WLAW105X180Q
WLAW105X180Q
    BANNER(邦纳)
    Module
    AREA WORK LIGHT 105 X 180MM
WLAW105X180Q 数据手册
WLA Series Work Light Datasheet General-purpose LED work light To view or download the latest technical information about this product, including specifications, dimensions, accessories, and wiring, see www.bannerengineering.com. • • • • • • • High power solid state LED array in white and color models Illuminates a large area with an even pattern of light and no shadows Designed for area and machine lighting Rugged thermoplastic housing rated to IP69K Lensed models provide a concentrated, more intense, beam pattern Available in four sizes Cabled and quick-disconnect models available Lensed models shown at left; non-lensed models shown at right Important: Read the following instructions before operating the light. Please download the complete WLA Series Work Light technical documentation, available in multiple languages, from www.bannerengineering.com for details on the proper use, applications, Warnings, and installation instructions of this device. Important: Lea el siguiente instructivo antes de operar el luminario. Por favor descargue desde www.bannerengineering.com toda la documentación técnica de los WLA Series Work Light, disponibles en múltiples idiomas, para detalles del uso adecuado, aplicaciones, advertencias, y las instrucciones de instalación de estos dispositivos. Models Non-Lensed Models1 Lensed Models (xx)1 · 11 = ± 11° lenses · 22 = ± 22° lenses · 30 = ± 30° lenses Housing Length "L1"2 WLAW105X180Q WLAW105X180LxxQ 105 mm WLAW190X180Q WLAW190X180LxxQ 190 mm WLAW275X180Q WLAW275X180LxxQ 275 mm WLAW360X180Q WLAW360X180LxxQ 360 mm Connection3 LED Color Environmental Rating Input Voltage 4-pin M12/Euro-style integral QD connector Cool white IP69K 12 C dc to 30 V dc Family LED Color Array Size (mm) Window Lensing WLA W 105X180 D L11 W = Cool white WW = Warm white R = Red G = Green B = Blue Y = Yellow 105X180 190X180 275X180 360X180 Blank = Clear plastic D = Diffused plastic Blank = No lenses L11 = ±11 degree lenses L22 = ±22 degree lenses L30 = ±30 degree lenses Connector Q Blank = 2 m cable Q = 4-pin M12/Euro-style QD (mating cordset required) 1 Additional color and window options listed in the model key. 2 See Dimensions (p. 3). 3 Integral QD models only are listed. For integral 2 m (6.5' ft PVC cable, omit suffix Q from model number (example, WLAW105X180). A model with a QD requires a mating cordset (see Accessories (p. 4)). Original Document 155425 Rev. F 12 September 2019 155425 WLA Series Work Light Specifications Supply Voltage and Current 12 V dc to 30 V dc (10% maximum ripple) Use only with suitable Class 2 power supply (UL) or SELV power supply (CE). See electrical characteristics on product label Maximum Current per Length Light Length 12 V dc 24 V dc 30 V dc 105 mm 0.8 A 0.4 A 0.32 A Watts 9.6 190 mm 1.6 A 0.8 A 0.64 A 19.2 275 mm 2.4 A 1.2 A 0.96 A 28.8 360 mm 3.2 A 1.6 A 1.28 A 38.4 Lumens and Lux Lumens4 Light Length Cool White 105 mm Warm White 550 Green 435 Red 325 Yellow 125 Blue 275 95 190 mm 1100 870 650 250 550 190 275 mm 1650 1305 975 375 825 285 360 mm 2200 1740 1300 500 1100 380 Non Lensed Models Max Lux4 at 1m Light Length Cool White Warm White Green Red L11 Lensed Models Max Lux4 at 1m Yellow Blue Cool White Warm White Green Red Yellow Blue 105 mm 215 170 115 55 110 30 2865 2290 2910 1375 1795 190 mm 430 340 230 110 220 60 5140 4110 4990 2605 3360 1385 275 mm 645 510 345 165 330 90 7565 6050 6400 3345 4705 1760 360 mm 860 680 460 220 440 120 8875 7100 7405 3730 5605 2030 