K30LGRYPQ
K30LGRYPQ
    BANNER(邦纳)
    Module
    堆叠灯 全套装置 绿色,红色,黄色 LED 导线引线
K30LGRYPQ 数据手册
EZ-LIGHT™ 2- or 3-Color General-Purpose Indicators Datasheet To view or download the latest technical information about this product, including specifications, dimensions, accessories, and wiring, go to www.bannerengineering.com. WARNING: • Do not use this device for personnel protection • Using this device for personnel protection could result in serious injury or death. • This device does not include the self-checking redundant circuitry necessary to allow its use in personnel safety applications. A device failure or malfunction can cause either an energized (on) or de-energized (off) output condition. Models LED Colors — 2 or 3 Lights, Independently Selected Models 1 Construction 2 1 2 PNP Input NPN Input Color 1 Color 2 T8LGRXPQP T8LGRXNQP Green Red Color 3 — T8LGXYPQP T8LGXYNQP Green — Yellow T8LXRYPQP T8LXRYNQP — Red Yellow M18GRXPQ M18GRXNQ Green Red — M18GXYPQ M18GXYNQ Green — Yellow M18XRYPQ M18XRYNQ — Red Yellow Yellow M18GRYPQ M18GRYNQ Green Red K30LGRXPQ K30LGRXNQ Green Red — K30LGXYPQ K30LGXYNQ Green — Yellow K30LXRYPQ K30LXRYNQ — Red Yellow K30LGRYPQ K30LGRYNQ Green Red Yellow K50LGRXPQ K50LGRXNQ Green Red — K50LGXYPQ K50LGXYNQ Green — Yellow K50LXRYPQ K50LXRYNQ — Red Yellow K50LGRYPQ K50LGRYNQ Green Red Yellow K50FLGRXPQ K50FLGRXNQ Green Red — K50FLGXYPQ K50FLGXYNQ Green — Yellow K50FLXRYPQ K50FLXRYNQ — Red Yellow K50FLGRYPQ K50FLGRYNQ Green Red Yellow K80LGRXPQ K80LGRXNQ Green Red — K80LGXYPQ K80LGXYNQ Green — Yellow K80LXRYPQ K80LXRYNQ — Red Yellow K80LGRYPQ K80LGRYNQ Green Red Yellow Polycarbonate/ABS alloy housing, thermoplastic diffuser IP67 Nickel-plated brass housing, thermoplastic diffuser Fully encapsulated IP67 22 mm threaded polycarbonate base, translucent polycarbonate dome Fully encapsulated IP67, IP69K per DIN 40050-9 30 mm polycarbonate base, translucent polycarbonate dome Fully encapsulated IP67, IP69K per DIN 40050-9 ABS base, translucent polycarbonate dome Fully encapsulated IP67, IP69K per DIN 40050-9 Polycarbonate base, translucent polycarbonate dome Electronics fully encapsulated IP67 • T8L Models: Standard 150 mm (6 in) PVC-jacketed cable with 4-pin M12 quick-disconnect connector models are listed. For integral 4-wire cabled model, omit suffix QP. For example, T8LGRXP. • K30L Models: Standard integral 4-pin M12 quick-disconnect connector models are listed. For 2 m (6.5 ft) integral 4-wire cabled model, omit suffix Q. For example, K30LGRXP. For 150 mm (6 in) PVC-jacketed cable with 4-pin M12 quick-disconnect connector, replace suffix Q with QP. For example, K30LGRXPQP. For terminal model, replace suffix Q with T. For example, K30LGRXPT. • K80L Models: Standard integral 4-pin M12 quick-disconnect connector models are listed. For terminal-wired model, omit suffix Q. For example, K80LGRXP. • Other Models: Standard integral 4-pin M12 quick-disconnect connector models are listed. For 2 m (6.5 ft) integral 4-wire cabled model, omit suffix Q. For example, M18GRXP. For 150 mm (6 in) PVC-jacketed cable with 4-pin M12 quick-disconnect connector, replace suffix Q with QP. For example, M18GRXPQP. • Models with a quick disconnect require a mating cordset. Contact Banner Engineering for other colors and color combinations. Original Document 121899 Rev. L 29 July 2022 121899 EZ-LIGHT™ 2- or 3-Color General-Purpose Indicators The following models are no longer available for order, but are still covered by the information in this document. LED Colors — 2 or 3 Lights, Independently Selected Models 1 Construction 2 PNP Input NPN Input Color 1 Color 2 T18GRXPQ T18GRXNQ Green Red Color 3 — T18GXYPQ T18GXYNQ Green — Yellow T18XRYPQ T18XRYNQ — Red Yellow T18GRYPQ T18GRYNQ Green Red Yellow T30GRXPQ T30GRXNQ Green Red — T30GXYPQ T30GXYNQ Green — Yellow T30XRYPQ T30XRYNQ — Red Yellow T30GRYPQ 3 T30GRYNQ Green Red Yellow T30GRBPQ — Green Red Blue T30GROPQ — Green Red Orange — T30RGR5PNQ Red