CL50GRXPQ
CL50GRXPQ
    BANNER(邦纳)
    Module
    堆叠灯 全套装置 绿色,红色 LED M12
CL50GRXPQ 数据手册
CL50 Column Light Datasheet Multi-Color General Purpose or Audible Indicators • • • • • • • • • Rugged, cost-effective, and easy-to-install multi-color indicators Illumination provides easy-to-see operator guidance and equipment status indication 1-, 2-, or 3-color models available Available in black or light gray housing Audible models available with standard, sealed, or omni-directional audible element Continuous, pulsed, and staccato tones available 18 V to 30 V dc operation Compact devices are completely self-contained, no controller needed No assembly required Non-Audible Models Models1 # of LED Colors LED Colors2 Connection3 Inputs Color 1 Color 2 Color 3 CL50GXXPQ Green - - PNP CL50GXXNQ Green - - NPN - Red - - Red - Green Red - Green Red - Green Red Yellow PNP Green Red Yellow NPN CL50XRXPQ 1 CL50XRXNQ CL50GRXPQ CL50GRXNQ CL50GRYPQ CL50GRYNQ 2 3 PNP NPN Integral 4-pin M12/Euro-style quick disconnect PNP NPN Audible Models Standard Audible Models1 # of LED Colors LED Colors 2 Connection3 Inputs Color 1 Color 2 Color 3 CL50GXXAPQ Green – – PNP CL50GXXANQ Green – – NPN – Red – – Red – Green Red – Green Red – Green Red Yellow PNP Green Red Yellow NPN CL50XRXAPQ 1 CL50XRXANQ CL50GRXAPQ CL50GRXANQ CL50GRYAPQ CL50GRYANQ 2 3 Sealed Audible Models 1 Continuous Pulsed at 1.6 Hz Staccato # of LED Colors PNP Integral 5-pin M12/Euro-style quick disconnect NPN PNP NPN LED Colors 2 Connection3 Color 1 Color 2 Color 3 Inputs CL50GXXALSPQ CL50GXXALS3PQ CL50GXXALS4PQ Green - - PNP CL50GXXALSNQ CL50GXXALS3NQ CL50GXXALS4NQ Green - - NPN CL50XRXALSPQ CL50XRXALS3PQ CL50XRXALS4PQ - Red - CL50XRXALSNQ CL50XRXALS3NQ CL50XRXALS4NQ - Red - Green Red - Green Red - NPN Green Red Yellow PNP CL50GRXALSPQ CL50GRXALS3PQ CL50GRXALS4PQ CL50GRXALSNQ CL50GRXALS3NQ CL50GRXALS4NQ CL50GRYALSPQ CL50GRYALS3PQ CL50GRYALS4PQ 1 2 3 Integral 5-pin M12/Euro-style quick disconnect PNP NPN PNP 1 Models with black housing are listed. For gray housing, add the suffix "C" at the end of the cabled model number or before the "Q" of quick disconnect model numbers. For example, CL50GXXAPC or CL50GXXAPCQ. 2 Available colors include: Green (G), Red (R), Yellow (Y), Blue (B), and White (W). Contact Banner Engineering for other colors and color combinations. 3 • To order the 150 mm (6 in) PVC cable model with a M12/Euro-style quick disconnect, replace the suffix "Q" with "QP" in the model number. For example, CL50GXXAPQP. • To order the 2 m (6.5 ft) PVC cable model, omit the suffix "Q" in the model number. For example, CL50GXXAP. • Models with a quick disconnect require a mating cordset. Original Document 145315 Rev. O 7 May 2019 145315 CL50 Column Light Sealed Audible Models 1 Continuous Pulsed at 1.6 Hz Staccato CL50GRYALSNQ CL50GRYALS3NQ CL50GRYALS4NQ Omni-Directional Sealed Audible Models 1 Continuous Pulsed at 1.6 Hz Staccato LED Colors 2 # of LED Colors Connection3 Color 1 Color 2 Color 3 Green Red Yellow NPN LED Colors 2 # of LED Colors Inputs Connection3 Color 1 Color 2 Color 3 Inputs CL50GXXAOSPQ CL50GXXAOS3PQ CL50GXXAOS4PQ Green - - PNP CL50GXXAOSNQ CL50GXXAOS3NQ CL50GXXAOS4NQ Green - - NPN CL50XRXAOSPQ CL50XRXAOS3PQ CL50XRXAOS4PQ - Red - CL50XRXAOSNQ CL50XRXAOS3NQ CL50XRXAOS4NQ - Red - Green Red - Green Red - Green Red Yellow PNP Green Red Yellow NPN CL50GRXAOSPQ CL50GRXAOS3PQ CL50GRXAOS4PQ CL50GRXAOSNQ CL50GRXAOS3NQ CL50GRXAOS4NQ CL50GRYAOSPQ CL50GRYAOS3PQ CL50GRYAOS4PQ CL50GRYAOSNQ CL50GRYAOS3NQ CL50GRYAOS4NQ Omni-Directional Sealed Audible Models with Intensity Adjustment 1 Continuous Pulsed at 1.6 Hz Staccato 1 2 3 PNP Integral 5-pin M12/Euro-style quick disconnect PNP NPN LED Colors 2 # of LED Colors NPN Connection3 Color 1 Color 2 Color 3 Inputs CL50GXXAOSIPQ CL50GXXAOS3IPQ CL50GXXAOS4IPQ Green - - PNP CL50GXXAOSINQ CL50GXXAOS3INQ CL50GXXAOS4INQ Green - - NPN CL50XRXAOSIPQ CL50XRXAOS3IPQ CL50XRXAOS4IPQ - Red - CL50XRXAOSINQ CL50XRXAOS3INQ CL50XRXAOS4INQ - Red - Green Red - Green Red - Green Red Yellow PNP Green Red Yellow NPN CL50GRXAOSIPQ CL50GRXAOS3IPQ CL50GRXAOS4IPQ CL50GRXAOSINQ CL50GRXAOS3INQ CL50GRXAOS4INQ CL50GRYAOSIPQ CL50GRYAOS3IPQ CL50GRYAOS4IPQ CL50GRYAOSINQ CL50GRYAOS3INQ CL50GRYAOS4INQ 1 2 3 PNP Integral 5-pin M12/Euro-style quick disconnect NPN PNP NPN Wiring Diagrams — Non-Audible Models PNP Input Indicator Color NPN Input 3 KEY 18-30V dc 4 1 = Brown C1 C1 C2 C3 Indicator Color 2 = White 1 C2 3 = Blue 2 C3 1 KEY 18-30V dc 4 1 = Brown 2 = White 3 3 = Blue 2 Key4 1 = Brown 2 = White 3 = Blue 4 = Black C1 = Color 1 C2 = Color 2 C3 = Color 3 4 = Black 4 = Black Wiring Diagrams — Audible Models PNP Input Indicator Color 3 4 C1 1 C2 C3 A NPN Input KEY 2 5 1 = Brown Indicator Color 2 = White C1 18-30V dc 3 = Blue 4 C2 3 2 4 = Black C3 5 = Gray A KEY 1 5 1 = Brown 18-30V dc 2 = White 3 = Blue 4 = Black 5 = Gray Key4 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray C1 = Color 1 C2 = Color 2 C3 = Color 3 A = Audible 4 If there is an "X" in the model number, the corresponding wire will not be used. 2 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 145315 Rev. O CL50 Column Light Functional Truth Table: PNP Models LED Function Color 1 On Pin 4 (Black Wire) Pin 1 (Brown Wire) Pin 2 (White Wire) +V dc Color 2 On +V dc Color 3 On +V dc Color 3 On (color 3 inhibits color 1) +V dc Color 2 On (color 2 inhibits color 1) +V dc Alarm models: Alarm function is independent of light functions. +V dc Color 3 On (color 3 inhibits color 2) Color 3 On (color 3 inhibits colors 1 & 2) Pin 3 (blue wire) connected to ground (–) . +V dc +V dc +V dc +V dc +V dc Pin 3 (Blue Wire) Pin 2 (White Wire) +V dc Functional Truth Table: NPN Models LED Function Color 1 On Pin 4 (Black Wire) –V dc Color 2 On –V dc Color 3 On –V dc Color 3 On (color 3 inhibits color 1) –V dc Color 2 On (color 2 inhibits color 1) –V dc Color 3 On (color 3 inhibits color 2) Color 3 On (color 3 inhibits colors 1 & 2) –V dc Pin 1 (brown wire) connected to +V dc. –V dc Alarm models: Alarm function is independent of light functions. –V dc –V dc –V dc –V dc –V dc Specifications Supply Voltage and Current 18 V dc to 30 V dc Indicators–maximum current per LED color: • 100 mA at 18 V dc • 70 mA at 30 V dc Standard Audible Alarm: 25 mA maximum current Sealed Audible Alarm: 35 mA maximum current Omni-Directional Sealed Audible Alarm: 45 mA maximum current Supply Protection Circuitry Protected against reverse polarity and transient voltages Indicator Response Time Indicator On/Off: 10 milliseconds maximum Audible Alarm Standard Audible Alarm: 2.7 KHz ± 500 Hz oscillation frequency; maximum intensity 92 db at 1 meter (3.3 ft) (typical) Sealed Audible Alarm: 2.9 KHz ± 250 Hz oscillation frequency; maximum intensity 94 db at 1 meter (3.3 ft) (typical) Omni-Directional Sealed Audible Alarm: 2.1 KHz ± 250 Hz oscillation frequency; maximum intensity 99 db at 1m (3.3 ft) (typical) Omni-Directional Sealed Audible Alarm with Intensity Adjustment: 2.1 KHz ± 250 Hz oscillation frequency; maximum