38.61.0.024.0060
38.61.0.024.0060
    FINDER
    Module
    通用 继电器 SPDT(1 Form C) 24VAC/DC 线圈 DIN 轨道
38.61.0.024.0060 数据手册
38 SЕRIES Relay interface modules 0.1 - 2 - 3 - 5 - 6 - 8 - 16 A Bottling plant Packaging machines Control panels Traffic light controls Vending machines Programmable controllers Panels for electrical distribution Labelling machines Prices, features, specifications, capabilities, appearance and availability of our products and services are subject to change without notice. FINDER assumes no responsibility for the presence of possible errors or insufficient information in this document. In case of discrepancies between the printed and online versions, the latter prevails. 38 38 SERIES Relay interface modules 0.1 - 2 - 3 - 5 - 6 - 8 - 16 A Common features • Instant ejection of relay by plastic retaining clip • Integral coil indication and protection circuit • 35 mm rail (EN 60715) mounting 6.2 mm wide • EMR - DC, AC or AC/DC coil versions • SSR - DC or AC/DC input versions • Screw and Screwless terminal options SERIES EMR Electromechanical Relays SSR Solid State Relays 38.51/38.61 38.81/38.91 B • Single solid state output: • 1 CO - 6 A/250 V AC Options 0.1 A/48 V DC, 6 A/24 V DC, 2 A/240 V AC • Silent, high speed switching • Long electrical life Page 1 6.2 mm wide • Special coil/input leakage current 38.51.3… - 38.61.3… Page 2 38.81.3… - 38.91.3… suppression types • EMR - AC or AC/DC coil versions • SSR - AC or AC/DC input versions • Screw and Screwless terminal options • Single solid state output: • 1 CO - 6 A/250 V AC Options 0.1 A/48 V DC, 6 A/24 V DC, 2 A/240 V AC • Silent, high speed switching • Long electrical life Page 1 6.2 mm wide 38.21 Page 2 38.21…9024-8240 • Timed Interface module • 4 functions & 4 time scales 0.1 s…6 h • EMR - AC/DC (12 or 24 V) supply versions • SSR - AC/DC (24 V) supply • Screw terminals • Single solid state output: • 1 CO - 6 A/250 V AC Options 6 A/24 V DC, 2 A/240 V AC • Silent, high speed switching • Long electrical life Page 3 14 mm wide 38.01/38.52/38.11/38.62 Page 3 38.31/38.41 XI-2023, www.findernet.com • 2 pole 8 A or 1 pole 16 A • EMR - DC or AC/DC coil versions • SSR - DC input versions • Screw and Screwless terminal options • Single solid state output: • 1 CO - 16 A/250 V AC • 2 CO - 8 A/250 V AC Options 5 A/24 V DC, 3 A/240 V AC • Silent, high speed switching • Long electrical life Page 4 Page 5 38 38 SERIES Relay interface modules - 1 Pole 6 A EMR SERIES 38.51/61 1 Pole - 6 A electromechanical relay interface modules, 6.2 mm wide. 38.51.3/38.61.3 Ideal interface for PLC and electronic systems • Sensitive DC coil or AC/DC coil versions • Integral coil indication and protection circuit • Instant ejection of relay using plastic retaining clip • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting 38.51/38.51.3 Screw terminal 38.61/38.61.3 Screwless terminal B • 1 pole electromechanical relay • Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting • Leakage current suppression • 1 pole electromechanical relay • Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting * S pecial version for max ambient temperature +70 °C. For outline drawing see page 13 Contact specification Contact configuration Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A V AC 1 CO (SPDT) 1 CO (SPDT) 6/10 6/10 250/400 250/400 Rated load AC1 VA 1500 1500 Rated load AC15 (230 V AC) VA 300 300 Single phase motor rating (230 V AC) kW 0.185 0.185 Breaking capacity DC1: 24/110/220 V A 6/0.2/0.12 6/0.2/0.12 mW (V/mA) 500 (12/10) 500 (12/10) AgNi AgNi Minimum switching load Standard contact material Coil specification Nominal voltage (UN)V AC/DC Rated power AC/DC 12 - 24 - 48 - 60 - (110…125) (110…125) — V AC (230…240)* — (230…240) V DC 6 - 12 - 24 - 48 - 60 - 220 (non polarized) — — VA (50 Hz)/W See page 9 1/1 0.5/— AC/DC (0.8…1.1)UN (94…138)V — AC (184…264)V — DC (0.8…1.2)UN Operating range (184…264)V — Holding voltage AC/DC 0.6 UN / 0.6 UN Must drop-out voltage AC/DC 0.1 UN / 0.05 UN Mechanical life AC/DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 60 · 103 60 · 103 ms 5/6 5/6 kV 6 (8 mm) 6 (8 mm) 0.6 UN / 0.6 UN 44 V 