NA13D230CG
NA13D230CG
    CARLOGAVAZZI
    Module
    NA13D230CG E-STOP MODULE
NA13D230CG 数据手册
5456SafetyCatalog.qk 9/26/04 9:03 PM Page 20 Emergency Stop and Safety Gate Modules NA1/3-D, NA1/3-D/230 • • • • • • • • • Safety Category 4 according to EN 954-1 Category 0 Emergency Stop 3 NO safety outputs 24 VAC / VDC, 110 or 230 VAC power supply single/dual channel automatic or manual reset self monitoring Failure diagnosis by LEDs Approvals: Product Description Ordering Key Emergency Stop and Safety Gate modules according to EN 60204-1, EN 292-1/-2, EN 418 and EN 1088. This family of safety module in Safety Category 4, Case Application Controlled Devices Safety Outputs Safety Category Power Supply includes 24 Vac/Vdc, 110 or 230 Vac. Every model is characterized by dual channel input and safety output contacts with force guided relay outputs. NA1/3-D/230 Type Selection Power supply References 24 VAC/VDC 110 VAC 230 VAC NA1/3-D NA1/3-D/110 NA1/3-D/230 Electrical Specifications Power supply NA1/3-D NA1/3-D/110 NA1/3-D 230 Power consumption Input current/voltage Safety outputs Auxiliary outputs 24 Vac/dc ± 10% 110 Vac ± 10% 230 Vac ± 10% 3 VA / 3 W 0.9 to 1.1 V 3 NO 1 NC Time Specifications Delay on energisation Delay on de-energisation Channel simultaneity Switching voltage / current /capability NA1/3-D NA1/3-D/110 NA1/3-D 230 Contact fuse protection Insulation voltage 24 Vdc / 5A 110 Vac / 5A 230 Vac / 5A 5 A fast or 4 A slow Pollution degree: 2. Overvoltage Category: 3 / 250 V Basis insulation: Overvoltage Category: 3 / 250 V Environmental Specifications < 30 ms ∞ Operating temperature Storage temperature -25°C to + 55°C -25°C to + 65°C Max cross section of external conductors Dimensions (H x W x D) Weight NA1/3-D NA1/3-D/110 NA1/3-D 230 2.5 mm2 rigid wire 2.5 mm2 flexible wire 22.5 x 114.5 x 99 mm Mechanical Specifications Protection degree terminals Protection degree housing Housing material Housing type Mounting 1-17 IP 20 IP 40 Polyamid PA6.6 22.5 mm housing models DIN rail 170 g 238 g 238 g Specifications are subject to change without notice (10.01.04) 5456SafetyCatalog.qk 9/26/04 9:03 PM Page 21 NA1/3-D, NA1/3-D/230 Dimensions 22,5 99 114,5 Wiring Diagrams Application Dual Channel Emergency Stop A1 A2 S33 S34 S11 S12 S21 S22 13 23 33 POWER SUPPLY 41 E-STOP Trasf. K2 START Control Logic AC - DC K1 + K2 K1 S33 S34 A1 A2 S21 S22 S11 S12 13 23 33 41 (+) (-) 14 24 34 42 14 24 34 42 Connections Connection Sample Terminal Function A1 A2 S11-S12 13 23 33 41 A1 S34 S33 S12 13 23 33 41 A1 S34 S33 S12 NA1/3-D NA1/3-D/230 Power Power Channel 2 Channel 2 Channel 1 Channel 1 13 23 33 41 13 23 33 41 14 24 34 42 14 24 34 42 S21 S22 S11 A2 14 24 34 42 NA1/3-D S21 S22 S11 A2 14 24 34 42 S21-S22 S33-S34 13-14 23-24 33-34 41-42 Connection +24 Vdc or AC supply GND or AC supply First input channel (E-STOP or Safety Switch Channel 1) Second input channel (E-STOP or Safety Switch Channel 2) START (automatic o manual) First safety output (N.O.) Second safety output (N.O.) Third safety output (N.O.) Auxiliary output (N.C.) NA1/3-D/110 or 230 Specifications are subject to change without notice (10.01.04) 1-18
NA13D230CG 价格&库存
很抱歉,暂时无法提供与“NA13D230CG”相匹配的价格&库存,您可以联系我们找货
