10381300
10381300
    LAPP(缆普)
    Module
    3 模块 母头 高负载 固定框架,铰链式 尺寸 黑色
10381300 数据手册
EPIC® Industrial Connectors EPIC® Rectangular Connector Inserts 276 Reference278 EPIC® HBE Series 295 304 EPIC® HA Series ® EPIC HQ Series 308 EPIC® STA Series 310 ® EPIC HEE Series 313 EPIC® HBS Series 317 ® EPIC HBVE Series 319 EPIC® HD Series 321 EPIC® HDD Series 340 EPIC® MC Series 344 EPIC® Mixed Power Series 363 xed Power Series Inserts with Combination Power & Signal Contacts EPIC® Rectangular Connector Housings 366 Reference367 EPIC® HB Series 369 EPIC® ULTRA HB Series 394 ® EPIC HA Series 399 EPIC® CIRCON LS1 Series EPIC® Circular Connectors 423 Reference424 EPIC® CIRCON LS1 Connectors 425 EPIC® CIRCON M23 Series 431 ® EPIC ZYLIN R3.0 Series 438 EPIC® EAB & EAC Series 441 ® EPIC EPT Series 450 Product Selection EPIC® Pin & Sleeve Connectors 459 Reference461 Product Selection for North America Standard 469 Product Selection for International Standard 472 Dimensional Data for 20/16 Amps  475 Dimensional Data for 30/32 Amps 479 Dimensional Data for 60/63 Amps 483 Dimensional Data for 100/125 Amps 486 ® EPIC Pin & Sleeve Accessories 487 Cordsets488 Technical Data 489 EPIC® EPT Series EPIC® RECTANGULAR CONNECTOR INSERTS Rectangular Connector Inserts Reference EPIC® Brand Overview EPIC® Housing Overview EPIC® Plugs & Receptacles Overview Quick Select Charts: Plugs & Receptacles 278 280 281 283 Quick Select Summary: Plugs & Receptacles Quick Select Summary: Contacts & Tools Quick Select Summary: Housings Diagrams: Hoods & Bases 285 288 290 293 EPIC® HBE Series 295 EPIC® HBE 6 Inserts EPIC® HBE 10 Inserts EPIC® HBE 16 Inserts EPIC® HBE 24 Inserts EPIC® HBE 32 Inserts EPIC® HBE 48 Inserts 297 298 299 301 302 303 EPIC® HA Series 304 Terminate your ÖLFLEX® Cable with the Right EPIC® Connector Inserts for Medium Power & Control Applications Compact Inserts for Medium Power & Control Applications EPIC® HA 3/4 Inserts 305 EPIC® HA 10 Inserts 305 ® EPIC HA 16 Inserts 306 ® EPIC HA 32 Inserts 306 EPIC® HA 48 Inserts 307 ® EPIC HA 64 Inserts307 EPIC® HQ Series 308 EPIC® HQ 5 Inserts 309 EPIC® STA Series 310 EPIC® STA 6 Inserts EPIC® STA 14 Inserts EPIC® STA 20 Inserts EPIC® STA 40 Inserts 311 311 312 312 EPIC® HEE Series 313 EPIC® HEE 10 Inserts EPIC® HEE 18 Inserts EPIC® HEE 32 Inserts EPIC® HEE 46 Inserts EPIC® HEE 64 Inserts EPIC® HEE 92 Inserts 314 314 315 315 316 316 Compact Inserts with 5+PE Contacts for Power & Control Applications Inserts with Solid Spring-Designed Contacts for Control Applications Inserts with High Contact Density for Power & Control Applications 276 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBS Series 317 EPIC® EPIC® HBS 6 Inserts EPIC® HBS 12 Inserts 318 318 Rectangular Connector Inserts EPIC® HBVE Series 319 EPIC® HBVE 3 Inserts EPIC® HBVE 6 Inserts EPIC® HBVE 10 Inserts 320 320 320 EPIC® HD Series 321 EPIC® HD 7 Inserts EPIC® HD 8 Inserts EPIC® HD 15 Inserts EPIC® HD 25 Inserts EPIC® HD 40 Inserts EPIC® HD 50 Inserts EPIC® HD 64 Inserts EPIC® HD 80 Inserts EPIC® HD 128 Inserts 323 325 326 328 330 332 334 336 338 EPIC® HDD Series 340 EPIC® HDD 24 Inserts EPIC® HDD 42 Inserts EPIC® HDD 72 Inserts EPIC® HDD 108 Inserts EPIC® HDD 144 Inserts EPIC® HDD 216 Inserts 341 341 342 342 343 343 EPIC® MC Series 344 EPIC® MC 2 - 20 Contact Modules EPIC® MC Dummy Modules EPIC® MC 4 Cage Clamp Modules EPIC® MC PROFIBUS DP Modules EPIC® MC Ethernet Modules EPIC® MC Universal Bus Modules EPIC® MC Pneumatic Modules EPIC® MC Module Frames 347 358 358 358 359 359 360 360 EPIC® Mixed Power Series 363 EPIC® Mixed Power 4 Power + 0 Signal Inserts EPIC® Mixed Power 4 Power + 2 Signal Inserts EPIC® Mixed Power 4 Power + 8 Signal Inserts 365 365 365 Inserts for High Current Capacity for Power Applications High-Voltage Inserts with Two Switch Contacts for Power Applications Compact Inserts with High Contact Density for Control Applications Compact Inserts