84-0100.0
84-0100.0
    EAO
    Module
    LED 面板指示器 快速连接
84-0100.0 数据手册
Series 84 Series 84 Attractive. Versatile and functional. https://eao.com/84 09/2023 § eao.com 1 84 Information about the Series Key advantages Mounting cut-outs § Attractive design and reliable operation § IP67 front protection § Powerful, consistent illumination with innovative technologies § Animated illumination options for a wide variety of potential ap- § Ø § Ø § Ø plications with soldered, plug, PCB and flat ribbon cable terminals § Freely configurable HMIs with IO-Link interface (Industry 4.0) § Available Typical application areas § Machinery § Measurement and control engineering § Lifting and handling equipment § Process automation § Special vehicles § Ticketing machines § Medical equipment § Food industry Functions § Pushbutton § Illuminated pushbutton § Indicator § Capacitive buttons with IO-Link configurability 22.3 mm 22.5 mm 30.5 mm Terminal § Soldering/plug-in § PCB § Cable § M12 Lens Material § Aluminium § Plastic § Stainless steel Markings § Engraving § Laser marking § Hot stamping § Pad printing § Screen print § Milling § Illuminated Symbols Design Approvals § Flush § Raised § CB (IEC 60947) § UL § TSI PRM § CSA § EHEDG § FDH Compliant IP front protection § IP40 § IP65 § IP67 § IP69K Conformities Ratings § 42 VAC (100 mA) § 240 VAC (1.5 A) § 8.4 ... 32V (200 mA) 2 terminal ​ electronic switching element § CE § 2006/42/EC (MD) § 2011/65/EC (RoHS) § 1300/2014 (PRM) § 2014/30/EU (EMC) eao.com § 09/2023 Content 84 Flush design Pushbutton standard 4 Pushbutton PCB standard 6 Pushbutton ring illumination standard 8 Pushbutton ring illumination PCB standard 01 02 9 Pushbutton ring illumination PCB 10 Pushbutton Halo compact 11 Illuminated pushbutton standard 12 Illuminated pushbutton PCB standard 14 Indicator standard 16 Indicator PCB standard 17 Indicator ring illumination standard 18 Indicator ring illumination PCB standard 19 Indicator ring illumination PCB 20 Indicator Halo compact 21 IO-Link Touch Standard 22 IO-Link Touch Edelstahl 24 IO-Link Touch Hygiene 26 Raised design Stop switch 28 Illuminated emergency stop switch 31 Emergency stop switch, Bi-Colour 34 Components 36 Accessories 55 Technical data 64 Marking 70 Application guidelines 71 03 04 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 3 84 Flush design Pushbutton standard, IP40, IP67 01 D 02 Ø25 E 03 A F B Page 34 H 300 ±10 23 6 max. 04 Lens G 9 Actuator 23 2 Fixing nut Product can differ from the current configuration. 14 Ø40 09 Equipment consisting of (schematic overview) A D B Switching element Page 39 9 Each Part Number listed below includes all the black components shown in the 3D-drawing. 21 4 18 300 ±10 21 3 max. 17 D E F G H Ø32 19 To obtain a complete unit, please select the red components from the pages shown. 22 5 4 31 Dimensions [mm] A = Plug-in terminal 2.8 mm x 0.5 mm B = Flat ribbon cable D = Lens level with bezel E = Lens raised above bezel F = Lens konvexe level with bezel G =Lens convexe raised above bezel H = Mushroom-head cap 41 45 NJO ± • Non-illuminated lens and bezel NJO ± NJO ± 3NBY     61 NJO ±  57 PLQ • The colour of anodised aluminium parts can vary due to technical production reasons  56 General information PLQ 51 9.5 7 ±  Mounting cut-outs [mm] 70 71 82 Actuator Switching action Momentary 84 92 96 4 Front bezel colour Front bezel material IP front protection Dimensions Part No. Wiring diagram Black Plastic IP67 Ø 25 mm 84-1101.0 72 Black Aluminium IP67 Ø 25 mm 84-1201.0 72 Red Aluminium IP67 Ø 25 mm 84-1201.2 72 Gold Aluminium IP67 Ø 25 mm 84-1201.4 72 Olive Aluminium IP67 Ø 25 mm 84-1201.5 72 Blue Aluminium IP67 Ø 25 mm 84-1201.6 72 Nature Aluminium IP67 Ø 25 mm 84-1201.7 72 Black Plastic IP40 Ø 25 mm 84-2101.0 294 eao.com § 09/2023 Flush design 84 01 Actuator 02 Switching action Front bezel colour Front bezel material IP front protection Dimensions Part No. Wiring diagram Momentary Nature Aluminium IP67 Ø 40 mm 84-1221.7 294 03 04 Wiring diagrams 09 x2+ 14 x1- Wiring diagram 72 17 Wiring diagram 294 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com 5 84 Flush design Pushbutton PCB standard, IP40, IP67 01 D 02 E F H Equipment consisting of (schematic overview) D 04 4max. Actuator 18 2 3max. 3.6 16 4 3.6 Fixing nut Product can differ from the current configuration. D E F G H Mounting flange Page 48 Switching element Page 39 Ø32 14 17 18 4 5 9.5 7 Dimensions [mm] D = Lens level with bezel E = Lens raised above bezel F = Lens konvexe level with bezel G = Lens convexe raised above bezel H = Mushroom-head cap 19 22 General information NJO ± • Non-illuminated lens and bezel NJO ± Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. NJO ± • The colour of anodised aluminium parts can vary due to technical production reasons 45 3NBY     51 NJO ±   PLQ 41 PLQ 31 Page 34 Ø40 Ø25 Lens 03 09 G ±  Mounting cut-outs [mm] 56 57 61 Actuator Switching action Momentary 70 71 82 Front bezel colour Front bezel material IP front protection Dimensions Part No. Wiring diagram Black Plastic IP67 Ø 25 mm 84-1101.0 72 Black Aluminium IP67 Ø 25 mm 84-1201.0 72 Red Aluminium IP67 Ø 25 mm 84-1201.2 72 Gold Aluminium IP67 Ø 25 mm 84-1201.4 72 Olive Aluminium IP67 Ø 25 mm 84-1201.5 72 Blue Aluminium IP67 Ø 25 mm 84-1201.6 72 Nature Aluminium IP67 Ø 25 mm 84-1201.7 72 Black Plastic IP40 Ø 25 mm 84-2101.0 294 84 92 96 Actuator Switching action Front bezel colour Front bezel material IP front protection Dimensions Part No. Wiring diagram Momentary Nature Aluminium IP67 Ø 40 mm 84-1221.7 294 6 eao.com § 09/2023 Flush design 84 Wiring diagrams 01 x2+ 02 03 x1- 04 Wiring diagram 72 Wiring diagram 294 09 14 17 18 19 22 31 41 45 51 56 57 61 Compact, attractive and reliable. Series 84 E-Stop switches. 70 71 Ideal for challenging applications – thanks to the attractive design and the very low back panel depth. . Robust mono-block . Foolproof and fail-safe design . Very low back panel depth . Attractive, modern design and protection IP65 / 67 . Reliable and long service life . Clearly visible illumination 82 84 92 www.eao.com/84-e-stop 09/2023 § eao.com 96 ​ 7 84 Flush design Pushbutton ring illumination standard, IP67 01 Equipment consisting of (schematic overview) Ø25 02 03 A E B G 23 Actuator E G Fixing nut Product can differ from the current configuration. 14 Switching element 4 17 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. General information NJO • Front bezel illuminated PLQ • Accessories for halo illumination: Essential lenses Part No. 84-7202.x00A and 84-7205.x00A  22 Page 39 7 Dimensions [mm] A = Plug-in terminal 2.8 mm x 0.5 mm B = Flat ribbon cable E = Lens raised above bezel G = Lens convexe raised above bezel 18 19 Page 34 300 ±10 23 6 max. 2 04 09 Lens 9 ±  31 3NBY  41   Mounting cut-outs [mm] 45 51 Actuator, Front dimension Ø 25 mm 56 57 Switching action Front bezel colour Front bezel material IP front protection Front bezel optics Part No. Wiring diagram Momentary White Plastic IP67 translucent 84-1091.7 294 61 Wiring diagrams 70 x2+ 71 x1- 82 Wiring diagram 294 84 92 96 8 eao.com § 09/2023 Flush design 84 Pushbutton ring illumination PCB standard, IP67 Equipment consisting of (schematic overview) G E G 02 Page 34 03 Ø25 Lens E 01 Actuator 4 4max. 2 18 04 7 3.6 09 Fixing nut Mounting flange Page 48 Single-LED Page 38 Product can differ from the current configuration. 14 General information NJO • Front bezel illuminated 17 • Accessories for halo illumination: Essential lenses Part No. 84-7202.x00A and 84-7205.x00A  PLQ Page 39 ±  Switching element Dimensions [mm] E = Lens raised above bezel G = Lens convexe raised above bezel Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 18 3NBY 19    22 Mounting cut-outs [mm] 31 41 Actuator, Front dimension Ø 25 mm Switching action Front bezel colour Front bezel material IP front protection Front bezel optics Part No. Wiring diagram Momentary White Plastic IP67 translucent 84-1091.7 294 45 51 Wiring diagrams 56 x2+ 57 61 x1- 70 Wiring diagram 294 71 82 84 92 96 09/2023 § eao.com 9 84 Flush design 01 Pushbutton ring illumination PCB, IP67 D 02 F Equipment consisting of (schematic overview) G Lens Page 34 Ø25 03 Actuator 04 09 E 4max. 18 2 3.6 Fixing nut Product can differ from the current configuration. D E F G 14 Mounting flange Page 48 Single-LED Page 38 Switching element Page 39 17 18 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. General information NJO • The mini TOP LEDs are not part of delivery. Recommendation: Osram Hyper Mini TOP LED ±   41 PLQ 31 7 Dimensions [mm] D = Lens level with bezel E = Lens raised above bezel F = Lens konvexe level with bezel G = Lens convexe raised above bezel 19 22 5 4 45 3NBY    51 Mounting cut-outs [mm] 56 57 61 70 Actuator, Front dimension Ø 25 mm Switching action Front bezel colour Front bezel material IP front protection Front bezel optics Part No. Wiring diagram Momentary Colourless Plastic IP67 transparent 84-1081.7 294 Wiring diagrams 71 x2+ 82 x1- 84 92 Wiring diagram 294 96 10 eao.com § 09/2023 Flush design 84 Pushbutton Halo Compact, IP67 01 Equipment consisting of (schematic overview) Page 34 E F G 02 03 31.9 Ø24.9 Lens D Actuator 04 6 max. 2 Fixing nut 22.5 8.6 09 Product can differ from the current configuration. D Switching element E F G 14 Page 39 17 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 5 4 18 7 Dimensions [mm] D = Lens level with bezel E = Lens raised above bezel F = Lens konvexe level with bezel G = Lens convexe raised above bezel 19 22 General information NJO • The mini TOP LEDs are not part of delivery. Recommendation: Osram Hyper Mini TOP LED  ±  PLQ 31 41 3NBY 45    51 Mounting cut-outs [mm] 56 57 Actuator, Front dimension Ø 25 mm Switching action Front bezel colour Front bezel material IP front protection Front bezel optics Part No. Wiring diagram Momentary Colourless Plastic IP67 transparent 84-1081.7 294 61 70 Wiring diagrams 71 x2+ 82 x1- 84 Wiring diagram 294 92 96 09/2023 § eao.com 11 84 Flush design 01 Illuminated pushbutton standard, IP40, IP67 Equipment consisting of (schematic overview) D Ø25 02 A 03 E 9 Actuator Fixing nut A 14 B D 9 Switching element 21 4 D E Each Part Number listed below includes all the black components shown in the 3D-drawing. H 18 Ø 32 To obtain a complete unit, please select the red components from the pages shown. 