MCETHM
MCETHM
    CARLOGAVAZZI
    Module
    选件卡,通信
MCETHM 数据手册
WM40 Power analyzer for three-phase systems Benefits Description WM40 is a modular power analyzer for single-, two- and three-phase systems. It is made up of a maximum of four components: the main unit that displays measurements on the LCD display and manages 16 alarms, and three accessory modules, one with digital outputs or analogue outputs, one with analogue outputs, digital inputs and outputs or analogue inputs and the other for communication. The digital output module associates alarms with static or relay outputs and/or transmits pulses proportional to energy consumption. The analogue output module associates 0-20mA or 0-10 V outputs to measured variables. The digital input/output module allows alarm or pulse transmission via digital outputs, tariff management, pulse counting or DMD synchronization via digital inputs. The analogue input module allows temperature, process signal and real neutral current monitoring. The communication module allows you configure the analyzer and transmit data using a different communication protocol according to the version and, if equipped with memory on board, permits log of data and events. 16/05/2022 WM40 DS ENG • Clarity. The wide backlit LCD display clearly shows the measurements and the configuration parameter values. • Simplicity. An optical port is available for quick analyzer configuration using OptoProg (CARLO GAVAZZI). • Specific software. WM40can be configured and measurements viewed from UCS configuration software (CARLO GAVAZZI). The software and subsequent updates are free. • Scalability. Three accessory modules can be added to WM40according to need. This way, the analyzer extends its control capacities and communicates data remotely. • Communication flexibility. The communication module is available in Modbus RTU, Modbus TCP/IP, BACnet IP, BACnet MS/TP and Profibus DP V0 versions. • Fast installation. WM40and accessory modules are all equipped with detachable terminals. Modules can be quickly installed via the specifically designed fast coupling pins. • Tamper-proof. WM40configuration access can be locked. Terminals and accessory modules can be sealed. CARLO GAVAZZI Controls SpA 1 WM40 Main functions • • • • • • • • • • Measure main electrical variables and voltage and current harmonic distortions Measure active and reactive energy Measure load operating hours Manage up to 16 alarms Manage up to 8 digital outputs (via optional accessory modules) Manage up to 6 digital inputs (via optional accessory modules) Manage temperature, process signal and real neutral current (via optional accessory module) Manage up to 4 analogue outputs (via optional accessory modules) Manage process signal, temperature and real neutral current input (via optional accessory module) Transmit data to other systems (via optional accessory module) Applications WM40 can be installed in any switchboard to control energy consumption, main electrical variables and harmonic distortion. In automation, WM40can use the communication module with Profibus protocol to both communicate data on consumption to supervision systems and manage them independently if installed on a machine. In building, WM40can be installed in existent architectures using the communication module with BACnet protocol (on RS485 or Ethernet). Components Module Description WM40 Main unit, measures and displays main electrical variables. With LCD display and touch keypad, it lets you set measurement parameters, configure accessory modules and manage up to 16 alarms. Digital inputs/outputs (optional) Accessory module with 4 or 6 digital outputs and 6 digital inputs. Expands main unit capacity, specifically allowing you to: transmit pulses proportional to energy consumption control digital outputs (static or relay according to the module) synchronize DMD calculation with digital inputs control tariffs reset alarms count pulses Analogue inputs (optional) Accessory module that lets you: read temperature values monitor a process signal measure real neutral current Communication (optional) Accessory module that lets you transmit data to other systems or configure the analyzer from remote 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 