NLG13D724SA
NLG13D724SA
    CARLOGAVAZZI
    Module
    RELAY SAFETY 4PST 6A 24V
NLG13D724SA 数据手册
Safety Modules Light curtains Types NLG02D, NLG13D Screw, fixed Screw, detachable • Safety Category 4, Performance Level e, according to EN 13849-1 • Safety Category 4 according to EN 954-1 • 2 x 6 A NO safety outputs (NLG02D) • 3 x 6 A NO safety outputs and 1 x 6 A NC auxiliary output (NLG13D) • Automatic / manual or monitored manual reset • Single / double channel operations • LED indication for outputs status and power supply ON • Connection by fixed or detachable terminals • For mounting on DIN-rail in accordance with DIN/EN 50 022 • 22.5 mm Euronorm housing Product Description Ordering Key NLG02D and NLG13D are safety modules designed to monitor sefety light curtains with PNP or relay outputs according to 98/37/EC Machinery Directive. This family of safety mod- Housing Function Auxiliary outputs Safety outputs Safety category Power supply Terminals Start/Reset type ules in Safety Category 4, Performance Level e, includes fixed screw and detachable screw as well as automatic/manual or monitored manual restart versions. N LG 0 2 D 724 S A Type Selection Auxiliary outputs Safety outputs Terminals Start/Reset type Supply: 24 VDC 1 NC 1 NC 1 NC 1 NC 2 NO 2 NO 2 NO 2 NO 3 NO 3 NO 3 NO 3 NO Screw, fixed Screw, fixed Screw, detachable Screw, detachable Screw, fixed Screw, fixed Screw, detachable Screw, detachable Automatic / Manual Monitored manual Automatic / Manual Monitored manual Automatic / Manual Monitored manual Automatic / Manual Monitored manual N LG 0 2 D 724 S A N LG 0 2 D 724 S C N LG 0 2 D 724 D A N LG 0 2 D 724 D C N LG 1 3 D 724 S A N LG 1 3 D 724 S C N LG 1 3 D 724 D A N LG 1 3 D 724 D C Time Specifications Delay ON energisation Delay ON de-energisation Channel simultaneity during outputs closing Input operating to START operating delay NLG...C Output Specifications < 150 ms < 30 ms Infinite > 500 ms Input specifications Function Input current/voltage NLG02D Terminals S12-S21 NLG13D Terminals S11-S22 2 NO min 10 mA / 17 V max 60 mA / 38 V min 10 mA / 17 V max 30 mA / 38 V Specifications are subject to change without notice (13.01.10) Safety outputs NLG02D NLG13D Auxilary output NLG13D Rated insulation voltage Contact ratings (AgSnO2) Resistive loads AC1 DC12 Small inductive loads AC15 DC13 External contact fuse protection Mechanical life Electrical life Dielectric strength Dielectric voltage Category 4, Performance Level e (EN 13849-1) 2 NO (13-14, 23-24) 3 NO (13-14, 23-24, 33-34) 1 NC (41-42) 250 VAC (rms) 2 µm Au 6 A @ 230 VAC 6 A @ 24 VDC 3 A @ 230 VAC 2.5 A @ 24 VDC 5 A fast, 4 A slow > 107 operations > 105 operations 4 kVAC (rms) 1 NLG02D, NLG13D Supply Specifications General Specifications Power supply Rated operational voltage through terminals: A1, A2 Short circuit protection Dielectric voltage Supply to input Supply to output Input to output Rated operational power Indication for Power supply ON Output relays ON Environment Degree of protection Pollution degree Operating temperature Storage temperature Mimimum protection degree of the installation location Housing dimensions Weight Screw terminals Tightening torque Upper terminals Lower terminals Approvals CE Marking EMC Immunity Emission Overvoltage cat. III (IEC 60664) 24 VDC -15% / +10% Internal PTC DC supply AC supply none none 4 kV 4 kV 4 kV 4 kV max 4 W LED, green LED, green (CH 1, 2) (EN 60529) IP 30 2 -25 to 65°C, R.H. < 95% -30 to 65°C, R.H. < 95% IP 54 22.5 x 99 x 114 mm Approx. 