Green Red T30RGXPQ — Red Green — Thermoplastic polyester housing, thermoplastic diffuser Fully encapsulated IP67 Thermoplastic polyester housing, thermoplastic diffuser Fully encapsulated IP67 Wiring Diagrams Multi Color Wiring NPN PNP 1 C1 C2 C3 4 3 2 3 + _ 4 C1 C2 C3 1 _ + 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Gray C1 = Color 1 C2 = Color 2 C3 = Color 3 Gray Wire not used in K30 Terminal models 2 Single Color Wiring NPN PNP Specifications Supply Voltage and Current T8L models: 10 V DC to 30 V DC at 20 mA maximum T18, M18, and K30L models: 10 V DC to 30 V DC at 25 mA maximum per LED color T30 models: 10 V DC to 30 V DC at 40 mA maximum per LED color K50L, K50FL, and K80L models: 18 V DC to 30 V DC at 40 mA maximum per LED color Indicators Entire translucent diffuser or dome provides indication. Green and yellow, when connected to discrete output of 3-wire or 4-wire sensors. For other colors, contact factory for availability. Input Response Time Indicator ON/OFF: 1 ms max. 3 2 Connections T8L models: 150 mm (6 in) PVC-jacketed cable with a 4-pin M12 male quickdisconnect connector (QP) or 2 m (6.5 ft) unterminated 4-wire integral cable, depending on model K30L models: Integral 4-pin M12 male quick-disconnect connector (Q), 150 mm (6 in) PVC-jacketed cable with a 4-pin M12 male quick-disconnect connector (QP), 2 m (6.5 ft) unterminated 4-wire integral cable, or 5 color-coded screw terminal for up to 16 AWG wire, depending on model. Screw terminal max torque: 0.11 N·m (1.0 lbf·in). K80L models: Integral 4-pin M12 male quick-disconnect connector (Q) standard; terminal-wired models available for use with bulk cable; compression fitting optional. Contact Factory for cable information. Other models: Integral 4-pin M12 male quick-disconnect connector (Q), 150 mm (6 in) PVC-jacketed cable with a 4-pin M12 male quick-disconnect connector (QP), or 2 m (6.5 ft) unterminated 4-wire integral cable, depending on model Construction See Models lists Standard integral 4-pin M12 quick-disconnect connector models are listed. To order the 9 m (30 ft) PVC cable model, replace the suffix "Q" with "W/30" in the model number. For example, T30GRYP W/30. To order the 150 mm (6 in) PUR cable model with a M12 quick disconnect, replace the suffix "Q" with "QPMA" in the model number. For example, T30GRYPQPMA. www.bannerengineering.com - Tel: + 1 888 373 6767 P/N 121899 Rev. L EZ-LIGHT™ 2- or 3-Color General-Purpose Indicators Environmental Rating Rated IP67. T8L not encapsulated; K80L has encapsulated electronics only; other models fully encapsulated. K30L, K50L, and K50FL QD models meet IP69K per DIN 40050-9. Cabled models also meet IP69K if the cable and cable entrance are protected from high-pressure spray. Operating Conditions Temperature: –40 °C to +50 °C (–40 °F to +122 °F) Certifications All models: Required Overcurrent Protection WARNING: Electrical connections must be made by qualified personnel in accordance with local and national electrical codes and regulations. Overcurrent protection is required to be provided by end product application per the supplied table. Overcurrent protection may be provided with external fusing or via Current Limiting, Class 2 Power Supply. Supply wiring leads < 24 AWG shall not be spliced. For additional product support, go to www.bannerengineering.com. Banner Engineering Europe Park Lane, Culliganlaan 2F bus 3, 1831 Diegem, BELGIUM Supply Wiring (AWG) Required Overcurrent Protection (Amps) 20 5.0 22 3.0 24 2.0 26 1.0 28 0.8 30 0.5 K50L, K50FL, T18, and T30 models only: Turck Banner LTD Blenheim House, Blenheim Court, Wickford, Essex SS11 8YT, Great Britain K30L and K50L models only: Dimensions T8L Models T18 Models M18 Models 15. 