MC485232
MC485232
    CARLOGAVAZZI
    Module
    选件卡,通信
MC485232 数据手册
WM30 Power analyzer for three-phase systems Benefits Description WM30 is a modular power analyzer for single-, two- and three-phase systems. It is made up of a maximum of four components: the main unit that displays measurements on the LCD display and manages 4 alarms, and three accessory modules, one with digital outputs, one with analogue outputs and the other for communication. The digital output module associates alarms with static or relay outputs and/or transmits pulses proportional to energy consumption. The analogue output module associates 0-20 mA or 0-10 V outputs to measured variables. The communication module allows you configure the analyzer and transmit data using a different communication protocol according to the version. • Clarity. The wide backlit LCD display clearly shows the measurements and the configuration parameter values. • Simplicity. An optical port is available for quick analyzer configuration using OptoProg (CARLO GAVAZZI). • Specific software. WM30 can be configured and measurements viewed from UCS configuration software (CARLO GAVAZZI). The software and subsequent updates are free. • Scalability. Three accessory modules can be added to WM30 according to need. This way, the analyzer extends its control capacities and communicates data remotely. • Communication flexibility. The communication module is available in Modbus RTU, Modbus TCP/IP, BACnet IP, BACnet MS/TP and Profibus DP V0 versions. • Fast installation. WM30 and accessory modules are all equipped with detachable terminals. Modules can be quickly installed via the specifically designed fast coupling pins. • Tamper-proof. WM30 configuration access can be locked. Terminals and accessory modules can be sealed. Main functions • • • • • • • Measure main electrical variables and voltage and current harmonic distortions Measure active and reactive energy Measure load operating hours Manage up to 4 alarms Manage two digital outputs (via optional accessory module) Manage two analogue outputs (via optional accessory module) Transmit data to other systems (via optional accessory module) 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 1 WM30 Applications WM30 can be installed in any switchboard to control energy consumption, main electrical variables and harmonic distortion. In automation, WM30can use the communication module with Profibus protocol to both communicate data on consumption to supervision systems and manage them independently if installed on a machine. In building, WM30can be installed in existent architectures using the communication module with BACnet protocol (on RS485 or Ethernet). Components Module Description WM30 Main unit, measures and displays main electrical variables. With LCD display and touch keypad, it lets you set measurement parameters, configure accessory modules and manage up to 4 alarms. Digital outputs (optional) Accessory module with two digital outputs. Expands main unit capacity, specifically allowing you to: transmit pulses proportional to energy consumption control digital outputs (static or relay according to the module) Analogue outputs (optional) Accessory module with two analogue outputs. Expands main unit capacity, specifically allowing you to associate a 0-20mA or 0-10V output to a measured variable Communication (optional) Accessory module that lets you transmit data to other systems or configure the analyzer from remote Compatible accessory modules Type Digital outputs Analogue outputs Communication 28/04/2022 WM30 DS ENG Module description Code Double static output M O O2 Double relay output M O R2 Double analogue output (+20mA dc) M O A2 Double analogue output (+10V dc) M O V2 Modbus RTU communication on RS485/RS232 M C 485232 Modbus TCP/IP communication on Ethernet M C ETH BACnet IP communication on Ethernet M C BAC IP BACnet MS/TP communication on RS485 M C BAC MS Profibus DP V0 communication on RS485 M C PB CARLO GAVAZZI Controls SpA 2 WM30 Possible configurations WM30only WM30+ 1 module WM30+ 2 modules WM30+ 3 modules NOTICE: maximum 1 module per type. In the configuration with 2 or 3 modules, the communication module is installed last. 