RV8H-L-AD220
RV8H-L-AD220
    IDEC(日本和泉)
    SIP
    通用 继电器 SPDT(1 Form C) 230VAC/DC 线圈 DIN 轨道
RV8H-L-AD220 数据手册
6mm and 14mm Slim Interface Relay RV8 Series 6mm Width Electromechanical Screw Terminal PRODUCT DESCRIPTION Solid State Spring Clamp Terminal IDEC 6mm and 14mm interface relays provide a compact solution for general purpose relay requirements. Available in electromechanical and solid state models, the RV8 series Interface relays are ideal for PLC and electronic systems, industrial automation, panel builders, assembly machine applications and other applications that require a high switching capability in a compact space. The RV8 series interface relays can be used as interfaces between the controller and the actuator to switch small and medium size loads. 6mm wide 6mm wide KEY FEATURES • Class I, Division 2 and Class I, Zone 2 Hazardous Location options (electromechanical relays only) SPECIFICATIONS Electromechanical Standard/ Hazardous Location C1D2 Class I, Division 2, Groups A, B, C, D, T4A Class I, Zone 2 AEx nA nC IIC T4 Class I, Zone 2 Ex nA nC IIC T4 X Gc UL/c-UL Listed Ratings 1 Pole 1C (SPDT) 1A (SPST) AgNi (Au plating) MOSFET, Transistor or Triac IP20 IP20 Between Contact and Coil 4,000V AC for 1 minute 2,500V AC for 1 minute Between Pole 1,000V AC for 1 minute - Contact Configuration Contact Material Degree of Protection Vibration Resistance Shock Resistance Operating Extremes Damage Limits Operating Extremes Damage Limits Mechanical Life (no load) Operating Temperature Frequency 10 to 55Hz, Amplitude 0.5mm (NO contact), 0.2mm (NC contact) Frequency 10 to 55Hz, Amplitude 1.0mm NO: 49m/s² NC: 29.4m/s² • Only 70mm in height from DIN rail • Gold-plated contacts (electrical mechanical relays only) UL/c-UL Listed, 1 Pole Number of Poles Dielectric Strength Solid State • Solid State relay versions available (6mm only) 980m/s2 • Pre-assembled relay and DIN mount socket • Universal screw terminals (flat and phillips) or spring clamp terminals • Universal AC/DC socket with built-in surge suppression and green LED • 6A-16A contact rating (electromechanical relays only) • Lever for easy locking and removal of relay • Operating temperature of -40ºC ~ +70°C (-20°C ~ +60°C for SSR) • RoHS compliant 980m/s² Over 10,000,000 operations (operation frequency 18,000 operations per hour) -40 to +70°C no freezing (-40 to +55°C for AD110 and AD220 coil voltages) -20 to +60°C Operating Humidity 5 to 85% (no condensation) 5 to 85% (no condensation) Weight (approx.) Screw Terminal: 30g, Spring Clamp Terminal: 26g Screw Terminal: 30g, Spring