RN218-0.4-02-100M
RN218-0.4-02-100M
    SCHAFFNER(夏弗纳)
    DIP4
    100 mH @ 10 kHz 2 线路共模扼流圈 通孔 400mA DCR 2.8 欧姆(标准)
RN218-0.4-02-100M 数据手册
DATA SHEET Common Mode Chokes RN series Current-compensated Chokes Rated currents from 0.3 to 10 A Approvals & Compliances DC to 400 Hz frequency 100 kHz to 3 MHz common-mode resonance frequency Dual-choke configurations Multiple PCB-mounting options Performance indicators RN chokes are attenuating common-mode or asymmetric (P/N –> E) interference signals, by being connected in series with the phase and neutral lines of an AC powerline input. Symmetrical components of the noise are also attenuated by the leakage inductance (stray inductance) of the windings. These chokes are typically used in conjunction with suppression capacitors. Features and Benefits High saturation resistance and excellent thermal behavior Through hole pin connections Dual-choke configuration Small compact design Multiple housing options Custom-specific versions are available on request Higher temperature versions Fully potted design usable for ruggedized applications Typical Applications Technical Specifications Switch-mode power applications Operating voltage 300 VAC Suppressing common-mode interference levels Operating frequency DC to 400 Hz EMI input filters Rated currents 0.3 to 10 A @ rated ambient temperature Rated inductance 0.4 to 100 mH For suppression-equipment with no earth connection Stray inductance Typically 1% of LN Inductance reduction (DC bias with IN) Less than 10% (25°C) High potential test voltage winding-towinding @ 25°C 1500 VAC, 60 sec, guaranteed 1500 VAC, 2 sec, factory test Winding-to-housing @ 25°C 4000 VAC, 60 sec, guaranteed MTBF @ 40°C/230 V (Mil-HB-217F) >5,000,000 hours Surge current @ 10 msec 20 x IN @ 25°C Temperature range (operation and storage) -40°C to 100°C (40/100/56) acc. IEC 60068-1 Flammability corresponding to Housing UL 94V-0 Potting compound UL 94V-0 Ringcore coating UL 94V-0 Design corresponding to UL 1283, IEC/EN 60938-1 Frequency (DC) 1 kHz Phase-angle control circuits in combination with saturating chokes Typical electrical schematic 2 Common Mode Chokes Schaffner Group DATA SHEET 04. Jul 2022 Choke Selection Table Choke Buy Current @ ambient Inductance Resistance A B H Weight (lN) temperature (LN) (RDC) [A] [°C] [mH] [mOhm] [mm] [mm] [mm] (g) RN102-0.3-02-22M 0.3 40 RN102-0.3-02-12M 0.3 40 22.0 1300 10.0 10.0 9.0 4 12.0 1100 10.0 10.0 9.0 3 RN102-0.6-02-4M4 0.6 40 4.4 380 10.0 10.0 9.0 3 RN102-1-02-3M0 RN102-1.5-02-1M6 1.0 40 3.0 210 10.0 10.0 9.0 3 1.5 40 1.6 94 10.0 10.0 9.0 3 RN102-2-02-1M1 2.0 40 1.1 70 10.0 10.0 9.0 3 RN112-0.4-02-39M 