TL50HGYRALSQ
TL50HGYRALSQ
    BANNER(邦纳)
    Module
    堆叠灯 全套装置 绿色,红色,黄色 LED 警报器 连接器
TL50HGYRALSQ 数据手册
TL50H High Brightness Tower Light Datasheet Multi-Color General-Purpose or Audible Indicators • • • • • • • • • Similar in design and construction to standard TL50 Tower Lights, but more than 4 times brighter, improving visibility in areas with high levels of ambient light Rugged, cost-effective, and easy-to-install multi-segment indicators Illuminated segments provide easy-to-see operator guidance and indication of equipment status Displays up to 5 colors Available in black or light gray housing Audible models available with standard, sealed, or omni-directional audible element Compact devices are completely self-contained, no controller needed 18 V dc to 30 V dc or 24 V ac operation No assembly required Non-Audible Models # of LED Colors Model 1 LED Colors 2 Connection3 TL50HRQ 1 Red TL50HGRQ 2 Green, Red TL50HGYRQ 3 Green, Yellow, Red TL50HBGYRQ 4 Blue, Green, Yellow, Red Integral 5-pin M12/Euro-style quick disconnect TL50HWBGYRQ 5 White, Blue, Green, Yellow, Red Integral 8-pin M12/Euro-style quick disconnect Inputs Integral 4-pin M12/Euro-style quick disconnect Bimodal (NPN or PNP) Audible Models Standard Audible Model 1 # of LED Colors LED Colors2 Connection 3 TL50HRAQ 1 Red TL50HGRAQ 2 Green, Red TL50HGYRAQ 3 Green, Yellow, Red Integral 5-pin M12/Euro-style quick disconnect TL50HBGYRAQ 4 Blue, Green, Yellow, Red Integral 8-pin M12/Euro-style quick disconnect Sealed Audible Model 1 Continuous Pulsed at 1.6 Hz Staccato Integral 4-pin M12/Euro-style quick disconnect # of LED Colors LED Colors2 Inputs Integral 4-pin M12/Euro-style quick disconnect Bimodal (NPN or PNP) TL50HRALS3Q TL50HRALS4Q 1 Red TL50HGRALSQ TL50HGRALS3Q TL50HGRALS4Q 2 Green, Red TL50HGYRALSQ TL50HGYRALS3Q TL50HGYRALS4Q 3 Green, Yellow, Red Integral 5-pin M12/Euro-style quick disconnect TL50HBGYRALSQ TL50HBGYRALS3Q TL50HBGYRALS4Q 4 Blue, Green, Yellow, Red Integral 8-pin M12/Euro-style quick disconnect Continuous Pulsed at 1.6 Hz Staccato # of LED Colors LED Colors2 Bimodal (NPN or PNP) Connection 3 TL50HRALSQ Omni-Directional Sealed Audible Model 1 Inputs Connection 3 Inputs Integral 4-pin M12/Euro-style quick disconnect Bimodal (NPN or PNP) TL50HRAOSQ TL50HRAOS3Q TL50HRAOS4Q 1 Red TL50HGRAOSQ TL50HGRAOS3Q TL50HGRAOS4Q 2 Green, Red TL50HGYRAOSQ TL50HGYRAOS3Q TL50HGYRAOS4Q 3 Green, Yellow, Red Integral 5-pin M12/Euro-style quick disconnect TL50HBGYRAOSQ TL50HBGYRAOS3Q TL50HBGYRAOS4Q 4 Blue, Green, Yellow, Red Integral 8-pin M12/Euro-style quick disconnect 1 Models with black housing are listed. For gray housing, add the suffix "C" at the end of the cabled model number or before the "QP" in 150 mm (6 in) PVC cable model numbers. For example, TL50HRC or TL50HRCQ. 2 The first color listed is the bottom color, going up in successive order. 3 • To order the 2 m (6.5 ft) PVC cable model, omit the suffix "Q" in the model number. For example, TL50HR. • To order the 150 mm (6 in) PVC cable model, replace the suffix "Q" with "QP" in the model number. For example, TL50HRQP. • Models with a quick disconnect require a mating cordset. Original Document 152837 Rev. P 6 May 2019 152837 TL50H High Brightness Tower Light Omni-Directional Sealed Audible Model with Intensity Adjustment 1 Continuous Pulsed at 1.6 Hz Staccato # of LED Colors LED Colors2 Connection 3 Inputs Integral 4-pin M12/Euro-style quick disconnect Bimodal (NPN or PNP) TL50HRAOSIQ TL50HRAOS3IQ TL50HRAOS4IQ 1 Red TL50HGRAOSIQ TL50HGRAOS3IQ TL50HGRAOS4IQ 2 Green, Red TL50HGYRAOSIQ TL50HGYRAOS3IQ TL50HGYRAOS4IQ 3 Green, Yellow, Red Integral 5-pin M12/Euro-style quick disconnect TL50HBGYRAOSIQ TL50HBGYRAOS3IQ TL50HBGYRAOS4IQ 4 Blue, Green, Yellow, Red Integral 8-pin M12/Euro-style quick disconnect Wiring Diagram — 4-Pin Models with 1 to 3 Segments NPN Input PNP Input 3 Indicator Color 18-30V dc 24V ac 4 C1 1 C2/A C3/A 3 Indicator Color 18-30V dc 24V ac 4 C1 1 = Brown 2 = White 3 = Blue 4 = Black C1 = Color 1 C2 = Color 2 C3 = Color 3 A = Audible 1 C2/A 2 Key: Pins 1 and 2 can activate the corresponding color or the audible function, if available. 2 C3/A Wiring Diagram — 5-Pin Models with 4 Segments NPN Input PNP Input Key: Indicator Color C1 3 18-30V dc 24V ac 4 Indicator Color 18-30V dc 24V ac 4 C1 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray C1 = Color 1 C2 = Color 2 C3 = Color 3 C4 = Color 4 A = Audible 1 1 C2 C2 2 2 C3 C3 C4/A 3 5 C4/A 5 Wiring Diagram — 8-Pin Models with 5 Segments PNP Input Indicator Color 7 6 C1 2 C2 C3 C4 C5/A 2 NPN Input 1 5 4 18-30V dc 24V ac Indicator Color Key: 7 6 18-30V dc 24V ac C1 2 C2 C3 C4 C5/A 1 5 1 = White 2 = Brown 3 = Green 4 = Yellow 5 = Gray 6 = Pink 7 = Blue 8 = Red C1 = Color 1 C2 = Color 2 C3 = Color 3 C4 = Color 4 C5 = Color 5 A = Audible Pins 3 and 8 are not used. 4 8 8 3 3 www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 152837 Rev. P TL50H High Brightness Tower Light Specifications Supply Voltage and Current 18 V dc to 30 V dc; or 24 V ac (± 3 V) at 50 Hz to 60 Hz Indicators—maximum current per LED color: • 100 mA at 18 V dc • 60 mA at 30 V dc • 75 mA at 24 V ac Standard Audible Alarm: 25 mA maximum current Sealed Audible Alarm: 35 mA maximum current Omni-Directional Sealed Audible Alarm: 45 mA maximum current Supply Protection Circuitry Protected against transient voltages Input Response Time Indicator On/Off: 10 milliseconds maximum Audible Alarm Standard Audible Alarm: 2.7 kHz ± 500 Hz oscillation frequency; maximum intensity 92 dB at 1 m (3.3 ft) (typical) Sealed Audible Alarm: 2.9 kHz ± 250 Hz oscillation frequency; maximum intensity 94 dB at 1 m (3.3 ft) (typical) Omni-Directional Sealed Audible Alarm: 2.1 kHz ± 250 Hz oscillation frequency; maximum intensity 99 dB at 1 m (3.3 ft) (typical) Omni-Directional Sealed Audible Alarm with Intensity Adjustment: 2.1 kHz ± 250 Hz oscillation frequency; maximum intensity 95 dB at 1 m (3.3 ft) (typical) Typical Reduction in Sound Intensity with Audible Adjustment (maximum to minimum) • Standard Audible: 30 dB • Sealed Audible: 20 dB • Omni-Directional Sealed Audible: 12 dB Audible Adjustment Standard Audible Alarm: Unscrew the cover (up to 1.5 turns maximum) to adjust the audible intensity. (Do not exceed 1.5 turns or the cover may detach during operation.) For maximum intensity, rotate the center plug 180° counterclockwise to remove it. Sealed Audible Alarm and Omni-Directional Sealed Audible Alarm with Intensity Adjustment: Rotate the front cover until the desired intensity is reached. Omni-Directional Sealed Audible Alarm: No adjustment. Connections Integral 4-pin, 5-pin, or 8-pin M12/Euro-style quick disconnect, 150 mm (6 in) PVC cable with a M12/Euro-style quick disconnect, or 2 m (6.5 ft) integral PVC cable, depending on model Models with a quick disconnect require a mating cordset Construction Bases and Covers: ABS Light Segment: Polycarbonate Vibration and