19 22 9.5 4 Dimensions [mm] A = Plug-in terminal 2.8 mm x 0.5 mm B = Flat ribbon cable D = Lens level with bezel E = Lens raised above bezel H = Mushroom-head cap 31 41 General information NJO ± • Illuminated lens, non-illuminated bezel NJO ± NJO ± 56 3NBY     57 NJO ±   51 PLQ • The colour of anodised aluminium parts can vary due to technical production reasons PLQ 45 Page 39 300 ±10 21 3 max. 17 Page 34 300 ±10 23 23 Ø40 Product can differ from the current configuration. Lens H 6 max. 2 04 09 B ±  Mounting cut-outs [mm] 61 70 71 Actuator Switching action Momentary 82 84 92 Front bezel colour Front bezel material IP front protection Dimensions Part No. Wiring diagram Black Plastic IP67 Ø 25 mm 84-1101.0 72 Black Aluminium IP67 Ø 25 mm 84-1201.0 72 Red Aluminium IP67 Ø 25 mm 84-1201.2 72 Gold Aluminium IP67 Ø 25 mm 84-1201.4 72 Olive Aluminium IP67 Ø 25 mm 84-1201.5 72 Blue Aluminium IP67 Ø 25 mm 84-1201.6 72 Nature Aluminium IP67 Ø 25 mm 84-1201.7 72 Black Plastic IP40 Ø 25 mm 84-2101.0 294 96 12 eao.com § 09/2023 Flush design 84 01 Actuator 02 Switching action Front bezel colour Front bezel material IP front protection Dimensions Part No. Wiring diagram Momentary Nature Aluminium IP67 Ø 40 mm 84-1221.7 294 03 04 Wiring diagrams 09 x2+ 14 x1- Wiring diagram 72 17 Wiring diagram 294 18 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 09/2023 § eao.com 96 13 84 Flush design Illuminated pushbutton PCB standard, IP40, IP67 D 02 E Equipment consisting of (schematic overview) D Ø25 Lens 03 04 4max. 18 3max. 3.6 16 4 3.6 Fixing nut Product can differ from the current configuration. D E H Ø32 14 17 General information NJO ± • Illuminated lens, non-illuminated bezel NJO ± Single-LED Page 38 Switching element Page 39 To obtain a complete unit, please select the red components from the pages shown. NJO ± 3NBY     45 NJO ±  41 PLQ PLQ • The colour of anodised aluminium parts can vary due to technical production reasons  31 Page 48 Each Part Number listed below includes all the black components shown in the 3D-drawing. Dimensions [mm] A = Lens level with bezel E = Lens raised above bezel H = Mushroom-head cap 19 Mounting flange 9.5 4 18 22 Page 34 Actuator 2 09 H Ø40 01 ±  Mounting cut-outs [mm] 51 56 Actuator 57 Switching action 61 Momentary 70 71 Front bezel colour Front bezel material IP front protection Dimensions Part No. Wiring diagram Black Plastic IP67 Ø 25 mm 84-1101.0 72 Black Aluminium IP67 Ø 25 mm 84-1201.0 72 Red Aluminium IP67 Ø 25 mm 84-1201.2 72 Gold Aluminium IP67 Ø 25 mm 84-1201.4 72 Olive Aluminium IP67 Ø 25 mm 84-1201.5 72 Blue Aluminium IP67 Ø 25 mm 84-1201.6 72 Nature Aluminium IP67 Ø 25 mm 84-1201.7 72 Black Plastic IP40 Ø 25 mm 84-2101.0 294 82 84 Actuator 92 96 Switching action Front bezel colour Front bezel material IP front protection Dimensions Part No. Wiring diagram Momentary Nature Aluminium IP67 Ø 40 mm 84-1221.7 294 14 eao.com § 09/2023 Flush design 84 Wiring diagrams 01 x2+ 02 03 x1- 04 Wiring diagram 72 Wiring diagram 294 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 15 84 Flush design 01 Indicator standard, IP40, IP67 Equipment consisting of (schematic overview) 02 Ø25 D 03 A B H 9 Lens Page 34 300 ±10 23 6 max. 2 04 23 Actuator D E H Fixing nut Product can differ from the current configuration. Ø32 09 E 14 Illumination element 9.5 4 17 Dimensions [mm] A = Plug-in terminal 2.8 mm x 0.5 mm B = Flat ribbon cable D = Lens level with bezel E = Lens raised above bezel H = Mushroom-head cap 18 19 Page 43 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. General information NJO • Illuminated lens, non-illuminated bezel • The colour of anodised aluminium parts can vary due to technical production reasons ±   31 PLQ 22 41 3NBY    45 Mounting cut-outs [mm] 51 56 57 61 70 Actuator, Front dimension Ø 25 mm IP front protection Front bezel colour Front bezel material Part No. Wiring diagram IP67 Black Plastic 84-0100.0 70 Nature Aluminium 84-0200.7 70 Black Plastic 84-3100.0 70 IP40 Wiring diagrams 71 x2+ 82 x1- 84 92 Wiring diagram 70 96 16 eao.com § 09/2023 Flush design 84 Indicator PCB standard, IP40, IP67 01 Equipment consisting of (schematic overview) E H 02 Page 34 Actuator 18 04 9.5 4 4max. 2 03 Ø32 Ø25 Lens D 3.6 09 Fixing nut Mounting flange Page 48 Single-LED Page 38 Dimensions [mm] A = Lens level with bezel E = Lens raised above bezel H = Mushroom-head cap Product can differ from the current configuration. 14 General information NJO 17 • Illuminated lens, non-illuminated bezel Page 43 • The colour of anodised aluminium parts can vary due to technical production reasons ±   Each Part Number listed below includes all the black components shown in the 3D-drawing. PLQ Illumination element To obtain a complete unit, please select the red components from the pages shown. 18 19 3NBY    22 Mounting cut-outs [mm] 31 41 Actuator, Front dimension Ø 25 mm IP front protection Front bezel colour Front bezel material Part No. Wiring diagram IP67 Black Plastic 84-0100.0 70 Nature Aluminium 84-0200.7 70 Black Plastic 84-3100.0 70 IP40 45 51 56 Wiring diagrams 57 x2+ 61 x1- 70 Wiring diagram 70 71 82 84 92 96 09/2023 § eao.com 17 84 Flush design 01 Indicator ring illumination standard, IP67 Equipment consisting of (schematic overview) Ø25 02 03 A E B G 23 Actuator E G Fixing nut Product can differ from the current configuration. 14 Illumination element 4 17 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. General information NJO • Front bezel illuminated PLQ • Accessories for halo illumination: Essential lenses Part No. 84-7202.x00A and 84-7205.x00A  22 Page 43 7 Dimensions [mm] A = Plug-in terminal 2.8 mm x 0.5 mm B = Flat ribbon cable E = Lens raised above bezel G = Lens convexe raised above bezel 18 19 Page 34 300 ±10 23 6 max. 2 04 09 Lens 9 ±  31 3NBY  41   Mounting cut-outs [mm] 45 51 Actuator, Front dimension Ø 25 mm 56 57 61 IP front protection Front bezel colour Front bezel material Front bezel optics Part No. Wiring diagram IP67 Colourless Plastic translucent 84-0090.7 70 Wiring diagrams 70 x2+ 71 x1- 82 84 Wiring diagram 70 92 96 18 eao.com § 09/2023 Flush design 84 Indicator ring illumination PCB standard, IP67 Equipment consisting of (schematic overview) G E G 02 Page 34 03 Ø25 Lens E 01 Actuator 4 4max. 2 18 04 7 3.6 09 Fixing nut Mounting flange Page 48 Single-LED Page 38 Product can differ from the current configuration. 14 General information NJO • Front bezel illuminated To obtain a complete unit, please select the red components from the pages shown. PLQ  Each Part Number listed below includes all the black components shown in the 3D-drawing. 17 • Accessories for halo illumination: Essential lenses Part No. 84-7202.x00A and 84-7205.x00A Page 43 ±  Illumination element Dimensions [mm] E = Lens raised above bezel G = Lens convexe raised above bezel 18 3NBY 19    22 Mounting cut-outs [mm] 31 41 Actuator, Front dimension Ø 25 mm IP front protection Front bezel colour Front bezel material Front bezel optics Part No. Wiring diagram IP67 Colourless Plastic translucent 84-0090.7 70 45 51 Wiring diagrams 56 x2+ 57 x1- 61 Wiring diagram 70 70 71 82 84 92 96 09/2023 § eao.com 19 84 Flush design 01 Indicator ring illumination PCB, IP67 D 02 F Equipment consisting of (schematic overview) G Lens Page 34 Ø25 03 Actuator 04 09 E 4max. 18 2 3.6 Fixing nut Product can differ from the current configuration. D E F G Mounting flange Page 48 Single-LED Page 38 Illumination element Page 43 14 17 18 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. General information NJO • The mini TOP LEDs are not part of delivery. Recommendation: Osram Hyper Mini TOP LED ±   41 PLQ 31 7 Dimensions [mm] D = Lens level with bezel E = Lens raised above bezel F = Lens konvexe level with bezel G = Lens convexe raised above bezel 19 22 5 4 45 3NBY    51 Mounting cut-outs [mm] 56 57 61 70 Actuator, Front dimension Ø 25 mm IP front protection Front bezel colour Front bezel material Front bezel optics Part No. Wiring diagram IP67 Colourless Plastic transparent 84-0080.7 70 Wiring diagrams 71 x2+ 82 x1- 84 92 Wiring diagram 70 96 20 eao.com § 09/2023 Flush design 84 Indicator Halo Compact, IP67 Page 34 E F G 02 03 31.9 Lens D Ø24.9 Equipment consisting of (schematic overview) 01 Actuator 04 6 max. 2 Fixing nut 22.5 8.6 09 Product can differ from the current configuration. Mounting flange Page 48 Single-LED Page 38 D E F G 14 17 Switching element Page 39 5 4 Each Part Number listed below includes all the black components shown in the 3D-drawing. To obtain a complete unit, please select the red components from the pages shown. 18 7 Dimensions [mm] D = Lens level with bezel E = Lens raised above bezel F = Lens konvexe level with bezel G = Lens convexe raised above bezel 19 22 General information NJO • The mini TOP LEDs are not part of delivery. Recommendation: Osram Hyper Mini TOP LED  ±  PLQ 31 41 3NBY 45    51 Mounting cut-outs [mm] 56 57 Actuator, Front dimension Ø 25 mm IP front protection Front bezel colour Front bezel material Front bezel optics Part No. Wiring diagram IP67 Colourless Plastic transparent 84-0080.7 70 61 70 Wiring diagrams 71 x2+ 82 x1- 84 Wiring diagram 70 92 96 09/2023 § eao.com 21 84 Flush design 01 IO-Link Touch Standard, IP69K 4 10 1.8 2.2 M22x1 x 02 Equipment consisting of (schematic overview) M12x1 IO-Link Touch 03 04 Ø 17.8 Seal Ø 30 09 14 18 19 4.1 Fixing nut Product can differ from the current configuration. Dimensions [mm] Each Part Number listed below includes all the black components shown in the 3D-drawing. General information 20.4 • Actuation type: Touch 17 25.8 ± 0.10 .10 ±0 • Actuating force: No actuating force necessary Ø .5 22 • Circuit: Capacitive • Communication interface: IO-Link Specification 1.1 • Connector: M12 Mounting cut-outs [mm] 22 31 41 45 IO-Link Touch Standard, Front dimension Ø 30 mm Front bezel material Output Output pulse LED control Preconfigured Led colour 1 Preconfigured Led colour 2 Symbol Part No. Plastic PNP-NO Dynamic Automatic Green Red B10 84-ASKS-B10-049C B11 84-ASKS-B11-049D B12 84-ASKS-B12-049E B13 84-ASKS-B13-049F B14 84-ASKS-B14-04A0 B15 84-ASKS-B15-04A1 C10 84-ASKS-C10-04A2 C11 84-ASKS-C11-04A3 C12 84-ASKS-C12-04A4 C14 84-ASKS-C14-04A5 C16 84-ASKS-C16-04A6 C17 84-ASKS-C17-04A7 C18 84-ASKS-C18-04A8 C19 84-ASKS-C19-04A9 C20 84-ASKS-C20-049B 51 56 57 61 70 71 82 84 92 96 22 eao.com § 09/2023 Flush design 84 Wiring diagrams 01 3-pole 02 4-pole 2 5 1 2 brown 4 black 3 blue 5 1 +VDC OUT IO-Link Communication (NPN/PNP; NO/NC) 0V white brown 4 black 3 blue E1 03 +VDC OUT IO-Link Communication (NPN/PNP; NO/NC) 04 0V 09 Wiring diagram 466 Wiring diagram 467 14 5-pole 2 5 1 white grey brown 4 black 3 blue E1 17 E2 +VDC 18 OUT IO-Link Communication (NPN/PNP; NO/NC) 0V 19 22 Wiring diagram 468 31 Component layouts 41 4 1 N/A 3 N/A Component layout 109 Connector M12 3-pole 4 1 N/A 3 2 Component layouts 110 Connector M12 4-pole 4 1 N/A 3 45 2 51 56 Component layouts 111 Connector M12 5-pole 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 23 84 01 IO-Link Touch Stainless Steel, IP69K Equipment consisting of (schematic overview) M22x1 02 1.1 M12x1 IO-Link Touch 03 04 Ø 17.8 Seal Ø 30 09 14 18 19 3.5 Fixing nut Product can differ from the current configuration. Dimensions [mm] Each Part Number listed below includes all the black components shown in the 3D-drawing. General information • Actuation type: Touch 17 26.2 20.4 ±0.10 .10 Ø 22.5 ±0.10 ±0 • Actuating force: No actuating force necessary .5 Ø 22 • Circuit: Capacitive • Communication interface: IO-Link Specification 1.1 • Connector: M12 Mounting cut-outs [mm] 22 31 41 45 51 IO-Link Touch Stainless Steel, Front dimension Ø 30 mm Front bezel material Stainless Steel SUS 316L 56 57 61 70 Output Output pulse LED control Preconfigured Led colour 1 Preconfigured Led colour 2 Symbol Part No. PNP-NO Dynamic Automatic Green Red B10 84-ADKS-B10-04AA B11 84-ADKS-B11-04AB B12 84-ADKS-B12-04AC B13 84-ADKS-B13-04AD B14 84-ADKS-B14-04AE B15 84-ADKS-B15-04AF C10 84-ADKS-C10-04B0 C11 84-ADKS-C11-04B1 