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 3 WM30 Features General features Material Front: ABS, self-extinguishing V-0 (UL 94) Back and accessory modules: PA66, self-extinguishing V-0 (UL 94) Protection degree Front: IP65 NEMA 4x NEMA 12 Terminals: IP20 Type: detachable Section: 2.5 mm2 maximum Terminals Torque: 0.5 Nm Overvoltage category Cat. III Pollution degree 2 Noise rejection (CMRR) 100 dB, from 42 to 62 Hz Double electrical insulation on areas accessible to the user. For insulation between inputs and outputs, see "Input and output insulation" below. Insulation Input and output insulation Note: test conditions: 4 kV rms ac for one minute. Type Power supply (H or Measurement inputs L) [kV] [kV] Digital outputs [kV] Serial port [kV] Ethernet port [kV] Power supply (H or L) - 4 4 4 4 Measurement inputs 4 - 4 4 4 Digital outputs 4 4 - 4 4 Serial port 4 4 4 - NP Ethernet port 4 4 4 NP - Key • NP: combination not possible • 4: 4 kV rms insulation (EN 61010-1, IEC 60664-1, overvoltage category III, pollution degree 2, double insulation on system with maximum 300 V rms to ground) Environmental specifications Operating temperature From -25 to +55 °C/from -13 to +131 °F Storage temperature From -30 to +70 °C/from -22 to 158 °F Note: R.H. < 90 % non-condensing @ 40 °C / 104 °F. 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 4 WM30 Conformity Directives 2014/35/EU (LVT - Low Voltage) 2014/30/EU (Electromagnetic Compatibility) 2011/65/EU, 2015/863/EU (Electric-electronic equipment hazardous substances) Standards Electromagnetic compatibility (EMC) - emissions and immunity: EN61000-6-3, EN61000-6-2 Electrical safety: EN 61010-1 Metrology: EN62053-22, EN62053-23 Pulse output: IEC 62053-31, DIN 43864 Approvals 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 5 Main unit Main features Description Main unit with LCD display and touch keypad to view measurements, configure the system and manage 4 alarms. It can be integrated by digital output, analogue output and communication modules. Four versions are available (AV4, AV5, AV6 and AV7) to manage different current and voltage inputs. It can be quickly configured with OptoProg via optical port. 28/04/2022 WM30 DS ENG • System and phase variables (4 x 3 digits): V L-L, V L-N, A, W/var/VA, PF, Hz • Active and reactive imported and exported energy meters (10 digits) • Calculate the average and maximum system and phase values of all the electrical variables • Calculate current and voltage THD (total harmonic distortions) up to the 32nd harmonic • Calculate load operating hours • Auxiliary power supply • 4 virtual alarms • Backlit LCD display and touch keypad • Optical port • Detachable terminals • Sealable terminal caps • Configuration via keypad or UCS configuration software (desktop or mobile Android App) • Filter to stabilize displayed measurements Main functions • Measure main electrical variables and harmonic voltage and current distortions • Measure active and reactive energy • Measure load operating hours • Manage up to 4 alarms CARLO GAVAZZI Controls SpA 6 Main unit Structure Fig. 1 Front Element Description A Optical port and plastic support for OptoProg (CARLO GAVAZZI) connection B Backlit LCD display C LED that blinks with frequency proportional to active energy consumption, see "LED" on page 14 D Touch keypad 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 7 Main unit A C D E F B Fig. 2 Back Element Description A Detachable power supply terminals B Detachable current input terminals C Detachable voltage input terminals D Rotary selector to lock configuration E Local bus port for accessory modules F Power supply status LED, see "LED" on page 14 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 8 Main unit Features Panel mounting Weight 420 g (packaging included) 96 89,97 Assembly 96 22,2 93 General features 27,9 Electrical specifications Electrical system Single-phase (2-wire) Managed electrical sys- Two-phase (3-wire) tem Three-phase with neutral (4-wire) Three-phase without neutral (3-wire) Voltage inputs Inputs AV4 AV5 Voltage connection 28/04/2022 WM30 DS ENG AV7 Direct or via VT/PT VT/PT transformation ratio Rated voltage L-N (from Un min to Un max) AV6 From 1 to 9999 From 220 to 400 V From 57.7 to 133 V CARLO GAVAZZI Controls SpA 9 Main unit Voltage inputs Rated voltage L-L (from Un min to Un max) From 380 to 