2 WM40 Compatible accessory modules Type Digital outputs Code Double static output M O O2 Double relay output M O R2 Double analogue output (+20mA dc) M O A2 Double analogue output (+10V dc) M O V2 6 digital inputs and 6 static outputs MF I6 O6 6 digital inputs and 4 relay outputs MF I6 R4 Temperature and analogue input (process signal) MATP Temperature, analogue input and neutral current direct measurement MATPN Modbus RTU communication on RS485/RS232 M C 485232 Modbus RTU communication on RS485/RS232+memory M C 485232 M Modbus TCP/IP communication on Ethernet M C ETH Modbus TCP/IP communication on Ethernet+memory M C ETH M BACnet IP communication on Ethernet M C BAC IP BACnet IP communication on Ethernet+memory M C BAC IP M BACnet MS/TP communication on RS485 M C BAC MS BACnet MS/TP communication on RS485+memory M C BAC MS M Profibus DP V0 communication on RS485 M C PB Profibus DP V0 communication on RS485+memory M C PB M Analogue outputs Digital inputs/outputs Analogue inputs Module description Communication Possible configurations WM40only WM40+ 1 module WM40+ 2 modules WM40+ 3 modules NOTICE: maximum 1 module per type with exception of analogue output modules (2 max). In the configuration with 2 or 3 modules, the communication module is installed last. 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 3 WM40 Features General features Material Front: ABS, self-extinguishing V-0 (UL 94) Back and accessory modules: PA66, self-extinguishing V-0 (UL 94) Protection degree Front: IP65 NEMA 4x NEMA 12 Terminals: IP20 Type: detachable Section: 2.5 mm2 maximum Terminals Torque: 0.5 Nm Overvoltage category Cat. III Pollution degree 2 Rejection (CMRR) 100 dB, from 42 to 62 Hz Insulation Double electrical insulation on areas accessible to the user. For insulation between inputs and outputs, see "Input and output insulation" below. Input and output insulation Note: test conditions: 4 kV rms ac for one minute. Power supply (H or L) [kV] Measurement inputs [kV] Power supply (H or L) - 4 4 4 4 4 4 Measurement inputs 4 - 4 4 4 4 Relay outputs MOR2 4 4 2 4 4 Relay outputs MFI6R4 4 4 4 2 Static outputs MOO2 4 4 4 Static outputs MFI6O6 4 4 Digital inputs 4 Analogue outputs 4 Type 16/05/2022 WM40 DS ENG Relay Relay Static outoutoutputs puts puts MOR2 MFI6R4 MOO2 [kV] Static Digital Anaout- inputs logue puts [kV] outputs MFI6O6 Analogue inputs Serial port [kV] Ethernet port [kV] 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 2 4 4 4 4 4 4 4 4 4 2 4 4 4 4 4 4 4 4 4 4 - 4 4 4 4 4 4 4 4 4 4 - 4 4 4 CARLO GAVAZZI Controls SpA 4 WM40 Power supply (H or L) [kV] Measurement inputs [kV] Analogue inputs 4 4 4 4 4 4 4 Serial port 4 4 4 4 4 4 Ethernet port 4 4 4 4 4 4 Type Relay Relay Static outoutoutputs puts puts MOR2 MFI6R4 MOO2 [kV] Static Digital Anaout- inputs logue puts [kV] outputs MFI6O6 Analogue inputs Serial port [kV] Ethernet port [kV] 4 4* - 4 4 4 4 - NP 4 4 4 NP - Key • NP: combination not possible • 4: 4 kV rms insulation (EN 61010-1, IEC 60664-1, overvoltage category III, pollution degree 2, double insulation on system with maximum 300 V rms to ground) Note: *between two different modules Environmental specifications Operating temperature From -25 to +55 °C/from -13 to +131 °F Storage temperature From -30 to +70 °C/from -22 to 158 °F Note: R.H. < 90 % non-condensing @ 40 °C / 104 °F. Conformity Directives 2014/35/EU (LVT - Low Voltage) 2014/30/EU (Electromagnetic Compatibility) 2011/65/EU (Electric-electronic equipment hazardous substances) Standards Electromagnetic compatibility (EMC) - emissions and immunity: EN61000-6-3, EN61000-6-2 Electrical safety: EN 61010-1 Metrology: EN62053-22, EN62053-23 Pulse output: IEC 62053-31, DIN 43864 Approvals 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 5 Main unit Main features Description Main unit with LCD display and touch keypad to view measurements, configure the system and manage 16 alarms. It can be integrated by digital output, analogue output, digital input/output, analogue input and communication modules. Four versions are available (AV4, AV5, AV6 and AV7) to manage different current and voltage inputs. It can be quickly configured with OptoProg via optical port. 16/05/2022 WM40 DS ENG • System and phase variables (4 x 3 digits): V L-L, V L-N, A, W/var/VA, PF, Hz • Active and reactive imported and exported energy meters (10 digits) • Calculate the average and maximum system and phase values of all the electrical variables • Calculate current and voltage THD (total harmonic distortions) and single harmonics up to the 32nd harmonic • Calculate load operating hours • Auxiliary power supply • 16 virtual alarms • Backlit LCD display and touch keypad • Optical port • Detachable terminals • Sealable terminal caps • Configuration via keypad or UCS configuration software • Filter to stabilize displayed measurements Main functions • Measure main electrical variables and harmonic voltage and current distortions • Measure single harmonics (raw data via communication and harmonics graph via UCS software) • Measure active and reactive energy • Measure load operating hours • Manage up to 16 alarms CARLO GAVAZZI Controls SpA 6 Main unit Structure Fig. 1 Front Element Description A Optical port and plastic support for OptoProg (CARLO GAVAZZI) connection B Backlit LCD display C LED that blinks with frequency proportional to active energy consumption, see "LED" on page 15 D Touch keypad 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 7 Main unit A C D E F B Fig. 2 Back Element Description A Detachable power supply terminals B Detachable current input terminals C Detachable voltage input terminals D Rotary selector to lock configuration E Local bus port for accessory modules F Power supply status LED, see "LED" on page 15 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 8 Main unit Features General features Assembly Panel mounting Weight 420 g (packaging included) Electrical specifications Electrical system Single-phase (2-wire) Managed electrical sys- Two-phase (3-wire) tem Three-phase with neutral (4-wire) Three-phase without neutral (3-wire) Voltage inputs Inputs AV4 AV5 Voltage connection AV6 AV7 Direct or via VT/PT VT/PT transformation ratio From 1 to 9999 Rated voltage L-N (from Un min to Un max) From 220 to 400 V From 57.7 to 133 V Rated voltage L-L (from Un min to Un max) From 380 to 690 V* From 100 to 230 V Voltage tolerance 16/05/2022 WM40 DS ENG -20%, + 15% CARLO GAVAZZI Controls SpA 9 Main unit Voltage inputs Continuous: 1.2 Un max For 500 ms: 2 Un max Overload Input impedance >1.6 MΩ Frequency From 40 to 440 Hz Note: *for UL applications max 600 VL-L, 40 °C (104 °F) Current inputs Inputs AV4 AV5 AV6 Current connection Via CT CT transformation ratio From 1 to 9999 Rated current (In) Minimum current (lmin) 1A 5A 1A 0.01 A 0.05 A 0.01 A 2A 6A 2A 1 mA 5 mA 1 mA Maximum current (lmax) Start-up current (lst) AV7 Continuous: Imax For 500 ms: 20 Imax Overload Input impedance < 0.2 VA Maximum CTxVT ratio 9999 x 9999 Power supply Power supply H L From 100 to 240 V ac/dc ± 10% From 24 to 48 V ac/dc ± 15% Consumption 10 W, 20 VA Measurements Method TRMS measurements of distorted waveforms Sampling 3200 samples/s @50 Hz 3840 samples/s @60 Hz Available measurements Active energy Unit System Phase Imported (+) Total kWh+ ● - Imported (+) partial kWh+ ● - Exported (+) Total kWh- ● - Exported (+) partial kWh- ● - 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 10 Main unit Reactive energy Unit System Phase Imported (+) Total kvarh+ ● - Imported (+) partial kvarh+ ● - Exported (+) Total kvarh- ● - Exported (+) partial kvarh- ● - Electrical variable Unit System Phase A ● ● MIN A ● ● DMD A ● ● MAX A ● ● DMD MAX A ● ● A ● - MIN A ● - DMD A ● - MAX A ● - DMD MAX A ● - Voltage L-N V ● ● MIN V ● ● DMD V ● ● MAX V ● ● DMD MAX V ● ● Current Neutral current Voltage L-L V ● ● MIN V ● ● DMD V ● ● MAX V ● ● DMD MAX V ● ● kW ● ● MIN kW ● ● DMD kW ● ● MAX kW ● ● DMD MAX kW ● ● kVA ● ● MIN kVA ● ● DMD kVA ● ● MAX kVA ● ● DMD MAX kVA ● ● kvar ● ● kvar ● ● Active power Apparent power Reactive power MIN 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 11 Main unit Electrical variable Unit System Phase DMD kvar ● ● MAX kvar ● ● DMD MAX kvar ● ● Power factor PF ● ● MIN PF ● ● DMD PF ● ● MAX PF ● ● DMD MAX PF ● ● Hz ● - MIN Hz ● - DMD Hz ● - MAX Hz ● - DMD MAX Hz ● - THD A % - ● MIN THD A % - ● DMD THD A % - ● MAX THD A % - ● DMD MAX THD A % - ● THD A % - ● MIN THD A % - ● DMD THD A % - ● MAX THD A % - ● DMD MAX THD A % - ● THD even Current* Frequency THD Current* THD odd Current* THD A % - ● MIN THD A % - ● DMD THD A % - ● MAX THD A % - ● DMD MAX THD A % - ● THD L-N % - ● MIN THD L-N % - ● DMD THD L-N % - ● MAX THD L-N % - ● DMD MAX THD L-N % - ● THD odd Voltage L-N* THD L-N % - ● MIN THD L-N % - ● DMD THD L-N % - ● MAX THD L-N % - ● DMD MAX THD L-N % - ● THD Voltage L-N* 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 12 Main unit Electrical variable Unit System Phase THD L-N % - ● MIN THD L-N % - ● DMD THD L-N % - ● MAX THD L-N % - ● DMD MAX THD L-N % - ● THD L-L % - ● MIN THD L-L % - ● DMD THD L-L % - ● MAX THD L-L % - ● DMD MAX THD L-L % - ● THD odd Voltage L-L* THD L-L % - ● MIN THD L-L % - ● DMD THD L-L % - ● MAX THD L-L % - ● DMD MAX THD L-L % - ● THD even Voltage L-N* THD Voltage L-L* THD even Voltage L-L* THD L-L % - ● MIN THD L-L % - ● DMD THD L-L % - ● MAX THD L-L % - ● DMD MAX THD L-L % - ● TDD A % - ● MIN TDD A % - ● DMD TDD A % - ● MAX TDD A % - ● DMD MAX TDD A % - ● - - ● MIN - - ● DMD - - ● MAX - - ● DMD MAX - - ● h ● - TDD Current* K-factor/factor K Run hour meter * Up to 32nd harmonic Note: the available variables depend on the type of system set. Measurement mode Depending on the APPLICATION setting, a different selection of variables is available on the display. The energy calculation is not affected and works always as bidirectional. 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 13 Main unit Energy metering For every measuring interval time, the energies of the single phases are summed; according to the sign of the result, the positive (kWh+) or negative totalizer (kWh-) is increased. Example: P L1= +2 kW, P L2= +2 kW, P L3= -3 kW Integration time = 1 hour +kWh=(+2+2-3)x1h=(+1)x1h=1 kWh -kWh=0 kWh Measurement accuracy Current From 0.05 In to Imax ±(0.2% rdg + 2dgt) From 0.01 In to 0.05 In ±(0.5% rdg + 2dgt) Phase-phase voltage From Un min -20% to Un max +15% ±(0.2% rdg +1dgt) Phase-neutral voltage From Un min -20% to Un max +15% ±(0.5% rdg +1dgt) Active and apparent power From 0.05 In to Imax (PF=0.5L, 1, 0.8C) ±(0.5% rdg +1dgt) From 0.01 In to 0.05 In (PF=1) ±(1% rdg +1dgt) 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 14 Main unit Reactive power From 0.1 In to Imax (sinϕ=0.5L, 0.5C) From 0.05 In to Imax (sinϕ=1) ±(1% rdg + 1 dgt) From 0.05 In to 0.1 In (sinϕ=0.5L, 0.5C) From 0.02 In to 0.05 In (PF=1) ±(1.5% rdg + 1 dgt) Power factor ±[0.001+0.5%(1 – PF rdg)] Active energy Class 0.5S (EN62053-22), class 0.5 (ANSI C12.20) Reactive energy Class 2 (EN62053-23, ANSI C12.1) THD ±1% TDD ±1% Frequency From 45 to 65 Hz ±(0.02% rdg + 1 dgt) From 65 to 340 Hz ±(0.05% rdg + 1 dgt) From 340 to 440 Hz ±(0.1% rdg + 1 dgt) Display Type Backlit LCD Refresh time 250 ms Description 5 rows: • 1st: 10 digits (6 mm) • 2nd, 3rd, 4th, 5th: 4 digits (9.5 mm) Variable readout Instantaneous: 4 digits, min: 0.001, max: 9 999 Energy: 10 digits, min: 0.01, max: 9 999 999 999 LED Red. Weight: proportional to energy consumption and depending on the CT and VT/ PT ratio product (16 Hz maximum frequency): Front Weight (kWh per pulse) CT*VT/PT 0.001 ≤7 0.01 From 7.1 to 70 0.1 From 70.1 to 700 1 From 700.1 to 7000 10 From 7001 to 70 k 100 > 70.01 k Red (G1, G2, G3, G4). Groups of Alarm status. Back 16/05/2022 WM40 DS ENG Green. Power supply status. CARLO GAVAZZI Controls SpA 15 Main unit Special functions • • • • • • • • 16 virtual alarms (up, down, in or out alarm) Filter to stabilize variable measurements with high fluctuations Load operating hour meter Clock Tariff management by clock/calendar, digital inputs or communication Total active and reactive energy meters and average, minimum, max dmd and maximum values reset Optical port for configuration via OptoProg Password protected settings menu 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 16 Main unit Connection Diagrams Fig. 3 Three-phase system with neutral (4-wire, 3P.n), unbalanced load and 3 CT. 315 mA fuse (F). Fig. 4 Three-phase system with neutral (4-wire, 3P.n), unbalanced load, 3 CT and 3 VT/PT. Fig. 5 Three-phase system with neutral (4-wire, 3P.2), balanced load, 1 CT. 315 mA fuse (F). Fig. 6 Three-phase system with neutral (4-wire, 3P.2), balanced load, 1 CT and 1 VT/PT. Fig. 7 Three-phase system without neutral (3-wire, 3P), unbalanced load and 3 CT. 315 mA fuse (F). Fig. 8 Three-phase system without neutral (3-wire, 3P), unbalanced load, 3 CT and 2 VT/PT. L1 L2 L3 Fig. 9 Three-phase system without neutral (3-wire, 3P) unbalanced load and 2 CT (Aron). 