0.4 40 39.0 1500 15.0 10.0 12.6 6 RN112-0.4-02-27M 0.4 40 27.0 1400 15.0 10.0 12.6 6 RN112-0.5-02-27M 0.5 40 27.0 1200 15.0 10.0 12.6 6 RN112-0.5-02-18M 0.5 40 18.0 1100 15.0 10.0 12.6 6 RN112-0.5-02-15M 0.5 40 15.0 700 15.0 10.0 12.6 6 RN112-0.6-02-15M 0.6 40 15.0 490 15.0 10.0 12.6 6 RN112-0.8-02-10M 0.8 40 10.0 380 15.0 10.0 12.6 6 RN112-1.2-02-6M8 1.2 40 6.8 250 15.0 10.0 12.6 6 RN112-1.5-02-3M3 1.5 40 3.3 102 15.0 10.0 12.6 6 RN112-2-02-1M8 2.0 40 1.8 74 15.0 10.0 12.6 6 RN112-2-02-1M0 2.0 40 1.0 70 15.0 10.0 12.6 6 RN112-2.6-02-0M4 2.6 40 0.4 40 15.0 10.0 12.6 6 RN112-3.6-02-0M4 3.6 40 0.4 27 15.0 10.0 12.6 6 RN112-4-02-0M7 4.0 40 0.7 24 15.0 10.0 12.6 6 RN114-0.3-02-47M 0.3 40 47.0 1700 20.1 12.5 13.2 10 RN114-0.5-02-39M 0.5 40 39.0 830 20.1 12.5 13.2 11 RN114-0.8-02-27M 0.8 40 27.0 500 20.1 12.5 13.2 11 RN114-1-02-15M 1.0 40 15.0 370 20.1 12.5 13.2 10 RN114-1.2-02-10M 1.2 40 10.0 195 20.1 12.5 13.2 10 RN114-1.5-02-6M8 1.5 40 6.8 123 20.1 12.5 13.2 11 RN114-2-02-4M2 2.0 40 4.2 100 20.1 12.5 13.2 11 RN114-2.5-02-3M3 2.5 40 3.3 72 20.1 12.5 13.2 11 RN114-3-02-2M0 3.0 40 2.0 52 20.1 12.5 13.2 10 RN114-4-02-1M5 4.0 40 1.5 34 20.1 12.5 13.2 11 RN116-0.5-02-47M 0.5 60 47.0 960 20.1 12.5 13.2 11 RN116-0.5-02-39M 0.5 60 39.0 920 20.1 12.5 13.2 11 RN116-0.5-02-27M 0.5 60 27.0 790 20.1 12.5 13.2 11 RN116-0.8-02-27M 0.8 60 27.0 370 20.1 12.5 13.2 13 RN116-1-02-15M 1.0 60 15.0 260 20.1 12.5 13.2 12 RN116-1-02-10M 1.0 60 10.0 210 20.1 12.5 13.2 11 RN116-1.3-02-6M8 1.3 60 6.8 140 20.1 12.5 13.2 12 RN116-1.5-02-10M 1.5 60 10.0 148 20.1 12.5 13.2 12 RN116-1.7-02-4M0 1.7 60 4.0 87 20.1 12.5 13.2 12 RN116-2-02-3M3 2.0 60 3.3 70 20.1 12.5 13.2 12 RN116-2-02-2M2 2.0 60 2.2 66 20.1 12.5 13.2 11 RN122-0.5-02-56M 0.5 40 56.0 1800 25.0 15.0 16.5 20 RN122-0.6-02-47M 0.6 40 47.0 1300 25.0 15.0 16.5 20 RN122-0.8-02-39M 0.8 40 39.0 1000 25.0 15.0 16.5 20 RN122-1-02-18M 1.0 40 18.0 630 25.0 15.0 16.5 19 RN122-1-02-10M 1.0 40 10.0 560 25.0 15.0 16.5 19 RN122-1.5-02-10M 1.5 40 10.0 250 25.0 15.0 16.5 20 RN122-2-02-6M8 2.0 40 6.8 156 25.0 15.0 16.5 20 RN122-2-02-5M0 2.0 40 5.0 140 25.0 15.0 16.5 21 RN122-2.5-02-5M6 2.5 40 5.6 110 25.0 15.0 16.5 20 RN122-3-02-4M5 3.0 40 4.5 80 25.0 15.0 16.5 21 RN122-4-02-3M3 4.0 40 3.3 46 25.0 15.0 16.5 22 RN122-4-02-1M8 4.0 40 1.8 42 25.0 15.0 16.5 22 3 Common Mode Chokes Choke Schaffner Group Buy Current @ ambient Inductance Resistance (lN) temperature (LN) (R DC ) [A] [°C] [mH] RN142-0.5-02-82M 0.5 40 RN142-1-02-33M 1.0 RN142-1.4-02-27M 1.4 RN142-2-02-6M8 DATA SHEET 04. Jul 2022 A B H Weight [mOhm] [mm] [mm] [mm] (g) 82.0 2700 30.0 20.0 19.7 36 40 33.0 810 30.0 20.0 19.7 37 