690 V* From 100 to 230 V Voltage tolerance -20%, + 15% Continuous: 1.2 Un max For 500 ms: 2 Un max Overload Input impedance >1.6 MΩ Frequency From 40 to 440 Hz Note: *for UL applications max 600 VL-L, 40 °C (104 °F) Current inputs Inputs AV4 AV5 AV6 Current connection Via CT CT transformation ratio Rated current (In) Minimum current (lmin) Maximum current (lmax) Start-up current (lst) AV7 From 1 to 9999 1A 5A 1A 0.01 A 0.05 A 0.01 A 2A 6A 2A 1 mA 5 mA 1 mA Continuous: Imax For 500 ms: 20 Imax Overload Input impedance < 0.2 VA Maximum CTxVT ratio 9999 x 9999 Power supply Power supply H L From 100 to 240 V ac/dc ± 10% From 24 to 48 V ac/dc ± 15% Consumption 10 W, 20 VA Measurements Method TRMS measurements of distorted waveforms Sampling 3200 samples/s @50 Hz 3840 samples/s @60 Hz 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 10 Main unit Available measurements Active energy Unit System Phase Imported (+) Total kWh+ ● - Imported (+) partial kWh+ ● - Exported (+) Total kWh- ● - Exported (+) partial kWh- ● - Reactive energy Unit System Phase Imported (+) Total kvarh+ ● - Imported (+) partial kvarh+ ● - Exported (+) Total kvarh- ● - Exported (+) partial kvarh- ● - Electrical variable Unit System Phase A ● ● DMD A ● ● MAX A ● ● A ● - DMD A ● - MAX A ● - V ● ● DMD V ● ● MAX V ● ● Current Neutral current Voltage L-N Voltage L-L V ● ● DMD V ● ● MAX V ● ● Asymmetry VLL % ● - Asymmetry VLN % ● - Active power kW ● ● DMD kW ● ● MAX kW ● ● Apparent power kVA ● ● DMD kVA ● ● MAX kVA ● ● kvar ● ● DMD kvar ● ● MAX kvar ● ● Power factor PF ● ● DMD PF ● ● Reactive power 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 11 Main unit Electrical variable Unit System Phase PF ● ● Hz ● - DMD Hz ● - MAX Hz ● - THD Current* THD A % - ● DMD THD A % - ● MAX THD A % - ● MAX Frequency THD Voltage L-N* THD L-N % - ● DMD THD L-N % - ● MAX THD L-N % - ● THD L-L % - ● DMD THD L-L % - ● MAX THD L-L % - ● h ● - THD Voltage L-L* Run hour meter * Up to 32nd harmonic Note: the available variables depend on the type of system set. Measurement mode Depending on the APPLICATION setting, a different selection of variables is available on the display. The energy calculation is not affected and works always as bidirectional. Energy metering For every measuring interval time, the energies of the single phases are summed; according to the sign of the result, the positive (kWh+) or negative totalizer (kWh-) is increased. Example: P L1= +2 kW, P L2= +2 kW, P L3= -3 kW Integration time = 1 hour +kWh=(+2+2-3)x1h=(+1)x1h=1 kWh -kWh=0 kWh Measurement accuracy Current From 0.05 In to Imax ±(0.2% rdg + 2dgt) From 0.01 In to 0.05 In ±(0.5% rdg + 2dgt) 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 12 Main unit Phase-phase voltage From Un min -20% to Un max +15% ±(0.2% rdg +1dgt) Phase-neutral voltage From Un min -20% to Un max +15% ±(0.5% rdg +1dgt) Active and apparent power From 0.05 In to Imax (PF=0.5L, 1, 0.8C) ±(0.5% rdg +1dgt) From 0.01 In to 0.05 In (PF=1) ±(1% rdg +1dgt) Reactive power From 0.1 In to Imax (sinϕ=0.5L, 0.5C) From 0.05 In to Imax (sinϕ=1) ±(1% rdg + 1 dgt) From 0.05 In to 0.1 In (sinϕ=0.5L, 0.5C) From 0.02 In to 0.05 In (PF=1) ±(1.5% rdg + 1 dgt) Power factor ±[0.001+0.5%(1 – PF rdg)] Active energy Class 0.5S (EN62053-22), class 0.5 (ANSI C12.20) Reactive energy Class 2 (EN62053-23, ANSI C12.1) THD ±1% Frequency From 45 to 65 Hz ±(0.02% rdg + 1 dgt) From 65 to 340 Hz ±(0.05% rdg + 1 dgt) From 340 to 440 Hz ±(0.1% rdg + 1 dgt) Display Type Backlit LCD Refresh time 250 ms Description 5 rows: • 1st: 10 digits (6 mm) • 2nd, 3rd, 4th, 5th: 4 digits (9.5 mm) Variable readout Instantaneous: 4 digits, min: 0.001, max: 9 999 Energy: 10 digits, min: 0.01, max: 9 999 999 999 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 13 Main unit LED Red (kWh). Weight: proportional to energy consumption and depending on the CT and VT/ PT ratio product (16 Hz maximum frequency): Front Weight (kWh per pulse) CT*VT/PT 0.001 ≤7 0.01 From 7.1 to 70 0.1 From 70.1 to 700 1 From 700.1 to 7000 10 From 7001 to 70 k 100 > 70.01 k Red (AL1, AL2, AL3, AL4). Alarm status. Back Green. Power supply status. Special functions • • • • • • • 4 virtual alarms (up, down, in or out alarm) Filter to stabilize variable measurements with high fluctuations Load operating hour