72 V Technical data XI-2023, www.findernet.com Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts V AC Ambient temperature range (UN ≤ 60 V/> 60 V)°C Protection category 1000 1000 –40…+70/–40…+55 —/–40…+55 IP 20 IP 20 Approvals relay (according to type) 1 38 SERIES 38 SERIES Relay interface modules - Single output SSR 38.81/38.91 Single output - solid state relay interface modules, 6.2 mm wide. 38.81.3/38.91.3 Ideal interface for PLC and electronic systems • DC, AC or AC/DC input versions • Supplied with integral coil indication and protection circuit • Silent, high switching speed and long electrical life clip • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting 38.81/38.81.3 Screw terminal 38.91/38.91.3 Screwless terminal • AC or DC output switching • SSR relay - DC input voltage • Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting • Leakage current suppression • AC or DC output • SSR relay - AC or AC/DC input voltage • Screw terminal and screwless terminal • 35 mm rail (EN 60715) mounting For outline drawing see page 13 Output specification Contact configuration 1 NO (SPST-NO) Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage A Switching voltage range  6/50 1 NO (SPST-NO) 0.1/0.5 2/80 6/50 0.1/0.5 2/80 V 24/33 DC 48/53 DC 240/— AC 24/33 DC 48/53 DC 240/— AC V (1.5…33)DC (1.5…53)DC (12…275)AC (1.5…33)DC (1.5…53)DC (12…275)AC 800 Repetitive peak off-state voltage Vpk — — 800 — — Minimum switching current mA 1 0.05 35 1 0.05 35 Max. “OFF-state” leakage current mA 0.001 0.001 1.5 0.001 0.001 1.5 0.4 1 1.6 0.4 1 1.6 Max. “ON-state” voltage drop V Input specification Nominal voltage (UN)V AC V DC V AC/DC — 230…240 6 - 24 - 60 — (110…125) - (220…240) 110…125 V DC See page 10 See page 10 Control current mA See page 10 See page 10 Release voltage V DC See page 10 See page 10 Operating range Technical data Operate/release time: ON/OFF (DC input) Dielectric strength between input/output Ambient temperature range Environmental protection ms V AC °C 0.2/0.6 0.04/0.11 12/12 0.2/0.6 0.04/0.11 2500 2500 –20…+55 –20…+55 IP20 IP20 12/12 Approvals relay (according to type) XI-2023, www.findernet.com B • Instant ejection of relay using plastic retaining 2 38 38 SERIES Timed interface modules - EMR & SSR SERIES 38.21 Slim timed interface module, 6.2 mm wide. 1 pole, 6 A - electromechanical relay 1 output, 2 A DC or AC - solid state relay 38.21…9024-8240 • Electromechanical or solid state output • Multi-functions timer • AC/DC supply • 4 time scales from 0.1 s to 6 h • Instant ejection of relay using plastic retaining B clip • 6.2 mm wide, 35 mm rail (EN 60715) mounting 38.21 Screw terminal • 1 pole electromechanical output relay • 12 or 24 V AC/DC supply • Screw terminal • 35 mm rail (EN 60715) mounting • DC or AC solid state output relays • 24 V AC/DC supply voltage • Screw terminal • 35 mm rail (EN 60715) mounting AI: On-delay DI: Interval GI: Pulse delayed SW: Symmetrical flasher (starting pulse on) AI: On-delay DI: Interval GI: Pulse delayed SW: Symmetrical flasher (starting pulse on) For outline drawing see page 13 Contact specification Contact configuration Rated current/ Maximum peak current Rated voltage/ Maximum switching voltage A V AC — 6/10 — 250/400 — VA 1500 — A 6/0.2/0.12 — mW (V/mA) 500 (12/10) — Rated load AC1 Breaking capacity DC1: 24/110/220 V Minimum switching load 1 CO (SPDT) Standard contact material AgNi — Output specification Output configuration Rated current/Maximum peak current A DC output (…9024) AC output (…8240) — 1 NO (SPST-NO) 1 NO (SPST-NO) — 6/50 2/80 Rated voltage/ Maximum blocking voltage V — (24/33)DC (240/—)AC Switching voltage range  V — (1.5…33)DC (12…275)AC Repetitive peak off-state voltage Vpk — — 800 Minimum switching current mA 1 35 Max. “OFF-state” leakage current mA — 0.001 1.5 V — 0.4 1.6 Max. “ON-state” voltage drop Supply specification Nominal voltage (UN) V AC (50/60 Hz)/DC Rated power Operating range 12 - 24 24 0.5 0.5 AC (0.8…1.1)UN (0.8…1.1)UN DC (0.8…1.1)UN (0.8…1.1)UN VA/W Technical data XI-2023, www.findernet.com Specified time range (0.1…3)s, (3…60)s, (1…20)min, (0.3…6)h Repeatability% ± 1 Recovery time  ≤ 50 ms Setting accuracy-full range % Ambient temperature  °C Protection category 5% –40…+70 –20…+55 IP 20 Approvals relay (according to type) 3 38 SERIES 38 SERIES Relay interface modules - 1 Pole 16 A and 2 Pole 8 A EMR 38.01/38.11 Electromechanical relay interface modules, 14 mm wide. 38.52/38.62 38.01 and 38.11 - 1 Pole 16 A 38.52 and 38.62 - 2 Pole 8 A Ideal interface for PLC and electronic systems clip • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting 38.01/52 Screw terminal • Screw terminal and screwless terminal • 1 pole electromechanical relay • 35 mm rail (EN 60715) mounting • Screw terminal and screwless terminal • 2 pole electromechanical relay • 35 mm rail (EN 60715) mounting 38.11/62 Screwless terminal * For currents > 10 A, contact terminals must be connected in parallel (21 with 11, 24 with 14, 22 with 12). For outline drawing see page 13 Contact specification Contact configuration Rated current/Maximum peak current Rated voltage/ Maximum switching voltage A V AC 1 CO (SPDT) 2 CO (DPDT) 16*/30 8/15 250/400 250/400 Rated load AC1 VA 4000 2000 Rated load AC15 (230 V AC) VA 750 400 Single phase motor rating (230 V AC) kW Breaking capacity DC1: 24/110/220 V A Minimum switching load mW (V/mA) Standard contact material 0.5 0.3 16/0.3/0.12 8/0.3/0.12 300 (5/5) 300 (5/5) AgNi AgNi 24 - 60 - (110…125) 24 - 60 - (110…125) Coil specification Nominal voltage (UN)V AC/DC Rated power AC/DC V AC 230…240 230…240 V DC 12 - 24 - 60 - 220 12 - 24 - 60 - 220 See page 9 See page 9 VA (50 Hz)/W Operating range AC/DC DC 0.8…1.1 0.8…1.1 (0.8…1.2)UN (0.8…1.2)UN Holding voltage AC/DC 0.6 UN / 0.6 UN 0.6 UN / 0.6 UN Must drop-out voltage AC/DC 0.1 UN / 0.05 UN 0.1 UN / 0.05 UN Mechanical life AC/DC cycles 10 · 106 10 · 106 Electrical life at rated load AC1 cycles 50 · 10 60 · 103 ms 8/10 8/10 kV 6 (8 mm) 6 (8 mm) Technical data Operate/release time  Insulation between coil and contacts (1.2/50 µs) Dielectric strength between open contacts V AC Ambient temperature range (UN ≤ 60 V/> 60 V)°C Protection category Approvals relay (according to type) 4 3 1000 1000 –40…+70/–40…+55 –40…+70/–40…+55 IP 20 IP 20 XI-2023, www.findernet.com B • Sensitive DC coil or AC/DC coil versions • Integral coil indication and protection circuit • Instant ejection of relay using plastic retaining 38 38 SERIES Relay interface modules - Single output SSR SERIES 38.31/38.41 Single output - solid state relay interface modules, 14 mm wide. Ideal interface for PLC and electronic systems • DC input versions • Supplied with integral coil indication and protection circuit • Silent, high switching speed and long electrical life • Instant ejection of relay using plastic retaining clip • UL Listing (certain relay/socket combinations) • 35 mm rail (EN 60715) mounting 38.31 Screw terminal 38.41 Screwless terminal B • Screw terminal and screwless terminal • AC or DC output switching • SSR relay - DC input voltage • 35 mm rail (EN 60715) mounting For outline drawing see page 13 Output specification Contact configuration Rated current/ Maximum peak current (10 ms) Rated voltage/ Maximum blocking voltage Switching voltage range A 1 NO (SPST-NO) 1 NO (SPST-NO) 5/40 3/40 V (24/35)DC (240/—)AC V (1.5…24)DC (12…275)AC Repetitive peak off-state voltage Vpk — 600 Minimum switching current mA 1 50 Max. “OFF-state” leakage current mA 0.01 1 V 0.3 1.1 Max. “ON-state” voltage drop Input specification Nominal voltage (UN)V AC/DC 24 V DC 12 - 24 V DC See page 10 Control current mA See page 10 Release voltage V DC See page 10 Operating range Technical data Operate/release time: ON/OFF (DC input) Dielectric strength between input/output Ambient temperature range Environmental protection ms V AC °C 0.05/0.25 12/12 2500 –20…+55 IP 20 XI-2023, www.findernet.com Approvals relay (according to type) 5 38 SERIES 38 SERIES Relay interface modules - Ordering information Ordering information Electromechanical relay - 1 or 2 Pole Example: 38 series screw terminal relay interface module, 1 CO (SPDT), sensitive 12 V DC coil. 3 8 . 5 B A B C D 1 . 7 . 0 1 2 . 