Clamp Terminal: 26g 1 (when using combination of RV relay and SV socket) 6mm and 14mm Slim Interface Relay RV8 Series 14mm Width PRODUCT DESCRIPTION Top View with Marking Plate Electromechanical Screw Terminal Electromechanical Spring Clamp Terminal 14mm interface relays are ideal for panels with limited room, these low-profile relays provide up to a 40% reduction in DIN rail space when compared with standard plug-in relays. RV8 relays are good for higher load switching applications, panels with high I/O content and commercial HVAC panels. UL listed when paired with a corresponding socket. (when using combination of RV relay and SV socket) 14mm wide SPECIFICATIONS 1 Pole Number of Poles 2 Pole Class I, Division 2, Groups A, B, C, D, T4 Class I, Zone 2 AEx nA nC IIC T4 Class I, Zone 2 Ex nA nC IIC T4 X Gc UL/c-UL Listed Ratings 1C (SPDT) 2C (DPDT) Contact Material AgNi AgNi (Au-plated) Degree of Protection Between contact and coil IP20 Contact Configuration Dielectric strength Between contacts of the same pole Between contact sets Vibration Resistance Shock Resistance IP20 5,000V AC for 1 minute Operating extremes Damage limits 1,000V AC for 1 minute - 2,500V AC for 1 minute Frequency 10 to 55Hz, Amplitude 0.75mm (NO contact), 0.175mm (NC contact) Frequency 10 to 55Hz, Amplitude 0.75mm (NO contact), 0.1mm (NC contact) NO: 98m/s² NC: 24.5m/s² Operating extremes Damage limits Electrical Life - Screw terminal Electrical Life - Spring Clamp terminal Mechanical Life (no load) Operating Temperature 980m/s² AC load:30,000 operations minimum (250V AC, 16A resistive load, operation frequency 360 operation per hour) AC load:30,000 operations minimum (250V AC, 12A resistive load, operation frequency 360 operation per hour) 980m/s² AC load:100,000 operations minimum (250V AC, 8A resistive load, ozperation frequency 360 operation per hour) AC load:100,000 operations minimum (250V AC, 6A resistive load, operation frequency 360 operation per hour) Over 10,000,000 operations (Operation frequency 18,000 operations per hour) Over 10,000,000 operations (Operation frequency 18,000 operations per hour) RV8H-1L1-D6, D9, D12, D18, D24, AD12, AD18, AD24, AD48, AD60, AD110 : -40 to +70°C (Contact current 12A max, 6A per terminal) no freezing : -40 to +55°C (Contact current 16A max, 8A per terminal) no freezing RV8H-2L-D6, D9, D12, D18, D24, AD12, AD18, AD24, AD48, AD60, AD110 : -40 to +70°C (Contact current 6A max) no freezing : -40 to +55°C (Contact current 8A max) no freezing RV8H-1L1- AD220 : -40 to +55°C (Contact current 16A max, 8A per terminal) no freezing