Models Brown Wire Red ON +V DC Red Flashing +V DC Yellow ON Yellow Flashing 1 2 +V DC White Wire Black Wire +V DC NPN Models Blue Wire Blue Wire 0 V DC 0 V DC 0 V DC 0 V DC +V DC 0 V DC +V DC 0 V DC 0 V DC White Wire Black Wire Brown Wire +V DC 0 V DC +V DC 0 V DC +V DC 0 V DC +V DC Pin 5 is not used; connects to 4-wire quick-disconnect cordset. If a cordset other than those specified in this document is used, use a 5-pin mating cordset. Contact Factory for other colors/color combinations, including: blue, white, orange. 3 K80L Models: Standard integral 5-pin M12 quick-disconnect connector models are listed (mating cordset required). For terminal-wired model, omit suffix Q (example, K80LGRY2P). Original Document 121902 Rev. L 29 July 2022 121902 EZ-LIGHT Indicators for 3-Color, 7-Function LED Function PNP Models Brown Wire White Wire Green ON Green Flashing Rotating Red-Green-Yellow +V DC NPN Models Black Wire Blue Wire +V DC 0 V DC +V DC +V DC 0 V DC +V DC +V DC 0 V DC Blue Wire 0 V DC White Wire Black Wire Brown Wire 0 V DC +V DC 0 V DC 0 V DC +V DC 0 V DC 0 V DC +V DC Table 2: Only quick-disconnect wiring is shown; cabled wiring is functionally identical. PNP Models NPN Models G = Green R = Red Y = Yellow X = Not Used Specifications Supply Voltage and Current M18 Models: 10 V DC to 30 V DC at 40 mA max. T30 Models: 10 V DC to 30 V DC at 50 mA max. K50L, K50FL and K80L Models: 18 to 30 V DC at 50 mA max. Indicators Entire translucent diffuser or dome provides indication. LEDs are independently selected: Green, Red, Yellow, ON steady or flashing. For other colors/combinations, contact Factory for availability Connections K80L Models: Integral 5-pin M12 male quick-disconnect connector standard. Terminal-wired models available for use with bulk cable; compression fitting optional. Contact Factory for cable information. Other Models: Integral 5-pin M12 male quick-disconnect connector (Q); 150 mm (6 in) PVC-jacketed cable with a 5-pin M12 male quick-disconnect connector (QP), (do not use center pin 5); or 2 m (6.5 ft) unterminated 5-wire PVC-jacketed cable Operating Conditions Temperature: –40 °C to +50 °C (–40 °F to +122 °F) Input Response Time Indicator ON: 250 ms (max.) Indicator OFF: 10 ms (max.) Indicator Flash Rate Single Color: 1 second flash rate (500 ms ON) Three Color: 1.5 second rotation rate (500 ms per color) Certifications Environmental Rating Rated IP67. K80L has encapsulated electronics only; other models fully encapsulated. K50L, and K50FL quick-disconnect models meet IP69K per DIN 40050-9 Cabled models also meet IP69K if the cable and cable entrance are protected from high-pressure spray. Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. All models: Banner Engineering Europe Park Lane, Culliganlaan 2F bus 3, 1831 Diegem, BELGIUM K50L, K50FL, and T30 models only: Turck Banner LTD Blenheim House, Blenheim Court, Wickford, Essex SS11 8YT, Great Britain K50L models only: 2 Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 121902 Rev. L EZ-LIGHT Indicators for 3-Color, 7-Function Dimensions M18 Models T30 Models K50L Models 50.0 mm (1.97") Ø 40.0 mm (1.57") Ø16.5 mm (0.65") 63.7 mm (2.51") M30 x 1.5 Thread 61 mm (2.4") 30 mm (1.2") 20 mm (0.79") Internal Threads ½ - 14 NPSM Max. Torque 2.25 Nm (20 in-lbf) 45.0 mm (1.77") M12 X 1 38 mm (1.50")* M30 x 1.5 (mounting nut included) Max. Torque 4.5 Nm (40 in-lbf) 11 mm (0.43") Ø 15 mm (0.59") M18 X 1 23 mm (0.9") M12 X 1 K50FL Models K80L Models 44.6 [1.76"] 80.8 mm (3.18") Ø50 [1.97"] 65.0 mm (2.56") 66.3 mm (2.61") 109.5 mm (4.31") 60.0 [2.36"] 35.0 [1.38"] 65.0 mm (2.56") 2x 5.0 [0.20"] 16.0 [0.63"] 2x 5.5 [0.21"] 17.0 [0.67"] 2x 5.0 [0.20"] Internal Threads ½ - 14 NPSM Max. Torque 2.25 Nm (20 in–lbf) 4X Ø 5.5 mm (Ø 0.22") Max. Torque 1.12 Nm (10 in–lbf) with supplied screws 40.0 [1.58"] 26.0 mm (1.02") 4X 8–32 UNC Max. Torque 1.12 Nm (10 in–lbf) M12 X 1 Accessories Cordsets 4-Pin Threaded M12 Cordsets—Single Ended Model Length MQDC-406 2 m (6.56 ft) MQDC-415 5 m (16.4 ft) MQDC-430 9 m (29.5 ft) MQDC-450 15 m (49.2 ft) MQDC-406RA 2 m (6.56 ft) MQDC-415RA 5 m (16.4 ft) MQDC-430RA 9 m (29.5 ft) Style Dimensions 44 Typ. 2 1 Straight M12 x 1 ø 14.5 32 Typ. [1.26"] 3 5 4 2 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) 1 3 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Unused 4 15 m (49.2 ft) M12 x 1 ø 14.5 [0.57"] To order bulk cable for terminal-wired K80L models, contact the factory. If cables other than those listed are used, use a 5-pin mating cable. P/N 121902 Rev. L www.bannerengineering.com - Tel: + 1 888 373 6767 3 EZ-LIGHT Indicators for 3-Color, 7-Function Brackets SMB18A • Right-angle mounting bracket with a curved slot for versatile orientation • 12-ga. stainless steel • 18 mm sensor mounting hole • Clearance for M4 (#8) hardware For use with M18 and T18 models or basemount T30 models. Other available 18 mm dia. brackets: SMB1815SF SMB18Q SMB18SF SMB312PD SMBAMS18RA SMBAMS18P 30 C A 41 B 46 Hole center spacing: A to B = 24.2 Hole size: A = ø 4.6, B = 17.0 × 4.6, C = ø 18.5 SMB30A • Right-angle bracket with curved slot for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor • 12-ga. stainless steel 45 C 61 B A 69 For use with T30 models or base-mount K50L models. Other available 30 mm diameter brackets are: SMBAMS30RA SMBAMS30P SMB30SC SMB30SC SMB30MM SMB3018SC Hole center spacing: A to B=40 Hole size: A=ø 6.3, B= 27.1 x 6.3, C=ø 30.5 SMBDX80DIN • Black reinforced thermoplastic • Bracket for mounting on a 35 mm DIN rail 89 K50FL models include a 48 mm (1.9 inch) circular velcro mounting kit for easy mounting with no additional hardware 89 Banner Engineering Corp Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
K50LGRY2NQ
1. 物料型号:提供了多种型号,包括M18GRY2PQ、K50LGRY2PQ等,每种型号都有不同的构造和输入类型(PNP或NPN)。
2. 器件简介:DC供电的LED指示器,具有常亮或闪烁功能,以及一个整体的M12快插连接器。
3. 引脚分配:提供了两种输入类型(PNP和NPN)的7种操作模式的接线表,包括红色、黄色和绿色LED的常亮和闪烁。
4. 参数特性:包括供电电压和电流、指示器的响应时间、闪烁速率等。
5. 功能详解:描述了指示器如何通过不同的接线方式实现不同的LED功能,如常亮、闪烁或颜色旋转。
6. 应用信息:警告不要将此设备用于人员保护,因为它不包括自我检查的冗余电路,可能在人员安全应用中造成故障或故障。
7. 封装信息:提供了不同型号的尺寸和螺纹规格,以及安装配件和支架的详细信息。
8. 认证信息:包括ULus、CE、cULus等认证标志。
9. 保修信息:Banner Engineering Corp. 提供一年有限保修,涵盖材料和工艺缺陷。
K50LGRY2NQ 价格&库存
很抱歉,暂时无法提供与“K50LGRY2NQ”相匹配的价格&库存,您可以联系我们找货