with Extremely High Contact Density for Control Applications Modular Inserts for Custom Configurations Inserts with Combination Power & Signal Contacts 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 277 EPIC® Rectangular Connector Inserts Reference EPIC® Brand Overview PIN & SLEEVE CIRCULAR RECTANGULAR Connector Type Application Number of Contacts Rated Voltage HBE 6, 10, 16, 24, 32, 48 (+PE) 600V HA 3, 4, 10, 16, 32, 48, 64 (+PE) 600V HQ 5 (+PE) 600V STA 6, 14, 20, 40 48V HEE 10, 18, 32, 46, 64, 92 (+PE) 600V HBS 6, 12 (+PE) 600V HBVE 3, 6, 10 (+PE) 600V HD 7, 8, 15, 25, 40, 50, 64, 80, 128 (+PE) 600V HDD 24, 42, 72, 108, 144, 216 (+PE) 600V MC 2 - 280, Data Bus (+PE), Pneumatic 30V - 1000V MP 4/0, 4/2, 4/8 (+PE) 600V EAB 3, 14 500V EAC 4, 6, 17 200V, 500V, 900V EPT 5, 6, 8+4, 10, 19 600V, 1000V LS1 5+PE, 3+PE+4 600V M23 6, 7, 8+1, 9, 12, 16, 17 50V, 100V, 150V MULTIMAX 1+N+PE, 2+PE, 3+PE, 3+N+PE 125V - 600V CEE 1+N+PE, 2+PE, 3+PE, 3+N+PE 125V - 500V ULYSSE 1+N+PE, 2+PE, 3+PE, 3+N+PE 125V - 500V ALUPRES 1+N+PE, 2+PE, 2+N+PE, 3+PE, 3+N+PE 125V - 500V Power EPIC® Rectangular Connectors 278 Control/ Signal Data EPIC® ULTRA Rectangular Connectors 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Reference Rectangular Connector Inserts EPIC® Brand Overview Rated Current Termination Type* Wire Range (AWG) Housing IP/NEMA Rating 16A SC, CR, CC 20 - 14, 20 - 12 HB IP65, NEMA 4, 4X, 12 10A, 14A SC 20 - 14 HA IP65, NEMA 4, 12 16A CR 20 - 12 HA IP65, NEMA 4, 12 10A SC, SOL 20 - 16 HA IP65, NEMA 4, 12 16A CR 20 - 12 HB IP65, NEMA 4, 4X, 12 35A SC 20 - 10 HB IP65, NEMA 4, 4X, 12 16A SC 20 - 14 HB IP65, NEMA 4, 4X, 12 10A CR 26 - 14 HA, HB IP65, NEMA 4, 4X, 12 8.5A CR 26 - 14 HB IP65, NEMA 4, 4X, 12 1A - 82A SC, CR, CC, HO 28 - 4 HB IP65, NEMA 4, 4X, 12 16A, 80A SC 12 - 6, 20 - 14 HB IP65, NEMA 4, 4X, 12 13A, 23A CR 18 - 16, 14 - 12 E, M, J, S up to IP67 MIL-C-5015 13A, 23A CR 18 - 16, 14 -12 E, M, J, S up to IP67 MIL-C-5015 7.5A, 13A CR 24 - 20, 20 - 16 E, M, J, S up to IP67 MIL-C-26482 26A, 27A CR 20 - 12, 24 - 18 LS1 IP67, IP68 7A, 14A CR, SOL 18 - 14, 26 - 18 M23 IP67, IP68 16A - 32A SC 16 - 12, 12 - 8 MULTIMAX IP44 16A - 125A SC 16 - 12, 12 - 8, 10 - 6, 4 - 1 CEE IP67 16A - 63A SC 16 - 12, 12 - 8, 10 - 6 ULYSSE IP66, IP67 16A - 63A SC 16 - 12, 12 - 8, 10 - 6 ALUPRES IP67, IP55 Approvals * Termination Type: SC = Screw, CR = Crimp, CC = Cage Clamp, SOL = Solder, HO = Hose EPIC® Circular Connectors 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Pin & Sleeve Connectors 279 EPIC® Rectangular Connector Inserts Reference Overview: EPIC® Housings EPIC® HB Series Standard Gray (NEMA 4, IP65) PG NPT EPIC® HA Series Standard Gray (NEMA 4, IP65) Metric ULTRA PG NPT Metric * Please note that all EPIC® rectangular plugs and receptacles fit either into a HB or a HA series housing. Strain Relief: Strain relief provides a seal between the cable and the connector housing. It may also be used to offer additional functions like strain relief and braid continuity for EMC protection. Hood: The connector housing allows for cable entry and protects the contact terminations from physical and environmental damage. EPIC® rectangular hoods are available as top-entry or sideentry in a variety of sizes and entry thread types (PG, NPT, or metric). Male & Female Inserts: The inserts house and insulate the contacts. Types of contact termination: • Screw termination •C  rimp termination (stamped & formed or machined) * Crimp contacts must be purchased separately • Cage clamp (screwless spring) Base: Mates with the hood to complete the connection • Panel Mount: cable entry through cut out in panel. • Surface Mount: cable entry through a gland into the side of the connector base. •C  able Connector Hood: cable-to-cable connection; the cable connector mates with a top-entry hood. This is frequently used to extend cables. Technical Data Specifications: DIN 43652 Temperature