RV8H-2L- AD220 : -40 to +55°C (Contact current 8A max) no freezing RV8H-1S1-D6, D9, D12, D18, D24, AD12, AD18, AD24, AD48, AD60, AD110 : -40 to +70°C (Contact current 12A max, 6A per terminal) no freezing RV8H-2S-D6, D9, D12, D18, D24, AD12, AD18, AD24, AD48, AD60, AD110 : -40 to +70°C (Contact current 6A max) no freezing RV8H-1S1- AD220 : -40 to +55°C (Contact current 12A max, 6A per terminal) no freezing RV8H-2S- AD220 : -40 to +55°C (Contact current 6A max) no freezing 5 to 85% (no condensation) Operating Humidity Weight (approx.) Screw Terminal: 52g Spring Clamp Terminal: 49g Screw Terminal: 52g Spring Clamp Terminal: 49g 2 PART NUMBERS 6mm Electromechanical Relay Screw Terminal AC/DC DC Input Voltage General Purpose Spring Clamp Terminal Hazardous Location (C1D2) General Purpose Hazardous Location (C1D2) 6V RV8H-L-D6 RV8H-L-D6-C1D2 RV8H-S-D6 RV8H-S-D6-C1D2 9V RV8H-L-D9 RV8H-L-D9-C1D2 RV8H-S-D9 RV8H-S-D9-C1D2 12V RV8H-L-D12 RV8H-L-D12-C1D2 RV8H-S-D12 RV8H-S-D12-C1D2 18V RV8H-L-D18 RV8H-L-D18-C1D2 RV8H-S-D18 RV8H-S-D18-C1D2 24V RV8H-L-D24 RV8H-L-D24-C1D2 RV8H-S-D24 RV8H-S-D24-C1D2 12V RV8H-L-AD12 RV8H-L-AD12-C1D2 RV8H-S-AD12 RV8H-S-AD12-C1D2 18V RV8H-L-AD18 RV8H-L-AD18-C1D2 RV8H-S-AD18 RV8H-S-AD18-C1D2 24V RV8H-L-AD24 RV8H-L-AD24-C1D2 RV8H-S-AD24 RV8H-S-AD24-C1D2 48V RV8H-L-AD48 RV8H-L-AD48-C1D2 RV8H-S-AD48 RV8H-S-AD48-C1D2 60V RV8H-L-AD60 RV8H-L-AD60-C1D2 RV8H-S-AD60 RV8H-S-AD60-C1D2 110V - 125V RV8H-L-AD110 RV8H-L-AD110-C1D2 RV8H-S-AD110 RV8H-S-AD110-C1D2 220V - 240V RV8H-L-AD220 RV8H-L-AD220-C1D2 RV8H-S-AD220 RV8H-S-AD220-C1D2 6mm Solid State Relay Input Voltage DC 6V 24V AC 120V 240V Output Voltage Screw Terminal Spring Clamp Terminal Part Number Part Number 24V DC, 3.5A RV8S-L-D24-D6 RV8S-S-D24-D6 48V DC, 0.1A RV8S-L-D48-D6 RV8S-S-D48-D6 240V AC, 2A zero cross RV8S-L-A240Z-D6 RV8S-S-A240Z-D6 240V AC, 2A random RV8S-L-A240-D6 RV8S-S-A240-D6 24V DC, 3.5A RV8S-L-D24-D24 RV8S-S-D24-D24 48V DC, 0.1A RV8S-L-D48-D24 RV8S-S-D48-D24 240V AC, 2A zero cross RV8S-L-A240Z-D24 RV8S-S-A240Z-D24 240V AC, 2A random RV8S-L-A240-D24 RV8S-S-A240-D24 24V DC, 3.5A RV8S-L-D24-A120 RV8S-S-D24-A120 48V DC, 0.1A RV8S-L-D48-A120 RV8S-S-D48-A120 240V AC, 2A zero cross RV8S-L-A240Z-A120 RV8S-S-A240Z-A120 240V AC, 2A random RV8S-L-A240-A120 RV8S-S-A240-A120 24V DC, 3.5A RV8S-L-D24-A240 RV8S-S-D24-A240 48V DC, 0.1A RV8S-L-D48-A240 RV8S-S-D48-A240 240V AC, 2A zero cross RV8S-L-A240Z-A240 RV8S-S-A240Z-A240 240V AC, 2A random RV8S-L-A240-A240 RV8S-S-A240-A240 3 14 mm Electromechanical Relay Screw Terminal General Purpose AC/DC DC Input voltage Spring Clamp Terminal