40 27.0 500 30.0 20.0 19.7 40 2.0 40 6.8 192 30.0 20.0 19.7 36 RN142-4-02-3M3 4.0 40 3.3 67 30.0 20.0 19.7 38 RN142-6-02-1M8 6.0 40 1.8 20 30.0 20.0 19.7 40 RN143-0.5-02-100M 0.5 40 100.0 2900 30.0 20.0 19.7 36 RN143-1-02-47M 1.0 40 47.0 890 30.0 20.0 19.7 38 RN143-2-02-10M 2.0 40 10.0 240 30.0 20.0 19.7 42 RN143-4-02-3M9 4.0 40 3.9 59 30.0 20.0 19.7 39 RN143-6-02-1M8 6.0 40 1.8 20 30.0 20.0 19.7 42 RN152-1-02-68M 1.0 40 68.0 1300 40.0 15.0 25.0 75 RN152-2-02-18M 2.0 40 18.0 450 40.0 15.0 25.0 64 RN152-4-02-6M8 4.0 40 6.8 87 40.0 15.0 25.0 74 RN152-6-02-3M9 6.0 40 3.9 42 40.0 15.0 25.0 68 RN152-8-02-2M7 8.0 40 2.7 22 40.0 15.0 25.0 73 RN152-10-02-1M8 10.0 40 1.8 14 40.0 15.0 25.0 73 RN202-0.3-02-22M 0.3 40 22.0 1300 5.1 15.2 13.5 4 RN202-0.3-02-12M 0.3 40 12.0 1100 5.1 15.2 13.5 4 RN202-0.6-02-4M4 0.6 40 4.4 380 5.1 15.2 13.5 4 RN202-1-02-3M0 1.0 40 3.0 210 5.1 15.2 13.5 4 RN202-1.5-02-1M6 1.5 40 1.6 94 5.1 15.2 13.5 4 RN202-2-02-1M1 2.0 40 1.1 70 5.1 15.2 13.5 4 RN204-0.3-02-22M 0.3 40 22.0 1300 7.6 10.0 14.3 3 RN204-0.3-02-12M 0.3 40 12.0 960 7.6 10.0 14.3 3 RN204-0.6-02-4M4 0.6 40 4.4 350 7.6 10.0 14.3 3 RN204-1-02-3M0 1.0 40 3.0 192 7.6 10.0 14.3 3 RN204-1.5-02-1M6 1.5 40 1.6 96 7.6 10.0 14.3 3 RN204-2-02-1M1 2.0 40 1.1 57 7.6 10.0 14.3 3 RN212-0.4-02-39M 0.4 40 39.0 1500 10.0 15.0 20.0 8 RN212-0.4-02-27M 0.4 40 27.0 1400 10.0 15.0 20.0 8 RN212-0.5-02-27M 0.5 40 27.0 1200 10.0 15.0 20.0 8 RN212-0.5-02-18M 0.5 40 18.0 1100 10.0 15.0 20.0 8 RN212-0.5-02-15M 0.5 40 15.0 700 10.0 15.0 20.0 8 RN212-0.6-02-15M 0.6 40 15.0 490 10.0 15.0 20.0 8 RN212-0.8-02-10M 0.8 40 10.0 380 10.0 15.0 20.0 8 RN212-1.2-02-6M8 1.2 40 6.8 250 10.0 15.0 20.0 8 RN212-1.5-02-3M3 1.5 40 3.3 102 10.0 15.0 20.0 8 RN212-2-02-1M8 2.0 40 1.8 74 10.0 15.0 20.0 8 RN212-2-02-1M0 2.0 40 1.0 70 10.0 15.0 20.0 8 RN212-2.6-02-0M4 2.6 40 0.4 40 10.0 15.0 20.0 8 RN212-3.6-02-0M4 3.6 40 0.4 27 10.0 15.0 20.0 8 RN212-4-02-0M7 4.0 40 0.7 24 10.0 15.0 20.0 8 RN214-0.3-02-47M 0.3 40 47.0 1700 12.5 10.0 25.0 14 RN214-0.5-02-56M 0.5 40 56.0 1700 12.5 10.0 25.0 15 RN214-0.5-02-39M 0.5 40 39.0 830 12.5 10.0 25.0 14 RN214-0.8-02-27M 0.8 40 27.0 500 12.5 10.0 25.0 15 RN214-1-02-15M 1.0 40 15.0 370 12.5 10.0 25.0 14 RN214-1.2-02-10M 1.2 40 10.0 195 12.5 10.0 25.0 15 RN214-1.5-02-6M8 1.5 40 6.8 123 12.5 10.0 25.0 15 RN214-2-02-4M2 2.0 40 4.2 100 12.5 10.0 25.0 14 4 Common Mode Chokes Choke Schaffner Group Buy Current @ ambient Inductance Resistance (lN) temperature (LN) (R DC ) [A] [°C] [mH] RN214-2-02-2M2 2.0 40 RN214-2.5-02-3M3 2.5 RN214-3-02-2M0 3.0 RN214-4-02-1M5 DATA SHEET 04. Jul 2022 A B H Weight [mOhm] [mm] [mm] [mm] (g) 2.2 67 12.5 10.0 