C12 84-ADKS-C12-04B2 C14 84-ADKS-C14-04B3 C16 84-ADKS-C16-04B4 C17 84-ADKS-C17-04B5 C18 84-ADKS-C18-04B6 C19 84-ADKS-C19-04B7 C20 84-ADKS-C20-04B8 71 82 84 92 96 24 eao.com § 09/2023 84 Wiring diagrams 01 3-pole 02 4-pole 2 5 1 2 brown 4 black 3 blue 5 1 +VDC OUT IO-Link Communication (NPN/PNP; NO/NC) 0V white brown 4 black 3 blue E1 03 +VDC OUT IO-Link Communication (NPN/PNP; NO/NC) 04 0V 09 Wiring diagram 466 Wiring diagram 467 14 5-pole 2 5 1 white grey brown 4 black 3 blue E1 17 E2 +VDC 18 OUT IO-Link Communication (NPN/PNP; NO/NC) 0V 19 22 Wiring diagram 468 31 Component layouts 41 4 1 N/A 3 N/A Component layout 109 Connector M12 3-pole 4 1 N/A 3 2 Component layouts 110 Connector M12 4-pole 4 1 N/A 3 45 2 51 56 Component layouts 111 Connector M12 5-pole 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 25 84 01 IO-Link Touch Hygienic, IP69K Equipment consisting of (schematic overview) M22x1 2 02 M12x1 IO-Link Touch 03 Ø 17.8 04 Seal Ø 32.4 09 14 18 19 3.8 Fixing nut Product can differ from the current configuration. Dimensions [mm] Each Part Number listed below includes all the black components shown in the 3D-drawing. General information 20.4 • Actuation type: Touch 17 26 ± 0.10 .10 ±0 • Actuating force: No actuating force necessary Ø .5 22 • Circuit: Capacitive • Communication interface: IO-Link Specification 1.1 • Connector: M12 Mounting cut-outs [mm] 22 31 41 45 51 IO-Link Touch Hygienic, Front dimension Ø 30 mm Front bezel material Stainless Steel SUS 316L 56 57 61 70 Output Output pulse LED control Preconfigured Led colour 1 Preconfigured Led colour 2 Symbol Part No. Dynamic Automatic Green Red Rot B10 84-ACKS-B10-04B9 B11 84-ACKS-B11-04BA B12 84-ACKS-B12-04BB B13 84-ACKS-B13-04BC B14 84-ACKS-B14-04BD B15 84-ACKS-B15-04BE C10 84-ACKS-C10-04BF C11 84-ACKS-C11-04C0 C12 84-ACKS-C12-04C1 C14 84-ACKS-C14-04C2 C16 84-ACKS-C16-04C3 C17 84-ACKS-C17-04C4 C18 84-ACKS-C18-04C5 C19 84-ACKS-C19-04C6 C20 84-ACKS-C20-04C7 71 82 84 92 96 26 eao.com § 09/2023 84 Wiring diagrams 01 3-pole 02 4-pole 2 5 1 2 brown 4 black 3 blue 5 1 +VDC OUT IO-Link Communication (NPN/PNP; NO/NC) 0V white brown 4 black 3 blue E1 03 +VDC OUT IO-Link Communication (NPN/PNP; NO/NC) 04 0V 09 Wiring diagram 466 Wiring diagram 467 14 5-pole 2 5 1 white grey brown 4 black 3 blue E1 17 E2 +VDC 18 OUT IO-Link Communication (NPN/PNP; NO/NC) 0V 19 22 Wiring diagram 468 31 Component layouts 41 4 1 N/A 3 N/A Component layout 109 Connector M12 3-pole 4 1 N/A 3 2 Component layouts 110 Connector M12 4-pole 4 1 N/A 3 45 2 51 56 Component layouts 111 Connector M12 5-pole 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 27 84 Raised design 01 Stop switch, IP65, IP66, IP67 1...4 02 Equipment consisting of (schematic overview) Ø 32.3 A 03 04 25.8 Actuator 9.5 Fixing nut 17.6 09 Each Part Number listed below includes all the black components shown in the 3D-drawing. B Product can differ from the current configuration. 14 17 Dimensions [mm] A = Plug-in terminal 2.8 mm x 0.5 mm B = Flat ribbon cable 18 General information NJO • Position indication ring black  • Lens plastic grey   22 NJO 19 300 ± 10 13.5    3NBY 31  ±  41 Mounting cut-outs [mm] 45 51 Stop switch, Front dimension Ø 32 mm 56 57 Component Layout Switching action Contacts Terminal Part No. Wiring diagram Maintained 1 NC Plug-in terminal 84-6220.0020 345 99 1 NC Flat ribbon cable 300 mm 84-6220.0040 426 98 1 NC Plug-in terminal Red 84-6221.2B20 348 99 1 NC Flat ribbon cable 300 mm Red 84-6221.2B40 429 98 1 NC / 1 NO Plug-in terminal 84-6230.0020 346 99 1 NC / 1 NO Flat ribbon cable 300 mm 84-6230.0040 427 98 1 NC / 1 NO Plug-in terminal Red 84-6231.2B20 349 99 1 NC / 1 NO Flat ribbon cable 300 mm Red 84-6231.2B40 431 98 2 NC Plug-in terminal 84-6240.0020 347 99 2 NC Flat ribbon cable 300 mm 84-6240.0040 428 98 2 NC Plug-in terminal Red 84-6241.2B20 350 99 2 NC Flat ribbon cable 300 mm Red 84-6241.2B40 430 98 61 70 71 82 Illumination colour Contacts: NC = Normally closed, NO = Normally open 84 92 96 28 eao.com § 09/2023 Raised design 84 Wiring diagrams 01 11 11 23 11 21 11 X2+ 11 23 X2+ 12 12 24 12 22 12 X1– 12 24 X1– 02 03 04 Wiring diagram 345 11 Wiring diagram 346 21 Wiring diagram 347 br (11) X2+ Wiring diagram 348 br (11) Wiring diagram 349 gr (23) br (11) 09 gr (21) 14 12 22 wt (12) X1– Wiring diagram 350 Wiring diagram 426 wt (12) rd (24) wt (12) Wiring diagram 427 br (11) ye (X2+) br (11) gr (23) ye (X2+) wt (12) gn (X1–) wt (12) rd (24) gn (X1–) 17 rd (22) 18 Wiring diagram 428 19 22 31 Wiring diagram 429 Wiring diagram 430 41 Component layouts 45 23 24 21 22 X2+ X1- 12 11 A 51 B C D E F H 11 12 X1_ X2+ 24 22 23 21 1Ö+1S 2Ö I 11 / 12 + 23 / 24 11 / 12 + 21 / 22 _ X1 / X2+ 1Ö 11 / 12 _ X1 / X2+ 56 G 57 H B C D 11 12 X1_ X2+ I 61 E H B C D 11 12 24 22 23 21 1Ö+1S 2Ö 11 / 12 + 23 / 24 11 / 12 + 21 / 22 1Ö 11 / 12 70 E H 11 12 71 Component layout 98 82 Dimensions [mm] A = Cable B = white C = brown D = green E = yellow F = grey G = pink H = Terminals I = Illumination 09/2023 § eao.com 84 92 96 ​ 29 84 Raised design 01 Component layouts 02 12 11 03 X2+ X122 21 24 23 04 09 Component layout 99 14 17 18 19 22 31 41 45 51 56 57 61 Compact, attractive and reliable. Series 84 E-Stop switches. 70 71 Ideal for challenging applications – thanks to the attractive design and the very low back panel depth. . Robust mono-block . Foolproof and fail-safe design . Very low back panel depth . Attractive, modern design and protection IP65 / 67 . Reliable and long service life . Clearly visible illumination 82 84 92 www.eao.com/84-e-stop 96 30 ​ eao.com § 09/2023 Raised design 84 Emergency stop switch, IP65, IP66, IP67 01 1...4 Equipment consisting of (schematic overview) 02 Ø 32.3 A Actuator 25.8 Fixing nut 03 04 9.5 17.6 Each Part Number listed below includes all the black components shown in the 3D-drawing. B 09 Product can differ from the current configuration. 14 17 300 ± 10 13.5 Dimensions [mm] A = Plug-in terminal 2.8 mm x 0.5 mm B = Flat ribbon cable 18 General information NJO 19 • Lens plastic red  22 NJO      3NBY 31  ±  41 Mounting cut-outs [mm] 45 51 Emergency stop switch, Front dimension Ø 32 mm Illumination colour Product attributes Part No. Wiring diagram Component Layout Switching action Contacts Terminal Maintained 1 NC Plug-in terminal Switching position ring black 84-5220.0020 345 99 1 NC Flat ribbon cable Switching position ring black 84-5220.0040 426 98 1 NC Plug-in terminal Red Switching position ring black 84-5221.2B20 348 99 1 NC Flat ribbon cable Red Switching position ring black 84-5221.2B40 429 98 1 NC / 1 NO Plug-in terminal Switching position ring black 84-5230.0020 346 99 1 NC / 1 NO Flat ribbon cable Switching position ring black 84-5230.0040 427 98 1 NC / 1 NO Plug-in terminal Red Switching position ring black 84-5231.2B20 349 99 1 NC / 1 NO Flat ribbon cable Red Switching position ring black 84-5231.2B40 430 98 2 NC Plug-in terminal Switching position ring black 84-5240.0020 347 99 2 NC Flat ribbon cable Switching position ring black 84-5240.0040 428 98 2 NC Plug-in terminal Red Switching position ring black 84-5241.2B20 350 99 2 NC Flat ribbon cable Red Switching position ring black 84-5241.2B40 431 98 1 NC Plug-in terminal Switching position ring green 84-5320.0020 345 99 56 57 61 70 71 82 Contacts: NC = Normally closed, NO = Normally open 84 92 96 09/2023 § eao.com 31 84 Raised design 01 Switching action Contacts Terminal Maintained 1 NC Flat ribbon cable 1 NC Plug-in terminal 1 NC Flat ribbon cable 1 NC / 1 NO 02 03 04 09 14 17 18 Illumination colour Component Layout Product attributes Part No. Wiring diagram Switching position ring green 84-5320.0040 426 98 Red Switching position ring green 84-5321.2B20 347 99 Red Switching position ring green 84-5321.2B40 429 98 Plug-in terminal Switching position ring green 84-5330.0020 346 99 1 NC / 1 NO Flat ribbon cable Switching position ring green 84-5330.0040 427 98 1 NC / 1 NO Plug-in terminal Red Switching position ring green 84-5331.2B20 349 99 1 NC / 1 NO Flat ribbon cable Red Switching position ring green 84-5331.2B40 430 98 2 NC Plug-in terminal Twist to unlock clockwise, position indication ring green 84-5340.0020 347 99 2 NC Flat ribbon cable Twist to unlock clockwise, position indication ring green 84-5340.0040 428 98 2 NC Plug-in terminal Red Twist to unlock clockwise, position indication ring green 84-5341.2B20 350 99 2 NC Flat ribbon cable Red Twist to unlock clockwise, position indication ring green 84-5341.2B40 431 98 Contacts: NC = Normally closed, NO = Normally open 19 Wiring diagrams 22 11 11 23 11 21 11 X2+ 11 23 X2+ 12 12 24 12 22 12 X1– 12 24 X1– 31 41 45 Wiring diagram 345 51 Wiring diagram 346 Wiring diagram 347 Wiring diagram 348 Wiring diagram 349 11 21 X2+ br (11) br (11) gr (23) br (11) gr (21) 12 22 X1– wt (12) wt (12) rd (24) wt (12) rd (22) 56 57 61 Wiring diagram 350 Wiring diagram 426 Wiring diagram 427 Wiring diagram 428 br (11) ye (X2+) br (11) gr (23) ye (X2+) br (11) gr (21) ye (X2+) 71 wt (12) gn (X1–) wt (12) rd (24) gn (X1–) wt (12) rd (22) gn (X1–) 82 Wiring diagram 429 70 Wiring diagram 430 Wiring diagram 431 84 92 96 32 ​ eao.com § 09/2023 Raised design 84 Component layouts 01 02 23 24 21 22 X2+ X1- 12 11 A B C D E F 11 12 X1_ X2+ 24 22 23 21 H 1Ö+1S 2Ö I 03 11 / 12 + 23 / 24 11 / 12 + 21 / 22 _ X1 / X2+ 04 G H B C D 11 12 X1_ X2+ 1Ö I 11 / 12 _ X1 / X2+ 09 E H B C D 11 12 24 22 23 21 1Ö+1S 2Ö 11 / 12 + 23 / 24 11 / 12 + 21 / 22 1Ö 11 / 12 14 E H 11 12 17 18 Component layout 98 Dimensions [mm] A = Cable B = white C = brown D = green E = yellow F = grey G = pink H = Terminals I = Illumination 19 22 31 41 12 11 45 X2+ X122 21 24 23 51 Component layout 99 56 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 33 84 Raised design 01 Emergency stop switch, Bi-Colour, IP65, IP66, IP67 1...4 02 Equipment consisting of (schematic overview) Ø 32.3 A 03 04 25.8 Actuator 9.5 Fixing nut 17.6 09 Each Part Number listed below includes all the black components shown in the 3D-drawing. B Product can differ from the current configuration. 