KUSBX-SLAS1N-W30
KUSBX-SLAS1N-W30
    KYCON
    插件
    USB连接器 4P SMD 端口数:1 额定电流:1A 额定电压:30V 工作温度:-25℃~+85℃
KUSBX-SLAS1N-W30 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBX-SLAS1N-W30 Part Number Builder KUSBX-SL Product Features Upright Flag Style Reduces PCB Footprint Compatible with Many Computer Peripherals Supports Hot Plugging Meets USB 2.0 Specifications Contact Area with Gold Plating CSA/NRTL Certified File No. LR78160 UL File No. E134345 Materials and Finish Insulator PBT Thermoplastic, UL94 V-0 Rated, White or Black Color Contact Material Phosphor Bronze Contact Plating Option Gold over Nickel on Contacts Tin over Nickel on Termination End Shell Copper Alloy Insulator Color Option Plating Option Series KUSBX-SL - Flag Style Universal Serial Bus Type AS1N - A Type Insulator Color Option B - Black W - White Plating Option Blank - Gold Flash 30 - 30µ” Gold Contact Kycon for other options KUSBX-SL Dimensions in mm 7.4 Electrical Characteristics 19.30 ref. 5.12 13.85 ref. 14.7 12.5 1.1 pos. 4 pos. 1 3.8 Rated Voltage 30V AC Rated Current 1.5A Contact Resistance 30 milliohms Max Insulation Resistance 1000 Megohms Min. Dielectric Withstanding Voltage 500V AC Operating Temperature See Drawing 30 Type 2.30 Performance Specifications W 5.72 ref. UNIVERSAL SERIAL BUS: KUSBX-SL Series Flag Stype Type A Receptacle, USB 2.0 Series AS1N 9.90 ref. 11.8 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0120 7.0
KUSBX-SLAS1N-W30 价格&库存
很抱歉,暂时无法提供与“KUSBX-SLAS1N-W30”相匹配的价格&库存,您可以联系我们找货
KUSBX-SLAS1N-W30
  • 1+13.429521+1.73591
