KMDMIX-NS3A-WS-BTR
KMDMIX-NS3A-WS-BTR
    KYCON
    SMD
    HDMI连接器 19Pin SMD
KMDMIX-NS3A-WS-BTR 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KMDMIX-NS3A-WS-BTR Part Number Builder KMDMIX NS3 A WS B Series Shield Option Boardlock Option Top Spring Insulator Option HDMI(TM):KMDMIX Series Mini Connector, Right Angle SMT HDMI(TM) Supports Deep Color over HDMI(TM) 19 Position Receptacle Smaller, More Compact Form Than The Traditional HDMI(TM) Counterpart Provides Low Impedance Mismatch Materials and Finish Housing High Temp Thermoplastic, UL94V-0 Rated, Color Black Contacts Phosphor Bronze Shield Nickel Plated Plating Standard - 30µ” Gold in Front Contacts and Gold Flash in Solder Area Insulator Option B - Black Packaging Option TR - Tape and Reel Contact Kycon for Other Options KMDMIX-NS3 Dimensions in mm 7.5 0.50±0.10 KMDMIX-NS3A-WS-BTR 11.20 10.5+0.03 -0.04 8.1±0.04 7.2 0.4 0.25+0.04 -0.02 Pin 1 3.2 Pin 19 7.50±0.05 8.3+0.1 -0.0 1.00 Durability 5000 Mating Cycles Min. Operating Temperature -25°C to +85°C Top Spring WS - With Top Spring 2.5+0.04 -0.03 Mechanical Characteristics Boardlock Option A - Standard Straight 1.22±0.05 1.8±0.06 Rated Voltage 40V AC (RMS) Rated Current 0.5Amps Min. Contact Resistance 10 milliohms Max. Insulation Resistance 100 Megohms Min. Dielectric Withstanding Voltage 500V AC RMS for 1 Min. Shield Option NS3 - Vertical SMT Shield Tabs, Flange 0.3+0.1 -0.0 Electrical Characteristics Packaging Option Series KMDMIX - HDMI(TM) Mini Connector Product Features Performance Specifications TR 0.80 2.00 1.00 0.80 4.50 10.85 Ø0.80±0.05 0.40 0.15±0.05 7.20 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0922
KMDMIX-NS3A-WS-BTR 价格&库存
很抱歉,暂时无法提供与“KMDMIX-NS3A-WS-BTR”相匹配的价格&库存,您可以联系我们找货
KMDMIX-NS3A-WS-BTR
  • 1+25.252661+3.26418
  • 10+21.4215210+2.76896
  • 25+20.0757025+2.59500
  • 50+19.1151450+2.47084
  • 100+18.20210100+2.35282
  • 250+17.06234250+2.20549
库存:2203
KMDMIX-NS3A-WS-BTR
  • 750+15.78966750+2.04098
  • 1500+15.036421500+1.94362
  • 2250+14.612682250+1.88885
  • 3750+14.095893750+1.82205
  • 5250+13.765675250+1.77936
库存:2203