meter Clock Total active and reactive energy meters and average, minimum, max dmd and maximum values reset Optical port for configuration via OptoProg Password protected settings menu 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 14 Main unit Connection Diagrams Fig. 3 Three-phase system with neutral (4-wire, 3P.n), unbalanced load and 3 CT. 315 mA fuse (F). Fig. 4 Three-phase system with neutral (4-wire, 3P.n), unbalanced load, 3 CT and 3 VT/PT. Fig. 5 Three-phase system with neutral (4-wire, 3P.2), balanced load, 1 CT. 315 mA fuse (F). Fig. 6 Three-phase system with neutral (4-wire, 3P.2), balanced load, 1 CT and 1 VT/PT. Fig. 7 Three-phase system without neutral (3-wire, 3P), unbalanced load and 3 CT. 315 mA fuse (F). Fig. 8 Three-phase system without neutral (3-wire, 3P), unbalanced load, 3 CT and 2 VT/PT. Fig. 9 Three-phase system without neutral (3-wire, 3P) unbalanced load and 2 CT (Aron). 315 mA fuse (F). Fig. 10 Three-phase system without neutral (3-wire, 3P), unbalanced load, 2 CT (Aron) and 2 VT/PT. Fig. 11 Three-phase system without neutral (3-wire, 3P.1), balanced load, 1 CT. 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 15 Main unit Fig. 12 Three-phase system without neutral (3-wire, 3P.1), balanced load, 1 CT and 2 VT/PT. Fig. 15 Single-phase system (2wire, 1P), 1 CT. 315 mA fuse (F). 28/04/2022 WM30 DS ENG Fig. 13 Two-phase system (3-wire, 2P), 2 CT. 315 mA fuse (F). Fig. 14 Two-phase system (3wire, 2P), 2 CT and 2 VT/PT. Fig. 16 Single-phase system (2-wire, 1P), 1 CT and 1 VT/PT. Fig. 17 Auxiliary power supply (H). 250 V [T] 630 mA fuse (F). Auxiliary power supply (L). 250 V [T] 3.15 A fuse (F). CARLO GAVAZZI Controls SpA 16 Main unit References WM30 AV 3 (9 characters total) Enter the code option instead of Code Options W - - M - - 3 - - 0 - - A - - V - - 4 From 380 to 690 V L-L ac, 1(2) A, connection via CT 5 From 380 to 690 V L-L ac, 5(6) A, connection via CT 6 From 100 to 230 V L-L ac, 5(6) A, connection via CT 7 From 100 to 230 V L-L ac, 1(2) A, connection via CT - - H auxiliary power supply from 100 to 240 V ac/dc L auxiliary power supply from 24 to 48 V ac/dc 3 Description Further reading Information Document Where to find it Instruction manual Instruction manual - WM30 www.productselection.net 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 17 Main unit CARLO GAVAZZI compatible components Purpose Current measurement accessories Component name/code Notes CTD1X, CTD2X, CTD3X, CTD4X Solid core current transformers (1 or 5 A secondary current, 40 to 1600 A primary current) for cable or bus bar. See relevant datasheets. CTD1Z Solid core current transformers (5 A secondary current, 50 to 200 A primary current) for cable or bus bar. See relevant datasheets. CTA5, CTA6 Split core current transformers for retrofit applications (5 A secondary current, 100 to 600 A primary current) for cable or bus bar. See relevant datasheets. CTD5S, CTD6S, CTD8S, CTD9S, CTD10S Split core current transformers (1 or 5 A secondary current, 100 to 3200 A primary current) for bus bar. See relevant datasheets. CTD8V, CTD8V, CTD9V, CTD9H, CTD10V, CTD10H Solid core current transformers (1 or 5 A secondary current, 150 to 3200 A primary current) for bus bar. See relevant datasheets. CTD8Q Solid core current transformers (5 A secondary current, 1000 to 4000 A primary current) for bus bar. See relevant datasheets. Manage two digital outputs/associate alarms to digital outputs M O O2 M O R2 See "Digital output modules" on page 19 Manage two analogue outputs M O A2 M O V2 See "Analogue output modules" on page 25 Transmit data remotely M C 485232 M C ETH M C BAC IP M C BAC M C PB See Configure analyzer via desktop application UCS configuration software Available for free download at: www.productselection.net Configure analyzer via Mobile Android App UCS Mobile Android App Available for free download at: Google Play Store Monitor data from several analyzers UWP3.0 See relevant datasheet Quickly configure several analyzers via optical interface OptoProg See relevant datasheet RS485/USB conversion SIU-PC3 See relevant datasheet 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 18 Digital output modules Main features • Two digital outputs (static or relay) • Three possible functions for each output • Configuration via main unit keypad or UCS configuration software • Easy mountingon main unit • Detachable terminals • Local bus connection to main unit Main functions Description • Manage two static or relay outputs • Associate static or relay outputs with alarms • Transmit pulses proportional to energy consumption Accessory module for WM analyzer family that associates static or relay outputs to alarms and/or transmits pulses proportional to energy consumption. Each output can run three different functions: alarm, remote control or pulse. 