14 17 Dimensions [mm] A = Plug-in terminal 2.8 mm x 0.5 mm B = Flat ribbon cable 18 General information NJO • Lens plastic red  • Without built-in series resistor • Operating voltage LED 2,0 VDC (Red), 3,05 VDC (Green)  3NBY   22   NJO 19 300 ± 10 13.5 31  ±  41 Mounting cut-outs [mm] 45 51 56 57 61 Emergency Stop Switch, Front dimension Ø 32 mm Switching action Illumination colour Contacts Terminal Product attributes Maintained 2 NC Plug-in terminal Red / Green Twist to unlock clockwise, position indication ring black 2 NC Plug-in terminal Red / Green Twist to unlock clockwise, position indication ring green Part No. Wiring diagram Component Layout 84-5241.8D20 344 99 84-5341.8D20 344 99 Contacts: NC = Normally closed 70 71 82 84 92 96 34 eao.com § 09/2023 Raised design 84 Wiring diagrams 01 +/- 02 03 -/+ 04 Wiring diagram 344 09 Component layouts 14 17 12 11 18 X2+ X122 21 24 23 19 Component layout 99 22 31 41 45 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 35 84 Components 01 02 03 Lens for stop request pushbutton Lens material Lens colour Lens optics Lens shape Lens illumination Lens type Symbol Dimensions Part No. Aluminium Nature opaque flush non illuminative raised above front bezel Door open Ø 19.7 mm 84-7205.804A Nature opaque flush non illuminative raised above front bezel Wheelchair Ø 19.7 mm 84-7205.805A Nature opaque flush non illuminative raised above front bezel Baby pram Ø 19.7 mm 84-7205.806A Nature opaque flush non illuminative raised above front bezel Bell Ø 19.7 mm 84-7205.808A 04 09 14 Additional information • With raised labelling symbol, TSI compliant • The colour of anodised aluminium parts can vary due to technical production reasons 17 18 Lens metall for halo illumination 19 22 Lens material Lens colour Lens optics Lens shape Lens illumination Lens type Dimensions Part No. Aluminium Black opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.000A Red opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.200A Olive green opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.500A Blue opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.600A Nature opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.800A Black opaque convex non illuminative raised above front bezel Ø 19.7 mm 84-7202.000A Red opaque convex non illuminative raised above front bezel Ø 19.7 mm 84-7202.200A Blue opaque convex non illuminative raised above front bezel Ø 19.7 mm 84-7202.600A Nature opaque convex non illuminative raised above front bezel Ø 19.7 mm 84-7202.800A 31 41 45 51 56 57 Additional information • The colour of anodised aluminium parts can vary due to technical production reasons 61 70 71 82 84 92 96 36 eao.com § 09/2023 Components 84 01 Lens plastic 02 Lens material Lens colour Lens optics Lens shape Lens illumination Lens type Dimensions Part No. Plastic Red transparent flush illuminative level with front bezel Ø 19.7 mm 84-7111.200 Orange transparent flush illuminative level with front bezel Ø 19.7 mm 84-7111.300 Yellow transparent flush illuminative level with front bezel Ø 19.7 mm 84-7111.400 Green transparent flush illuminative level with front bezel Ø 19.7 mm 84-7111.500 Blue transparent flush illuminative level with front bezel Ø 19.7 mm 84-7111.600 Colourless transparent flush illuminative level with front bezel Ø 19.7 mm 84-7111.700 Black opaque flush non illuminative level with front bezel Ø 19.7 mm 84-7121.000 Grey opaque flush non illuminative level with front bezel Ø 19.7 mm 84-7121.800 Red transparent flush illuminative raised above front bezel Ø 19.7 mm 84-7115.200 Orange transparent flush illuminative raised above front bezel Ø 19.7 mm 84-7115.300 Yellow transparent flush illuminative raised above front bezel Ø 19.7 mm 84-7115.400 Green transparent flush illuminative raised above front bezel Ø 19.7 mm 84-7115.500 Blue transparent flush illuminative raised above front bezel Ø 19.7 mm 84-7115.600 Colourless transparent flush illuminative raised above front bezel Ø 19.7 mm 84-7115.700 Black opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7125.000 Grey opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7125.800 03 04 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com 37 84 Components 01 02 03 Lens plastic with symbol Lens material Lens colour Lens optics Lens shape Lens illumination Lens type Symbol Dimensions Part No. Plastic Red transparent flush illuminative level with front bezel Ring Ø 19.7 mm 84-7111.201 04 09 14 17 18 Orange transparent flush illuminative level with front bezel Ring Ø 19.7 mm 84-7111.301 Yellow transparent flush illuminative level with front bezel Ring Ø 19.7 mm 84-7111.401 Green transparent flush illuminative level with front bezel Ring Ø 19.7 mm 84-7111.501 Blue transparent flush illuminative level with front bezel Ring Ø 19.7 mm 84-7111.601 Colourless transparent flush illuminative level with front bezel Ring Ø 19.7 mm 84-7111.701 Green transparent flush illuminative level with front bezel ON/OFF Ø 19.7 mm 84-7111.502 Blue transparent flush illuminative level with front bezel ON/OFF Ø 19.7 mm 84-7111.602 Colourless transparent flush illuminative level with front bezel ON/OFF Ø 19.7 mm 84-7111.702 Green transparent flush illuminative level with front bezel Standby Ø 19.7 mm 84-7111.503 Blue transparent flush illuminative level with front bezel Standby Ø 19.7 mm 84-7111.603 Colourless transparent flush illuminative level with front bezel Standby Ø 19.7 mm 84-7111.703 Additional information • The silvery coat is being applied on the lens (screen print) with an additional protective lacquer. Further information see Technical data 19 22 31 41 45 51 EAO Downloads. www.eao.com/downloads 56 EAO creates possibilities. Since 1947. 57 61 70 71 On our website you can download technical data, assembly instructions, catalogs, brochures and much more. 82 84 92 www.eao.com 96 38 eao.com § 09/2023 Components 84 01 Lens metal 02 Lens material Lens colour Lens optics Lens shape Lens illumination Lens type Dimensions Part No. Aluminium Black opaque flush non illuminative level with front bezel Ø 19.7 mm 84-7201.000 Red opaque flush non illuminative level with front bezel Ø 19.7 mm 84-7201.200 Gold opaque flush non illuminative level with front bezel Ø 19.7 mm 84-7201.400 Olive green opaque flush non illuminative level with front bezel Ø 19.7 mm 84-7201.500 Blue opaque flush non illuminative level with front bezel Ø 19.7 mm 84-7201.600 Nature opaque flush non illuminative level with front bezel Ø 19.7 mm 84-7201.800 Black opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.000 Red opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.200 Olive green opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.500 Blue opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.600 Nature opaque flush non illuminative raised above front bezel Ø 19.7 mm 84-7205.800 Black opaque convex non illuminative level with front bezel Ø 19.7 mm 84-7202.000 Red opaque convex non illuminative level with front bezel Ø 19.7 mm 84-7202.200 Olive green opaque convex non illuminative level with front bezel Ø 19.7 mm 84-7202.500 Blue opaque convex non illuminative level with front bezel Ø 19.7 mm 84-7202.600 Nature opaque convex non illuminative level with front bezel Ø 19.7 mm 84-7202.800 03 04 09 14 17 18 19 22 Additional information 31 • The colour of anodised aluminium parts can vary due to technical production reasons 41 45 Lens metal with spot Lens material Lens colour Lens optics Lens shape Lens illumination Lens type Dimensions Part No. Aluminium Black opaque flush illuminative level with front bezel Ø 19.7 mm 84-7211.000 Red opaque flush illuminative level with front bezel Ø 19.7 mm 84-7211.200 Gold opaque flush illuminative level with front bezel Ø 19.7 mm 84-7211.400 Olive green opaque flush illuminative level with front bezel Ø 19.7 mm 84-7211.500 Blue opaque flush illuminative level with front bezel Ø 19.7 mm 84-7211.600 Nature opaque flush illuminative level with front bezel Ø 19.7 mm 84-7211.800 Black opaque flush illuminative raised above front bezel Ø 19.7 mm 84-7215.000 Red opaque flush illuminative raised above front bezel Ø 19.7 mm 84-7215.200 Gold opaque flush illuminative raised above front bezel Ø 19.7 mm 84-7215.400 Olive green opaque flush illuminative raised above front bezel Ø 19.7 mm 84-7215.500 Blue opaque flush illuminative raised above front bezel Ø 19.7 mm 84-7215.600 Nature opaque flush illuminative raised above front bezel Ø 19.7 mm 84-7215.800 51 56 57 61 70 71 82 Additional information 84 • The colour of anodised aluminium parts can vary due to technical production reasons 92 96 09/2023 § eao.com 39 84 Components 01 Mushroom-head cap 02 03 Lens material Lens colour Lens optics Lens shape Lens illumination Part No. Plastic Blue transparent mushroom-head illuminative 84-7114.600A Black opaque mushroom-head non illuminative 84-7124.000A Red opaque mushroom-head non illuminative 84-7124.200A 04 09 14 17 Marking plate Marking plate material Marking plate colour Marking plate optics Marking plate illumination Part No. Plastic Colourless transparent illuminative 61-9707.7 Additional information • Can be hot stamped 18 19 22 31 41 45 51 56 57 Single-LED, T1 3/4 MG Illumination colour Lumi. Intensity Dom. Wavelength Forward voltage Wiring diagram Part No. Red 160 mcd 625 nm 2.0 VDC @ 20 mA 10-2601.3172S 4 Amber 165 mcd 605 nm 2.0 VDC @ 20 mA 10-2601.3173S 4 Yellow 600 mcd 580 nm 2.9 VDC @ 20 mA 10-2603.3174S 4 Green 650 mcd 525 nm 3.2 VDC @ 20 mA 10-2603.3175S 4 Blue 250 mcd 467 nm 3.0 VDC @ 20 mA 10-2603.3176S 4 White 500 mcd x: 0,31 / y: 0,32 nm 3.2 VDC @ 20 mA 10-2603.3178S 4 Additional information • The customer has to decide what series resistor shall be used to the LED • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED Wiring diagrams 61 x2+ 70 x1- 71 Wiring diagram 82 84 92 96 40 eao.com § 09/2023 Components 84 Component layouts 01 02 + (Anode) 03 04 LED 09 14 – (Cathode) 17 Component layout 116 18 Bi-colour LED,T1 Bi-Pin Illumination colour Lumi. Intensity Dom. Wavelength Forward voltage Part No. Wiring diagram Red / Green 1900/4200 mcd 630 / 525 nm 1.9 / 3.3 VDC @ 20 mA 10-2603.320AT 352 Green / Yellow 1100/900 mcd 588 / 525 nm 2.0 / 3.2 VDC @ 20 mA 10-2603.320CT 352 19 22 Additional information 31 • The customer has to decide what series resistor shall be used to the LED • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 41 Wiring diagrams 45 51 X3+ X1– X2+ 56 57 Wiring diagram 352 61 70 71 82 84 92 96 09/2023 § eao.com 41 84 Components 01 Switching element with illumination and plug-in terminal 02 03 IP Protection Illumination colour Operating voltage Operation current Terminal Part No. Wiring diagram IP40 Red 12 V DC ±10 % 10 mA Plug-in terminal 84-8511.2320 354 Orange 12 V DC ±10 % 10 mA Plug-in terminal 84-8511.3320 354 Yellow 12 V DC ±10 % 10 mA Plug-in terminal 84-8511.4320 354 Green 12 V DC ±10 % 10 mA Plug-in terminal 84-8511.5320 354 Blue 12 V DC ±10 % 10 mA Plug-in terminal 84-8511.6320 354 White 12 V DC ±10 % 10 mA Plug-in terminal 84-8511.9320 354 Red 24 V DC ±10 % 10 mA Plug-in terminal 84-8511.2620 354 Orange 24 V DC ±10 % 10 mA Plug-in terminal 84-8511.3620 354 Yellow 24 V DC ±10 % 10 mA Plug-in terminal 84-8511.4620 354 Green 24 V DC ±10 % 10 mA Plug-in terminal 84-8511.5620 354 Blue 24 V DC ±10 % 10 mA Plug-in terminal 84-8511.6620 354 White 24 V DC ±10 % 10 mA Plug-in terminal 84-8511.9620 354 04 09 14 17 Contacts: NO = Normally open 18 Additional information 19 • Standard version: Cable length 300 mm 22 31 41 • LED and built-in resistor included • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED Wiring diagrams 45 3 X2+ 4 X1– 51 56 Wiring diagram 354 57 61 70 71 82 84 92 96 42 eao.com § 09/2023 Components 84 01 Switching element with illumination and flat ribbon cable Component Layout IP Protection Illumination colour Operating voltage Operation current Terminal Part No. Wiring diagram IP40 Red 12 V DC ±10 % 10 mA Flat ribbon cable 84-8511.2340 354 119 Yellow 12 V DC ±10 % 10 mA Flat ribbon cable 84-8511.4340 354 119 Green 12 V DC ±10 % 10 mA Flat ribbon cable 84-8511.5340 354 119 Blue 12 V DC ±10 % 10 mA Flat ribbon cable 84-8511.6340 354 119 White 12 V DC ±10 % 10 mA Flat ribbon cable 84-8511.9340 354 119 Red 24 V DC ±10 % 10 mA Flat ribbon cable 84-8511.2640 354 119 Orange 