Hazardous Location (C1D2) 1 Pole 2 Pole General Purpose 1 Pole 2 Pole 6V RV8H-1L1-D6 RV8H-2L-D6 RV8H-1L1-D6-C1D2 RV8H-2L-D6-C1D2 RV8H-1S1-D6 RV8H-2S-D6 RV8H-1S1-D6-C1D2 RV8H-2S-D6-C1D2 9V RV8H-1L1-D9 RV8H-2L-D9 RV8H-1L1-D9-C1D2 RV8H-2L-D9-C1D2 RV8H-1S1-D9 RV8H-2S-D9 RV8H-1S1-D9-C1D2 RV8H-2S-D9-C1D2 12V RV8H-1L1-D12 RV8H-2L-D12 RV8H-1L1-D12-C1D2 RV8H-2L-D12-C1D2 RV8H-1S1-D12 RV8H-2S-D12 RV8H-1S1-D12-C1D2 RV8H-2S-D12-C1D2 18V RV8H-1L1-D18 RV8H-2L-D18 RV8H-1L1-D18-C1D2 RV8H-2L-D18-C1D2 RV8H-1S1-D18 RV8H-2S-D18 RV8H-1S1-D18-C1D2 RV8H-2S-D18-C1D2 24V RV8H-1L1-D24 RV8H-2L-D24 RV8H-1L1-D24-C1D2 RV8H-2L-D24-C1D2 RV8H-1S1-D24 RV8H-2S-D24 RV8H-1S1-D24-C1D2 RV8H-2S-D24-C1D2 12V RV8H-1L1-AD12 RV8H-2L-AD12 RV8H-1L1-AD12-C1D2 RV8H-2L-AD12-C1D2 RV8H-1S1-AD12 RV8H-2S-AD12 RV8H-1S1-AD12-C1D2 RV8H-2S-AD12-C1D2 18V RV8H-1L1-AD18 RV8H-2L-AD18 RV8H-1L1-AD18-C1D2 RV8H-2L-AD18-C1D2 RV8H-1S1-AD18 RV8H-2S-AD18 RV8H-1S1-AD18-C1D2 RV8H-2S-AD18-C1D2 24V RV8H-1L1-AD24 RV8H-2L-AD24 RV8H-1L1-AD24-C1D2 RV8H-2L-AD24-C1D2 RV8H-1S1-AD24 RV8H-2S-AD24 RV8H-1S1-AD24-C1D2 RV8H-2S-AD24-C1D2 48V RV8H-1L1-AD48 RV8H-2L-AD48 RV8H-1L1-AD48-C1D2 RV8H-2L-AD48-C1D2 RV8H-1S1-AD48 RV8H-2S-AD48 RV8H-1S1-AD48-C1D2 RV8H-2S-AD48-C1D2 60V RV8H-1L1-AD60 RV8H-2L-AD60 RV8H-1L1-AD60-C1D2 RV8H-2L-AD60-C1D2 RV8H-1S1-AD60 RV8H-2S-AD60 RV8H-1S1-AD60-C1D2 RV8H-2S-AD60-C1D2 110V - 125V RV8H-1L1-AD110 RV8H-2L-AD110 RV8H-1L1-AD110-C1D2 RV8H-2L-AD110-C1D2 RV8H-1S1-AD110 220V - 240V RV8H-1L1-AD220 RV8H-2L-AD220 RV8H-1L1-AD220-C1D2 RV8H-2L-AD220-C1D2 RV8H-1S1-AD220 4 1 Pole 2 Pole Hazardous Location (C1D2) 1 Pole RV8H-2S-AD110 RV8H-1S1-AD110-C1D2 2 Pole RV8H-2S-AD110-C1D2 RV8H-2S-AD220 RV8H-1S1-AD220-C1D2 RV8H-2S-AD220-C1D2 RATINGS 6mm Electromechanical Coil Ratings Circuit AC Resistance ±15% (Ω)1 (at 23°C) Circuit DC Resistance ±15% (Ω)1 (at 23°C) 35 - 170 9V 18.6 - 485 12V 14.6 - 820 18V 11.6 - 1550 0.2 24V 10.6 - 2270 0.25 Rated Voltage DC 6V AC/DC Operating Characteristics Rated Current ±15% (mA)1 (at 23°C) Pickup Voltage (at 23°C) Dropout Voltage (at 23°C) Maximum Allowable Voltage (at 23°C) Power Consumption (W) 0.21 0.2 90% max 7% min 0.2 110% 12V 15.5 755 800 0.2 18V 13.3 1365 1345 0.25 24V 13.7 1730 1790 48V 4 11880 12230 60V 0.33 90% max 7% min 110% 0.2 3.4 17600 17910 110V - 125V 3.4 - 3.9 31790 - 31890 32450 - 32900 0.2 0.5 220V - 240V 3.3 - 3.6 65670 - 66070 65940 - 68570 0.85 Note 1 ±10% for 6V, 9V and 12V 6mm Electromechanical Contact Ratings Allowable Contact Power Resistive Load 1500VA, 180W DC Rated Load Resistive Load 250V AC 6A, 30V DC 6A Allowable Switching Current 6A Allowable Switching