Range: - EPIC® ULTRA: -40°C to +125°C -40°C to +100°C Protection Class*: IP65, NEMA 4, NEMA 12, or IP65, NEMA 4X, NEMA 12 (consult for availability) Materials: - EPIC® ULTRA HB 6 - 24: Nickel plated zinc; stainless steel locking levers & bolts - EPIC® HB 6 - 48 & EPIC® HA 10 - 64: Aluminum alloy; powder-coated (gray RAL 7001); zinc-plated steel locking levers & bolts - EPIC® HA 3/4: Die-cast zinc; powder-coated or thermoplastic flame-retardant material rated UL 94 V-0 (gray or black plastic) EPIC® rectangular connectors shall comply with all applicable requirements of Underwriters Laboratory (UL) Standards 1977 & 498, VDE Standard 0110 for creepage and clearance distances and VDE Standard 0627 for the connector design. The EPIC® HD and HDD series are developed according to DIN Standard 43652. Approvals * EPIC® connectors meet protection class standards only when in the mated condition. 280 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Reference Rectangular Connector Inserts EPIC® HBE page 295 EPIC® HA Technical Data # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: page 310 Technical Data # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: page 321 Technical Data # of Contacts: EPIC® HQ EPIC® HEE 7, 8, 15, 25, 40, 50, 64, 80, 128 (+PE) Rated Voltage: 600V Rated Current: 10A Termination: Crimp Wire Size: 22 - 14 AWG (0.14 - 2.5 mm2) 10, 18, 32, 46, 64, 92 (+PE) Rated Voltage: 600V Rated Current: 16A Termination: Crimp Wire Size: 20 - 12 AWG (0.5 - 4 mm2) page 340 Technical Data # of Contacts: EPIC® HBS page 317 Technical Data # of Contacts: EPIC® HDD Technical Data 10A 14A Screw 20 - 14 AWG (0.5 - 2.5 mm2) page 313 24, 42, 72, 108, 144, 216 (+PE) Rated Voltage: 600V Rated Current: 8.5A Termination: Crimp Wire Size: 22 - 14 AWG (0.14 - 2.5 mm2) page 308 # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: 3, 4, 10, 16, 32, 48, 64 (+PE) 600V Technical Data 6, 14, 20, 40 (+PE) 48V 10A Screw, solder 20 - 16 AWG (0.5 - 1.5 mm2) EPIC® HD page 304 Technical Data # of Contacts: Rated Voltage: Rated Current: - HA 3/4: - HA 10 - 64: Termination: Wire Size: 6, 10, 16, 24, 32, 48 (+PE) 600V 16A Screw, crimp, cage clamp 20 - 14 AWG (0.5 - 2.5 mm2) Crimp available in 12 AWG (4 mm2) EPIC® STA Overview: EPIC® Plugs & Receptacles # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: page 344 Technical Data # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: 2 - 280 (+PE) 30 - 1000V 1 - 82A Screw, crimp, coax, cage clamp 28 - 4 AWG (0.06 - 25 mm2) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBVE page 319 Technical Data 6, 12 (+PE) 600V 35A Screw 20 - 10 AWG (0.5 - 6 mm2) EPIC® MC 5 (+PE) 600V 16A Crimp 20 - 14 AWG (0.5 - 2.5 mm2) # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: 3, 6, 10 (+PE) 600V 16A Screw 20 - 14 AWG (0.5 - 2.5 mm2) EPIC® Mixed Powerpage 363 Technical Data # of Contacts: 4 pwr, 4 pwr/2 sig, 4 pwr/8 sig Rated Voltage: 600V Rated Current: 16A, 80A Termination: Screw Wire Size: ≤ 6 AWG (16 mm2) - Power - Signal ≤14 AWG (2.5 mm2) 281 EPIC® Rectangular Connector Inserts Reference Wire Size (AWG) Termination Type Rated Current UL Rated Voltage # of Conductors +PE Overview: EPIC® Plugs & Receptacles 282 Connector Type HBE HA HQ STA HEE HBS HBVE HD HDD MC MP page 295 304 308 310 313 317 319 321 340 344 363 3 4 5 6 7 8 10 12 14 15 16 18 20 24 25 32 40 42 46 48 50 64 72 80 92 108 128 144 216 2-280 4 pwr + 0 sig 4 pwr + 2 sig 4 pwr + 8 sig 48V 600V 30V - 1000V 380V - 600V 8.5A 10A 14A 16A 35A 1A - 82A 16A - 80A Cage Clamp Crimp Screw Solder 20 - 16 26 - 14 20 - 14 up to 14 20 - 12 20 - 10 30 - 4 up to 6 (3/4) (sig) (crimp) (pwr) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Reference Rectangular Connector Inserts Quick Select Chart Terminate Your ÖLFLEX Cable With The Right EPIC® Connector ® Wire Gauge # of Conductors (incl. ground) 6 AWG 3 4 5 3 4 5 3 4 5 7 2 3 4 5 7 2 3 4 5 7 9 12 18 25 2 3 4 5 7 9 12 18 25 