GMX-SMT2-S-88-TR
GMX-SMT2-S-88-TR
    KYCON
    SMD
    模块化连接器 - 插孔 8p8c(RJ45,以太网) 90°角(直角) 屏蔽
GMX-SMT2-S-88-TR 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number GMX-SMT2-S6-88 Part Number Builder LR78160 MODULAR JACKS AND PLUGS: GMX-SMT2 Series Surface Mount Modular Jack Product Features Low Profile Design Suitable for PC Add-On Board Applications Available in 4, 6, 8, and 10 Position Housings Available Fully Shielded for EMI/RFI Protection CSA/NRTL Certified File No. LR78160 UL File No. E134345 Performance Specifications Materials and Finish Housing Material High Temperature Thermoplastic, Reflow Compatible, UL 94V-0 Rated, Black Color Shield Material Copper Alloy, Nickel Plated Contact Material Phosphor Bronze Electrical Characteristics Insulation Resistance 500 Megohms Min. Dielectric Withstanding Voltage 1000V RMS, 60Hz Contact Resistance 20 milliohms Max. Current Rating 1.0A Voltage Rating 125V DC Operating Temperature -40°C to +85°C Durability 1000 Mating Cycles Min. GMX-SMT2 S6 88 Series Shield Option No. of Positions & Contacts Plating Options Packaging Options Series GMX-SMT2 - Surface Mount Right Angle Modular Jack with Post Shield Options N - Non-Shielded S - Shielded with Thru Hole Shield Pins S2 - Shielded with SMT Shield Tabs (only with 66, 88 and 1010) S6 - Shielded with Top and Side Grounding Tabs, SMT Shield Pins (Available only with 8 Positions) S7 - Fully Shielded with Top and Side Grounding Tabs, Thru Hole Shield (Available only with 8 Positions) Number of Positions / Contacts 44 - 4 Positions / 4 Contacts (Only N Option ) 64 - 6 Positions / 4 Contacts 66 - 6 Positions / 6 Contacts 88 - 8 Positions / 8 Contacts 1010 - 10 Positions / 10 Contacts Plating Option Blank - Gold Flash 50 - 50µ" Gold Plating Packaging Option Blank - Bulk TR - Tape & Reel Contact Kycon for Other Options GMX-SMT2 Series Dimensions in mm GMX-SMT2-N-88 Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
GMX-SMT2-S-88-TR 价格&库存
很抱歉,暂时无法提供与“GMX-SMT2-S-88-TR”相匹配的价格&库存,您可以联系我们找货