0 0 5 0 Series D: Special versions 0 = Standard Type 0 = Electromechanical 16 A relay, with screw terminal 1 = Electromechanical 16 A relay, with screwless terminal 2 = Timer multifunction (AI, DI, GI, SW), with screw terminal 5 = Electromechanical relay, with screw terminal 6 = Electromechanical relay, with screwless terminal C: Options 5 = Standard DC 6 = Standard AC or AC/DC B: Contact circuit 0 = CO (nPDT) A: Contact material 0 = AgNi Standard 4 = AgSnO2 5 = AgNi + Au No. of poles 1 = 1 pole, 6 or 16 A 2 = 2 pole, 8 A Coil version 0 = AC (50/60 Hz)/DC, DC only, for 240 V version 3 = L eakage current suppression for (110…125)V AC/DC - (230…240)V AC 7 = Sensitive DC, (6, 12, 24, 48, 60)V only 8 = AC (50/60 Hz) Coil voltage See coil specifications Selecting features and options: only combinations in the same row are possible. Type Coil version A B C D 38.01/11 7 0-4 0 5 0 38.01/11 0-8 0-4 0 6 0 38.51/61 7 0-4-5 0 5 0 38.51/61 0-3-8 0-4-5 0 6 0 38.52/62 7 0-5 0 5 0 0-8 0-5 0 6 0 0 0 0 6 0 XI-2023, www.findernet.com 38.52/62 38.21 6 38 38 SERIES Relay interface modules - Ordering information SERIES Ordering information Solid state relay - Single output - 6.2 & 14 mm wide Example: 38 series screw terminal SSR relay interface module, 6.2 mm wide, 6 A output, 24 V DC input. 3 8 . 8 1 . 7 . 0 2 4 . 9 0 2 4 Series B Output version 9024 = 6 A - 24 V DC (38.21, 38.81 & 38.91) 9024 = 5 A - 24 V DC (38.31 & 38.41) 7048 = 0.1 A - 48 V DC (38.81 & 38.91) 8240 = 2 A - 240 V AC (38.21, 38.81 & 38.91) 8240 = 3 A - 240 V AC (38.31 & 38.41) Type 21 = Timer SSR 6.2 mm wide, with screw terminal 31 = SSR 14 mm wide, with screw terminal 41 = SSR 14 mm wide, with screwless terminal 81 = SSR 6.2 mm wide, with screw terminal 91 = SSR 6.2 mm wide, with screwless terminal Input version 0 = AC (50/60 Hz)/DC, DC only, for 240 V version 3 = Leakage current suppression for (110…125)V AC/DC and (230…240)V AC SSR only 7 = DC, (6, 24, 60)V SSR only Input voltage See input specifications Selecting features and options: only combinations in the same row are possible. Input version Output version 38.81/91 7 9024 - 7048 - 8240 38.81/91 0-3 9024 - 7048 - 8240 38.31/41 0-7 9024 - 8240 38.21 0 9024 - 8240 XI-2023, www.findernet.com Type 7 38 38 SERIES Relay interface modules - Technical data SERIES Technical data - 1 & 2 Pole Electromechanical Relays Insulation Insulation according to EN 61810-1 insulation rated voltage V 250 rated impulse withstand voltage 4 pollution degree 3 2 overvoltage category III III Insulation between coil and contacts (1.2/50 µs) kV 6 (8 mm) Dielectric strength between open contacts V AC 1000 Insulation between coil terminals Rated impulse voltage (surge) differential mode (according to EN 61000-4-5) kV (1.2/50 µs) 2 Other data 1 Pole 6 A Bounce time: NO/NC Vibration resistance (10…55)Hz: NO/NC Power lost to the environment 1 Pole 16 A - 2 Pole 8 A ms 1/6 2/5 g 10/5 15/2 without contact current W 0.2 (12 V) - 0.9 (240 V) 0.5 (24 V) - 0.9 (240 V) with rated current W 0.5 (12 V) - 1.5 (240 V) 1.3 (24 V) - 1.7 (240 V) Terminals 38.21 / 38.51 Wire strip length 38.61 mm 10 Screw torque 10 Nm 0.5 Max. wire size — solid cable stranded cable solid cable stranded cable mm2 1 x 2.5 / 2 x 1.5 1 x 2.5 / 2 x 1.5 1 x 2.5 1 x 2.5 AWG 1 x 14 / 2 x 16 1 x 14 / 2 x 16 1 x 14 1 x 14 38.01 / 38.52 Wire strip length Screw torque 38.11 / 38.62 mm 10 10 Nm 0.5 — Max. wire size solid cable stranded cable solid cable stranded cable 1 x 2.5 / 2 x 1.5 1 x 2.5 / 2 x 1.5 1 x 2.5 1 x 2.5 1 x 14 / 2 x 16 1 x 14 1 x 14 mm 2 AWG 1 x 14 / 2 x 16 Contact specification - 1 & 2 Pole Electromagnetic Relays Cycles Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 H 38 - Maximum DC1 breaking capacity, 1 Pole 6 A DC breaking current (A) F 38 - Electrical life (AC) v contact current, 1 Pole 6 A DC voltage (V) Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 38.01/11 limit current 38.52/62 limit current 2 contacts in series single contact DC voltage (V) : 2 Pole 8 A : 1 Pole 16 A 8 • When switching a resistive load (DC1) having voltage and current values under the curve, an electrical life of ≥ 60 · 103 (1 Pole) or ≥ 80 · 103 (2 Pole) can be expected. • In the case of DC13 loads, the