Voltage 400V AC, 125V DC Allowable Switching Power 1500VA, 180W DC Minimum Applicable Load 6V DC/10mA 6mm Solid State Input Ratings Random Crossing Zero Crossing Type Control Voltage Range Output / Input Voltage Pickup Voltage Dropout Voltage Input Current Maximum Operation Time Maximum Release Time 4.5-12V DC 24V DC / 6V DC 4.5V DC 1.5V DC 10mA±10%(±6VDC) 120μs 200μs 19.6-30V DC 24V DC / 24V DC 19.6V DC 5V DC 9mA±10%(±24VDC) 350μs 200μs 96-132V AC 24V DC / 120V AC 96V AC 12V AC 10mA±10%(±120VAC) 11ms 14ms 192-264V AC 24V DC / 240V AC 192V AC 24V AC 10mA±10%(±240VAC) 11ms 14ms 4.5-12V DC 48V DC / 6V DC 4.5V DC 1.5V DC 6mA±10%(±6VDC) 40μs 300μs 19.6-30V DC 48V DC / 24V DC 19.6V DC 5V DC 7mA±10%(±24VDC) 40μs 300μs 96-132V AC 48V DC / 120V AC 96V AC 12V AC 10mA±10%(±120VAC) 8ms 14ms 192-264V AC 48V DC / 240V AC 192V AC 24V AC 10mA±10%(±240VAC) 8ms 14ms 4.5-12V DC 240V AC / 6V DC 4.5V DC 2V DC 15mA±10%(±6VDC) 10ms 10ms 19.6-30V DC 240V AC / 24V DC 19.6V DC 5V DC 7mA±10%(±24VDC) 10ms 10ms 96-132V AC 240V AC / 120V AC 96V AC 12V AC 10mA±10%(±120VAC) 16ms 20ms 192-264V AC 240V AC / 240V AC 192V AC 24V AC 10mA±10%(±240VAC) 16ms 20ms 4.5-12V DC 240V AC / 6V DC 4.5V DC 2V DC 15mA±10%(±6VDC) 300μs 10ms 19.6-30V DC 240V AC / 24V DC 19.6V DC 5V DC 7mA±10%(±24VDC) 300μs 10ms 96-132V AC 240V AC / 120V AC 96V AC 12V AC 10mA±10%(±120VAC) 8ms 20ms 192-264V AC 240V AC / 240V AC 192V AC 24V AC 10mA±10%(±240VAC) 8ms 20ms 5 6mm Solid State Output Ratings Typical Input Voltage 24V DC 48V DC 240V AC Output Device MOSFET Photo-transistor Triac Operating Voltage Range 0-24V DC 0-48V DC 24-280V AC (47-63Hz) Maximum Load Current 3.5A 100mA 2A Minimum Load Current 1mA 1mA 70mA 30V DC 60V DC 600V AC Maximum Surge Current 9A (10ms) 300mA (10ms) 120A pk (16.6ms) Maximum l2t for Fusing – – 60A² sec 0.4V 1V 1.1V (peak) 0.001mA 0.001mA 4mA Normally Open Normally Open Normally Open Maximum Blocking Voltage Typical On-State Leakage Current Maximum Off-State Leakage Current Switching Configuration 14mm Electromechanical Coil Ratings Rated Current ±15% (mA)1 (at 23°C) Circuit AC Resistance ±15% (Ω)1 (at 23°C) Rated Voltage AC/DC DC DC AC 50Hz AC 60Hz DC AC 50Hz AC 60Hz Operating Characteristics (Against Rated Voltage) Pickup Voltage (at 23°C) Dropout Voltage (at 23°C) Maximum Allowable Voltage (at 23°C) Maximum Allowable Voltage2 Operation and release time Power Consumption (W) DC AC (50Hz) AC (60Hz) 6V 75.0 80 0.45 - - 9V 44.0 205 0.40 - - 12V 32.0 375 0.38 - - 18V 24.0 750 0.43 - - 120% 24V 20.0 12V 32.0 29.0 29.0 1200 375 414 414 18V 24.0 24.0 24.0 750 750 750 24V 20.0 21.0 21.0 