KUSBX-SMT-AS1N-W30
KUSBX-SMT-AS1N-W30
    KYCON
    SMD
    USB连接器 4P SMD 端口数:1 额定电流:1A 额定电压:30V 工作温度:-40℃~+85℃
KUSBX-SMT-AS1N-W30 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBX-SMT-AS1N-B Part Number Builder LR78160 KUSBX-SMT UNIVERSAL SERIAL BUS: KUSBX-SMT Series Surface Mount USB Series Surface Mount Compatible with Many Computer Peripherals A and B Types Available Supports Hot Plugging Contact Area with Gold Plating CSA/NRTL Certified File No. LR78160 UL File No. E134345 Plating Option Packaging Type AS1N - A Type BS1N - B Type Insulator Color Option B - Black W - White Performance Specifications Materials and Finish Insulator High Temperature Thermoplastic, UL94V-0 Rated, White or Black Color Contacts Phosphor Bronze Contact Plating Gold over Nickel on Contacts Tin over Nickel on Termination End Shell Copper Alloy, Nickel Plated over Copper Plating Option Blank - Gold Flash 30 - 30µ" Gold Plating Packaging Blank - Bulk TR - Tape and Reel Contact Kycon for more options KUSBX-SMT Dimensions in mm KUSBX-SMT-AS1N 12.5 5.12 7.0 7.05 pos. 4 7.05 14.6 7.1 pos. 1 2.50 10.3 14.5 4.3 2.50 2.00 13.35 KUSBX-SMT-BS1N Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013 7.0 13.1 14.0 Rated Voltage 30V AC Rated Current 1A Contact Resistance 30 milliohms Max. Insulation Resistance 1000 Megohms Min. Dielectric Withstanding Voltage 500V AC For 1 Minute Operating Temperature See Drawing Insulator Color Type Series KUSBX-SMT - Surface Mount Universal Serial Bus Product Features Electrical Characteristics B AS1N
KUSBX-SMT-AS1N-W30 价格&库存
很抱歉,暂时无法提供与“KUSBX-SMT-AS1N-W30”相匹配的价格&库存,您可以联系我们找货
KUSBX-SMT-AS1N-W30
  • 1+10.024401+1.29851