connection of a diode in parallel with the load will permit a similar electrical life as for a DC1 load. Note: the release time for the load will be increased. XI-2023, www.findernet.com Resistive load - cosφ = 1 Inductive load - cosφ = 0.4 H 38 - Maximum DC1 breaking capacity, 1 Pole 16 A and 2 Pole 8 A DC breaking current (A) F 38 - Electrical life (AC) v contact current, 1 Pole 16 A and 2 Pole 8 A Cycles B 400 kV 4 38 38 SERIES Relay interface modules - Technical data SERIES Coil specifications - 1 Pole 6 A Electromechnical Relay Coil data sensitive DC, 1 Pole Nominal voltage UN V 6 12 24 48 60 220 Coil code 7.006 7.012 7.024 7.048 7.060 0.240 Coil data AC/DC, 1 Pole Operating range Umin V 4.8 9.6 19.2 38.4 48 176 Umax V 7.2 14.4 28.8 57.6 72 264 Rated coil Power consumption consumption I at UN P at UN mA W 35 0.2 0.2 15.2 0.3 10.4 0.3 6.3 0.4 7 0.9 4 Nominal voltage UN V 12 24 48 60 110…125 Coil code 0.012 0.024 0.048 0.060 0.125 Operating range Umin V 9.6 19.2 38.4 48 88 Umax V 13.2 26.4 52.8 66 138 Rated coil Power consumption consumption I at UN P at UN mA VA/W 16 0.2/0.2 12 0.3/0.2 6.9 0.3/0.3 7 0.5/0.5 5(*) 0.6/0.6(*) (*) Rated coil consumption and power consumption values relate to UN = 125 V. Coil data AC, 1 Pole (indicated for max ambient temperature +70 °C) Nominal voltage UN V (230…240) AC Coil code Operating range Umin V 184 8.240 Umax V 264 Rated coil Power consumption consumption P at UN I at UN mA VA/W 3 0.7/0.3 Coil data, leakage current suppression types, 1 Pole Nominal voltage Coil code UN V (110…125) AC/DC 3.125 (230…240) AC 3.240 Operating range Umin V 94 184 Umax V 138 264 Rated coil Power consumption consumption P at UN I at UN mA VA/W 8(*) 1/1(*) 7(*) 1.7/0.5(*) (*) Rated coil consumption and power consumption values relate to UN = 125 and 240 V. The 38 Series interface modules (supply version 3) have built-in leakage current suppression to address industry concerns of the contacts not dropping-out when there is residual current in the circuit; at (110…125)V AC and (230…240)V AC. This problem can occur, for example, when connecting the interface modules to PLC‚s with triac outputs or when connecting via relatively long cables. Coil specifications - 1 Pole 16 A and 2 Pole 8 A Electromechanical Relay Coil data sensitive DC, 1 Pole 16 A and 2 Pole 8 A Nominal voltage UN V 12 24 60 220 Coil code 7.012 7.024 7.060 0.240 Operating range Umin Umax V 9.6 19.2 48 176 V 14.4 28.8 72 264 Coil data AC/DC, 1 Pole 16 A and 2 Pole 8 A Rated coil Power consumption consumption P at UN I at UN mA W 41 0.5 19.5 0.5 8 0.5 4 0.9 Nominal voltage UN Coil code V 24 60 110…125 0.024 0.060 0.125 Operating range Umin Umax V 19.2 48 88 V 26.4 66 138 Rated coil Power consumption consumption P at UN I at UN mA W 20 0.5/0.5 7.1 0.5/0.5 4.6 0.6/0.6 Coil data AC, 1 Pole 16 A and 2 Pole 8 A Nominal voltage UN V 230…240 Coil code 8.230 Operating range Umin Umax V 184 V 264 Rated coil Power consumption consumption P at UN I at UN mA VA/W 5.3 1.2/0.6 Coil specification - 1 & 2 Pole Electromagnetic Relays R 38 - DC coil operating range v ambient temperature 1 Pole and 2 Pole 1 2 XI-2023, www.findernet.com 3 4 1 - Max. permitted coil voltage at nominal load (DC coil). 2 - Max. permitted coil voltage at nominal load (AC/DC coils U ≤ 60 V). 3 - Max. permitted coil voltage at nominal load (AC/DC coils U > 60 V). 4 - Min pick-up voltage with coil at ambient temperature. 9 B 38 38 SERIES Relay interface modules - Technical data SERIES Technical data - Solid State Relays Other data 38.81/38.91 Power lost to the environment W 0.25 (24 V DC) 0.5 with rated current W 0.4 2.2 (DC output)/3 (AC output) Terminals 38.81 Wire strip length 38.91 mm 10 Screw torque 10 Nm 0.5 Max. wire size — solid cable stranded cable solid cable mm2 1 x 2.5 / 2 x 1.5 1 x 2.5 / 2 x 1.5 1 x 2.5 1 x 2.5 AWG 1 x 14 / 2 x 16 1 x 14 / 2 x 16 1 x 14 1 x 14 38.31 Wire strip length 38.41 mm 10 Screw torque 10 Nm 0.5 Max. wire size stranded cable — solid cable stranded cable solid cable mm2 1 x 2.5 / 2 x 1.5 1 x 2.5 / 2 x 1.5 1 x 2.5 stranded cable 1 x 2.5 AWG 1 x 14 / 2 x 16 1 x 14 / 2 x 16 1 x 14 1 x 14 Input specifications - Solid State Relays type 38.81 and 38.91 - 6.2 mm wide Input data DC Nominal Supply voltage code UN V 6 24 60 220 7.006 7.024 7.060 0.240 Input data AC/DC Operating range Umin V 5 16.8 35.6 176 Umax V 7.2 30 72 264 Release Rated coil Power voltage consumption consumption I at UN U P V mA W 2.4 7 0.2 10 10.5 0.3 20 6.5 0.4 — 4 0.9 Nominal voltage UN V 110…125 Supply Operating range code 0.125 Umin V 88 Umax V 138 Release Rated coil Power voltage consumption consumption P I at UN U V mA VA/W 22 5.5* 0.7/0.7 (*) Rated coil consumption and power consumption values relate to UN = 125 and 240 V. Input data - Leakage current suppression types Nominal voltage Supply Operating range Release Rated coil Power code voltage consumption consumption I at UN P at UN Umin Umax U UN V V V V mA W 110…125 AC/DC 3.125 94 138 44 8(*) 1/1(*) 230…240 AC 3.240 184 264 72 6.5(*) 1.6/0.6(*) (*) Rated coil consumption and power consumption values relate to UN = 125 and 240 V. The 38 Series interface modules (supply version 3) have built-in leakage current suppression to address industry concerns of the contacts not dropping-out when there is residual current in the circuit; at (110…125)V AC and (230…240)V AC. This problem can occur, for example, when connecting the interface modules to PLC‚s with triac outputs or when connecting via relatively long cables. Input specification - Solid State Relay types 38.31 and 38.41 - 14 mm wide Input data DC Nominal Supply voltage code UN V 12 7.012 24 7.024 Input data AC/DC Operating range Umin V 9.6 16.8 Umax V 18 30 Release Rated coil voltage consumption I at UN U V mA 5 9 5 12 Power consumption P W 0.2 0.3 Nominal Supply voltage code UN V 24 0.024 Operating range Umin V 16.8 Umax V 30 Release Rated coil voltage consumption I at UN U V mA 9 16.5 Power consumption P W 0.3 XI-2023, www.findernet.com B 38.31/38.41 without output current 10 38 38 SERIES Timed interface modules SERIES Output specification - Solid State Relays L 34-1 - Output DC current v ambient temperature 38.x1.x.xxx.9024 (only 38.81/91/21) L 34 - Output AC current v ambient temperature 38.x1.x.xxx.8240 (only 38.81/91/21) B I: SSR installed as a group (without gap between sockets) II: SSR installed individually in free air , or with a gap ≥ 9 mm, which implies a not significant influence from nearby components Max recommended switching frequency (Cycles/Hour, with 50% Duty-cycle) at ambient temperature 50°C, single mounting (only 38.81/91/21) Load 38.x1.x.xxx.9024 38.x1.x.xxx.8240 38.x1.x.xxx.7048 180 000 — — 24 V 3 A DC L/R = 10 ms 5000 — — 24 V 2 A DC L/R = 40 ms 3600 — — 24 V 1 A DC L/R = 40 ms 6500 — — 24 V 0.8 A DC L/R = 40 ms 9000 — — 24 V 1.5 A DC L/R = 80 ms 3250 — — 230 V 2 A AC1 — 60 000 — 230 V 1.25 A AC15 — 3600 — 48 V 0.1 A DC1 — — 60 000 XI-2023, www.findernet.com 24 V 6 A DC1 11 38 SERIES 38 SERIES Timed interface modules Additional technical data - Timed Interface Module EMC specifications Type of test Reference standard Electrostatic discharge EN 61000-4-2 4 kV air discharge EN 61000-4-2 8 kV Radio-frequency electromagnetic field (80 ÷ 1000 MHz) EN 61000-4-3 10 V/m Fast transients (burst) (5-50 ns, 5 kHz) on Supply terminals EN 61000-4-4 4 kV Surges (1.2/50 µs) on Supply terminals common mode EN 61000-4-5 4 kV differential mode EN 61000-4-5 4 kV Radio-frequency common mode (0.15 ÷ 80 MHz) on Supply terminals EN 61000-4-6 10 V Radiated and conducted emission EN 55022 class B Other data EMR SSR Power lost to the environment without contact current W 0.1 0.1 with rated current W 0.6 0.5 Terminals 38.21 Wire strip length mm 10 Screw torque Nm 0.5 (3…60)s (0.1…3)s stranded cable mm2 1 x 2.5 / 2 x 1.5 1 x 2.5 / 2 x 1.5 AWG 1 x 14 / 2 x 16 1 x 14 / 2 x 16 1 2 3 4 1 2 3 4 1 2 3 4 Times scales solid cable 1 2 3 4 Max. wire size (0.3…6)h (1…20)min Functions U = Supply voltage 1 2 3 4 1 2 3 4 1 2 3 4 Wiring diagram 12 Supply voltage NO contact/output OFF Open ON Open (time in progress) ON Closed = Output contact (AI) On-delay. Apply power to timer. Output contacts transfer after preset time has elapsed. Reset occurs when power is removed. (DI) Interval. Apply power to timer. Output