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 19 Digital output modules Structure C A A D A B A Fig. 18 Front Element Description A Main unit fastening pins B Detachable digital output terminals C Local bus port for main unit D Local bus port for communication module Digital output functions Digital outputs can run three different functions: • Alarm: output associated with an alarm and directly managed by WM30 • Remote control: output status managed via communication • Pulse: pulse transmission output on active or reactive, imported or exported energy consumption. 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 20 Digital output modules Features General On main unit Weight 80g Power supply Self power supply via local bus 62,99 Mounting 89,49 16 Static output module (M O O2) Maximum number of outputs 2 Type Opto-mosfet Features VON: 2.5 V dc, 100 mA max VOFF: 42 V dc max Configuration parameters Output function: alarm/remote control/pulse Associated output alarm and normal status ("alarm" function only) Pulse weight, transmitted energy type, test transmission settings ("pulse" function only) Configuration mode Via keypad or UCS software Relay output module (M O R2) Maximum number of outputs 2 Type SPDT relay 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 21 Digital output modules Features AC1: 5 A @ 250 V ac AC15: 1 A @250 V ac Configuration parameters Output function: alarm/remote control/pulse Associated output alarm and normal status ("alarm" function only) Pulse weight, transmitted energy type, test transmission settings ("pulse" function only) Configuration mode Via keypad or UCS software 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 22 Digital output modules Connection Diagrams 1 2 3 4 5 6 3 4 5 6 7 8 7 Fig. 19 M O O2. Double static opto-mosfet output. 28/04/2022 WM30 DS ENG 2 Fig. 20 M O R2. Double relay output. CARLO GAVAZZI Controls SpA 23 Digital output modules References Order code Code Description M O O2 Double static output M O R2 Double relay output Further reading Information Document Where to find it Instruction manual - WM30 Instruction manual - WM30 www.productselection.net Digital output module instruction manual CARLO GAVAZZI compatible components Purpose Power the module via analyzer 28/04/2022 WM30 DS ENG Component name/code WM20 WM30 WM40 Notes The digital output module only works connected to an analyzer. See relevant datasheets. CARLO GAVAZZI Controls SpA 24 Analogue output modules Main features • Two analogue outputs (0 to 20 mA or 0 to 10V) • Configuration via main unit keypad or UCS configuration software • Easy mounting on main unit • Detachable terminals • Local bus connection to main unit Main functions • Associate electrical variables to analogue outputs. Description Accessory module for WM analyzer family that associates analogue outputs to electrical variables. Depending on the versione the output range can be set between 0 and 20 mA or 0 and 10 V dc. 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 25 Analogue output modules Structure Fig. 21 Front Element Description A Main unit fastening pins B Local bus port for main unit C Analogue outputs D Local bus port for communication module Analogue output functions Analogue outputs can be linked to any electrical variables. 