315 mA fuse (F). 16/05/2022 WM40 DS ENG Fig. 10 Three-phase system without neutral (3-wire, 3P), unbalanced load, 2 CT (Aron) and 2 VT/PT. S1 S2 Fig. 11 Three-phase system without neutral (3-wire, 3P.1), balanced load, 1 CT. CARLO GAVAZZI Controls SpA 17 Main unit Fig. 12 Three-phase system without neutral (3-wire, 3P.1), balanced load, 1 CT and 2 VT/PT. Fig. 15 Single-phase system (2wire, 1P), 1 CT. 315 mA fuse (F). 16/05/2022 WM40 DS ENG Fig. 13 Two-phase system (3-wire, 2P), 2 CT. 315 mA fuse (F). Fig. 14 Two-phase system (3wire, 2P), 2 CT and 2 VT/PT. Fig. 16 Single-phase system (2-wire, 1P), 1 CT and 1 VT/PT. Fig. 17 Auxiliary power supply (H). 250 V [T] 630 mA fuse (F). Auxiliary power supply (L). 250 V [T] 3.15 A fuse (F). CARLO GAVAZZI Controls SpA 18 Main unit References WM40 AV 3 (9 characters total) Enter the code option instead of Code Options W - - M - - 4 - - 0 - - A - - V - - 4 From 380 to 690 V L-L ac, 1(2) A, connection via CT 5 From 380 to 690 V L-L ac, 5(6) A, connection via CT 6 From 100 to 230 V L-L ac, 5(6) A, connection via CT 7 From 100 to 230 V L-L ac, 1(2) A, connection via CT - - H auxiliary power supply from 100 to 240 V ac/dc L auxiliary power supply from 24 to 48 V ac/dc 3 Description Further reading Information Document Where to find it Instruction manual Instruction manual - WM40 www.productselection.net 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 19 Main unit CARLO GAVAZZI compatible components Purpose Current measurement accessories Component name/code Notes CTD1X, CTD2X, CTD3X, CTD4X Solid core current transformers (1 or 5 A secondary current, 40 to 1600 A primary current) for cable or bus bar. See relevant datasheets. CTD1Z Solid core current transformers (5 A secondary current, 50 to 200 A primary current) for cable or bus bar. See relevant datasheets. CTA5, CTA6 Split core current transformers for retrofit applications (5 A secondary current, 100 to 600 A primary current) for cable or bus bar. See relevant datasheets. CTD5S, CTD6S, CTD8S, CTD9S, CTD10S Split core current transformers (1 or 5 A secondary current, 100 to 3200 A primary current) for bus bar. See relevant datasheets. CTD8V, CTD8V, CTD9V, CTD9H, CTD10V, CTD10H Solid core current transformers (1 or 5 A secondary current, 150 to 3200 A primary current) for bus bar. See relevant datasheets. CTD8Q Solid core current transformers (5 A secondary current, 1000 to 4000 A primary current) for bus bar. See relevant datasheets. Manage two digital outputs/associate alarms to digital outputs M O O2 M O R2 See "Digital output modules" on page 22 Manage two analogue outputs M O A2 M O V2 See "Analogue output modules" on page 28 Manage 6 digital inputs and 4 relay outputs MF I6 R4 See "Digital input/output modules" on page 34 Manage 6 digital inputs and 6 static outputs MF I6 O6 See "Digital input/output modules" on page 34 Manage a temperature input and a process signal (analogue input) MATP See "Analogue output modules" on page 28 Manage a temperature input, a process signal (analogue input) and a neutral current input MATPN See "Analogue output modules" on page 28 M C 485232 M C ETH M C BAC IP M C BAC MS M C PB See "Communication modules" on page 47 M C 485232 M M C ETH M M C BAC IP M M C BAC MSM M C PB M See "Communication modules" on page 47 Transmit data remotely Transmit data remotely and log data/events 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 20 Main unit Purpose Component name/code Notes Configure analyzer via desktop application UCS configuration software Available for free download at: www.gavazziautomation.com Configure analyzer via Mobile Android App UCS Mobile Android App Available for free download at: Google Play Store Monitor data from several analyzers VMU-C, UWP3.0 See relevant datasheet Quickly configure several analyzers via optical interface OptoProg See relevant datasheet RS485/USB conversion SIU-PC3 See relevant datasheet 