1200 1143 1143 48V 7.6 9.0 9.0 6316 5333 5333 80% max 7% min 110%2 15ms max 110% 0.48 - - 0.38 0.35 0.35 0.43 0.43 0.43 0.48 0.50 0.50 0.36 0.43 0.43 7.6 9.0 9.0 7895 6667 6667 0.46 0.54 0.54 110V - 125V 4.4~5.1 5.3-5.8 5.3-5.8 24510 21552 21552 0.64 0.73 0.73 220V - 240V 4~4.6 4.5-5.2 4.8-5.5 52174 46154 43636 1.10 1.25 1.32 60V Note 1: Input voltages lower than 24V: ±10% Note 2: At rated operating temperature 14mm Contact Ratings Allowable contact power Screw Terminal Spring Clamp Terminal 1 Pole 4,000VA 1 Pole 3,000VA Resistive load Inductive load Rated Load Resitive load Allowable Switching Power Minimum Applicable Load (reference value) 2 Pole 1,500VA B300 (pilot duty) 1 Pole 250V AC, 16A (8A per terminal) at 55°C, 12A (6A per terminal) at 70°C 1 Pole 250V AC, 12A (6A per terminal) at 70°C 2 Pole 250V AC, 8A at 55°C, 6A at 70°C 2 Pole 250V AC, 6A at 70°C Inductive load Allowable Switching Current 2 Pole 2,000VA B300 (pilot duty) B300 (pilot duty) B300 (pilot duty) 1 Pole 16A (8A per terminal) at 55°C, 12A (6A per terminal) at 70°C 1 Pole 12A (6A per terminal) at 70°C 2 Pole 8A at 55°C, 6A at 70°C 2 Pole 6A at 70°C 1 Pole 4,000VA 1 Pole 3,000VA 2 Pole 2,000VA 2 Pole 1,500VA 1 Pole 6VDC 100mA 1 Pole 6VDC 100mA 2 Pole 5VDC 10mA 2 Pole 5VDC 10mA 6 ACCESSORIES Jumper, Spacer, and Screwdriver Marking Plate Part Numbers Color Part Number 6mm Jumper for 6mm Relay (20 combs) 1, 2, 6 Black Gray Blue SV9Z-J20B SV9Z-J20W SV9Z-J20S 14mm Jumper for 14mm Relay (32 combs, with 2 combs per relay, or 16 discrete relays.) 3, 4, 6 Black SV9Z-J232B Gray SV9Z-J232W Blue SV9Z-J232S 14mm Vertical Orientation Horizontal Orientation 6mm Part Number SV9Z-PW10 blank SV9Z-PW10-➀1-10 1-10 SV9Z-PW10-➀11-20 11-20 SV9Z-PW10-➀21-30 21-30 SV9Z-PW10-➀31-40 31-40 SV9Z-PW10-➀41-50 41-50 SV9Z-PW10-➀51-60 51-60 SV9Z-PW10-➀61-70 61-70 SV9Z-PW10-➀71-80 71-80 SV9Z-PW10-➀81-90 81-90 SV9Z-PW10-➀91-100 91-100 SV9Z-PW10-➀A-J A-J SV9Z-PW10-➀K-T K-T SV9Z-PW10-➀U-Z U-Z SV9Z-PW10-➀GROUND SV9Z-PW10-➀AC 1. In place of ➀ insert orientation code: V=Vertical, H=Horizontal 2. Each unit has 10 pieces (marking plates). Spacer (circuit separator) 5, 6 Marking Plate Placement SV9Z-SA2W Marking Plate Locking Lever Screwdriver BC1S-SD0 1. Jumper combs come with 20 points for 6mm relays. If shorter lengths are needed, simply cut off the excess points. 2. Ensure that the total current to the jumper does not exceed the overall rated current (Rated current: 6A). 3. Jumper combs come with 16 pairs of combs for 14mm relays. If shorter lengths are needed, simply cut off the excess points. 