200 g Max. 0.5 Nm Max. 0.8 Nm CULUS, TUV Yes Electromagnetic Compatibillity According to EN 61000-6-2 According to EN 61000-6-3 Mode of Operation The safety modules NLG02D and NLG13D monitor ElectroSensitive Equipments (ESPE) with PNP or relay outputs according to 98/37/EC Machinery Directive. If the safety system (NLG+ESPE) is correctly supplied, the input terminals of the module are activated (light beams not interrupted) and there aren’t fault conditions, the module is enabled to close the safety outputs and the external contactors can be energized. When the input terminals are not activated (light beams interrupted) the module is not enabled to close the safety outputs and the external contactors can not be energized. 2 Automatic START Provided that the terminals X1 and X2 (NLG02...A) or S33 and S34 (NLG13...A) are connected, the safety outputs close and the auxiliary output opens (NLG13...A) as soon as both the module inputs are activated. The relevant CH1 and CH2 LED turn on. Deactivating even one module input forces immediately the safety outputs to open and the auxiliary output (NLG13...A) to close. A new operating cycle is possible only after deactivating both input contacts and then operating them again. Manual START Provided that both the module inputs are activated, the safety outputs close and the auxiliary output opens (NLG13...A) as soon as the NO START pushbutton is pushed connecting X1 and X2 (NLG02...A) or S33 and S34 (NLG13...A). A new operating cycle is possible only after deactivating both the module inputs, activating them again and pushing the START button. Monitored manual START The monitored manual START versions (NLG...C) work as described in the previous paragraph (Manual START) except for a minimum delay of 500 ms from the activated status of the module inputs to the pushing of the START button. If the inputs of the module are closed with the START switch already closed, the safety outputs don’t close and the auxiliary doesn’t open (NLG13...C): it is necessary to release the START button and deactivate the module inputs before starting a new cycle, then operate the inputs of the module and finally, after at least 500 ms, operate the START button. So if the NO START button gets welded, the outputs don’t close anymore. Specifications are subject to change without notice (13.01.10) NLG02D, NLG13D Operation Diagrams NLG02D...SA, NLG02D...DA NLG13D...SA, NLG13D...DA NLG02D...SC, NLG02D...DC NLG13D...SC, NLG13D...DC Wiring Diagrams NLG02D - Two 1-wire PNP outputs - Safety cat. 4 NLG13D - Two 1-wire PNP outputs - Safety cat. 4 * Note * Note NLG02D - Two 1-wire relay outputs - Safety cat. 4 * Note NLG13D - Two 1-wire relay outputs - Safety cat. 4 * Note * Note: The same power supply has to be used both for the module and for the light curtain. Specifications are subject to change without notice (13.01.10) 3 NLG02D, NLG13D Wiring Diagrams (cont.) NLG02D - One 1-wire PNP output - Safety cat. 2 NLG13D - One 1-wire PNP output - Safety cat. 2 * Note * Note NLG02D - One 1-wire relay output - Safety cat. 2 NLG13D - One 1-wire relay output - Safety cat. 2 * Note * Note NLG02D - Two 2-wire PNP outputs - Safety cat. 4 NLG13D - Two 2-wire PNP outputs - Safety cat. 4 NLG02D - Two 2-wire relay outputs - Safety cat. 4 NLG13D - Two 2-wire relay outputs - Safety cat. 4 * Note: The same power supply has to be used both for the module and for the light curtain. 4 Specifications are subject to change without notice (13.01.10) NLG02D, NLG13D Wiring Diagrams (cont.) NLG02D - One 2-wire PNP output - Safety cat. 2 NLG13D - One 2-wire PNP output - Safety cat. 2 NLG02D - One 2-wire relay output - Safety cat. 2 NLG13D - One 2-wire relay output - Safety cat. 2 Dimensions Versions with fixed terminals Specifications are subject to change without notice (13.01.10) Versions with detachable terminals 5
NLG13D724SA 价格&库存
很抱歉,暂时无法提供与“NLG13D724SA”相匹配的价格&库存,您可以联系我们找货