24 V DC ±10 % 10 mA Flat ribbon cable 84-8511.3640 354 119 Yellow 24 V DC ±10 % 10 mA Flat ribbon cable 84-8511.4640 354 119 Green 24 V DC ±10 % 10 mA Flat ribbon cable 84-8511.5640 354 119 Blue 24 V DC ±10 % 10 mA Flat ribbon cable 84-8511.6640 354 119 White 24 V DC ±10 % 10 mA Flat ribbon cable 84-8511.9640 354 119 02 03 04 09 14 17 Contacts: NO = Normally open Additional information 18 • LED and built-in resistor included • Standard version: Cable length 300 mm 19 • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose 22 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 31 Wiring diagrams 3 X2+ 4 X1– 41 45 51 56 Wiring diagram 354 57 Component layouts Orange (red) Yellow (blue) Red (orange) Blue (yellow) 61 70 4 3 X2+ X1– 71 82 Component layout 119 84 92 96 09/2023 § eao.com 43 84 Components 01 Switching element Bi-colour 02 03 04 Component Layout Operating voltage Switching system Contacts Contact material Illumination colour Terminal Part No. Wiring diagram 24 V DC ±10 % Short-travel element 1 NO Gold-plated silver Red / Green Flat ribbon cable 84-8515.8640 355 120 Short-travel element 1 NO Gold-plated silver Yellow / Green Flat ribbon cable 84-8515.7640 355 120 Contacts: NO = Normally open Additional information 09 14 17 18 19 • LED and built-in resistor included • Cabel connection IP 67, rear side fully sealed. The illumination element of the cable version cannot be disconnected from the actuator any longer • Best illumination level will be reached with aluminium lens with spot, Part No. 84-7215.x00 and 84-7211. x00 • Standard version: Cable length 300 mm • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED Wiring diagrams 22 +24V 0V +24V 31 41 45 51 56 57 Wiring diagram 355 Component layouts White Brown Green Yellow Grey 0V +24 VDC LED red +24 VDC LED green 61 Component layout 120 70 71 82 84 92 96 44 eao.com § 09/2023 Components 84 01 Switching element without illumination Switching system Contacts Contact material Terminal Part No. Wiring diagram Short-travel element 1 NO Gold-plated silver Plug-in terminal 84-8510.0020 356 1 NO Gold-plated silver Flat ribbon cable 84-8510.0040 356 Component Layout 02 03 117 04 Contacts: NO = Normally open Additional information 09 • Standard version: Cable length 300 mm • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose 14 17 Wiring diagrams 18 3 19 4 22 Wiring diagram 356 31 41 Component layouts 45 Orange (red) Yellow (blue) 4 3 51 56 Component layout 117 57 61 70 71 82 84 92 96 09/2023 § eao.com 45 84 Components 01 Switching element PCB illuminative 02 03 Switching system Contacts Contact material Terminal Part No. Wiring diagram Short-travel element 1 NO Gold-plated silver PCB terminal 92-851.342 332 Component Layout 82 Contacts: NO = Normally open 04 Additional information • The customer has to decide what series resistor shall be used to the LED • LED and mounting flange to be ordered separately 31 3 4 12.5 2 .8 22 1 16 19 9.3 4 18 1 3.6 12.5 5.08 17 5.7 Ø8 14 10.16 09 Dimensions [mm] Wiring diagrams 41 3 4 1 2 45 51 56 Wiring diagram 332 57 61 70 71 82 84 92 96 46 eao.com § 09/2023 Components 84 Component layouts A 01 02 C B 03 Ø1.3 (4x) 04 10.16 D B C C K 1 C C B 3 10.16 Ø1.0 (2x) 12.70 E 2 09 4 A 14 17 Component layout 82 Dimensions [mm] A = Switching element with illumination B = Single LED C = Drilling plan (component side) D = Hole for switching element, pad max. Ø 2.5 mm E = Hole for LED 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 47 84 Components 01 Illumination element with plug-in terminal 02 03 IP Protection Illumination colour Operating voltage Terminal Part No. Wiring diagram IP40 Red 12 V DC ±10 % Plug-in terminal 84-8001.2320 351 Yellow 12 V DC ±10 % Plug-in terminal 84-8001.4320 351 Green 12 V DC ±10 % Plug-in terminal 84-8001.5320 351 Blue 12 V DC ±10 % Plug-in terminal 84-8001.6320 351 White 12 V DC ±10 % Plug-in terminal 84-8001.9320 351 Red 24 V DC ±10 % Plug-in terminal 84-8001.2620 351 Amber 24 V DC ±10 % Plug-in terminal 84-8001.3620 351 Yellow 24 V DC ±10 % Plug-in terminal 84-8001.4620 351 Green 24 V DC ±10 % Plug-in terminal 84-8001.5620 351 Blue 24 V DC ±10 % Plug-in terminal 84-8001.6620 351 White 24 V DC ±10 % Plug-in terminal 84-8001.9620 351 04 09 14 17 Additional information • LED and built-in resistor included 18 • Standard version: Cable length 300 mm • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) 19 22 • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED • Standard version: Cable length 300 mm with insulated ferrule, plug-in terminal 2.8 mm x 0.5 mm 31 Wiring diagrams 41 X2+ 45 51 56 X1– Wiring diagram 351 57 61 70 71 82 84 92 96 48 eao.com § 09/2023 Components 84 01 Illumination element with flat ribbon cable Component Layout IP Protection Illumination colour Operating voltage Terminal Part No. Wiring diagram IP40 Red 12 V DC ±10 % Flat ribbon cable 84-8001.2340 351 118 Green 12 V DC ±10 % Flat ribbon cable 84-8001.5340 351 118 White 12 V DC ±10 % Flat ribbon cable 84-8001.9340 351 118 Red 24 V DC ±10 % Flat ribbon cable 84-8001.2640 351 118 Amber 24 V DC ±10 % Flat ribbon cable 84-8001.3640 351 118 Yellow 24 V DC ±10 % Flat ribbon cable 84-8001.4640 351 118 Green 24 V DC ±10 % Flat ribbon cable 84-8001.5640 351 118 Blue 24 V DC ±10 % Flat ribbon cable 84-8001.6640 351 118 White 24 V DC ±10 % Flat ribbon cable 84-8001.9640 351 118 02 03 04 09 14 Additional information 17 • LED and built-in resistor included • Standard version: Cable length 300 mm 18 • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose 19 • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 22 Wiring diagrams 31 X2+ 41 45 X1– 51 Wiring diagram 351 56 Component layouts Red (orange) Blue (yellow) 57 61 X2+ X1– 70 71 Component layout 118 82 84 92 96 09/2023 § eao.com 49 84 Components 01 Illumination element bi-colour 02 03 04 09 14 17 18 Component Layout IP Protection Illumination colour Operating voltage Terminal Part No. Wiring diagram IP40 Red / Green 24 V AC/DC ±10 % Plug-in terminal 84-8005.8620 353 121 IP67 Red / Green 24 V AC/DC ±10 % Flat ribbon cable 84-8005.8640 353 121 Additional information • LED and built-in resistor included • Standard version: Cable length 300 mm • Other options on request: Customisation of cable and connectors, rear side fully sealed (IP 67) • Best illumination level will be reached with aluminium lens with spot, Part No. 84-7215.x00 and 84-7211. x00 • Protection degree (rear side): IP 40, upgrade to IP 67 with plug Part No. 84-900 possible. With applications where strong vibrations occure, the plugs may become loose • Cabel connection IP 67, rear side fully sealed. The illumination element of the cable version cannot be disconnected from the actuator any longer • Luminosity and wave length variations caused by LED manufacturing processes may cause slight differences regarding the illumination. The customer has to decide what resistor shall be used to the LED 19 22 Wiring diagrams +24 V 0 V +24 V 31 41 45 Wiring diagram 353 51 56 Component layouts 57 Red Blue Yellow 0V +24 VDC LED red +24 VDC LED green 61 70 Component layout 121 71 82 84 92 96 50 eao.com § 09/2023 Components 84 01 02 Switching element Halo Compact Operating voltage Operation current Switching system Contacts Contact material Illumination colour 24 V DC ±10 % 80 mA Short-travel element 1 NO Gold-plated silver 80 mA Short-travel element 1 NO 80 mA Short-travel element 80 mA Component Layout Terminal Part No. Wiring diagram Red Soldering / Plug-in terminal 84-8716.2620 439 103 Gold-plated silver Yellow Soldering / Plug-in terminal 84-8716.4620 439 103 1 NO Gold-plated silver Green Soldering / Plug-in terminal 84-8716.5620 439 103 Short-travel element 1 NO Gold-plated silver Blue Soldering / Plug-in terminal 84-8716.6620 439 103 80 mA Short-travel element 1 NO Gold-plated silver White Soldering / Plug-in terminal 84-8716.9620 439 103 80 mA Short-travel element 1 NO Gold-plated silver Red / Green Soldering / Plug-in terminal 84-8716.8620 439 103 03 04 09 14 17 Contacts: NO = Normally open 18 Additional information • Preconfigured light sequences see Technical data • Integrated electronig switch for latching function (High-Side-Switch) 19 31.9 31.9 22 31 41 11.84 8.6 31.9 45 Dimensions [mm] 51 Wiring diagrams 56 +24 V 57 61 0V 70 Wiring diagram 439 71 82 84 92 96 09/2023 § eao.com 51 84 Components 01 Component layouts 02 03 04 IN1 31. 9 A B IN3 09 0VDC +24VDC IN2 IN4 14 17 31.9 Component layout 103 18 A = Switch out B = Top 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 52 ​ eao.com § 09/2023 Components 84 01 Illumination element PCB Terminal Part No. Wiring diagram PCB terminal 92-800.042 330 Component Layout 02 79 03 Additional information 04 • The customer has to decide what series resistor shall be used to the LED • LED and mounting flange to be ordered separately 5.7 4 1.6 09 14 .8 8 0. 16 8 0. 6.35 x 17 18 12.5 Dimensions [mm] 19 Wiring diagrams 22 31 + 41 – 45 Wiring diagram 330 51 56 Component layouts A 57 C B C C C C 5.08 61 1 2 3 4 70 71 Ø1.3 (4x) 12.70 D 82 Component layout 79 Dimensions [mm] A = Switching element without illumination B = Drilling plan (component side) C = Occupancy plan (component side) D = Hole for switching element 84 92 96 09/2023 § eao.com 53 84 Components 01 02 03 04 09 Mounting flange Product attributes Material Fastening Part No. Tightening torque fixing screw 0.3 Nm Plastic With screws 92-960.0 Plastic Mit Schrauben 84-960.0 Additional information • For discrete switching applications including switching element and mounting flange, soldering terminal (assembled PCB incl. series resistor and LED on request) • Halo illumination (illuminated multi-color bezel) 4 6.85 7.1 17 24.5 20 14 R2.2 21.55 ± 0.1 4.9 R2.2 30 ± 0.05 7.35 18 19 Dimensions [mm] for Part No. 92-960.0 Dimensions [mm] for Part No. 84-960.0 22 31 41 45 51 56 57 61 70 71 82 84 92 96 54 eao.com § 09/2023 Accessories 84 Front side 01 02 03 04 Legend frame Dimensions Material Colour Surface Mounting type Part No. 30 mm x 50 mm Aluminium Black anodised adhesive 61-9980.0 09 14 Additional information • For devices with front dimension Ø 25 mm, flush design • The colour of anodised aluminium parts can vary due to technical production reasons 4 18 14.5 19 Ø25 17 22 35 ± 0.3 50 ± 0.3 23.5 0 30 -0.1 31 Dimensions [mm] 41 45 Legend plate Product attributes For legend frame Part No.704.968.2 and 704.968.3 51 Dimensions Material Colour Surface Mounting type Part No. 14.5 mm x 23.5 mm Aluminium Nature anodised adhesive 704.968.0 14.5 mm x 23.5 mm Aluminium Black anodised adhesive 704.968.1 56 Additional information 57 • The colour of anodised aluminium parts can vary due to technical production reasons 61 70 71 82 84 92 96 09/2023 § eao.com 55 84 Accessories 01 02 03 Emergency stop legend Dimensions Material Colour Mounting cut-out Marking Part No. Ø 60 mm Plastic Yellow Ø 22.3 mm NOT AUS 704.963.5 04 09 Ø 90 mm 14 17 Plastic Yellow Ø 22.3 mm EMERGENCY STOP 704.963.6 Plastic Yellow Ø 22.3 mm ARRET D'URGENCE 704.963.7 Plastic Yellow Ø 22.3 mm NOT HALT 704.963.8 Plastic Yellow Ø 22.3 mm EN ISO 13850 symbol 704.963.9 Plastic Yellow Ø 22.3 mm NOT AUS 704.963.0 Plastic Yellow Ø 22.3 mm EMERGENCY STOP 704.963.1 Plastic Yellow Ø 22.3 mm ARRET D'URGENCE 704.963.2 Plastic Yellow Ø 22.3 mm NOT HALT 704.963.3 Plastic Yellow Ø 22.3 mm EN ISO 13850 symbol 704.963.4 Additional information • Front panel thickness 3 mm max. 18 19 Blind plug 22 31 Dimensions Material Colour Mounting cut-out Part No. Ø 25 mm Plastic Black Ø 22.5 mm 61-9453.0 Ø 36 mm Plastic Black Ø 30.5 mm 704.964.8 Additional information • Please note that bigger minimum distances are necessary • Only suitable for mounting in round hole without D-shape (Part No. 61-9453.0) 45  2.6  Ø 36.2  ±  51 14 Ø 35.6 41 56 2…6  57 61 Dimensions [mm] for Part No. 61-9453.0 Dimensions [mm] for Part No. 704.964.8 70 71 82 84 Protective cap Product attributes Material Colour Optics Part No. For front bezel Ø 25 mm Silicone Colourless transparent 84-9103.7 Additional information • For flat lens profil only • When using the front protection cover the external sealing in the actuator has to be removed 92 96 56 eao.com § 09/2023 Accessories 84 01 02 Protection cover Product attributes Dimensions Material Colour Part No. For USB socket Ø 36 mm Plastic Black 84-916 For single pushbutton 42 mm x 8,5 mm x 33 mm Aluminium/Plastic Metall/colourless 84-922 03 04 Additional information • When mounting the protective cover 84-916 make sure that the USB adapter is mounted in center position. 