NSO13DB24SA
NSO13DB24SA
    CARLOGAVAZZI
    Module
    SAFETY GATES MODULE 2NO IN 3 OUT
NSO13DB24SA 数据手册
Safety Modules Safety Gate and Safety Magnetic Sensor Types NSO02D, NSO13D • Safety Category 4, Performance Level e, according to EN 13849-1 • Safety Category 4 according to EN 954-1 • Category 0 Emergency Stop (EN 60204-1) • Input type: 2 NO • 2 x 6 A NO safety outputs (NSO02D) • 3 x 6 A NO safety outputs and 1 x 6 A NC auxiliary output (NSO13D) • Automatic / manual or monitored manual reset • Single / double channel operations • LED indication for outputs status and power supply ON • Connection by fixed or detachable terminals • For mounting on DIN-rail in accordance with DIN/EN 50 022 • 22.5 mm Euronorm housing Screw, fixed Screw, detachable Product Description Safety gate and safety magnetic sensor modules according to EN 60204-1, EN 292-1/-2, EN 418 and EN1088. This family of safety module in Safety Category 4, Ordering Key N SO 0 2 D B24 S A Performance Level e, includes fixed screw and detachable screw as well as automatic/manual or monitored manual restart versions. Housing Function Auxiliary outputs Safety outputs Safety category Power supply Terminals Start/Reset type Type Selection Auxiliary outputs 1 1 1 1 NC NC NC NC Safety outputs 2 NO 2 NO 2 NO 2 NO 3 NO 3 NO 3 NO 3 NO Terminals Start/Reset type Supply: 24 VAC/DC Screw, Screw, Screw, Screw, Screw, Screw, Screw, Screw, Automatic Monitored Automatic Monitored Automatic Monitored Automatic Monitored N N N N N N N N fixed fixed detachable detachable fixed fixed detachable detachable Time Specification Delay ON energisation Delay ON de-energisation Recovery time Channel simultaneity during outputs closing Input operating to START operating delay NSO...C 1 SO SO SO SO SO SO SO SO 0 0 0 0 1 1 1 1 2 2 2 2 3 3 3 3 D D D D D D D D B24 B24 B24 B24 B24 B24 B24 B24 SA SC DA DC SA SC DA DC Output Specification < 150 ms < 30 ms ≥ 30 ms Infinite > 500 ms Input Specifications Function Input current Terminals S11-S12 Terminals S21-S22 External contact resistance Terminals S11-S12 Terminals S21-S22 / Manual manual / Manual manual / Manual manual / Manual manual 2 NO, voltage free max 10 mA max 10 mA max. 60Ω max. 60Ω Safety outputs NSO02D NSO13D Auxilary output NSO13D Rated insulation voltage Contact ratings (AgSnO2) Safety outputs Resistive loads AC1 DC12 Small inductive loadsAC15 DC13 Auxiliary output External contact fuse protection Mechanical life Electrical life Dielectric strength Dielectric voltage Category 4, Performance Level e (EN 13849-1) 2 NO (13-14, 23-24) 3 NO (13-14, 23-24, 33-34) 1 NC (41-42) 250 VAC (rms) 2 µm Au 6 A @ 230 VAC 6 A @ 24 VDC 3 A @ 230 VAC 2.5 A @ 24 VDC 6A, 24 VAC/DC 5 A fast, 4 A slow > 107 operations > 105 operations 4 kVAC (rms) Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 27/09/12 NSO02D, NSO13D Supply Specification General Specifications Power supply Rated operational volatge through terminal: A1, A2 Indication for Power supply ON Output relays ON Environment Degree of protection Pollution degree Operating temperature Storage temperature Mimimum protection degree of the installation location Housing dimensions Weight Screw terminals Tightening torque Upper terminals Lower terminals Approvals CE Marking EMC Immunity Emission Overvoltage cat III (IEC 60664) 24VAC - 15% / 10%, 50 to 60 Hz 24 VDC - 15% / +10% Internal PTC DC supply AC supply none none 4 kV 4kV 4kV 4kV max 5 VA Short circuit protection Dielectric voltage Supply to input Supply to output Input to output Rated operational voltage LED, green LED, green (CH 1, CH2) (EN 60529) IP 20 2 -25 to 65°C, R.H. < 95% -30 to 65°C, R.H. < 95% IP 54 22.5 x 99 x 114 mm Approx. 200 g Max. 0.5 Nm Max 0.8 Nm CULUS, TUV Yes Electromagnetic Compatibillity According to EN 61000-6-2 According to EN 61000-6-3 Mode of Operation The safety modules NSO02D and NSO13D monitor both mechanical switches and safety magnetic sensors (2 NO contact outputs), according to 98/37/CE Machinery Directive. If the unit is correctly supplied and the input terminals are closed (i.e. safety gate closed), the module is enabled to close the safety outputs and the external contactors can be energized. When the input terminals are open (i.e. safety gate open) the module is not enabled to close the safety outputs and the external contactors can not be energized. Automatic START Provided that the terminals X1 and X2 (NSO02...A) or S33 and S34 (NSO13...A) are connected, the safety outputs close and the auxiliary output opens (NSO13...A) as soon as both S1 and S2 switches are closed. The relevant CH1 and CH2 LED turn on. Releasing even one input contact (S1 and/or S2) forces immediately the safety outputs to open and the auxiliary output (NSO13...A) to close. A new operating cycle is possible only after releasing both input contacts and then operating them again. Manual START Provided that both S1 and S2 switches are closed, the safety outputs close and the auxiliary output opens (NSO13...A) as soon as the NO START pushbutton is pushed [connecting X1 and X2 (NSO02...A) or S33 and S34 (NSO13...A)] A new operating cycle is possible only after releasing both input contacts, closing them again and pushing the START button. Monitored manual START The monitored manual START versions (NSO...C) work as described in the previous paragraph (Manual START) except for a minimum delay of 500 ms from the closed status of the input contacts to the pushing of the START button. If the input terminals get closed with the START switch already closed, the safety outputs don’t close and the auxiliary doesn’t open (NSO13...C): it is necessary to release the START button and the input contacts before starting a new cycle, then operate the input contacts and finally, after at least 500 ms, operate the START button. So if the NO START button gets welded, the outputs don’t close anymore. Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 27/09/12 2 NSO02D, NSO13D Operational Diagram NSO02D...SA, NSO02D...DA NSO13D...SA, NSO13D...DA NSO02D...SC, NSO02D...DC NSO13D...SC, NSO13D...DC Wiring Diagrams NSO02D - Magnetic sensor and one access monitoring (Double channel) 3 NSO13D - Magnetic sensor and one access monitoring (Double channel) Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 27/09/12 NSO02D, NSO13D Wiring Diagrams (cont.) NSO02D - Magnetic sensors and two accesses monitoring Double channel) NSO13D - Magnetic sensors and two accesses monitoring (Double channel) NSO02D - Mechanical switch and one access monitoring (Single channel) NSO13D - Mechanical switch and one access monitoring (Single channel) Dimensions Versions with fixed terminals Versions with detachable terminals Specifications are subject to change without notice. Pictures are just an example. For special features and/or customization, please ask to our sales network. 27/09/12 4
NSO13DB24SA 价格&库存
很抱歉,暂时无法提供与“NSO13DB24SA”相匹配的价格&库存,您可以联系我们找货