intensity 95 dB at 1m (3.3 ft) (typical) Indicators LEDs or audible are independently selected Indicator Characteristics Audible Adjustment Standard Audible Alarm: Unscrew the cover (up to 1.5 turns maximum) to adjust the audible intensity. Do not exceed 1.5 turns or the cover may detach during operation. For maximum intensity, rotate the center plug 180° counterclockwise to remove it. Sealed Audible Alarm and Omni-Directional Sealed Audible Alarm with Intensity Adjustment: Rotate the front cover until the desired intensity is reached Typical Reduction in Sound Intensity with Audible Adjustment (maximum to minimum): • Standard Audible: 30 dB • Sealed Audible: 20 dB • Omni-Directional Sealed Audible: 12 dB Construction Bases and Covers: ABS Light Segment: Polycarbonate Vibration and Mechanical Shock Meets IEC 60068-2-6 requirements (Vibration: 10 Hz to 55 Hz, 1.0 mm amplitude, 5 minutes sweep, 30 minutes dwell) Meets IEC 60068-2-27 requirements (Shock: 30G 11 ms duration, half sine wave) Operating Conditions Non-Audible: –40 °C to +50 °C (–40 °F to +122 °F) Standard and Sealed Audible: –20 °C to +50 °C (–4 °F to +122 °F) 95% at +50 °C maximum relative humidity (non-condensing) Environmental Rating UL Type 4X Indoor and UL Type 13 Non-Audible and Sealed Audible: IEC IP67 Standard Audible: IEC IP50 Certifications Connections Integral 4-pin or 5-pin M12/Euro-style quick disconnect, 150 mm (6 in) PVC cable with a M12/Euro-style quick disconnect, or 2 m (6.5 ft) integral PVC cable, depending on model Models with a quick disconnect require a mating cordset Required Overcurrent Protection P/N 145315 Rev. O Color Dominant Wavelength (nm) or Color Temperature (CCT) Lumen Output (Typical at 25 °C) Green 525 nm 72 Red 625 nm 38 Yellow 590 nm 30 Blue 475 nm 28 White 5000 K 85 WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 www.bannerengineering.com - Tel: + 1 888 373 6767 3 CL50 Column Light Dimensions Column Light Height (H) H ø50 [1.97] M30 X 1.5 (Mounting Nut Included) 19 [0.75] Internal Threads 1/2-14 NPSM Max Torque 2.25 Nm [20 in-lbs] Non-Audible 114.2mm (4.5 in) Standard Audible* 145.3mm (5.7 in) Sealed Audible 168.2mm (6.6 in) Omni-Directional Sealed Audible 182.2mm (7.2 in) *Column Light (H) with top unscrewed approximately 3.5 mm to allow sound to escape All measurements are listed in millimeters [inches], unless noted otherwise. 8.3 [0.33] Accessories Cordsets 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions Pinout (Female) 44 Typ. Straight M12 x 1 ø 14.5 3 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC-450RA 2 1 15.2 m (50 ft) 1 = Brown 2 = White 3 = Blue 4 = Black M12 x 1 ø 14.5 [0.57"] 5-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model MQDC1-501.5 Length Style 0.50 m (1.5 ft) MQDC1-506 1.83 m (6 ft) MQDC1-515 4.57 m (15 ft) MQDC1-530 9.14 m (30 ft) MQDC1-506RA 1.83 m (6 ft) MQDC1-515RA 4.57 m (15 ft) Dimensions 44 Typ. Straight M12 x 1 ø 14.5 2 1 3 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC1-530RA Pinout (Female) 9.14 m (30 ft) 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray M12 x 1 ø 14.5 [0.57"] 4 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 145315 Rev. O CL50 Column Light Mounting Brackets All measurements are listed in millimeters [inches], unless noted otherwise. SMB30A • Right-angle bracket with curved slot for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor • 12-ga. stainless steel SMB30FA • Swivel bracket with tilt and pan movement for precise adjustment • Mounting hole for 30 mm sensor • 12-ga. 304 stainless steel • Easy sensor mounting to extrude rail T-slot • Metric and inch size bolt available 45 C 61 B A 83.2 36.3 68.9 B A 69 Hole center spacing: A to B=40 Hole size: A=ø 6.3, B= 27.1 x 6.3, C=ø 30.5 SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor Bolt thread: SMB30FA, A= 3/8 - 16 x 2 in; SMB30FAM10, A= M10 - 1.5 x 50 Hole size: B= ø 30.1 SMBAMS30P • Flat SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. 