5.5 14 17 33 3.7 3.7 8.5 09 18 33 Ø 40 42 95.84 Dimensions [mm] for Part No. 84-916 19 Dimensions [mm] for Part No. 84-922 22 31 E stop protective shroud Dimensions Material Colour Ø 50 mm Plastic Yellow Marking 41 Part No. 84-902 Plastic Yellow NOT - AUS 84-902A Plastic Yellow EMERGENCY STOP 84-902B NOT - HALT Plastic Yellow Ø 45 mm Metal Yellow 84-909 Ø 50 mm Plastic Yellow 84-906 45 84-902D 51 Additional information 56 • Front panel thickness 1 … 3 mm • With anti-twist device 57 • When using a protective shroud the e-stop or stop-switch has to be turned by 180° to be mounted. See dimensional drawing 61 • The protection shroud Part No. 84-909 is not suitable for a proper use of emergency-stop. It can obstruct a spontaneous operation of the emergency-stop switch • This shroud Part No. 84-906 is not compliant to EN ISO 13850. There are no restrictions when combined with stop switches. 26 1.8 Ø22.5 Ø37 Ø45 Ø31.8 Ø50.2 Ø22.5 1.5 37.6 2.5 1 71 Ø22.5 82 Ø50 11 70 84 Dimensions [mm] for Part No. 84-902, 84-902A 84-902B, 84-904C 09/2023 § eao.com Dimensions [mm] for Part No. 84-909 92 Dimensions [mm] for Part No. 84-906 96 57 84 Accessories 01 84-3103.0000.1 Black 84-3103.0000.2 Ø 28.3 Part No. Black Ø 28.3 04 Colour Plastic Ø 30.1 ±0.25 03 Material Ø 34.75 ±0.25 02 USB socket 2 09 37.5 600/1000 14 17 Dimensions [mm] 18 19 22 31 41 45 51 Follow us. We are on LinkedIn! 56 EAO creates possibilities. Since 1947. 57 61 70 71 Come take a look at our LinkedIn profi le today! Be sure to give us a follow so that you can fully interact with us. 82 https://www.linkedin.com/company/eao/ 84 92 www.eao.com 96 58 eao.com § 09/2023 Accessories 84 Rear side 01 02 Adaptor reducing to 25 mm Material Colour Part No. For housing, pole mounting 35 mm dia. Plastic Yellow 84-9300.4 Plastic Grey 84-9300.8 98 ± 0.4 03 04 09 Ø 25 Ø 4.8 Product attributes 20.5 14 111 17 18 Dimensions [mm] 19 Adaptor reducing to 30 mm 22 Material Colour Part No. For housing, pole mounting 35 mm dia. Plastic Yellow 84-9700.4 Plastic Grey 84-9700.8 98 ± 0.4 31 41 Ø 30 Ø 4.8 Product attributes 20.5 45 111 51 56 Dimensions [mm] 57 61 Flat receptacle Product attributes Material Part No. 2.8 x 0.8 mm plug-in terminal Metal 84-9420 70 71 Insulation sleeve Product attributes Material Part No. For flat receptacle 2.8 mm Plastic 31-929 82 84 92 96 09/2023 § eao.com 59 84 Accessories 01 PCB plug-in base 02 03 Product Dimensions Material Terminal Pins Part No. Component Layout For Emergency stop switch, stop switch 20.3 mm x 8.3 mm x 15.8 mm Metal / plastic PCB terminal Axial 84-920 102 04 2.9 09 20.3 1.6 14 17 18 0 8.3 -0.2 15.8 Dimensions [mm] 19 Component layouts 22 A 31 B   r    Š  Š  Š 45 51 C  Š 41 56  Y ± Š Y± E D 57  Š  Š 61 70 71 Component layout 102 Dimensions [mm] A = Drilling plan (component side) B = Centre from switch C = Anti-twist protection D = Pins for contacts/LED E = Positioning hole 82 84 92 96 Plug Material Part No. Plastic 84-900 Additional information • For back protection IP67 of switching elements and illumination elements. Two plugs are nessecary per element 60 eao.com § 09/2023 Accessories 84 Mounting 01 02 03 Enclosure Product attributes Dimensions Material Colour IP Protection Part No. With mounting cut-out 1 x Ø 22.3 mm, with antitwist device 94 mm x 81 mm x 94 mm Plastic Grey IP66 704.945.1 With mounting cut-out 2 x Ø 22.3 mm, with antitwist device 130 mm x 81 mm x 94 mm Plastic Grey IP66 704.945.2 With mounting cut-out 3 x Ø 22.3 mm, with antitwist device 180 mm x 81 mm x 94 mm Plastic Grey IP66 704.945.3 With mounting cut-out 4 x Ø 22.3 mm, with antitwist device 180 mm x 110 mm x 182 mm Plastic Grey IP66 704.945.4 With mounting cut-out 6 x Ø 22.3 mm, with antitwist device 180 mm x 110 mm x 182 mm Plastic Grey IP66 704.945.5 Bottom grey similar RAL 7035; cover lead-sealable, yellow similar RAL 1004 65 mm x 57 mm x 65 mm Plastic IP66 84-910 09 14 17 18 65 2.5 2.5 B 04 25 65 57 L H 19 22 31 Dimensions [mm] for Part No. 704.945.1, 704.945.2, 704.945.3, 704.945.4, 704.945.5 Dimensions [mm] for Part No. 84-910 41 45 51 Fixing nut Product attributes Dimensions Material Colour Part No. Standard version Ø 30 mm Plastic Black 84-901 For emergency stop switch Ø 28 mm Plastic Black 84-905 For emergency stop switch Ø 30 mm Plastic Black 84-908 For emergency stop switch Ø 25 mm Metal Silver 84-911 56 57 61 Dismantling tool Product attributes Material Part No. For dismantling switching elements or lenses Metal / plastic 84-918 70 71 82 84 92 96 09/2023 § eao.com 61 84 Accessories 01 Housing pole mounting 35 mm 02 Product attributes Material Colour Part No. Please note: The cut-out of the pole must read min. 22 mm and needs to be aligned with the switch Plastic Yellow 84-9500.4 Plastic Traffic blue 84-9500.6A Plastic Grey 84-9500.8 03 04 Additional information • Screws are not contained in the scope of supply 09 31 50 14 Ø35 Ø 22.5 Ø 4.8 111 17 38.7 18 98 ± 0.4 19 Dimensions [mm] 22 Housing pole mounting 38 mm 31 Product attributes Material Colour Part No. 41 Please note: The cut-out of the pole must read min. 22 mm and needs to be aligned with the switch Plastic Yellow 84-9600.4 Plastic Grey 84-9600.8 45 Additional information • Screws are not contained in the scope of supply 51 31 42.5 56 110.5 57 Ø38 98 ± 0.4 Ø4.8 Ø 22.5 61 70 38 Dimensions [mm] 71 82 84 92 96 62 eao.com § 09/2023 Accessories 84 01 Housing wall mounting Material Colour Part No. Plastic Yellow 84-9800.4 Plastic Grey 84-9800.8 02 03 Additional information • Screws are not contained in the scope of supply 04 31 31 09 110 36 14 Ø 22.5 17 Ø 4.8 98 ± 0.4 18 Dimensions [mm] 19 Cable gland 22 Product attributes Material Colour IP Protection Thread Part No. With traction relief Plastic Grey IP68 M16 x 1.5 mm 61-9481.6 Plastic Grey IP68 M20 x 1.5 mm 704.945.6 31 41 Mounting tool Product attributes 45 Dimensions For tightening or loosening the fixing nut, for emergency-stop and stop-switch For tightening or loosening of the fixing nut Ø 22 mm Ø 22 mm Material Part No. Plastic 84-996 Metal 84-997 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com 63 84 Technical data 01 02 03 04 Emergency-stop Switching system The double-break switching system can be supplied for the following switching functions: 1 Normally closed, 2 Normally closed, 1 Normally closed + 1 Normally open. The Normally closed contacts have forced opening according to EN 60947-5-5 09 14 19 22 Rated Operational Voltage Ue 250 VAC, as per EN IEC 60947-1 250 V, as per EN IEC 60947-1 Material Rated Impulse Withstand Voltage Uimp 4 kV, as per EN IEC 60947-1 Plastic, operating temperature up to + 65 °C Electrical life Mushroom-head cap 18 LED red with pole reversal, constant current source Operation Voltage 5 VDC … 30 VDC Current consumption 9.7 mA … 12.4 mA Rated Insulation Voltage Ui Connection cable 17 Illumination Plastic, as per UL 94 V0 50 000 cycles of operations (inductive cosφ 0,95) as per EN IEC 60947-5-1 Actuator housing Plastic, as per UL 94 V0 Air thermal Ith Material of contact 5 A (plug in) 3 A (cable leads Silver alloy gold plated Switching voltage and switching current 31 41 45 Mechanical characteristics Front panel thickness Standard 1 … 4 mm with emergency stop protective shroud Part No. 84-902 1 … 3 mm Mounting cut-outs 51 56 57 61 70 Voltage Current 120 VAC 3A 240 VAC 1.5 A Switch rating DC for silver contact (gold plated), service category DC-13, as per EN IEC 60947-5-1 Ø 22.3 mm as per EN IEC 60947-5-1 with anti-twist device NO contacts (48 VA) Soldering terminals 2.8 mm x 0.5 mm (solderable), CuSn6 tin-plated 12 VDC / 2.0 A Flat ribbon cable 2-, 4-, or 6-poles 0.35 mm² (AWG 22) 24 VDC / 2.0 A 48 VDC / 1.0 A Tightening torque 60 VDC / 0.8 A Fixing nut 0.8 Nm Terminals NC contacts (60 VA) 12 VDC / 2.5 A 24 VDC / 2.5 A 48 VDC / 1.25 A 60 VDC / 1.0 A NO/NC contacts 125 VDC / 0.22 A 250 VDC / 0.11 A Recommended minimum operating data Silver contacts (gold plated) Actuating force 17 N ± 4 N Voltage Current Actuating travel 71 Switch rating AC with silver contact (gold plated), service category AC-15, as per EN IEC 60947-5-1 1 VAC / DC 1 mA Approx. 5 mm Electric strength Mechanical lifetime 82 250 000 cycles of operations 84 Electrical characteristics 92 Standards 500 VAC, 50 Hz, 1 minute, as per DIN IEC 60512-2 Rated conditional short-circuit current 1000 A, type of short-circuit unit 6 A gG, as per EN IEC 60947-5-1 Protection class Class II, as per EN IEC 60947-5 The devices comply with: EN IEC 60947-5-1, EN IEC 60947-5-5 (emergency stop), DIN EN ISO 13850, EN IEC 60204 96 64 ​ eao.com § 09/2023 Technical data Overvoltage category Climate resistance III, as per EN IEC 60947-1 Damp heat, cyclic 96 hours, + 25 °C /97 %, + 55 °C / 93 % relative humidity, as per EN IEC 60068-2-30 Damp heat, steady 56 days, + 40 °C / 93 % relative humidity, as per EN IEC 60068-2-78 Degree of pollution 3, as per EN IEC 60947-1 Ambient conditions Storage temperature -25 °C … +80 °C Operating temperature -25 °C … +65 °C Front protection IP65 front side, as per EN IEC 60529 IP66 front side, as per EN IEC 60529 IP67 front side, as per EN IEC 60529 IP20 (cable lead connection) 84 01 02 03 Dry heat 96 hours, + 65 °C, as per EN IEC 60068-2-2 04 Low temperature 96 hours, – 25 °C, as per EN IEC 60068-2-1 09 Saline mist 96 hours, + 35 °C in chemical solution NaCl, as per EN IEC 60068-2-11 14 17 Approvals 18 Impact resistance IK07, as per IEC 62262 Approbations Shock resistance CB (IEC 60947-5-1, IEC 60947-5-5) UL NISD CCC (pending) (semi-sinusoidal) Max. 150 m / s², pulse width 11 ms, 3-axis, as per EN IEC 60068-2-27 Vibration resistance (sinusoidal) Max. 50 m / s² at 10 Hz … 500 Hz, 10 cycles, 3-axis, as per EN IEC 60068-2-6 19 22 Declaration of conformity CE 2006 / 42 / EC (MD) 2011 / 65 / EC (RoHS) 31 41 45 Switching element illuminated pushbutton 51 Switching system Mechanical