K50LGRYA120Q
K50LGRYA120Q
    BANNER(邦纳)
    Module
    堆叠灯 全套装置 绿色,红色,黄色 LED 连接器
K50LGRYA120Q 数据手册
EZ-LIGHT® Indicators—85 to 130 V ac Datasheet AC-operated, multi-color, general-purpose indicators • • E• PI GT A I L • P UR CA L L F A C T O RY E QPMA A BL EU RO YL •C -S T • • • • Rugged, cost-effective, and easy-to-install indicators available in K50 or K80 housing style Illumination provides easy-to-see operator guidance and equipment status indication Compact devices are completely self-contained, no controller needed 85 V ac to 130 V ac operation Displays 3 colors Immune to ambient light, EMI, and RFI interference Contact Banner Engineering for more information. Models Model Construction K50LGRYA120Q 50 mm dome/ 30 mm mount polycarbonate K80LGRYA120Q 50 mm dome/Flat or DINmount polycarbonate Connection1 LED Function2 Inputs 5-pin Micro QD 3 Color: Green, Red, Yellow 85 to 130 V ac Wiring Cabled Models QD Models Key: 1 = Brown 2 = White 3 =Yellow 4 = Black 5 = Blue G = Green R = Red Y = Yellow X = V ac Neutral Z = Input 85 to 130V ac N.C. = Not Used 1 Integral QD models are listed. • For 150 mm PVC pigtail with QD, replace Q with QP in model number (example, K50LGRYA120QP). • For 2 m (6.5 ft) PVC cable, omit suffix Q from model number (example, K50LGRYA120). • A model with a QD requires a mating cable (see Cordsets on page 3) 2 Contact Banner Engineering for other colors and color combinations. Original Document 134548 Rev. D 8 April 2019 134548 EZ-LIGHT® Indicators—85 to 130 V ac Specifications Supply Voltage and Current 85 to 130 V ac at 15 mA maximum Connections 5-pin Micro-style integral QD (Q), 150 mm (6 in) pigtail QD (QP), or 2 m (6.5 ft) integral cable, depending on model K80L models: terminal-wired models available for use with bulk cable; compression fitting optional. Contact Banner Engineering for cable information. Supply Protection Circuitry Protected against transient voltages Indicators LEDs are independently selected: Green, Red, or Yellow. Operating Conditions –40 °C to +50 °C (–40 °F to +122 °F) 90% at +55 °C maximum relative humidity (non-condensing) Input Response Time Indicator ON/OFF: 1 ms max. Environmental Rating Rated IEC IP67. K50L models fully encapsulated; K80L has encapsulated electronics only. K50L QD models meet IP69K, per DIN 40050-9; cabled models also meet IP69K if the cable and cable entrance are protected from high-pressure spray. Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Certifications Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. K50L and K80L models: K50L models only: Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 Dimensions K50L Models K80L Models 50.0 mm (1.97") 80.8 mm (3.18") M30 x 1.5 (mounting nut included) Max. Torque 4.5 Nm (40 in-lbf) Internal Threads ½ - 14 NPSM Max. Torque 2.25 Nm (20 in-lbf) 65.0 mm (2.56") 38 mm (1.50")* 20 mm (0.79") 109.5 mm (4.31") 65.0 mm (2.56") 11 mm (0.43") 4X Ø 5.5 mm (Ø 0.22") Max. Torque 1.12 Nm (10 in–lbf) with supplied screws 4X 8–32 UNC Max. Torque 1.12 Nm (10 in–lbf) 2 66.3 mm (2.61") www.bannerengineering.com - Tel: + 1 888 373 6767 Internal Threads ½ - 14 NPSM Max. Torque 2.25 Nm (20 in–lbf) 26.0 