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 21 Digital output modules Main features • Two digital outputs (static or relay) • Three possible functions for each output • Configuration via main unit keypad or UCS configuration software • Easy mountingon main unit • Detachable terminals • Local bus connection to main unit Main functions Description • Manage two static or relay outputs • Associate static or relay outputs with alarms • Transmit pulses proportional to energy consumption Accessory module for WM analyzer family that associates static or relay outputs to alarms and/or transmits pulses proportional to energy consumption. Each output can run three different functions: alarm, remote control or pulse. 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 22 Digital output modules Structure C A A D A B A Fig. 18 Front Element Description A Main unit fastening pins B Detachable digital output terminals C Local bus port for main unit D Local bus port for communication module Digital output functions Digital outputs can run three different functions: • Alarm: output associated with an alarm and directly managed by WM40 • Remote control: output status managed via communication • Pulse: pulse transmission output on active or reactive, imported or exported energy consumption. 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 23 Digital output modules Features General On main unit Weight 80g Power supply Self power supply via local bus 62,99 Mounting 89,49 16 Static output module (M O O2) Maximum number of outputs 2 Type Opto-mosfet Features VON: 2.5 V dc, 100 mA max VOFF: 42 V dc max Configuration parameters Output function: alarm/remote control/pulse Associated output alarm and normal status ("alarm" function only) Pulse weight, transmitted energy type, test transmission settings ("pulse" function only) Configuration mode Via keypad or UCS software Relay output module (M O R2) Maximum number of outputs 2 Type SPDT relay 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 24 Digital output modules Features AC1: 5 A @ 250 V ac AC15: 1 A @250 V ac Configuration parameters Output function: alarm/remote control/pulse Associated output alarm and normal status ("alarm" function only) Pulse weight, transmitted energy type, test transmission settings ("pulse" function only) Configuration mode Via keypad or UCS software 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 25 Digital output modules Connection Diagrams 1 2 3 4 5 6 3 4 5 6 7 8 7 Fig. 19 M O O2. Double static opto-mosfet output. 16/05/2022 WM40 DS ENG 2 Fig. 20 M O R2. Double relay output. CARLO GAVAZZI Controls SpA 26 Digital output modules References Order code Code Description M O O2 Double static output M O R2 Double relay output Further reading Information Document Where to find it Instruction manual - WM40 Instruction manual - WM40 www.productselection.net Digital output module instruction manual CARLO GAVAZZI compatible components Purpose Power the module via analyzer 16/05/2022 WM40 DS ENG Component name/code WM20 WM30 WM40 Notes The digital output module only works connected to an analyzer. See relevant datasheets. CARLO GAVAZZI Controls SpA 27 Analogue output modules Main features • Two analogue outputs (0 to 20 mA or 0 to 10V) • Configuration via main unit keypad or UCS configuration software • Easy mounting on main unit • Detachable terminals • Local bus connection to main unit Main functions • Associate electrical variables to analogue outputs. Description Accessory module for WM analyzer family that associates analogue outputs to electrical variables. Depending on the versione the output range can be set between 0 and 20 mA or 0 and 10 V dc. 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 28 Analogue output modules Structure Fig. 21 Front Element Description A Main unit fastening pins B Local bus port for main unit C Analogue outputs D Local bus port for communication module Analogue output functions Analogue outputs can be linked to any electrical variables. 