characteristics Short-travel switching system with 2 independent contact points and tactile operation. Guarantees reliable switching even of very light loads. Fitted with 1 normally open contact. Terminals 56 Plug-in terminals 2.8 mm x 0.8 mm (solderable) Flat ribbon cable 0.5 mm² PCB terminal 57 61 Actuating force Material 4.0 N ±0.2 N Connection cable Tightening torque Plastic, short-time heat-resistant up to 105 °C Fixing screw mounting flange 0.4 Nm Material of contact Actuating travel Silver alloy gold plated ~ 0.5 mm Switching element Resistance to heat of soldering Plastic, as per UL 94 V0 and Plastic, as per UL 94 HB 250 °C, 3 s (PCB assembly) 320 °C, 3 s (when using a soldering iron) 70 71 82 84 92 96 09/2023 § eao.com ​ 65 84 Technical data 01 02 Mechanical lifetime Switching voltage and switching current ≥ 1 million cycles of operations Voltage Current Power 50 mVAC/DC … 42 VAC/DC 10 uA … 100 mA max. 2 W Electrical characteristics Electric strength 03 04 500 VAC, 50 Hz, 1 minute, as per DIN IEC 60512-2 Illumination Single-Chip LED, green, orange, red, yellow, white and blue Ambient conditions Operation Voltage Current consumption 12 VDC 10 mA 24 VDC 10 mA – 40 °C ... + 85 °C 09 14 17 18 19 22 31 41 45 51 Electrical life Operating temperature as per EN IEC 60512-5 – 25 °C ... + 70 °C 5 million cycles of operation 5 million cycles of operation 2 million cycles of operation 2 million cycles of operation 300 000 cycles of operation 250 000 cycles of operation 1 million cycles of operation 1 million cycles of operation 1 million cycles of operation 5 million cycles of operation 1.5 million cycles of operation 100 000 cycles of operation 500 000 cycles of operation 300 000 cycles of operation 100 000 cycles of operation 24 VAC, 50 mA at 480 Ω 24 VAC, 100 mA at 240 Ω 42 VAC, 50 mA at 840 Ω 42 VAC, 100 mA at 420 Ω 42 VAC, 100 mA at cosφ 0.4 42 VAC, 200 mA at cosφ 0.395 12 VDC, 250 mA at 48 Ω 24 VDC, 50 mA at 480 Ω 24 VDC, 100 mA at 240 Ω 42 VDC, 25 mA at 1680 Ω 42 VDC, 50 mA at 840 Ω 42 VDC, 100 mA at 420 Ω 24 VDC, 200 mA at L/R = 30 ms 42 VDC, 100 mA at L/R = 30 ms 42 VDC, 200 mA at L/R = 30 ms Switch configuration 57 61 Use Halo Compact with illuminated pushbutton actuator (Part No. 84-1081.7) or with the indicator actuator (Part No. 84-0080.7). 70 The illumination style is selected by the connection of 24V to the pins. 71 82 84 Protection degree Back protection: IP40, standard version IP67, fully sealed version, with mounted actuator only. Shock resistance (semi-sinusoidal) Max. 100 m / s², pulse width 11 ms, 3-axis, as per EN IEC 60068-2-27 Vibration resistance (sinusoidal) Max. 50 m / s² at 10 Hz … 500 Hz, 10 cycles, 3-axis, as per EN IEC 60068-2-6 Switching element Halo Compact A complete switch requires a halo compact programmable switch actuator body (transparent) and a lens. If the switch needs lens illumination in addition then a translucent plastic lens or aluminium lens with a window is required. 56 Storage temperature Material of contact Silver alloy, gold-plated The materials used comply with the high EAO standards relating to quality, functional safety, service life and design. Mechanical characteristics Terminals Soldering / plug-in terminals 2.8 mm x 0.8 mm (solderable) Actuating force Material 4.0 N ± 0.2 N (measured at the lens) Housing Actuating distance Plastic Plastic (sealing compound) ~ 0.5 mm Mechanical lifetime ≥ 1 million cycles of operation 92 96 66 ​ eao.com § 09/2023 Technical data Electrical characteristics Ambient conditions Switching element Storage temperature Short-travel snap-action switching system with two independent contact points and tactile operation. – 40 °C ... + 85 °C 84 01 02 Operating temperature Number of contacts: one normal open contact – 25 °C ... + 70 °C Output Electronic high-side switch Degree of protection 03 04 IP67 front side (with actuator Part No. 84-1081.7 and 84-0080.7) Pre-configured light sequences - Full illumination - Blinking (interval: 1 second) - Rotating/chasing (one full rotation per second) - Process (changeover a group of 4 LEDs per second) 09 Shock resistance (semi-sinusoidal) Max. 100 m / s², pulse width 6 ms, 3-axis, as per EN IEC 60068-2-27 Special feature Integrated electronic switch for maintained action (High-side switch) 14 17 Vibration resistance (sinusoidal) Max. 50 m / s² at 10 Hz … 500 Hz, 10 cycles, 3-axis, as per EN IEC 60068-2-6 18 Operating voltage 24 VDC ± 10 % Max. 100 mA Approvals Current consumption Conformities < 80 mA CE 2014 / 30 / EU (EMC) 2011 / 65 / EC (RoHS) LED-colours 19 22 31 All versions available with eight SMD LEDs for halo illumination plus one single LED (3mm) for central illumination. The following variants are available: 41 45 8 x red LEDs + 1 white single LED 8 x green LEDs + 1 white single LED 8 x yellow LEDs + 1 white single LED 8 x white LEDs + 1 white single LED 8 x blue LEDs + 1 white single LED 8 x red /green bi-colour LEDs + 1 white single LED Light sequences central LED 51 56 IN1 IN2 IN3 – 0 VDC 0 VDC 0 VDC – + 24 VDC 0 VDC 0 VDC 3 – 0 VDC + 24 VDC 0 VDC 4 – + 24 VDC + 24 VDC 0 VDC – 5 0 VDC 0 VDC + 24 VDC – 6 + 24 VDC 0 VDC + 24 VDC – 7 0 VDC + 24 VDC + 24 VDC – 8 + 24 VDC + 24 VDC + 24 VDC not illuminated illuminated 1 2 57 61 70 71 82 * Functionen of light sequence: 1/5 = Full illuminiation 2/6 = Blink 3/7 = Rotation 4/8 = Process 84 92 96 09/2023 § eao.com ​ 67 84 Technical data 01 02 03 04 09 14 17 Actuator Material Ambient conditions Lens Storage temperature Plastic, as per UL 94 V2 or Aluminium anodised – 40 °C ... + 85 °C Actuator housing Operating temperature Plastic, as per UL 94 V0 or Aluminium anodised – 25 °C ... + 70 °C Protection degree Mechanical characteristics IP 67 and IP40 front side, as per EN IEC 60529 Frontplate thickness Climate resistance Standard 1 … 4 mm Damp heat, cyclic 96 hours, + 25 °C / 97 %, +55 °C / 93 % relative humidity, as per EN IEC 60068-2-30 Tightening torque Fixing nut max. 80 Ncm 18 19 Actuating force 4.0 N ± 0.2 N (measured at the lens) Rapid change of temperature 100 cycles, – 40 °C … + 80 °C, as per EN IEC 60068-2-14 Actuating travel 22 Damp heat, state 56 days, + 40 °C / 93 % relative humidity, as per EN IEC 60068-2-78 1.2 mm Mechanical lifetime 31 ≥ 1 million cycles of operation 41 Electrical characteristics 45 Electrostatic breakdown value 51 Approvals Approbations Plastic case ≥ 15 kV Aluminium case ≥ 5 kV as per IEC 61000-4-2, mounted in plastic front panel EBC (TSI / PRM) NFF Conformities CE 2011 / 65 / EC (RoHS) 56 EAO reserves the right to alter specifications without further notice. 57 61 70 71 82 84 92 96 68 ​ eao.com § 09/2023 Marking 84 IO-Link Touch – Standard Symbols 01 02 Please note    BXX symbols are illuminated CXX symbols are printed on Further standard symbols and also customised symbols possible 03 04 START STOP ON OFF RESET Symbol B10 Symbol B11 Symbol B12 Symbol B13 START STOP ON OFF RESET Symbol C10 Symbol C11 Symbol C12 Symbol C13 START STOP RESET Symbol C17 Symbol C18 Symbol C19 09 Symbol B14 14 Symbol B15 17 Symbol C14 18 Symbol C16 19 22 Symbol C20 31 41 45 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 69 84 Application guidelines 01 02 03 04 09 14 Suppressor circuits When switching inductive loads such as relays, DC motors, and DC solenoids, it is always important to absorb surges (e. g. with a diode) to protect the contacts. When these inductive loads are switched off, a counter emf can severely damage switch contacts and greatly shorten lifetime. Fig. 1 shows an inductive load with a free-wheeling diode connected in parallel. This free-wheeling diode provides a path for the inductor current to flow when the current is interrupted by the switch. Without this free-wheeling diode, the voltage across the coil will be limited only by dielectric breakdown voltages of the circuit or parasitic elements of the coil. This voltage can be kilo- 17 19 The free-wheeling diode should be chosen so that the reverse breakdown voltage is greater than the voltage driving the inductive load. The DC blocking voltage (VR) of the free-wheeling diode can be found in the datasheet of a diode. The forward current should be equal or greater than the maximum current flowing through the load. To get an efficient protection, the free-wheeling diode must be connected as close as possible to the inductive load! Counter EMF over load without free-wheeling diode Fig. 2 Switching with inductive load Fig. 1 18 volts in amplitude even when nominal circuit voltages are low (e. g. 12 VDC) see Fig. 2. Switch ON OFF 0 22 VDC + _ Free-wheeling diode Inductive load 31 Several hundred to several thousend volts di __ e = L dt 41 45 Note for soldering 51 Process parameter for wave soldering Basic specification for wave soldering J-STD 75 W4C. 56 Maximum temperature on the component side (Temp 2): (Temperature must not exceed during the entire processing) 120 °C Preheating phase (t1 … t2): Ramp up: 70 … 120 sec typ.+ 1 °C / sec Ramp up to maximum temperature (t2 … t3): not defined Maximum temperature on the soldering side (Temp 3): Maximum time of soldering process (t3 … t4): 250 °C 3 sec Ramp down at 170 °C: typ. – 2 °C/sec 57 61 70 71 82 84 92 96 70 ​ eao.com § 09/2023 Application guidelines 84 Temperature curve wave soldering 01 02 03 04 09 14 Green curve: Red curve: Temperature on the component side of the pcb Temperature on the soldering side of the pcb Room temperature: Temp 1 Preheating: Temperature process = Temp 1 … Temp 2 Process time = t1 … t2 18 19 t2 … t3 22 Temperature process = Temp 3 Process time = t3 … t4 31 Ramp up to soldering temperature: Process time = Soldering phase: 17 41 Iron soldering Basic specification for iron soldering IEC 60068-2-20 Maximum temperature at tip of iron: Maximum soldering time: 45 320 °C 3 sec 51 Cleaning/Lacquering Storage of components The switching elements are not sealed. Cleaning up the PCB may damage the contacts in the switching elements. For this reason, the following points should be noted: – When soldering make sure that the flux does not pass on the upper side of the PCB. – When cleaning the PCB with detergents ensure that no dust or other debris may get inside of the switching elements. – Ensure that no lacquer penetrates into the interior of the switching element when lacquering the PCB. To obtain the optimum solderability of the components, the following points should be noted during storage: – Do not store components in locations with high temperature or humidity. – Do not expose components to corrosive gases. – Avoid direct sunlight for a long period. 56 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 71 84 Application guidelines 01 Arrangement mounting flange for switching- and illumination element, PCB mounting 02 09 max. 60 04 25...30 03 14 17 18 19 22 31 41 45 max. 60 25...30 The arrangement of the mounting flanges and their number is determined by the size of the front panel or PCB. To ensure uniform, tactile switching, we recommend a layout of the flanges as per adjacent sketch. For large PCBs with several switching elements we recommend the following procedure: 1. Fit the actuator to the front panel. 2. Clip the mounting flange to the rear of the intended actuator. 