4. Ensure that the total current to the jumper does not exceed the overall rated current (Rated current: 6A for spring-clamp terminals and 8A for screw type terminations). 5. Width of spacer: 2mm 6. When using a cut jumper, please use a spacer on the cut side. For additional information see instruction sheet. 7 Engraving Insert DIMENSIONS (MM) 6mm Electromechanical and Solid State Relay 74.2 74.2 35.0 88.0 69.6 6mm Spring Clamp Terminal 69.6 6mm Screw Terminal 35.0 93.4 6.1 6.1 14mm Electromechanical Relay 74.2 74.2 35.0 88.0 69.6 14mm Spring Clamp Terminal 69.6 14mm Screw Terminal 35.0 93.4 14.0 8 14.0 INTERNAL CONNECTIONS 6mm Electromechanical Relay DC AC/DC PROTECTION AND INDICATION CIRCUIT A1 A2 14 11(13+) 12 PROTECTION AND INDICATION CIRCUIT A1+ A2- 14 11(13+) 12 6mm Solid State Relay INPUT : AC120V,AC240V OUTPUT : DC24V A1 A2 INPUT : DC6V,DC24V OUTPUT : DC24V PROTECTION AND INDICATION CIRCUIT 14 13(13+) INPUT : AC120V,AC240V OUTPUT : DC48V A1 A2 A2 A2- PROTECTION AND INDICATION CIRCUIT 14 13(13+) PROTECTION AND INDICATION CIRCUIT 14 13(13+) PROTECTION AND INDICATION CIRCUIT 14 13(13+) INPUT : DC6V,DC24V OUTPUT : DC48V PROTECTION AND INDICATION CIRCUIT 14 13(13+) INPUT : AC120V,AC240V OUTPUT : AC240V A1 A1+ A1+ A2INPUT : DC6V,DC24V OUTPUT : AC240V PROTECTION AND INDICATION CIRCUIT 14 13(13+) A1+ A2- 14mm Electromechanical Relay 1 Pole AC/DC A1 A2 DC PROTECTION AND INDICATION CIRCUIT 14/24 11/21 12/22 A1+ A2- PROTECTION AND INDICATION CIRCUIT 14/24 11/21 12/22 14mm Electromechanical Relay 2 Pole AC/DC A1 A2 DC PROTECTION AND INDICATION CIRCUIT 14 11 12 24 21 22 A1+ A2- PROTECTION AND INDICATION CIRCUIT 14 11 12 9 24 21 22 ACCESSORIES DIMENSIONS SV9Z-PW10* Marking Plate SV9Z-J20* Jumper for 6mm Relay 115.9 Cut 6.0 10.5 16.5 6.1 1.0 2.8 120.0 6.0 12.3 3.0 86.5 *Available blank or pre-marked. *Available in Black, Gray and Blue SV9Z-SA2W Spacer for 6 and 14mm Relay SV9Z-J232* Jumper for 14mm Relay 217.6 6.0 12.2 71.4 66.8 222.2 *Available in black, gray and blue. 35.0 96.7 2.0 10 2.8 12.3 15-P 14.0 CHARACTERISTICS 6mm Electromechanical Relay Maximum Switching Power AC Maximum Switching Power DC AC Resistive load Contact Current (A) Contact Current (A) AC Inductive load (p. f=0.35) DC Resistive load DC Inductive load (L/R = 56ms) Contact Voltage (V) Contact Voltage (V) 24V24V DCDC 48V48V DCDC 4.0 4.0 0.120.12 24V DC3.0 3.0 0.10 48V48V DC0.10 DC Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) 3.5 3.5 State Continuous Load Current vs. Ambient Temperature Curves 6mm Solid 24V24V DCDC 48V DC 0.080.08 0.120.12 0.060.06 0.100.10 0.040.04 0.080.08 0.020.02 