L22 Lensed Models Max Lux4 at 1m Light Length Cool White Warm White Green Red 815 L30 Lensed Models Max Lux4 at 1m Yellow Blue Cool White Warm White Green Red Yellow Blue 105 mm 1110 880 1125 530 695 315 760 600 770 365 475 215 190 mm 2155 1705 2090 1090 1410 580 1500 1185 1450 760 980 405 275 mm 3160 2500 2675 1400 1965 735 2210 1745 1870 975 1375 515 360 mm 4160 3290 3470 1750 2625 950 2890 2285 2410 1215 1825 660 Light Characteristics Cool White: 5300–7000K Warm White: 2600–4300K Green: 520–535 nm Red: 620–630 nm Yellow: 585–595 nm Blue: 460–475 nm Connections Integral 4-pin M12 male quick disconnect (QD) (4-pin connecting cordset required); or 2 m (6.5 ft) integral cable Construction PBT housing; acrylic window; nickel-plated brass connector or PVC-jacketed cable Mounting When mounting light to combustible or insulating surfaces, a minimum of 1 inch of clearance around all sides is required. Use supplied standoffs or alternative mounting method to achieve spacing. Accessory bracket available. Environmental Rating Rated IEC IP67 and IP69K, per DIN 40050 Operating Temperature –20 °C to +50 °C (–4 °F to +122 °F) Storage Temperature –40 °C to +70 °C (–40 °F to +158 °F) Vibration and Mechanical Shock All models meet Mil. Std. 202F requirements method 201A (vibration: 10 to 60 Hz max., double amplitude 0.06", maximum acceleration 10G). Also meets IEC 947-5-2; 30G 11 ms duration, half sine wave. Certifications Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Note: Do not spray cable with high-pressure sprayer, or cable damage will result. 4 2 Lumen and lux values are typical when operating at 25 °C ambient. Values lowered by 35% on diffused windows models. www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 155425 Rev. F WLA Series Work Light Beam Pattern Perce ntage of Max Light Intensity (Lux %) 100% 75% 50% 25% L22 L11 0% -100 -80 -60 -40 -20 0 20 40 L30 60 Non-Lensed 80 100 Light Pattern from Center (cm) Figure 1. Percentage of Maximum Light Intensity for Lensed and Nonlensed Models at 1 Meter (Typical) Dimensions L2 L1 Model L1 L2 WLAW105X.. 105.1 mm (4.14 in) 92.8 mm (3.66 in) WLAW190X.. 188.9 mm (7.44 in) 176.7 mm (6.96 in) WLAW275X.. 272.7 mm (10.74 in) 260.3 mm (10.25 in) WLAW360X.. 356.6 mm (14.04 in) 344.3 mm (13.55 in) Wiring Female 1 + 12–30 V dc 3 1 Wiring Key: 1 = Brown 3 = Blue 3 Male – 1 3 P/N 155425 Rev. F www.bannerengineering.com - Tel: + 1 888 373 6767 3 WLA Series Work Light Accessories Cordsets 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) MQDC-450 15.2 m (50 ft) MQDC-406RA 1.83 m (6 ft) MQDC-415RA 4.57 m (15 ft) MQDC-430RA 9.14 m (30 ft) Style Dimensions 44 Typ. Straight M12 x 1 ø 14.5 1 4 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC-450RA Pinout (Female) 15.2 m (50 ft) 2 3 1 = Brown 2 = White 3 = Blue 4 = Black M12 x 1 ø 14.5 [0.57"] Brackets SMBBSSM • 316 stainless steel bracket and hardware • Includes 2 brackets; four M5 socket drive, button head screws to attach to light 2X Ø6.8 35 2X Ø5.5 180 SMBBSRA • 316 stainless steel bracket and hardware • Right-angle swivel bracket for versatile orientation 10.75 SMBWLAMAG • Kit includes two magnets, two M5 phillips head screws, and two M5 nuts with lock rings • ø = 51.8 mm (2.04 in) Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. Mexican Importer Banner Engineering de Mèxico, S. de R.L. de C.V. David Alfaro Siqueiros 103 Piso 2 Valle oriente San Pedro Garza Garcia Nuevo Leòn, C. P. 66269 81 8363.2714 © Banner Engineering Corp. All rights reserved
WLAW105X180Q 价格&库存
很抱歉,暂时无法提供与“WLAW105X180Q”相匹配的价格&库存,您可以联系我们找货