contacts transfer immediately. After the preset time has elapsed, contacts reset. (GI) Pulse delayed. Apply power to timer. Output contacts transfer after preset time has elapsed. Reset occurs after a fixed time of 0.5 s. (SW) Symmetrical flasher (starting pulse on). Apply power to timer. Output contacts transfer immediately and cycle between ON and OFF for as long as power is applied. The ratio is 1:1 (time on = time off ). XI-2023, www.findernet.com LED 1 2 3 4 B contact discharge 38 38 SERIES Relay interface modules - Dimensional data SERIES Outline drawings Types 3  8.21 38.51 / 38.51.3 38.81 / 38.81.3 Screw terminal Types 3  8.01 38.31 38.52 Screw terminal B Types 3  8.11 38.41 38.62 Screwless terminal XI-2023, www.findernet.com Types 3  8.61 / 38.61.3 38.91 / 38.91.3 Screwless terminal 13 38 SERIES 93 SERIES Sockets and accessories for 38 series B 93.01 93.51 93.02 93.52 Approvals (according to type): Certain relay/socket combinations 14 Screw terminal - 1 Pole relay 6 A Interface Module Code Coil voltage 38.51.0.012.0060 12 V AC/DC 38.51.0.024.0060 24 V AC/DC 38.51.0.048.0060 48 V AC/DC 38.51.0.060.0060 60 V AC/DC 38.51.0.125.0060 (110…125)V AC/DC 38.51.3.125.0060 (110…125)V AC/DC 38.51.3.240.0060 (230…240)V AC 38.51.7.006.0050 6 V DC 38.51.7.012.0050 12 V DC 38.51.7.024.0050 24 V DC 38.51.7.048.0050 48 V DC 38.51.7.060.0050 60 V DC 38.51.0.240.0060 220 V DC 38.51.8.240.0060 (230…240)V AC Screwless terminal - 1 Pole relay 6 A Interface Module Code Coil voltage 38.61.0.012.0060 12 V AC/DC 38.61.0.024.0060 24 V AC/DC 38.61.0.125.0060 (110…125)V AC/DC 38.61.3.125.0060 (110…125)V AC/DC 38.61.3.240.0060 (230…240)V AC 38.61.7.012.0050 12 V DC 38.61.7.024.0050 24 V DC 38.61.0.240.0060 220 V DC 38.61.8.240.0060 (230…240)V AC Screw terminal - 1 Pole relay 16 A Interface Module Code Coil voltage 38.01.7.012.0050 12 V DC 38.01.7.024.0050 24 V DC 38.01.7.060.0050 60 V DC 38.01.0.024.0060 24 V AC/DC 38.01.0.060.0060 60 V AC/DC 38.01.0.125.0060 125 V AC/DC 38.01.0.240.0060 220 V DC 38.01.8.230.0060 230 V AC Screwless terminal - 1 Pole relay 16 A Interface Module Code Coil voltage 38.11.7.012.0050 12 V DC 38.11.7.024.0050 24 V DC 38.11.7.060.0050 60 V DC 38.11.0.024.0060 24 V AC/DC 38.11.0.060.0060 60 V AC/DC 38.11.0.125.0060 125 V AC/DC 38.11.0.240.0060 220 V DC 38.11.8.230.0060 230 V AC Screw terminal - 2 Pole relay 8 A Interface Module Code Coil voltage 38.52.0.024.0060 24 V AC/DC 38.52.0.060.0060 60 V AC/DC 38.52.0.125.0060 (110…125)V AC/DC 38.52.7.012.0050 12 V DC 38.52.7.024.0050 24 V DC 38.52.7.060.0050 60 V DC 38.52.0.240.0060 220 V DC 38.52.8.230.0060 (230…240)V AC Screwless terminal - 2 Pole relay 8 A Interface Module Code Coil voltage 38.62.0.024.0060 24 V AC/DC 38.62.0.060.0060 60 V AC/DC 38.62.0.125.0060 (110…125)V AC/DC 38.62.7.012.0050 12 V DC 38.62.7.024.0050 24 V DC 38.62.7.060.0050 60 V DC 38.62.0.240.0060 220 V DC 38.62.8.230.0060 (230…240)V AC Relay 34.51.7.012.0010 34.51.7.024.0010 34.51.7.048.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.005.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.048.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 Socket 93.01.0.024 93.01.0.024 93.01.0.060 93.01.0.060 93.01.0.125 93.01.3.125 93.01.3.240 93.01.7.024 93.01.7.024 93.01.7.024 93.01.7.060 93.01.7.060 93.01.0.240 93.01.8.240 Relay 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.060.0010 34.51.7.012.0010 34.51.7.024.0010 34.51.7.060.0010 34.51.7.060.0010 Socket 93.51.0.024 93.51.0.024 93.51.0.125 93.51.3.125 93.51.3.240 93.51.7.024 93.51.7.024 93.51.0.240 93.51.8.240 Relay 41.61.9.012.0010 41.61.9.024.0010 41.61.9.060.0010 41.61.9.024.0010 41.61.9.060.0010 41.61.9.110.0010 41.61.9.110.0010 41.61.9.110.0010 Socket 93.02.7.024 93.02.7.024 93.02.7.060 93.02.0.024 93.02.0.060 93.02.0.125 93.02.0.240 93.02.8.230 Relay 41.61.9.012.0010 41.61.9.024.0010 41.61.9.060.0010 41.61.9.024.0010 41.61.9.060.0010 41.61.9.110.0010 41.61.9.110.0010 41.61.9.110.0010 Socket 93.52.7.024 93.52.7.024 93.52.7.060 93.52.0.024 93.52.0.060 93.52.0.125 93.52.0.240 93.52.8.230 Relay 41.52.9.024.0010 41.52.9.060.0010 41.52.9.110.0010 41.52.9.012.0010 41.52.9.024.0010 