Page 1/6
Data sheet
SM01Y01VXNN03G1 7-inch Reel solder pad/component side
P/N
ASM01Y0164-3G16
2023/06/28
Version: T
Illustrations
Dimensional drawing
PCB-Layout
See enlarged drawings at the end of document
Product specification
• spring clamp terminal block, SMT solderable
• one-way contact
• direction of connection vertical 0°
• Tape & Reel packaging
Data sheet
Page 2/6
P/N
ASM01Y0164-3G16
2023/06/28
Version: T
Technical Data
General Data
min. number of poles
1
max. number of poles
1
Protection category
IP00
Min. insul. strip length
4 mm
Rated current
13 A
Terminal data
rat.wiring solid AWGmax
0.75 mm² - 1.5 mm² / AWG 18 - AWG 16
Material
contact material
CuBe
Contact surface
Ni + Sn
Climatic Data
upper limit temperature
150 °C
lower limit temperature
-40 °C
general
Tolerance
ISO 2768 -mH
Solderability
Acc. to IPC/JEDEC J-STD-020D-MSL 1
Sicherheitshinweis
Safety instructions
Components have to be fixed in a way to prevent any
transmission of forces on to the contact. Components with more
than one pin are recommended.
Data sheet
Page 3/6
P/N
ASM01Y0164-3G16
2023/06/28
Version: T
Counterpart
P/N
Designation
709023
Tape_ASM01Y_16mm K03547 Tape_ASM01Y_16mm
Data sheet
Page 4/6
P/N
ASM01Y0164-3G16
2023/06/28
Version: T
Illustrations
Dimensional drawing
Application example
Data sheet
Page 5/6
P/N
ASM01Y0164-3G16
2023/06/28
Version: T
Illustrations
PCB-Layout
Data sheet
Page 6/6
P/N
ASM01Y0164-3G16
2023/06/28
Version: T
Illustrations
Powered by TCPDF (www.tcpdf.org)
很抱歉,暂时无法提供与“ASM01Y0164-3G16”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1100+1.082111100+0.13086
- 2200+1.015192200+0.12277
- 3300+0.984043300+0.11900
- 5500+0.951565500+0.11507
- 7700+0.933617700+0.11290
- 11000+0.9171311000+0.11091
- 27500+0.8844027500+0.10695
- 55000+0.8666855000+0.10481
- 国内价格 香港价格
- 1+5.744171+0.69463
- 10+2.6927110+0.32563
- 25+2.0990125+0.25383
- 50+1.7784150+0.21506
- 100+1.53745100+0.18592
- 250+1.30913250+0.15831
- 500+1.18569500+0.14339