Mechanical Shock Meets IEC 60068-2-6 requirements (Vibration: 10 Hz to 55 Hz, 1.0 mm amplitude, 5 minutes sweep, 30 minutes dwell) Meets IEC 60068-2-27 requirements (Shock: 30G 11 ms duration, half sine wave) Certifications Indicators LEDs are independently selected; 1 to 5 colors depending on model Indicator Characteristics Color Dominant Wavelength (nm) or Color Temperature (CCT) Lumen Output (Typical at 25 °C) Green 525 nm 60 Red 625 nm 32 Yellow 590 nm 23 Blue 475 nm 23 White 5000 K 50 Operating Conditions Non-Audible: –40 °C to +50 °C (–40 °F to +122 °F) Standard and Sealed Audible: –20 °C to +50 °C (–4 °F to +122 °F) 95% at +50 °C maximum relative humidity (non-condensing) Environmental Rating UL Type 4X Indoor and UL Type 13 Non-Audible and Sealed Audible: IEC IP67 Standard Audible: IEC IP50 Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Dimensions 50.0 [1.97"] Tower Height (H) # of Colors H M30 x 1.5 (mounting nut included) Internal Threads 1/2–14 NPSM Max Torque 2.25 Nm [20in–lbf] Non-Audible Standard Audible* Sealed Audible Omni-Directional Sealed Audible 1 61.2 mm (2.4 in) 92.0 mm (3.6 in) 115.1 mm (4.5 in) 129.1 mm (5.1 in) 2 101.9 mm (4.0 in) 132.7 mm (5.2 in) 155.8 mm (6.1 in) 169.8 mm (6.7 in) 3 142.6 mm (5.6 in) 173.4 mm (6.8 in) 196.5 mm (7.7 in) 210.5 mm (8.3 in) 4 183.3 mm (7.2 in) 214.1 mm (8.4 in) 237.2 mm (9.3 in) 251.2 mm (9.9 in) 5 224.0 mm (8.8 in) - - - * Tower height (H) with top unscrewed approximately 3.5 mm (0.18 in) to allow sound to escape 19.0 [0.75"] 8.3 [0.33"] All measurements are listed in millimeters [inches], unless noted otherwise. P/N 152837 Rev. P www.bannerengineering.com - Tel: + 1 888 373 6767 3 TL50H High Brightness Tower Light Accessories Cordsets 4-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model Length MQDC-406 1.83 m (6 ft) MQDC-415 4.57 m (15 ft) MQDC-430 9.14 m (30 ft) Style Dimensions Pinout (Female) 3 4 Straight MQDC-450 2 1 44 Typ. M12 x 1 ø 14.5 15.2 m (50 ft) 1 = Brown 2 = White 3 = Blue 4 = Black 5-Pin Threaded M12/Euro-Style Cordsets—Single Ended Model MQDC1-501.5 Length Style 0.50 m (1.5 ft) MQDC1-506 1.83 m (6 ft) MQDC1-515 4.57 m (15 ft) MQDC1-530 9.14 m (30 ft) MQDC1-506RA 1.83 m (6 ft) MQDC1-515RA 4.57 m (15 ft) Dimensions 44 Typ. Straight M12 x 1 ø 14.5 2 1 3 4 32 Typ. [1.26"] 5 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray 30 Typ. [1.18"] Right-Angle MQDC1-530RA Pinout (Female) 9.14 m (30 ft) M12 x 1 ø 14.5 [0.57"] 8-Pin Threaded M12/Euro-Style Cordsets with Open-Shield Model Length MQDC2S-806 1.83 m (6 ft) MQDC2S-815 4.57 m (15 ft) MQDC2S-830 9.14 m (30 ft) Style Dimensions Pinout (Female) 44 Typ. 2 Straight MQDC2S-850 15.2 m (50 ft) MQDC2S-806RA 1.83 m (6 ft) MQDC2S-815RA 4.57 m (15 ft) MQDC2S-830RA 9.14 m (30 ft) M12 x 1 ø 14.5 32 Typ. [1.26"] 30 Typ. [1.18"] Right-Angle MQDC2S-850RA 15.2 m (50 ft) M12 x 1 ø 14.5 [0.57"] 4 www.bannerengineering.com - Tel: + 1 888 373 6767 1 7 6 3 4 8 5 1 = White 2 = Brown 3 = Green 4 = Yellow 5 = Gray 6 = Pink 7 = Blue 8 = Red P/N 152837 Rev. P TL50H High Brightness Tower Light Mounting Brackets All measurements are listed in millimeters [inches], unless noted otherwise. SMB30A • Right-angle bracket with curved slot for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor • 12-ga. stainless steel SMB30FA • Swivel bracket with tilt and pan movement for precise adjustment • Mounting hole for 30 mm sensor • 12-ga. 304 stainless steel • Easy sensor mounting to extrude rail T-slot • Metric and inch size bolt available 45 C 61 B A 83.2 36.3 68.9 B A 69 Hole center spacing: A to B=40 Hole size: A=ø 6.3, B= 27.1 x 6.3, C=ø 30.5 SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor Bolt thread: SMB30FA, A= 3/8 - 16 x 2 in; SMB30FAM10, A= M10 - 1.5 x 50 Hole size: B= ø 30.1 SMBAMS30P • Flat SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. 