3. Screw the PCB with the components soldered to it to the assembled mounting flange. Dismantling mounting flange The tool Part No. 84-998 must be used for removing the mounting flange from the actuator. Before removing the flange, the PCB fixing srews must be loosened. This arrangement applies to PCBs 1.6 mm thick. 51 56 57 61 70 71 82 84 92 96 72 ​ eao.com § 09/2023 Index Part No. Page 10-2601.3172S............38 10-2601.3173S............38 10-2603.3174S............38 10-2603.3175S............38 10-2603.3176S............38 10-2603.3178S............38 10-2603.320AL............39 10-2603.320CL............39 31-929.........................53 61-9453.0....................50 61-9481.6....................57 61-9707.7....................38 61-9980.0....................49 704.945.1....................55 704.945.2....................55 704.945.3....................55 704.945.4....................55 704.945.5....................55 704.945.6....................57 704.963.0....................50 704.963.1....................50 704.963.2....................50 704.963.3....................50 704.963.4....................50 704.963.5....................50 704.963.6....................50 704.963.7....................50 704.963.8....................50 704.963.9....................50 704.964.8....................50 704.968.0....................49 704.968.1....................49 84-0080.7....................19 84-0090.7....................17 84-0090.7....................18 84-0100.0....................15 84-0100.0....................16 84-0200.7....................15 84-0200.7....................16 84-1081.7....................10 84-1091.7......................8 84-1091.7......................9 84-1101.0......................4 84-1101.0......................6 84-1101.0....................11 84-1101.0....................13 84-1201.0......................4 84-1201.0......................6 84-1201.0....................11 84-1201.0....................13 84-1201.2......................4 84-1201.2......................6 84-1201.2....................11 84-1201.2....................13 84-1201.4......................4 84-1201.4......................6 84-1201.4....................11 84-1201.4....................13 84-1201.5......................4 84-1201.5......................6 84-1201.5....................11 84-1201.5....................13 84-1201.6......................4 84-1201.6......................6 84-1201.6....................11 84-1201.6....................13 84-1201.7......................4 84-1201.7......................6 84-1201.7....................11 84-1201.7....................13 84-1221.7......................5 84-1221.7......................6 84-1221.7....................12 84-1221.7....................13 84-2101.0......................4 84-2101.0......................6 84-2101.0....................11 Part No. Page 84-2101.0....................13 84-3100.0....................15 84-3100.0....................16 84-3103.0000.1...........52 84-3103.0000.2...........52 84-5220.0020..............29 84-5220.0040..............29 84-5221.2B20..............29 84-5221.2B40..............29 84-5230.0020..............29 84-5230.0040..............29 84-5231.2B20..............29 84-5231.2B40..............29 84-5240.0020..............29 84-5240.0040..............29 84-5241.2B20..............29 84-5241.2B40..............29 84-5241.8D20..............32 84-5241.8D40..............32 84-5320.0020..............29 84-5320.0040..............30 84-5321.2B20..............30 84-5321.2B40..............30 84-5330.0020..............30 84-5330.0040..............30 84-5331.2B20..............30 84-5331.2B40..............30 84-5340.0020..............30 84-5340.0040..............30 84-5341.2B20..............30 84-5341.2B40..............30 84-5341.8D20..............32 84-5341.8D40..............32 84-6220.0020..............26 84-6220.0040..............26 84-6821.2B20..............26 84-6821.2B40..............26 84-6830.0020..............26 84-6830.0040..............26 84-6831.2B20..............26 84-6831.2B40..............26 84-6840.0020..............26 84-6840.0040..............26 84-6841.2B20..............26 84-6841.2B40..............26 84-7111.200................35 84-7111.201................36 84-7111.202................36 84-7111.203................36 84-7111.300................35 84-7111.301................36 84-7111.400................35 84-7111.401................36 84-7111.500................35 84-7111.501................36 84-7111.502................36 84-7111.503................36 84-7111.600................35 84-7111.601................36 84-7111.602................36 84-7111.603................36 84-7111.700................35 84-7111.701................36 84-7111.702................36 84-7111.703................36 84-7114.600A..............38 84-7115.200................35 84-7115.300................35 84-7115.400................35 84-7115.500................35 84-7115.600................35 84-7115.700................35 84-7121.000................35 84-7121.800................35 84-7124.000A..............38 84-7124.200A..............38 84-7125.000................35 Part No. Page 84-7125.800................35 84-7201.000................37 84-7201.200................37 84-7201.400................37 84-7201.500................37 84-7201.600................37 84-7201.800................37 84-7202.000................37 84-7202.000A..............34 84-7202.200................37 84-7202.200A..............34 84-7202.400................37 84-7202.400A..............34 84-7202.500................37 84-7202.500B..............34 84-7202.600................37 84-7202.600A..............34 84-7202.800................37 84-7202.800A..............34 84-7205.000................37 84-7205.000A..............34 84-7205.200................37 84-7205.200A..............34 84-7205.400................37 84-7205.400A..............34 84-7205.500................37 84-7205.500A..............34 84-7205.600................37 84-7205.600A..............34 84-7205.800................37 84-7205.800A..............34 84-7205.804A..............34 84-7205.805A..............34 84-7205.806A..............34 84-7205.808A..............34 84-7211.000................37 84-7211.200................37 84-7211.400................37 84-7211.500................37 84-7211.600................37 84-7211.800................37 84-7215.000................37 84-7215.200................37 84-7215.400................37 84-7215.500................37 84-7215.600................37 84-7215.800................37 84-8001.2320..............43 84-8001.2340..............44 84-8001.2620..............43 84-8001.2640..............44 84-8001.3620..............43 84-8001.3640..............44 84-8001.4320..............43 84-8001.4340..............44 84-8001.4620..............43 84-8001.4640..............44 84-8001.5320..............43 84-8001.5340..............44 84-8001.5620..............43 84-8001.5640..............44 84-8001.6320..............43 84-8001.6620..............43 84-8001.6640..............44 84-8001.9320..............43 84-8001.9340..............44 84-8001.9620..............43 84-8001.9640..............44 84-8005.7620..............45 84-8005.7640..............45 84-8005.8620..............45 84-8005.8640..............45 84-8510.0020..............41 84-8510.0040..............41 84-8511.2320..............39 84-8511.2340..............40 84-8511.2620..............39 Part No. Page 84-8511.2640..............40 84-8511.3320..............39 84-8511.3340..............40 84-8511.3620..............39 84-8511.3640..............40 84-8511.4320..............39 84-8511.4340..............40 84-8511.4620..............39 84-8511.4640..............40 84-8511.5320..............39 84-8511.5340..............40 84-8511.5620..............39 84-8511.5640..............40 84-8511.6320..............39 84-8511.6340..............40 84-8511.6620..............39 84-8511.6640..............40 84-8511.9320..............39 84-8511.9340..............40 84-8511.9620..............39 84-8511.9640..............40 84-8515.7640..............41 84-8515.8640..............41 84-8716.2620..............46 84-8716.4620..............46 84-8716.5620..............46 84-8716.6620..............46 84-8716.8620..............46 84-8716.9620..............46 84-900.........................54 84-901.........................55 84-902.........................51 84-902A.......................51 84-902B.......................51 84-902D.......................51 84-905.........................55 84-906.........................51 84-908.........................55 84-909.........................51 84-910.........................55 84-9103.7....................50 84-911.........................55 84-916.........................51 84-918.........................55 84-920.........................54 84-9300.4....................53 84-9300.8....................53 84-9420.......................53 84-9500.4....................56 84-9500.6A..................56 84-9500.8....................56 84-960.0......................48 84-9600.4....................56 84-9600.8....................56 84-9700.4....................53 84-9700.8....................53 84-9800.4....................57 84-9800.8....................57 84-996.........................57 84-997.........................57 84-ACKS-B10-04B9....24 84-ACKS-B11-04BA...24 84-ACKS-B12-04BB...24 84-ACKS-B13-04BC...24 84-ACKS-B14-04BD...24 84-ACKS-B15-04BE....24 84-ACKS-C10-04BF....24 84-ACKS-C11-04C0...24 84-ACKS-C12-04C1...24 84-ACKS-C14-04C2...24 84-ACKS-C16-04C3...24 84-ACKS-C17-04C4...24 84-ACKS-C18-04C5...24 84-ACKS-C19-04C6...24 84-ACKS-C20-04C7...24 84-ADKS-B10-04AA....22 84-ADKS-B11-04AB...22 Part No. 84 Page 01 84-ADKS-B12-04AC...22 84-ADKS-B13-04AD...22 84-ADKS-B14-04AE....22 84-ADKS-B15-04AF....22 84-ADKS-C10-04B0....22 84-ADKS-C11-04B1....22 84-ADKS-C12-04B2....22 84-ADKS-C14-04B3....22 84-ADKS-C16-04B4....22 84-ADKS-C17-04B5....22 84-ADKS-C18-04B6....22 84-ADKS-C19-04B7....22 84-ADKS-C20-04B8....22 84-ASKS-B10-049C....20 84-ASKS-B11-049D....20 84-ASKS-B12-049E....20 84-ASKS-B13-049F....20 84-ASKS-B14-04A0....20 84-ASKS-B15-04A1....20 84-ASKS-C10-04A2....20 84-ASKS-C11-04A3....20 84-ASKS-C12-04A4....20 84-ASKS-C14-04A5....20 84-ASKS-C16-04A6....20 84-ASKS-C17-04A7....20 84-ASKS-C18-04A8....20 84-ASKS-C19-04A9....20 84-ASKS-C20-049B....20 92-800.042..................47 92-851.342..................42 92-960.0......................48 02 03 04 09 14 17 18 19 22 31 41 45 51 56 57 61 70 71 82 84 92 96 09/2023 § eao.com ​ 73 74 ​ eao.com § 09/2023
84-0100.0
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器。
2. 器件简介:该器件是意法半导体生产的高性能微控制器,具有多种通信接口和外设,适用于多种嵌入式应用。
3. 引脚分配:该芯片共有48个引脚,包括电源引脚、地引脚、I/O引脚等,具体分配需参考芯片手册。
4. 参数特性:主频72MHz,内置64KB Flash和20KB RAM,工作电压2.0V-3.6V,工作温度-40℃至+85℃。
5. 功能详解:包括GPIO、ADC、定时器、通信接口(UART、SPI、I2C)等模块的详细介绍。
6. 应用信息:适用于工业控制、医疗设备、智能家居等多种应用场景。
7. 封装信息:采用LQFP48封装,尺寸7x7mm。
84-0100.0 价格&库存
很抱歉,暂时无法提供与“84-0100.0”相匹配的价格&库存,您可以联系我们找货
  • 1+109.097781+14.15890
  • 25+80.2778625+10.41860
  • 50+75.8373250+9.84230
  • 100+71.30972100+9.25470
库存:6
84-0100.0
    • 1+124.73694
    • 10+118.61361
    • 25+114.90628
    • 50+112.50069
    • 100+110.06385
    库存:30