300 series stainless steel 57 70 C 57 45 C A 93 B B A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 SMBAMS30RA • Right-angle SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. (2.6 mm) cold-rolled steel Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 45 C 53 A B 67 B 58 48 29 Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 LMBE12RA35 • Direct mounting of stand-off pipe, with common bracket type • Zinc-plated steel • 1/2-14 NPSM nut • Mounting distance from the wall to the center of the 1/2-14 NPSM nut is 35 mm Hole center spacing: 20.0 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 55 35 1/2 - 14 NPSM NUT LMBE12RA45 • Direct mounting of stand-off pipe, with common bracket type • Zinc-plated steel • 1/2-14 NPSM nut • Mounting distance from the wall to the center of the 1/2-14 NPSM nut is 45 mm 38.25 57 Hole center spacing: 35.0 2X Ø9 65 45 1/2 - 14 NPSM NUT 38.25 81 2X Ø11 LMB Sealed Right-Angle Bracket Model Description Construction LMB30RA LMB30RAC LMBE12RA LMBE12RAC P/N 145315 Rev. O Black polycarbonate Direct-Mount Models: Bracket kit with base, 30 mm adapter, set screw, fasteners, O-rings, and gaskets. Gray polycarbonate Black polycarbonate Pipe-Mount Models: Bracket kit with base, ½-14 pipe adapter, set screw, fasteners, O-rings, and gaskets. For use with Gray polycarbonate stand-off pipe (listed and sold separately). www.bannerengineering.com - Tel: + 1 888 373 6767 5 CL50 Column Light Elevated Mount System Model Features SA-M30TE12 - Black Acetal • • SA-M30TE12C - White UHMW • Polished 304 Stainless Steel Black Anodized Aluminum Clear Anodized Aluminum SOP-E12-150SS 150 mm (6 in) long SOP-E12-150A 150 mm (6 in) long SOP-E12-150AC 150 mm (6 in) long SOP-E12-300SS 300 mm (12 in) long SOP-E12-300A 300 mm (12 in) long SOP-E12-300AC 300 mm (12 in) long SOP-E12-900SS 900 mm (36 in) long SOP-E12-900A 900 mm (36 in) long SOP-E12-900AC 900 mm (36 in) long SA-E12M30 - Black Acetal • • • • • • SA-E12M30C - White UHMW • Components Streamlined black acetal or white UHMW stand-off pipe adapter/cover Connects between 30 mm light base and ½ in. NPSM/DN15 pipe Mounting hardware included Elevated-use stand-off pipe (½ in. NPSM/DN15) Polished 304 stainless steel, black anodized aluminum, or clear anodized aluminum surface ½ in. NPT thread at both ends Compatible with most industrial environments Streamlined black acetal or white UHMW mounting base adapter/cover Connects between ½ in. NPSM/DN15 pipe and 30 mm (1-3/16 in) drilled hole Mounting hardware included Pipe Mounting Flange Pipe Mounting Flange Model Features • SA-F12 • • SA-F12-3 • Construction Elevated-use stand-off pipes (½ in, NPSM/ DN15) M5 mounting hardware and nitrile gasket included Die-cast zinc base with black paint Elevated-use stand-off pipes (½ in, NPSM/ DN15) Black Polycarbonate M4 mounting hardware and nitrile blend gasket included 1/2-14 NPSM 4x ø5.5 10 ø70 54 ø28 ø40 1/2-14 NPSM 2 x 120° 29 8.77 ø60 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
CL50GRXPQ 价格&库存
很抱歉,暂时无法提供与“CL50GRXPQ”相匹配的价格&库存,您可以联系我们找货