8 mm (0.62") 8.8 mm (0.35") 19.1 mm (0.75") M8 X 1 ø16.3 mm (0.64") Ø16.5 mm (0.65") 53.6 mm (2.11") M18 x 1 Thread 61 mm (2.4") 30 mm (1.2") 33.0 mm (1.3") Ø 15 mm (0.59") M12 X 1 150 mm (6") PVC cable with M12 quick-disconnect connector M18 X 1 M12 X 1 T30 Models K30L Models Ø 40.0 mm (1.57") 23 mm (0.9") K30 Terminal Models 30.0 mm (1.18") 63.7 mm (2.51") M30 x 1.5 Thread 58.0 mm (2.28") 42 [1.65] 52.4 [2.06] 120037 M12 X 1 Ø 15 mm (0.59") P/N 121899 Rev. L 45.0 mm (1.77") 31.0 mm (1.22") 16.0 mm (0.63") M22 X 1.5 -6g M22 X 1.5 Max. Torque 2.25 Nm (20 in-lbf) M12 X 1 www.bannerengineering.com - Tel: + 1 888 373 6767 3 EZ-LIGHT™ 2- or 3-Color General-Purpose Indicators K50L Models K50FL Models K80L Models 44.6 [1.76"] 50.0 mm (1.97") 80.8 mm (3.18") Ø50 [1.97"] 35.0 [1.38"] 20 mm (0.79") 65.0 mm (2.56") 2x 5.5 [0.21"] 11 mm (0.43") Internal Threads ½ - 14 NPSM Max. Torque 2.25 Nm (20 in–lbf) 17.0 [0.67"] 4X Ø 5.5 mm (Ø 0.22") Max. Torque 1.12 Nm (10 in–lbf) with supplied screws 2x 5.0 [0.20"] 40.0 [1.58"] 26.0 mm (1.02") 4X 8–32 UNC Max. Torque 1.12 Nm (10 in–lbf) M12 X 1 Accessories Cordsets 4-Pin Threaded M12 Cordsets—Single Ended Model Length MQDC-406 2 m (6.56 ft) MQDC-415 5 m (16.4 ft) MQDC-430 9 m (29.5 ft) MQDC-450 15 m (49.2 ft) MQDC-406RA 2 m (6.56 ft) MQDC-415RA 5 m (16.4 ft) MQDC-430RA 9 m (29.5 ft) Style Dimensions Pinout (Female) 44 Typ. 2 1 Straight M12 x 1 ø 14.5 32 Typ. [1.26"] 3 5 4 2 30 Typ. [1.18"] Right-Angle MQDC-450RA 109.5 mm (4.31") 2x 5.0 [0.20"] 16.0 [0.63"] Internal Threads ½ - 14 NPSM Max. Torque 2.25 Nm (20 in-lbf) 66.3 mm (2.61") 60.0 [2.36"] 38 mm (1.50")* M30 x 1.5 (mounting nut included) Max. Torque 4.5 Nm (40 in-lbf) 65.0 mm (2.56") 1 3 1 = Brown 2 = White 3 = Blue 4 = Black 5 = Unused 4 15 m (49.2 ft) M12 x 1 ø 14.5 [0.57"] Banner Engineering Corp. Limited Warranty Banner Engineering Corp. warrants its products to be free from defects in material and workmanship for one year following the date of shipment. Banner Engineering Corp. will repair or replace, free of charge, any product of its manufacture which, at the time it is returned to the factory, is found to have been defective during the warranty period. This warranty does not cover damage or liability for misuse, abuse, or the improper application or installation of the Banner product. THIS LIMITED WARRANTY IS EXCLUSIVE AND IN LIEU OF ALL OTHER WARRANTIES WHETHER EXPRESS OR IMPLIED (INCLUDING, WITHOUT LIMITATION, ANY WARRANTY OF MERCHANTABILITY OR FITNESS FOR A PARTICULAR PURPOSE), AND WHETHER ARISING UNDER COURSE OF PERFORMANCE, COURSE OF DEALING OR TRADE USAGE. This Warranty is exclusive and limited to repair or, at the discretion of Banner Engineering Corp., replacement. IN NO EVENT SHALL BANNER ENGINEERING CORP. BE LIABLE TO BUYER OR ANY OTHER PERSON OR ENTITY FOR ANY EXTRA COSTS, EXPENSES, LOSSES, LOSS OF PROFITS, OR ANY INCIDENTAL, CONSEQUENTIAL OR SPECIAL DAMAGES RESULTING FROM ANY PRODUCT DEFECT OR FROM THE USE OR INABILITY TO USE THE PRODUCT, WHETHER ARISING IN CONTRACT OR WARRANTY, STATUTE, TORT, STRICT LIABILITY, NEGLIGENCE, OR OTHERWISE. Banner Engineering Corp. reserves the right to change, modify or improve the design of the product without assuming any obligations or liabilities relating to any product previously manufactured by Banner Engineering Corp. Any misuse, abuse, or improper application or installation of this product or use of the product for personal protection applications when the product is identified as not intended for such purposes will void the product warranty. Any modifications to this product without prior express approval by Banner Engineering Corp will void the product warranties. All specifications published in this document are subject to change; Banner reserves the right to modify product specifications or update documentation at any time. Specifications and product information in English supersede that which is provided in any other language. For the most recent version of any documentation, refer to: www.bannerengineering.com. For patent information, see www.bannerengineering.com/patents. © Banner Engineering Corp. All rights reserved
K30LGRYPQ 价格&库存
很抱歉,暂时无法提供与“K30LGRYPQ”相匹配的价格&库存,您可以联系我们找货