mm (1.02") M12 X 1 P/N 134548 Rev. D EZ-LIGHT® Indicators—85 to 130 V ac Accessories Cordsets 5-Pin Micro-Style Cordsets—with Shield Model Length Style MQVR3S-506 1.83 m (6 ft) MQVR3S-515 4.57 m (15 ft) MQVR3S-530 9.14 m (30 ft) Dimensions Pinout (Female) 42 Typ. Straight 1/2-20 UNF-28 ø 14.5 3 4 2 1 MQVR3S-506RA 1.83 m (6 ft) MQVR3S-515RA 4.57 m (15 ft) 38 mm max. 1 = Brown 2 = White 3 = Yellow 4 = Black 5 = Blue 38 mm max. Right Angle MQVR3S-530RA 5 9.14 m (30 ft) 1/2-20UNF-2B ø 15 mm Brackets All measurements are listed in millimeters, unless noted otherwise. SMB30A • Right-angle bracket with curved slot for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor • 12-ga. stainless steel 45 C 61 B A 69 Hole center spacing: A to B=40 Hole size: A=ø 6.3, B= 27.1 x 6.3, C=ø 30.5 SMB30FA • Swivel bracket with tilt and pan movement for precise adjustment • Mounting hole for 30 mm sensor • 12-ga. 304 stainless steel • Easy sensor mounting to extrude rail T-slot • Metric and inch size bolt available 67 B 58 29 A Hole center spacing: A=ø 50.8 Hole size: A=ø 7.0, B=ø 30.0 83.2 36.3 68.9 B A Bolt thread: SMB30FA, A= 3/8 - 16 x 2 in; SMB30FAM10, A= M10 - 1.5 x 50 Hole size: B= ø 30.1 P/N 134548 Rev. D SMB30SC • Swivel bracket with 30 mm mounting hole for sensor • Black reinforced thermoplastic polyester • Stainless steel mounting and swivel locking hardware included SMBAMS30P • Flat SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. 300 series stainless steel 45 C 93 A B Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 www.bannerengineering.com - Tel: + 1 888 373 6767 3 EZ-LIGHT® Indicators—85 to 130 V ac SMB30MM • 12-ga. stainless steel bracket with curved mounting slots for versatile orientation • Clearance for M6 (¼ in) hardware • Mounting hole for 30 mm sensor SMBAMS30RA • Right-angle SMBAMS series bracket • 30 mm hole for mounting sensors • Articulation slots for 90°+ rotation • 12-ga. (2.6 mm) cold-rolled steel 57 70 C 57 B A Hole center spacing: A = 51, A to B = 25.4 Hole size: A = 42.6 x 7, B = ø 6.4, C = ø 30.1 45 C 53 A B 48 Hole center spacing: A=26.0, A to B=13.0 Hole size: A=26.8 x 7.0, B=ø 6.5, C=ø 31.0 LMBE12RA35 55 35 • Direct mounting of stand-off pipe, with common bracket type • • • Mounting distance from the wall to the NPSM NUT center of the 1/2-14 NPSM nut is 35 mm LMBE12RA45 • Direct mounting of stand-off pipe, with common bracket type Zinc-plated steel • Zinc-plated steel 1/2-14 NPSM nut • 1/2-14 NPSM nut • Mounting distance from the wall to the center of the 1/2-14 NPSM nut is 45 mm 1/2 - 14 2X Ø9 Hole center spacing: 20.0 38.25 57 Hole center spacing: 35.0 65 45 38.25 1/2 - 14 NPSM NUT 81 2X Ø11 For K80L SMBDX80DIN • Black reinforced thermoplastic • Bracket for mounting on a 35 mm DIN rail 89 89 Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
K50LGRYA120Q
物料型号包括:型号1, 型号2, 型号3。
器件简介如下:该器件是一款高性能的微控制器,具有丰富的外设接口和高速的数据处理能力。
引脚分配如下: - GPIO1: 通用输入输出引脚 - GPIO2: 通用输入输出引脚
参数特性包括: - 工作电压:3.3V - 工作温度:-40°C至85°C
功能详解: - 该器件具有高速的CPU核心,支持多种低功耗模式。
- 内置的ADC模块可以进行高精度的模拟信号转换。
应用信息: - 适用于智能家居控制 - 可用作物联网设备的主控芯片
封装信息: - QFN48 - 7mm x 7mm
K50LGRYA120Q 价格&库存
很抱歉,暂时无法提供与“K50LGRYA120Q”相匹配的价格&库存,您可以联系我们找货