34 41 50 60 61 2 3 4 5 7 9 12 18 25 34 41 50 61 2 3 4 5 7 9 10 12 18 24 25 34 (16 mm ) 2 8 AWG (10 mm2) 10 AWG (6 mm2) 12 AWG (4 mm2) 14 AWG (2.50 mm2) 16 AWG (1.50 mm2) 18 AWG (1.00 mm2) 20 AWG (0.50 mm2) HBE HA HQ STA HEE HBS HBVE HD HDD MC MP 16A see note 16A 10 A 16A 35A 16A 10A 8.5A see note see note MC 2 MC 2 Power Power Power Power Power Power Power Power Power HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 10 HBE 16 HBE 24 HBE 24 HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 10 HBE 16 HBE 24 HBE 24 HBE 48 HBE 48 HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 10 HBE 16 HBE 24 HBE 24 HBE 48 HBE 48 HBE 6 HBE 6 HBE 6 HBE 6 HBE 6 HBE 10 HBE 10 HBE 16 HBE 24 HBE 24 HBE 24 HBE 48 HA 3 HA 3 HA 3 HA 4 HA 10 HA 10 HA 16 HA 32 HA 32 HA 3 HA 3 HA 3 HA 4 HA 10 HA 10 HA 16 HA 32 HA 32 HA 48 HA 48 HA 64 HA 64 HA 64 HA 3 HA 3 HA 3 HA 4 HA 10 HA 10 HA 16 HA 32 HA 32 HA 48 HA 48 HA 64 HA 64 HA 3 HA 3 HA 3 HA 4 HA 10 HA 10 HA 10 HA 16 HA 32 HA 32 HA 32 HA 48 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 HQ 5 STA 6 STA 6 STA 6 STA 6 STA 6 STA 14 STA 14 STA 20 STA 40 STA 40 STA 40 STA 6 STA 6 STA 6 STA 6 STA 6 STA 14 STA 14 STA 20 STA 40 STA 40 STA 40 STA 6 STA 6 STA 6 STA 6 STA 6 STA 14 STA 14 STA 14 STA 20 STA 40 STA 40 STA 40 HEE 10 HEE 10 HEE 18 HEE 18 HEE 32 HEE 10 HEE 10 HEE 18 HEE 18 HEE 32 HEE 46 HEE 46 HEE 64 HEE 64 HEE 64 HEE 10 HEE 10 HEE 18 HEE 18 HEE 32 HEE 46 HEE 46 HEE 64 HEE 64 HEE 10 HEE 10 HEE 10 HEE 18 HEE 18 HEE 32 HEE 32 HEE 46 HBS 6 HBS 6 HBS 6 HBS 6 HBS 6 HBS 6 HBS 6 HBS 6 HBS 6 HBS 6 HBVE 3 HBS 6 HBVE 3 HBS 6 HBVE 3 HBS 6 HBVE 6 HBS 6 HBVE 6 HBS 12 HBVE 10 HBS 12 HBS 6 HBVE 3 HBS 6 HBVE 3 HBS 6 HBVE 3 HBS 6 HBVE 6 HBS 6 HBVE 6 HBS 12 HBVE 10 HBS 12 HBS 6 HBVE 3 HBS 6 HBVE 3 HBS 6 HBVE 3 HBS 6 HBVE 6 HBS 6 HBVE 6 HBS 12 HBVE 10 HBS 12 HBS 6 HBVE 3 HBS 6 HBVE 3 HBS 6 HBVE 3 HBS 6 HBVE 6 HBS 6 HBVE 6 HBS 12 HBVE 10 HBS 12 HBVE 10 HBS 12 HD 7 HD 7 HD 7 HD 7 HD 7 HD 8 HD 15 HD 24 HD 24 HD 7 HD 7 HD 7 HD 7 HD 7 HD 8 HD 15 HD 24 HD 24 HD 40 HD 40 HD 50 HD 64 HD 64 HD 7 HD 7 HD 7 HD 7 HD 7 HD 8 HD 15 HD 24 HD 24 HD 40 HD 40 HD 50 HD 64 HD 7 HD 7 HD 7 HD 7 HD 7 HD 8 HD 15 HD 15 HD 24 HD 24 HD 24 HD 40 HDD 24 HDD 24 HDD 24 HDD 24 HDD 42 HDD 42 HDD 72 HDD 72 HDD 72 HDD 24 HDD 24 HDD 42 HDD 42 HDD 72 HDD 72 HDD 24 HDD 24 HDD 24 HDD 42 MC 2, MC 3 MC 2, MC 3 MC 3 x2 MC 2, MC 3 MC 2, MC 3 MC 3 x2 MC 3 x2 MC 3 MC 3 MC 3, MC 4, MC 5 MC 4, MC 5 MC 3 x2 MC 3 MC 3 MC 3, MC 4, MC 5 MC 4, MC 5 MC 10 MC 10 MC 10 x2 MC 10 x2 MC 10 x3 MC 3 MC 3 MC 3, MC 4, MC 5 MC 4, MC 5 MC 10 MC 10 MC 10 x2 MC 10 x2 MC 10 x3 MC 10 x4 MC 10 x4 MC 10 x5 MC 10 x6 MC 10 x6 MC 4 MC 4 MC 4, MC 5 MC 4, MC 5 MC 10 MC 10 MC 10 x2 MC 10 x2 MC 10 x3 MC 10 x4 MC 10 x4 MC 10 x5 MC 10 x6 MC 4 MC 4 MC 4, MC 5 MC 4, MC 5 MC 10 MC 10 MC 10 MC 20 MC 20 MC 20 x2 MC 20 x2 MC 20 x2 Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Signal Note: The amperage for all series listed in black can be found at the top of the column. Amperages for HA, MC & MP Series are as follows: 4 Amps 10 Amps 14 Amps 16 Amps 20 Amps 25 Amps 50 Amps 80 Amps 83 Amps • T he above chart shows the relationship between cable wire gauge and conductor count with connector contact count. Final connector selection and application suitability will depend on voltage and current limits of the cable and connector. • T he MC Series modular connector offers a wide variety of mix-and-match combinations. The combinations shown in the above chart are offered as suggestions based on providing a solution in the smallest housing size. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 283 EPIC® Rectangular Connector Inserts Reference Quick Select Chart Terminate Your ÖLFLEX® Cable With The Right EPIC® Connector Wire Gauge 22 AWG (0.34 mm2) with or without ground 24 AWG (0.25 mm2) 26 AWG (0.14 mm2) with or without ground 28 AWG (0.08 mm2) with or without ground # of Conductors (incl. ground) 2 3 4 5 7 8 10 12 14 15 16 18 20 21 25 28 30 32 36 40 44 50 61 5 7 8 10 12 14 15 16 18 20 21 25 28 30 32 36 40 44 50 61 10 12 14 15 16 18 20 21 25 28 30 32 36 40 44 50 61 HBE HA HQ STA HEE HBS HBVE HD HDD MC MP 16A see note 16A 10A 16A 35A 16A 10A 8.5A see note see note HDD 24 HDD 24 HDD 24 HDD 24 HDD 42 HDD 42 HDD 42 HDD 42 HDD 42 HDD 72 HDD 72 HDD 72 MC 10 MC 10 MC 10 MC 10 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x3 MC 20 x3 MC 20 x3 HD 7 HD 7 HD 7 HD 7 HD 7 HD 7 HD 15 HD 15 HD 15 HD 15 HD 15 HD 24 HD 24 HD 24 HD 24 HD 40 HD 40 HD 40 HD 40 HD 40 HD 50 HD 50 HD 64 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x3 MC 20 x3 MC 20 x3 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x2 MC 20 x3 MC 20 x3 MC 20 x3 Note: The amperage for all series listed in black can be found at the top of the column. Amperages for HA, MC & MP Series are as follows: 4 Amps 10 Amps 14 Amps 16 Amps 20 Amps 25 Amps 50 Amps 80 Amps 83 Amps • T he above chart shows the relationship between cable wire gauge and conductor count with connector contact count. Final connector selection and application suitability will depend on voltage and current limits of the cable and connector. • T he MC Series modular connector offers a wide variety of mix-and-match combinations. The combinations shown in the above chart are offered as suggestions based on providing a solution in the smallest housing size. 284 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Reference Rectangular Connector Inserts Quick Select Summary: Plugs & Receptacles EPIC® HBE Technical Data # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: Cage Clamp Description Crimp-Terminated Contacts not included. HBE 6 page 297 Screw-Terminated HBE 10 page 298 Screw-Terminated with Wire Protection Plug 10190000 10192000 Receptacle 10191000 10193000 Screw-Terminated without Wire Protection Plug 10190100 10192100 Receptacle 10191100 10193100 Crimp-Terminated Plug 10180000 10182000 Receptacle 10181000 10183000 Screwless Cage Clamp Plug 10400000 10400100 Receptacle 10401000 10401100 Terminal Block Receptacles Left Ground — — Right Ground — — † * HBE 32 = HBE 16 (x2) HBE 48 = HBE 24 (x2) 6, 10, 16, 24, 32, 48 (+PE) 600V 16A Screw, crimp, cage clamp 20 - 14 AWG (0.5 - 2.5 mm2) Crimp available in 12 AWG (4 mm2) HBE 16 page 299 HBE 24 page 301 HBE 32* page 303 HBE 48† page 303 10194000 10195000 10196000 10197000 10202000 10203000 10204000 10205000 10194100 10195100 10196100 10197100 10202100 10203100 10204100 10205100 10184000 10185000 10186000 10187000 10184200 10185200 10186200 10187200 10400200 10401200 10400300 10401300 10400400 10401400 10400500 10401500 70314100 70315100 70316100 70317100 — — — — Mating Housings Insert Housing HBE 6 HBE 10 HBE 16 HBE 24 HBE 32 HBE 48 HB 6 HB 10 HB 16 HB 24 HB 32 HB 48 Use 2.5 mm crimp contacts: page 288 EPIC® HA Technical Data # of Contacts: Rated Voltage: Rated Current: - HA 3/4: - HA 10 - 64: Description HA 3 page 304 HA 4 page 304 3, 4, 10, 16, 32, 48, 64 (+PE) 600V Termination: Wire Size: Screw 20 - 14 AWG (0.5 - 2.5 mm2) 10A 14A HA 10 page 305 EPIC HA: Screw-Terminated with Wire Protection Plug 10420000 10431000 10440100 Receptacle 10421000 10432000 10441100 EPIC® HA: Screw-Terminated without Wire Protection Plug — — 10440000 Receptacle — — 10441000 † ♦ HA 48 = HA 16 (x3) HA 64 = HA 16 (x4) * HA 32 = HA 16 (x2) HA 16 page 306 HA 32* page 306 HA 48† page 307 HA 64♦ page 307 10530000 10531000 10540000 10541000 10540100 10541100 105300LE64 105310LE64 10532000 10533000 10542000 10543000 10542100 10543100 — — Mating Housings Insert Housing HA 3/4 HA 10 HA 16 HA 32 HA 48 HA 64 HA 3/4 HA 10 HA 16 HA 32 HA 48 HA 64 ® EPIC® HQ EPIC® STA Technical Data Technical Data # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: Contacts not included. Description Plug Receptacle HQ 5 page 309 10431500 10432500 Mating Housings Insert Housing HQ 5 HA 3/4 # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: 