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 26 Analogue output modules Features General On main unit Weight 80g Power supply Self power supply via local bus 62,99 Mounting 89,49 16 Analogue output module 0-20mA (M O A2) Maximum number of outputs 2 Type 0 to 20 mA dc Accuracy 0.2% FS Features Response time ≤ 400 ms typical (filter excluded) Ripple ≤1% (according to IEC 60688-1, EN 60688-1) Total temperature drift ≤500 ppm/°C Load ≤600Ω Configuration parameters Associated electrical variable. Min analogue output (as a percentage of 20mA) Max analogue output (as a percentage of 20mA) Electrical variable value corresponding to min output. Electrical variable value corresponding to max output. Configuration mode Via keypad or UCS software 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 27 Analogue output modules Analogue output module 0-10V (M O V2) Maximum number of outputs 2 Type 0 to 10 V dc Accuracy 0.2% FS Features Response time ≤ 400 ms typical (filter excluded) Ripple ≤1% (according to IEC 60688-1, EN 60688-1) Total temperature drift ≤350 ppm/°C Load ≥10kΩ Configuration parameters Associated electrical variable. Min analogue output (as a percentage of 10 V) Max analogue output (as a percentage of 10 V) Electrical variable value corresponding to min output. Electrical variable value corresponding to max output. Configuration mode Via keypad or UCS software 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 28 Analogue output modules Connection Diagrams Out1 1 2 Out2 3 4 Fig. 22 M O A2. Double analogue output 0-20mA. 28/04/2022 WM30 DS ENG Out1 1 2 Out2 3 4 Fig. 23 M O V2. Double analogue output 0-10V. CARLO GAVAZZI Controls SpA 29 Analogue output modules References Order code Code Module description M O A2 Double analogue output 0-20mA. M O V2 Double analogue output 0-10V. Further reading Information Document Where to find it WM30 instruction manual Instruction manual - WM30 www.productselection.net Analogue output module instruction manual CARLO GAVAZZI compatible components Purpose Power the module via analyzer 28/04/2022 WM30 DS ENG Component name/code WM20 WM30 WM40 Notes The digital output module only works connected to an analyzer. See relevant datasheets. CARLO GAVAZZI Controls SpA 30 Communication modules Main features • Supported communication protocols: Modbus, BACnet, Profibus. See "Communication module overview " on page 21 • Configuration via main unit keypad or UCS configuration software • Easy mounting on main unit • Local bus connection to main unit Main functions • Transmit data remotely • Configure the system Description Accessory module for WM analyzer family connected to the main unit that transmits system data remotely using a different communication protocol according to the version. Communication module overview Module code M C 485232 M C ETH M C BAC IP M C BAC MS M C PB 28/04/2022 WM30 DS ENG Communication protocols Port Modbus RTU RS485, RS232 Modbus TCP/IP Ethernet BACnet IP, Modbus TCP/IP Ethernet BACnet MS/TP RS485 Modbus TCP/IP Ethernet Profibus DP V0 slave RS485 Modbus RTU micro USB CARLO GAVAZZI Controls SpA 31 Communication modules Structure A D B B A C B B A Fig. 24 Front Note: NOTE: the image refers to the M C BAC MS module. Area A Description Communication port area Note: the communication ports depend on the communication module, see "Communication module overview" on the previous page B Main unit fastening pins C Communication status LED (M C 485232, M C BAC MS, M C PB) D Local bus port for main unit or digital output module 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 32 Communication modules Features General Mounting On main unit (with or without digital output module) Power supply Self power supply via local bus Weight 80g M C 485232 module RS485 port Protocols Modbus RTU Devices on the same bus Max 160 (1/5 unit load) Communication type Multidrop, bidirectional Connection type 2 wires, maximum distance 1000 m Configuration parameters Modbus address (from 1 to 247) Baud rate (9,6/ 19,2/ 38,4/ 115,2 kbps) Parity (None/ Odd/ Even) Configuration mode Via keypad or UCS software RS232 port Protocols Modbus RTU Communication type Bidirectional Connection type 3 wires, maximum distance 15 m 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 33 Communication modules Configuration parameters Modbus address (from 1 to 247) Baud rate (9,6/ 19,2/ 38,4/ 115,2 kbps) Parity (None/ Odd/ Even) Configuration mode Via keypad or UCS software Note: the RS485 and RS232 ports are alternative. LED Meaning Communication status: Yellow: receiving Green: transmitting M C ETH module Ethernet port Protocols Modbus TCP/IP Client connections Maximum 5 simultaneously Connection type RJ45 connector (10 Base-T, 100 Base-TX), maximum