25.0 14 40 3.3 72 12.5 10.0 25.0 15 40 2.0 52 12.5 10.0 25.0 14 4.0 40 1.5 34 12.5 10.0 25.0 15 RN216-0.5-02-47M 0.5 60 47.0 960 12.5 10.0 25.0 15 RN216-0.5-02-39M 0.5 60 39.0 920 12.5 10.0 25.0 15 RN216-0.5-02-27M 0.5 60 27.0 790 12.5 10.0 25.0 15 RN216-0.8-02-27M 0.8 60 27.0 370 12.5 10.0 25.0 16 RN216-1-02-15M 1.0 60 15.0 260 12.5 10.0 25.0 16 RN216-1-02-10M 1.0 60 10.0 210 12.5 10.0 25.0 15 RN216-1.3-02-6M8 1.3 60 6.8 140 12.5 10.0 25.0 16 RN216-1.5-02-10M 1.5 60 10.0 148 12.5 10.0 25.0 16 RN216-1.7-02-4M0 1.7 60 4.0 87 12.5 10.0 25.0 16 RN216-2-02-3M3 2.0 60 3.3 70 12.5 10.0 25.0 16 RN216-2-02-2M2 2.0 60 2.2 66 12.5 10.0 25.0 15 RN218-0.4-02-100M 0.4 40 100 2800 10.0 12.5 20.0 8 RN218-0.6-02-47M 0.6 40 47.0 1200 10.0 12.5 20.0 8 RN218-0.7-02-39M 0.7 40 39.0 1150 10.0 12.5 20.0 8 RN218-0.9-02-27M 0.9 40 27.0 620 10.0 12.5 20.0 8 RN218-1-02-22M 1.0 40 22.0 520 10.0 12.5 20.0 8 RN218-1.1-02-15M 1.1 40 15.0 420 10.0 12.5 20.0 8 RN218-1.4-02-10M 1.4 40 10.0 330 10.0 12.5 20.0 8 RN218-1.7-02-6M8 1.7 40 6.8 180 10.0 12.5 20.0 8 RN218-2.2-02-3M3 2.2 40 3.3 100 10.0 12.5 20.0 8 RN222-0.5-02-56M 0.5 40 56.0 1800 15.0 12.5 29.3 27 RN222-0.6-02-47M 0.6 40 47.0 1300 15.0 12.5 29.3 26 RN222-0.8-02-39M 0.8 40 39.0 1000 15.0 12.5 29.3 27 RN222-1-02-33M 1.0 40 33.0 1300 15.0 12.5 29.3 29 RN222-1-02-18M 1.0 40 18.0 630 15.0 12.5 29.3 26 RN222-1.5-02-10M 1.5 40 10.0 250 15.0 12.5 29.3 26 RN222-2-02-6M8 2.0 40 6.8 156 15.0 12.5 29.3 28 RN222-2.5-02-5M6 2.5 40 5.6 110 15.0 12.5 29.3 27 RN222-3-02-4M5 3.0 40 4.5 80 15.0 12.5 29.3 28 RN222-4-02-3M3 4.0 40 3.3 46 15.0 12.5 29.3 28 RN232-0.6-02-47M 0.6 40 47.0 1300 15.0 12.5 34.3 37 RN232-1-02-18M 1.0 40 18.0 390 15.0 12.5 34.3 38 RN232-1.6-02-10M 1.6 40 10.0 170 15.0 12.5 34.3 38 RN232-2.5-02-5M6 2.5 40 5.6 86 15.0 12.5 34.3 38 RN232-4-02-3M3 4.0 40 3.3 54 15.0 12.5 34.3 38 RN242-0.5-02-82M 0.5 40 82.0 2700 15.0 12.5 34.3 37 RN242-1-02-33M 1.0 40 33.0 810 15.0 12.5 34.3 38 RN242-1.4-02-27M 1.4 40 27.0 500 15.0 12.5 34.3 38 RN242-2-02-6M8 2.0 40 6.8 192 15.0 12.5 34.3 37 RN242-4-02-3M3 4.0 40 3.3 67 15.0 12.5 34.3 38 RN242-6-02-1M8 6.0 40 1.8 20 15.0 12.5 34.3 41 Test conditions: Measuring frequency: 10 kHz; 50 mV; Inductance tolerance: +50%, -30%; Resistance tolerance: ±15% @ 25°C; Electrical characteristics @ 25°C: ±2°C; Stray Inductance measurement between pin 1 and 2 (pin 3 and 4 shorted) For mechanical tolerances refer to mechanical data section. 