RBMT-14
RBMT-14
    SOURIAUCONNECTIONTECHNOLOGY(苏里奥)
    Module
    CONN GRND TRACK 14.000" L
RBMT-14 数据手册
RB Modules Description Applications Grounding and wiring integration devices for commercial/military aircraft. Standards Characteristics Material • Ground block body : aluminum alloy • Feed back modules body : polyphenylene sulfide (PPS) • Ground track body : PPS • Ground block cap and insert : PPS • Grommet and ground track strain : silicone rubber • Relief grommet contact : copper alloy Protection • Contact gold (1.27µm) over nickel (1,91 µm) Mechanical • Magnetic permeability : materials do not exhibit a relative magnetic permeability of greater than 2, in accordance with MIL-T-81714, para 4.6.15 • Contact retention : size 16-20 : 88,9 N size 14-16 : 112,2 N • Probe damage : in accordance with MIL-T-81714 para 4.6.2 • Endurance : 100 cycles of mating and unmating Electrical • Contact resistance : size 16-20 : 9 mΩ size 14-16 : 5 mΩ • Withstanding voltage : sea level : 1500 VRms in accordance with MIL-T 81714 Altitude : 600 VRms in accordance with MIL-T 81714 • Insulation resistance : 5000 MΩ (feedback modules only) • Insulation resistance : 50 MΩ after (elevated temperature) 1000 hours at 150°C feedback modules only • RB series meet the electrical, mechanical and environmental performances criteria of MIL-J-81714. • The system provides a large number of ground terminations within close proximity to signal wires («HERF» requirements). • Modules available in five buss configurations and designed to accommodate # 16 and # 20 AWG cables terminated with M39029 contacts. • Program switch module contains 2, 12 positions single pole, single throw DIP switches in a sealed compartment that is accessed by removing captured sealing plugs. • Other switches such as SEDT, DPBT, DPST and 4PST can also be accommodate. Climatical • Resistance to salt spray humidity vibration in accordance shock with MIL-T-81714 thermal shock temperature : 1000 hours at 150°C Ordering information Ground & Mounting track,ground block, and feedback module FCI Burndy Part number RBGB20-777 RBGB16-777 RBTB20-2 RBTB20-4 RBTB20-8 RBTB16-3 RBTB16-6 RBGT2 RBGT4 RBGT6 RBGT10 RBGT14 RBGT16 RBGT22 RBGT26 RBMT2 RBMT4 RBMT6 RBMT10 RBMT14 RBMT16 RBMT22 RBMT26 RBD20-1 RBD20-3 RBR20-2 RBR20-3 RBR20-4 RBR20-5 RBM20M-1DJ5 RBM18M-1DJ5 RBM16V-1DJ5 RBM12Z-1DJ5 196 Boeing Part number S280W555-1 S280W555-2 S280W555-102 S280W555-104 S280W555-108 S280W555-203 S280W555-206 S280W555-502 S280W555-504 S280W555-506 S280W555-510 S280W555-514 S280W555-516 S280W555-522 S280W555-526 S280W555-602 S280W555-604 S280W555-606 S280W555-610 S280W555-614 S280W555-616 S280W555-622 S280W555-626 S280W555-751 S280W555-753 S280W555-702 S280W555-703 S280W555-704 S280W555-705 Description Ground block module - 16 x 20 AWG Ground block module - 12 x 16 AWG Terminal feedback module - 2 x 8 bus - 20 AWG Terminal feedback module - 4 x 4 bus - 20 AWG Terminal feedback module - 8 x 2 bus - 20 AWG Terminal feedback module - 3 x 4 bus - 16 AWG Terminal feedback module - 6 x 2 bus - 16 AWG Terminal module ground track - 2.00 in. Terminal module ground track - 4.00 in. Terminal module ground track - 6.00 in. Terminal module ground track - 10.00 in. Terminal module ground track - 14.00 in. Terminal module ground track - 16.00 in. Terminal module ground track - 22.00 in. Terminal module ground track - 26.00 in. Terminal module ground track - 2.00 in. Terminal module ground track - 4.00 in. Terminal module ground track - 6.00 in. Terminal module ground track - 10.00 in. Terminal module ground track - 14.00 in. Terminal module ground track - 16.00 in. Terminal module ground track - 22.00 in. Terminal module ground track - 26.00 in. Terminal diode module - JANTX1N6818 Terminal diode module - JANTX1N5553 Terminal resistor module - RLR07C4301 FR Terminal resistor module - RLR07C1202 FR Terminal resistor module - RLR07C4992 FR Terminal resistor module - Mat disp brightness control M39029/1-101 pin contact - size 16-20 M39029/1 special pin contact - size 16-18 M39029/1-102 pin contact - size 14-16 M39039/1-103 pin contact - size 12-12 RB Modules Rack & panel and right angle mounting ground blocks and program switch module FCI Burndy Part number RBGP16-1 RBGP48-1 RBGP104-1 RBGS16-1 RBGS32-1 RBDSC-1 Boeing Part number Description Rack and panel mounting ground block Rack and panel mounting ground block Rack and panel mounting ground block Right angle mounting ground shelf strip Right angle mounting ground shelf strip Program switch module S280W555-401 S280W555-402 Ground block assembly P/N RBGB 20-777 P/N RBG 16-777 Feedback module P/N RBTB 20-4 Grounding track assembly Mounting track assembly P/N RBGT 2 RBM T 2 197 RB Modules Feedback module mounted in grounding track Feedback module mounted in mounting track RBG T2 / RBT B 20 - 4 RBM T 2 / RB T B 20 - 4 Diode / resistor module assembly Feedback module mounted in track with resistor module RBD 20 - 3 RBM T 2 / RBR 20 - 3 / RBT B 20 - 4 Program switch module RBDSC - 1 198
RBMT-14 价格&库存
很抱歉,暂时无法提供与“RBMT-14”相匹配的价格&库存,您可以联系我们找货
