SMPX-32LCC-N
SMPX-32LCC-N
    KYCON
    PLCC
    32(2 x 7,2 x 9) 位置 PLCC 插口 锡 表面贴装型
SMPX-32LCC-N 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Check Stock Request a Sample Certificate of Origin Send Us An Email Generated Part Number SMPX-20LCC-N Part Number Builder CHIP CARRIER SOCKETS: SMPX Series SMPX Series Surface Mount PLCC Socket Product Features Applications Include All Electronic PC Boards Requiring Use of a Socket with Same Footprints as Most Common Plastic Leaded Chip Carriers Accepts Molded Plastic Chip Carriers Conforming to JEDEC Specification MO-047 for Square and MO-052 for Rectangular Configuration Visual and Mechanical Polarization for PXLCC Insertion Open Frame Design for Ease of Contact Inspection & Repair For High Temperature SMT Soldering up to 230 °C Optional PCB Polarizing Pegs Available Low profile; Less than .2” Mated Height Extraction Tool Slots* Open Top Design for Cooler Running Chip Carrier Automatic Insertion Machine Compatible CSA/NRTL Certified File No. LR78160 Performance Specifications Materials and Finish Body High Temperature Thermoplastic, Black Color Contact Material Phosphor Bronze Contact Finish 160µ” Tin over Nickel Plating 20 LCC N Number of Contact Body Type Polarized Packaging Series SMPX - Surface Mount PLCC Socket Number of Contacts 20 - 20 Contacts 28 - 28 Contacts 32 - 32 Contacts 44 - 44 Contacts 52 - 52 Contacts 68 - 68 Contacts 84 - 84 Contacts Polarized N - Non-Polarized P - Polarized Packaging Blank - Tubes TR - Tape and Reel (Available only with N Option) Contact Kycon for other Options SMPX- Series Dimensions in mm A-A A Detail A B-B Electrical Characteristics H 4.6 Detail A 1.27 Polarizing Peg 1.5 Dimensions in mm * PXLCC Extraction Tool P/N TLPX-PXLCC Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2015 3.55 F Ø1.5 Contact Current Rating 1A Contact Resistance 15 milliohms Max. Dielectric Withstanding Voltage 1000VAC Min. for 1 Minute Insulation Resistance 10000 Megohms Min Temperature Rating -50°C to +105°C G B 0.15±0.08
SMPX-32LCC-N 价格&库存
很抱歉,暂时无法提供与“SMPX-32LCC-N”相匹配的价格&库存,您可以联系我们找货