0.060.06 0.000.00 0.040.04 0 0 4.0 4.0 2.4 2.4 3.5 1.8 1.8 3.5 3.0 1.2 1.2 3.0 2.4 2.4 0.6 0.6 1.8 1.8 0.0 0.0 0 0 1.2 1.2 No gap air gap No air Air gap 6.2 mm Air gap ≥ 6.2≥ mm No air Nogap air gap Air gap ≥ 6.2≥mm Air gap 6.2 mm 10 10 20 20 0.6 0.6 0.0 0.0 0 0 30 30 40 40 50 50 60 60 Ambient Temperature Ambient Temperature (°C)(°C) 10 10 20 20 30 30 40 40 Ambient Temperature (°C)(°C) Ambient Temperature 50 50 0.000.00 0 0 60 60 2.0 2.0 Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) Load Current (Amperes) 10 10 20 20 30 30 40 40 50 50 60 60 20 20 30 30 40 40 50 50 60 60 50 50 60 60 Ambient Temperature (°C)(°C) Ambient Temperature 2.0 2.0 1.7 1.7 1.7 1.7 2.3 1.3 1.3 2.3 No gap air gap No air 2.0 1.0 1.0 2.0 Air gap 6.2 mm Air gap ≥ 6.2≥ mm 1.7 1.7 0.7 0.7 1.3 1.3 0.3 0.3 No air Nogap air gap Air gap ≥ 6.2≥mm Air gap 6.2 mm 10 10 20 20 30 30 40 40 50 50 1.0 1.0 0.0 0.0 0 0 0.7 0.7 60 60 Ambient Temperature Ambient Temperature (°C)(°C) 0.3 0.3 Legend 60 60 240V ACAC Random Cross 240V Random Cross 2.3 1.3 1.3 2.3 0.0 0.0 0 0 50 50 2.3 2.3 240V ACAC Zero Cross 240V Zero Cross 1.0 1.0 0.0 0.0 0 0 0.7 0.7 40 40 240V AC Random Cross 2.3 2.3 1.3 1.3 0.3 0.3 30 30 Ambient Temperature Ambient Temperature (°C)(°C) 240V Random Cross 240V ACAC Random Cross 240V AC Zero Cross 1.7 1.7 0.7 0.7 No minimum No minimum air gap required air gap required 10 10 20 20 0.020.02 240V Zero Cross 240V ACAC Zero Cross 2.0 1.0 1.0 2.0 No minimum No minimum air gap required air gap required 10 10 20 20 30 30 40 40 Ambient Temperature (°C)(°C) Ambient Temperature No spacing required between units. 10 10 Ambient Temperature Ambient Temperature (°C)(°C) 0.3 0.3 50 50 0.0 0.0 0 0 60 60 Spacing of 6.2mm minimum required between units 11 10 10 20 20 30 30 40 40 Ambient Temperature (°C)(°C) Ambient Temperature Not Recommended 14mm Electromechanical Relays 14 mm Electrical Life Curve AC Load Operations (x10,000 operations) 1000 100 1 Pole 10 2 Pole 1 0 1 2 3 4 5 8 16 10 Contact Current (A) 14mm Contact Ratings DC AC 1 Pole 16 10 8 Contact Current (A) Contact Current (A) 1 Pole 2 Pole 1 0.1 10 20 30 40 50 16 10 8 1 0.1 100 200 300 400 500 2 Pole 10 20 30 40 50 100 200 300 400 500 Contact Voltage (V) Contact Voltage (V) IDEC Corporation • 1175 Elko Drive • Sunnyvale, CA 94089 • 800-262-IDEC (4332) • Fax: 408-745-5258 • www.IDEC.com/usa ©2017 IDEC Corporation. All Rights Reserved. RV9Y-DS400-0 3/17 5,000K 1703310236 12
RV8H-L-AD220 价格&库存
很抱歉,暂时无法提供与“RV8H-L-AD220”相匹配的价格&库存,您可以联系我们找货
RV8H-L-AD220
    • 1+80.75160
    • 200+31.25520
    • 500+30.15360
    • 1000+29.61360