distance 100 m Configuration parameters IP address Subnet mask Gateway TCP/IP port Configuration mode Via keypad or UCS software M C BAC IP module Ethernet port Protocols BACnet IP (reading) Modbus TCP/IP (reading and configuration) Client connections (Modbus only) Maximum 5 simultaneously Connection type RJ45 connector (10 Base-T, 100 Base-TX), maximum distance 100 m BACnet IP protocol: Configuration parameters • • • • • Instance number (from 0 to 9999 via keypad, from 0 to 4194302 via communication) Foreign Device enabling BBMD address UDP port WM30 time-to-live recording as Foreign Device on specified BBMD server Modbus TCP/IP protocol: • • • • 28/04/2022 WM30 DS ENG IP address Subnet mask Gateway TCP/IP port CARLO GAVAZZI Controls SpA 34 Communication modules Ethernet port Supported services "I-have", "I-am", "Who-has", "Who-is", "Read-property (multiple)" Supported objects Type 2 (analogue value including COV property), type 5 (binary value, for alarm transmission), type 8 (device) Configuration mode Via keypad or UCS software M C BAC MS module RS485 port Protocols BACnet MS/TP (measurement reading and object description writing) Communication type Multidrop, monodirectional Connection type 2 wires, maximum distance 1000 m Supported services "I-have", "I-am", "Who-has", "Who-is", "Read-property (multiple)" Supported objects Type 2 (analogue value including COV property), type 5 (binary value, for alarm transmission), type 8 (device) BACnet IP protocol: Configuration parameters • Instance number (from 0 to 9999 via keypad, from 0 to 4194302 via communication) • Baud rate (9,6/ 19,2/ 38,4/ 57,6/ 76,8 kbps) • MAC address (from 0 to 127) Configuration mode Via keypad or UCS software Ethernet port Protocols Modbus TCP/IP (configuration) Client connections (Modbus only) Maximum 5 simultaneously Connection type RJ45 connector (10 Base-T, 100 Base-TX), maximum distance 100 m Configuration parameters IP address Subnet mask Gateway TCP/IP por Configuration mode Via keypad or UCS software LED Meaning Communication status: Yellow: receiving Green: transmitting M C PB module Profibus port Protocols Profibus DP V0 slave Connection type 9-pin D-sub receptacle RS485 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 35 Communication modules Configuration parameters Address, via keypad Other settings with UCS software via serial communication Configuration mode Via keypad or UCS software Micro-USB port Protocols Modbus RTU Type USB 2.0 (USB 3.0 compatible) Connection type Micro-USB B Baud rate Any (maximum 115.2 kbps) Address 1 LED Meaning 28/04/2022 WM30 DS ENG Communication status: Red: between module and main unit Green: between module and Profibus master CARLO GAVAZZI Controls SpA 36 Communication modules Connection Diagrams 8 8 7 7 6 6 4 4 3 3 2 1 2 1 Fig. 25 M C 485232. RS485 serial port. Note: additional meters with RS485 are connected in daisy chain. The serial output must only be terminated on the last network meter connecting terminals B+ and T. 8 7 6 4 3 2 1 Fig. 26 M C 485232. RS232 serial port. 4 4 3 3 2 1 2 1 Fig. 27 M C BAC MS. RS485 serial port. Note: additional meters with RS485 are connected in daisy chain. The serial output must only be terminated on the last network meter connecting terminals B+ and T. 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 37 Communication modules References Order code Code MC 485232 MC ETH Module description Modbus RTU communication on RS485/RS232 Modbus TCP/IP communication on Ethernet MC BAC IP BACnet IP communication on Ethernet MC BAC MS BACnet MS/TP communication on RS485 MC PB Profibus DP V0 communication on RS485 Further reading Information Document Where to find it WM30 instruction manual Instruction manual - WM30 www.productselection.net Communication module instruction manual (M C 485232, M C ETH, M C BAC IP, M C BAC MS) Communication module instruction manual (M C PB) CARLO GAVAZZI compatible components Purpose Power the module via analyzer Component name/code WM20 WM30 WM40 Notes The communication module only works connected to an analyzer. See relevant datasheets. COPYRIGHT ©2022 Content subject to change. Download the PDF: www.gavazziautomation.com 28/04/2022 WM30 DS ENG CARLO GAVAZZI Controls SpA 38
MC485232 价格&库存
很抱歉,暂时无法提供与“MC485232”相匹配的价格&库存,您可以联系我们找货