300 series stainless steel 57 70 C 57 45 C A 93 B B A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 SMBAMS30RA • Right-angle SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. (2.6 mm) cold-rolled steel Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included 45 C 53 A B 67 B 58 48 29 Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 LMBE12RA35 • Direct mounting of stand-off pipe, with common bracket type • Zinc-plated steel • 1/2-14 NPSM nut • Mounting distance from the wall to the center of the 1/2-14 NPSM nut is 35 mm Hole center spacing: 20.0 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 55 35 1/2 - 14 NPSM NUT LMBE12RA45 • Direct mounting of stand-off pipe, with common bracket type • Zinc-plated steel • 1/2-14 NPSM nut • Mounting distance from the wall to the center of the 1/2-14 NPSM nut is 45 mm 38.25 57 Hole center spacing: 35.0 2X Ø9 65 45 1/2 - 14 NPSM NUT 38.25 81 2X Ø11 LMB Sealed Right-Angle Bracket Model Description Construction LMB30RA LMB30RAC LMBE12RA LMBE12RAC P/N 152837 Rev. P Black polycarbonate Direct-Mount Models: Bracket kit with base, 30 mm adapter, set screw, fasteners, O-rings, and gaskets. Gray polycarbonate Black polycarbonate Pipe-Mount Models: Bracket kit with base, ½-14 pipe adapter, set screw, fasteners, O-rings, and gaskets. For use with Gray polycarbonate stand-off pipe (listed and sold separately). www.bannerengineering.com - Tel: + 1 888 373 6767 5 TL50H High Brightness Tower Light Elevated Mount System Model Features SA-M30TE12 - Black Acetal • • SA-M30TE12C - White UHMW • Polished 304 Stainless Steel Black Anodized Aluminum Clear Anodized Aluminum SOP-E12-150SS 150 mm (6 in) long SOP-E12-150A 150 mm (6 in) long SOP-E12-150AC 150 mm (6 in) long SOP-E12-300SS 300 mm (12 in) long SOP-E12-300A 300 mm (12 in) long SOP-E12-300AC 300 mm (12 in) long SOP-E12-900SS 900 mm (36 in) long SOP-E12-900A 900 mm (36 in) long SOP-E12-900AC 900 mm (36 in) long SA-E12M30 - Black Acetal • • • • • • SA-E12M30C - White UHMW • Components Streamlined black acetal or white UHMW stand-off pipe adapter/cover Connects between 30 mm light base and ½ in. NPSM/DN15 pipe Mounting hardware included Elevated-use stand-off pipe (½ in. NPSM/DN15) Polished 304 stainless steel, black anodized aluminum, or clear anodized aluminum surface ½ in. NPT thread at both ends Compatible with most industrial environments Streamlined black acetal or white UHMW mounting base adapter/cover Connects between ½ in. NPSM/DN15 pipe and 30 mm (1-3/16 in) drilled hole Mounting hardware included Pipe Mounting Flange Pipe Mounting Flange Model Features • SA-F12 • • SA-F12-3 • Construction Elevated-use stand-off pipes (½ in, NPSM/ DN15) M5 mounting hardware and nitrile gasket included Die-cast zinc base with black paint Elevated-use stand-off pipes (½ in, NPSM/ DN15) Black Polycarbonate M4 mounting hardware and nitrile blend gasket included 1/2-14 NPSM 4x ø5.5 10 ø70 54 ø28 ø40 1/2-14 NPSM 2 x 120° 29 8.77 ø60 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
TL50HGYRALSQ 价格&库存
很抱歉,暂时无法提供与“TL50HGYRALSQ”相匹配的价格&库存,您可以联系我们找货