5 Common Mode Chokes Schaffner Group Product selector Distribution Inventory Up-to-date inventory levels for global distributors is available at https://products.schaffner.com/stock Thermal Derating If higher ambient temperatures than the specified apply, the nominal current needs to be reduced according to the graph below. Graph on the left side applies to RN with rated ambient temperature of 40 °C, right side for rated ambient temperature of 60 °C. DATA SHEET 04. Jul 2022 6 Common Mode Chokes Schaffner Group Typical Attenuation/Resonance Frequency Characteristics Per CISPR 17; 50 Ω/50 Ω asym X can be exchanged with either 1 or 2 for different housing configuration, attenuation is similar RN 102, RN 202 RN 204 RN 112, RN 212 (1 A) RN 114, RN 214 RN 116, RN 216 DATA SHEET 04. Jul 2022 7 Common Mode Chokes Schaffner Group RN 218 RN 122, RN 222 RN 232 RN 142, RN 242 RN 143 RN 152 DATA SHEET 04. Jul 2022 Common Mode Chokes Schaffner Group DATA SHEET 04. Jul 2022 Mechanical Data RN 112, RN 114, RN 116, RN 122, RN 142/3 3 4 1 2 P L 1 H L B 1 P B 2 4 3 L 1 2 L P 4 3 2 1 3 4 B 2 3 1 H P 1 4 3 2 P A H W 4 4 RN 212, RN 218 A W 3 4 2 P RN 204 A 3 1 1 P P RN 202 3 2 H 4 3 2 1 W L 4 P 1 A W 3 B P B 4 2 H P A W H W A RN 152 B RN 102 2 L P RN 214, RN 216, RN 222, RN 232, RN 242 A H 4 1 2 4 3 2 1 L P W 3 B 8 P Pin material: Steel (base), Cu (under plating), Sn (final plating 6µm) Dimensions A B H L W P ØP (±0.6 mm) (±0.6 mm) (±0.3 mm) (±0.3 mm) (±0.3 mm) (±0.5 mm) (±0.1 mm) RN 102 10.0 mm 10.0 mm 9.0 mm 14.0 mm 14.0 mm 4.0 mm 0.6 mm RN 112 15.0 mm 10.0 mm 12.6 mm 17.7 mm 17.1 mm 4.0 mm 0.8 mm RN 114 20.1 mm 12.5 mm 13.2 mm 22.5 mm 21.5 mm 4.0 mm 0.8 mm RN 116 20.1 mm 12.5 mm 13.2 mm 22.5 mm 21.5 mm 4.0 mm 0.8 mm RN 122 25.0 mm 15.0 mm 16.5 mm 28.0 mm 27.0 mm 4.0 mm 0.8 mm RN 142 30.0 mm 20.0 mm 19.7 mm 33.1 mm 32.5 mm 4.3 mm 0.8 mm RN 143 30.0 mm 20.0 mm 19.7 mm 33.1 mm 32.5 mm 4.3 mm 0.8 mm RN 152 40.0 mm 15.0 mm 25.0 mm 43.0 mm 41.8 mm 4.5 mm 1.2 mm RN 202 5.1 mm 15.2 mm 13.5 mm 8.8 mm 18.2 mm 4.5 mm 0.8 mm RN 204 7.6 mm 10.0 mm 14.3 mm 9.0 mm 14.0 mm 4.0 mm 0.5 mm RN 212 10.0 mm 15.0 mm 20.0 mm 12.5 mm 18.0 mm 4.0 mm 0.8 mm RN 214 12.5 mm 10.0 mm 25.0 mm 15.5 mm 23.0 mm 4.0 mm 0.8 mm RN 216 12.5 mm 10.0 mm 25.0 mm 15.5 mm 23.0 mm 4.0 mm 0.8 mm RN 218 10.0 mm 12.5 mm 20.0 mm 12.5 mm 18.0 mm 4.0 mm 0.8 mm RN 222 15.0 mm 12.5 mm 29.3 mm 18.0 mm 31.0 mm 4.0 mm 0.8 mm RN 232 15.0 mm 12.5 mm 34.3 mm 18.0 mm 31.0 mm 4.2 mm 0.8 mm RN 242 15.0 mm 12.5 mm 34.3 mm 18.0 mm 31.0 mm 4.2 mm 0.8 mm Please visit www.schaffner.com to find more details on filter connections. 9 Common Mode Chokes Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road, Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 04. Jul 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
RN218-0.4-02-100M 价格&库存
很抱歉,暂时无法提供与“RN218-0.4-02-100M”相匹配的价格&库存,您可以联系我们找货