41.52.9.060.0010 41.52.9.110.0010 41.52.9.110.0010 Socket 93.02.0.024 93.02.0.060 93.02.0.125 93.02.7.024 93.02.7.024 93.02.7.060 93.02.0.240 93.02.8.230 Relay 41.52.9.024.0010 41.52.9.060.0010 41.52.9.110.0010 41.52.9.012.0010 41.52.9.024.0010 41.52.9.060.0010 41.52.9.110.0010 41.52.9.110.0010 Socket 93.52.0.024 93.52.0.060 93.52.0.125 93.52.7.024 93.52.7.024 93.52.7.060 93.52.0.240 93.52.8.230 XI-2023, www.findernet.com Electromechanical Relay & Socket Combinations 38 93 SERIES Sockets and accessories for 38 series SERIES Solid State Relay & Socket Combinations - 6.2 mm wide 93.01 93.51 Approvals (according to type): Certain relay/socket combinations Screw terminal Interface Module Code 38.81.7.006.xxxx 38.81.7.024.xxxx 38.81.7.060.xxxx 38.81.0.125.xxxx 38.81.0.240.xxxx 38.81.3.125.xxxx 38.81.3.240.xxxx Screwless terminal Interface Module Code 38.91.7.006.xxxx 38.91.7.024.xxxx 38.91.7.060.xxxx 38.91.0.125.xxxx 38.91.0.240.xxxx 38.91.3.125.xxxx 38.91.3.240.xxxx Input voltage 6 V DC 24 V DC 60 V DC (110…125)V AC/DC 220 V DC (110…125)V AC/DC (230…240)V AC Relay 34.81.7.005.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx Socket 93.01.7.024 93.01.7.024 93.01.7.060 93.01.0.125 93.01.0.240 93.01.3.125 93.01.3.240 Input voltage 6 V DC 24 V DC 60 V DC (110…125)V AC/DC 220 V DC (110…125)V AC/DC (230…240)V AC Relay 34.81.7.005.xxxx 34.81.7.024.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx 34.81.7.060.xxxx Socket 93.51.7.024 93.51.7.024 93.51.7.060 93.51.0.125 93.51.0.240 93.51.3.125 93.51.3.240 B Example: .xxxx .9024 .7048 .8240 Solid State Relay & Socket Combinations - 14 mm wide 93.52 Approvals (according to type): Screw terminal Interface Module Code 38.31.0.024.xxxx 38.31.7.012.xxxx 38.31.7.024.xxxx Screwless terminal Interface Module Code 38.41.0.024.xxxx 38.41.7.012.xxxx 38.41.7.024.xxxx Input voltage 24 V AC/DC 12 V DC 24 V DC Relay 41.81.7.024.xxxx 41.81.7.012.xxxx 41.81.7.024.xxxx Socket 93.02.0.024 93.02.7.024 93.02.7.024 Input voltage 24 V AC/DC 12 V DC 24 V DC Relay 41.81.7.024.xxxx 41.81.7.012.xxxx 41.81.7.024.xxxx Socket 93.52.0.024 93.52.7.024 93.52.7.024 SSR / EMR & Timer Socket Combinations XI-2023, www.findernet.com Screw terminal Interface Module Code 38.21.0.012.0060 38.21.0.024.0060 38.21.0.024.xxxx Input / Coil voltage 12 V AC/DC 24 V AC/DC 24 V AC/DC Relay 34.51.7.012.0010 34.51.7.024.0010 34.81.7.024.xxxx Socket 93.21.0.024 93.21.0.024 93.21.0.024 93.21 Approvals (according to type): 15 38 SERIES 93 SERIES Sockets and accessories for 38 series P A PEAN N T E O O T EUR EUR Accessories 20-way jumper link for 38.21/51/61/81/91 093.20 (blue) Rated values 36 A* - 250 V 093.20.0 (black) 093.20.1 (red) * Maximum capacity of the jumper link. Each individual pole must not exceed the 6 A limit of the interface to which it is connected. PEAN 093.20 O P A PEAN N T E T EUR EUR Approvals (according to type): O PEAN 8-way jumper link for 38.01/11/31/41/52/62 093.08 (blue) Rated values 10 A - 250 V 093.08.0 (black) 093.08.1 (red) 093.08 Approvals (according to type): Plastic separator 093.01 093.01 Thickness 2 mm, required at the start and the end of a group of interfaces. Can be used for visual separation group, must be used for: - protective separation of different voltages of neighbouring PLC interfaces according to VDE 0106-101 - protection of cut jumper links Sheet of marker tags for 38.21/51/61/81/91, plastic, 48 tags, 6 x 10 mm 093.48 Sheet of marker tags (CEMBRE Thermal transfer printers) for 38.01/11/31/41/52/62 types (48 tags), 6 x 12 mm 060.48 093.48 060.48 XI-2023, www.findernet.com B 16 Please see general technical information
38.61.0.024.0060 价格&库存
很抱歉,暂时无法提供与“38.61.0.024.0060”相匹配的价格&库存,您可以联系我们找货
  • 1+152.79182
库存:18
38.61.0.024.0060
    • 1+238.12920
    • 200+95.01840
    • 500+91.84320
    • 1000+90.27720
    • 1+211.527231+27.37435
    • 10+188.4142710+24.38324
    • 30+178.2716230+23.07065
    • 50+173.7396150+22.48415
    • 100+167.77019100+21.71163
    • 250+160.18713250+20.73028
    • 500+154.67607500+20.01708
    库存:773
    38.61.0.024.0060
    • 1+171.64472
    • 10+156.55955
    • 50+143.59446
    • 250+139.27277
    库存:531