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 29 Analogue output modules Features General On main unit Weight 80g Power supply Self power supply via local bus 62,99 Mounting 89,49 16 Analogue output module 0-20mA (M O A2) Maximum number of outputs 2 Type 0 to 20 mA dc Accuracy 0.2% FS Features Response time ≤ 400 ms typical (filter excluded) Ripple ≤1% (according to IEC 60688-1, EN 60688-1) Total temperature drift ≤500 ppm/°C Load ≤600Ω Configuration parameters Associated electrical variable. Min analogue output (as a percentage of 20mA) Max analogue output (as a percentage of 20mA) Electrical variable value corresponding to min output. Electrical variable value corresponding to max output. Configuration mode Via keypad or UCS software 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 30 Analogue output modules Analogue output module 0-10V (M O V2) Maximum number of outputs 2 Type 0 to 10 V dc Accuracy 0.2% FS Features Response time ≤ 400 ms typical (filter excluded) Ripple ≤1% (according to IEC 60688-1, EN 60688-1) Total temperature drift ≤350 ppm/°C Load ≥10kΩ Configuration parameters Associated electrical variable. Min analogue output (as a percentage of 10 V) Max analogue output (as a percentage of 10 V) Electrical variable value corresponding to min output. Electrical variable value corresponding to max output. Configuration mode Via keypad or UCS software 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 31 Analogue output modules Connection Diagrams Out1 1 2 Out2 3 4 Fig. 22 M O A2. Double analogue output 0-20mA. 16/05/2022 WM40 DS ENG Out1 1 2 Out2 3 4 Fig. 23 M O V2. Double analogue output 0-10V. CARLO GAVAZZI Controls SpA 32 Analogue output modules References Order code Code Module description M O A2 Double analogue output 0-20mA. M O V2 Double analogue output 0-10V. Further reading Information Document Where to find it WM40 instruction manual Instruction manual - WM40 www.productselection.net Analogue output module instruction manual CARLO GAVAZZI compatible components Purpose Power the module via analyzer 16/05/2022 WM40 DS ENG Component name/code Notes WM30 WM40 The digital output module only works connected to an analyzer. See relevant datasheets. CARLO GAVAZZI Controls SpA 33 Digital input/output modules Main features • 6 digital inputs • 4 relay outputs or 6 static outputs • Configuration via main unit keypad or UCS configuration software • Easy mounting on main unit • Detachable terminals • Local bus connection to main unit Main functions Description Accessory module for WM analyzer family with digital outputs for alarm or pulses transmission and digital outputs for tariff management, DMD synchronization and pulse counting. Each output can run three different functions: alarm, remote control or pulse. Digital inputs can run four different functions: tariff management, remote control, pulse counting (positive/negative active energy, reactive energy, protection trip, water/gas/heating) or remote alarm reset. 16/05/2022 WM40 DS ENG • Transmit pulses with frequency proportional to energy consumption • Associate alarms to static or relay outputs • Remote output control • Tariff management • Pulse counting • Remote alarm reset CARLO GAVAZZI Controls SpA 34 Digital input/output modules Structure Part Description A Detachable terminal block for inputs/outputs or area specific to communication ports B Fastening pins to main unit or other accessory module C Internal local bus port for communications with main unit or other accessory module D External local bus port for communication with communication module. Not included in communication modules. 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 35 Digital input/output modules Features General Mounting On main unit Weight 80g Power supply Self power supply via local bus Digital input/static output module (M F I6 O6) Static outputs Maximum number of outputs 6 Type Opto-mosfet Features VON: 2.5 V dc, 100 mA max VOFF: 42 V dc max Functions Pulse output (kWh+, kWh-, kvarh+ or kvarh-) Alarm output Remote control Configuration parameters Function Alarm status Variable Pulse weight Configuration mode Via keypad or UCS software 16/05/2022 WM40 DS ENG CARLO GAVAZZI Controls SpA 36 Digital input/output modules Digital outputs Maximum number of outputs 6 Type voltage-free contacts Features 20Hz max, duty cycle 50% Open contact voltage: ≤3.3 V dc Closed contact current:
MCETHM 价格&库存
很抱歉,暂时无法提供与“MCETHM”相匹配的价格&库存,您可以联系我们找货