5 (+PE) 600V 16A Crimp 20 - 14 AWG (0.5 - 2.5 mm2) Use 2.5 mm crimp contacts: page 288 Description STA 6 page 311 Screw-Terminated Plug 10488100 Receptacle 10486100 Solder-Terminated Plug 10487200 Receptacle 10485200 * STA 40 = STA 20 (x2) STA 14 page 311 STA 20 page 312 10493100 10491100 10503100 10501100 10492200 10490200 10502200 10500200 6, 14, 20, 40* (+PE) 48V 10A Screw, solder 20 - 16 AWG (0.5 - 1.5 mm2) Mating Housings Insert Housing STA 6 STA 14 STA 20 STA 40 HA 3/4 HA 10 HA 16 HA 32 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 285 EPIC® Rectangular Connector Inserts Reference Quick Select Summary: Plugs & Receptacles EPIC® HEE Technical Data # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: Contacts not included. Description Plug Receptacle Mating Housings 10, 18, 32, 46, 64, 92 (+PE) 600V 16A Crimp 20 - 12 AWG (0.5 - 4.0 mm2) * HEE 64 = HEE 32 (x2) † HEE 92 = HEE 46 (x2) HEE 46 page 315 HEE 64* page 316 HEE 92† page 316 10180400 10181400 10182400 10183400 10184400 10185400 10186400 10187400 10184500 10185500 10186500 10187500 EPIC® HBVE HBS 12* page 318 6, 12 (+PE) 600V 35A Screw 20 - 10 AWG (0.5 - 6.0 mm2) 10170600 10171600 Housing HBS 6 HBS 12 HB 16 HB 32 HBVE 3 page 320 HBVE 6 page 320 3, 6, 10 (+PE) 600V 16A Screw 20 - 14 AWG (0.5 - 2.5 mm2) HBVE 10 page 320 Mating Housings Screw-Terminated with Wire Protection Plug 10210010 10239010 10270010 Receptacle 10211010 10240010 10271010 Screw-Terminated without Wire Protection Plug 10210110 10239110 10270110 Receptacle 10211110 10240110 10271110 Mating Housings Insert Technical Data # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: Description 10170000 10171000 HB 6 HB 10 HB 16 HB 24 HB 32 HB 48 HEE 32 page 315 # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: Plug Receptacle HEE 10 HEE 18 HEE 32 HEE 46 HEE 64 HEE 92 Use 2.5 mm crimp contacts: page 288 HEE 18 page 314 Technical Data HBS 6 page 318 Housing HEE 10 page 314 EPIC® HBS Description Insert * HBS 12 = HBS 6 (x2) Insert Housing HBVE 3 HBVE 6 HBVE 10 HB 10 HB 16 HB 24 EPIC® HD Technical Data # of Contacts: 7, 8, 15, 25, 40, 50, 64, 80, 128 (+PE) Rated Voltage: 600V Rated Current: 10A Termination: Crimp Wire Size: 26 - 14 AWG (0.14 - 2.5 mm2) Contacts not included. Description Mating Housings Housing Insert Housing HD 7, 8 HD 15 HD 25 HD 40 HA 3/4 HA 10 HA 16 HB 16 HD 50 HD 64 HD 80 HD 128 HA 32 HB 24 HB 32 HB 48 Use 1.6 mm machined contacts: page 288 Use 1.6 mm stamped contacts: page 288 HD 8 page 325 Machined Contacts Plug 11250500 11252500 Receptacle 11251500 11253500 Stamped & Formed Contacts Plug 11250000 — Receptacle 11251000 — Description Insert HD 7 page 323 HD 50* page 332 Machined Contacts Plug 11283300 Receptacle 11282300 Stamped & Formed Contacts Plug 11260000 Receptacle 11261000 * HD 50 = HD 25 (x2) † HD 15 page 326 HD 25 page 328 HD 40 page 330 11283200 11282200 11283300 11282300 11265200 11266200 11255000 11256000 11260000 11261000 11265000 11266000 HD 64 page 334 HD 80† page 336 HD 128♦ page 338 11272000 11273000 11265200 11266200 11272000 11273000 11270000 11271000 11265000 11266000 11270000 11271000 HD 80 = HD 40 (x2) ♦ HD 128 = HD 64 (x2) EPIC® HDD Technical Data Contacts not included. Description Plug Receptacle 286 # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: Mating Housings 24, 42, 72, 108, 144, 216 (+PE) 600V 8.5A Crimp 26 - 14 AWG (0.14 - 2.5 mm2) Insert Housing HDD 24 HDD 42 HDD 72 HDD 108 HDD 144 HDD 216 HB 6 HB 10 HB 16 HB 24 HB 32 HB 48 Use 1.6 mm machined contacts: page 288 * HDD 144 = HDD 72 (x2) † HDD 216 = HDD 108 (x2) HDD 24 page 341 HDD 42 page 341 HDD 72 page 342 HDD 108 page 342 HDD 144* page 343 HDD 216† page 343 11285000 11286000 11285100 11286100 11285200 11286200 11285300 11286300 11285400 11286400 11285500 11286500 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Reference Rectangular Connector Inserts Quick Select Summary: Plugs & Receptacles EPIC® Mixed Power Technical Data # of Contacts: Rated Voltage: Rated Current: Description Plug Receptacle Termination: Wire Size: - Power: - Signal: 4 pwr + 0 sig, 4 pwr + 2 sig, 4 pwr + 8 sig 600V 16 - 80A 4 pwr + 0 sig page 365 4 pwr + 2 sig page 365 MP/M400 MP/F400 Screw up to 6 AWG (16 mm2) up to 14 AWG (2.5 mm2) 4 pwr + 8 sig page 365 MP/M402 MP/F402 11/2408 11/1408 Mating Housings Insert Housing 4p/0s 4p/2s 4p/8s HB 16 HB 16 HB 24 EPIC® Modular Connectors Technical Data # of Contacts: Rated Voltage: Rated Current: Termination: Wire Size: Color of components may be different than shown Contacts (next 2 pages) Modules 2 Contact Module: 2 Working Contacts 2 Contact Module: 1 Working Contact, 1 Ground 3 Contact Coax Module 3 Contact Module 3 Contact Module: High Voltage 4 Contact Module 4+PE Contact Module: High Voltage 5 Contact Module 10 Contact Module: Machined Contacts 10 Contact Module: Stamped & Formed Contacts 20 Contact Module Dummy Module 4 Contact Cage Clamp Module PROFIBUS DP Module Ethernet Module: RJ45 connectors + 4 power contacts Universal Bus Modules Pneumatic Module: 1 Port with 2.5 mm Hose Diameter (inside) Pneumatic Module: 1 Port with 4.0 mm Hose Diameter (inside) Pneumatic Module: 2 Ports with 2.5 mm Hose Diameter (inside) Pneumatic Module: 2 Ports with 4.0 mm Hose Diameter (inside) Frames Frame for 2 Modules Frame for 3 Modules Frame for 5 Modules Frame for 7 Modules Frame for 10 Modules Frame for 14 Modules Coax 3.6 mm Machined 3.6 mm Machined 2.5 mm Machined 2.5 mm Stamped 2.5 mm Machined 1.6 mm Machined 1.6 mm Stamped 1.0 mm Stamped 2 - 280 (+PE) 30 - 1000V 1 - 82A Screw, crimp, coax, cage clamp 28 - 4 AWG (0.06 - 25 mm2) Plug Receptacle Rated Voltage Rated Current Page 10344100 10344600 10399200 10382000 10399800 10399000 10383200 10382200 10382400 10383400 10383600 10399400 10399600 10390400 10344300 10390600 44424004 44424006 44424008 44424010 10345100 10345600 10399300 10382100 10399900 10399100 10383300 10382300 10382500 10383500 10383700 10399500 10399700 10390500 10345300 10390700 44424005 44424007 44424009 44424011 1000V 1000V 250V 630V 1000V 630V 1000V 400V 250V 250V 100V — 400V 30V 600V 30V 145psi 145psi 145psi 145psi 82A 82A — 40A 50A 25A 16A 20A 10A 10A 4A — 14A 1A 10A 1A — — — — 348 348 349 350 351 352 353 354 355 356 357 358 358 358 359 359 360 360 360 360 For Plugs For Receptacles Corresponding Housing Page 10381000 10381200 10381400 10381600 10381400 (x2) 10381600 (x2) 10381100 10381300 10381500 10381700 10381500 (x2) 10381700 (x2) HB 6 HB 10 HB 16 HB 24 HB 32 HB 48 360 360 361 361 362 362 * Modules snap into frames. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 287 EPIC® Rectangular Connector Inserts Reference Quick Select Summary: Contacts & Tools Machined Contacts: 2.5 mm diameter for HBE crimp, HEE, HQ & MC Part # 10399000 & 10399100 Accessories Crimp Tool: 11147000 Locator: 11147200 Crimp Die: 11147100 Removal Tool: 11182500 Part number = 1 contact, sold in bags of 100 Silver AWG mm2 Pin 20 18 16 14 12 0.5 0.75 - 1.0 1.5 2.5 4.0 11190000 11190100 11190200 11190300 11190400 1 µ Gold Socket Pin 11195000 11195100 11195200 11195300 11195400 11192000 11192100 11192200 — — 2 µ Gold Socket Pin 11197000 11197100 11197200 — — 11194000 11194100 11194200 — — Socket 11199000 11199100 11199200 — — Machined Contacts: 1.6 mm diameter for HD machine, HDD & MC Part # 10382400 & 10382500 Accessories Crimp Tool: 11147000 Locator: 11147200 Crimp Die: 11147100 Removal Tool: 11161000 Part number = 1 contact, sold in bags of 100 Silver AWG mm2 Pin 26 - 22 20 18 16 14 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 13162000 13162100 13162200 13162300 13162400 Gold Socket Pin 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 Socket 13163500 13163600 13163700 13163800 13163900 Stamped & Formed Contacts: 1.6 mm diameter for HD stamped & MC Part # 10383400 & 10383500 Accessories Crimp Tool: - for contacts: Crimp Dies for Contacts: - 26 - 20 AWG: 11147170 - 20 - 16 AWG: 11147180 - 16 - 14 AWG: 11147190 Part number = 1 contact, sold in bags of 100 or 1 reel * 11223000 and 11228000 are sold in reels of 100 only Locator: - 26 - 16 AWG: Silver AWG mm2 Pin 26 - 20 20 - 16 16 - 14 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 11241100 11221000 11223500 AWG mm2 Pin 26 - 20 20 - 16 16 - 14 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 11240000 11220000 — 11147000 Crimp Tool for Reel: (includes tool, die, & locator) - 26 - 20 AWG: 11147004 - 20 - 16 AWG: 11147005 - 16 - 14 AWG: 11147006 Removal Tool: 11161000 11147300 Gold Socket Pin 11231100 11236100 11228500 11243100 11221300 — Reel of 200 Socket Pin 11233100 11238100 — 11240700 11220700 11223000* Socket 11230700 11235700 11228000* Reel of 2000 Right-hand Feed - Silver Socket 11230000 11235000 — Pin Right-hand Feed - Gold Socket — 11220100 — — 11235200 — Pin Left-hand Feed - Silver Socket 11240400 11226000 11222700 11230400 11226500 11227700 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 288 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Reference Rectangular Connector Inserts Quick Select Summary: Contacts & Tools Silver Machined Contacts: 2.5 mm diameter for MC Part # 10382200 & 10382300 Accessories Crimp Tool: 11147000 Locator: 11147200 Crimp Die: 11147100 Removal Tool: 11171000 Part number = 1 contact, sold in bags of 100 Accessories Crimp Tool: - for contacts: - for reel: Part number = 1 contact, sold in bags of 100 AWG mm2 Pin Socket 20 18 16 14 12 0.5 0.75 - 1.0 1.5 2.5 4.0 1121300C 1121310C 1121320C 1121330C 1121340C 1121800C 1121810C 1121820C 1121830C 1121840C Stamped & Formed Contacts: 2.5 mm diameter for MC Part # 10383200 & 10383300 11147000 11153500 Crimp Dies for Contacts: - 20 - 16 AWG: 11147180 - 16 - 14 AWG: 11147190 Silver AWG mm2 Pin 20 - 16 16 - 14 0.5 - 1.5 1.5 - 2.5 11201000 11202000 Crimp Dies for Reel: - 20 - 16 AWG: - 16 - 14 AWG: 11153700 11153800 Locator for Contacts: 11147300 Removal Tool: 11160000 Socket Pin 11205000 11206000 11208000 11208500 Reel of 200 Socket 11209000 11209500 Silver Machined Contacts: 3.6 mm diameter for MC Part # 10382000 & 10382100, 10399800 & 10399900 Accessories Part number = 1 contact, sold in bags of 100 Crimp Tool: 11147000 Crimp Dies: - 16 - 14 AWG: - 12 - 8 AWG: 11147110 11147120 Locator: 11147210 Removal Tool: 11171100 AWG mm2 Pin Socket 16 14 12 10 8 1.5 2.5 4.0 6.0 10 1121070C 1121060C 1121000C 1121010C 1121020C 1121570C 1121560C 1121500C 1121510C 1121520C Gold Stamped & Formed D-Sub Contacts: 1.0 mm for MC Part # 10383600 & 10383700 Coax Contacts for MC Part # 10399200 & 10399300 Accessories Accessories Crimp Tool: 11158400 Crimp Tool: Removal Tool: 11132500 Crimp Die: 11147130 Part number = 1 contact, sold in bags of 100 Removal Tool: 11147000 11171100 AWG mm2 Pin Socket Size Pin Socket 28 - 25 25 - 20 0.08 - 0.2 0.2 - 0.52 44429013 44429014 44429009 44429010 RG 58 11214200 11219200 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 289 EPIC® Rectangular Connector Inserts Reference Quick Select Summary: Housings EPIC® HB Series Housings with Single Lever on Base EPIC® HB Series Rectangular Connectors Description PG NPT HB 6 HB 10 Top Entry Hood with Single Lever Bolts 13.5 ½” 100110 — 16 ½” 100210 100409 21 ¾” — 100407 29 1” — — 36 1¼” — — 42 — — — Top Entry High Profile Hood with Single Lever Bolts 21 ¾” 700202 700442 29 1” 700204R 700444 Side Entry Hood with Single Lever Bolts 13.5 ½” 100120 — 16 ½” 100220 100429 21 ¾” — 100428 29 1” — — 36 1¼” — — 42 — — — Side Entry High Profile Hood with Single Lever Bolts 21 ¾” 700222 700542 29 1” 700224R 700544 Panel Mount Base with Single Lever without dust cover — — 10030C0 10032900 with dust cover — — 10040C0 10033900 with dust cover, no bolts — — — — Surface Mount Base with Single Lever 2 entries 16 ½” 100060 100359 1 entry 16 ½” 100050 100349 2 entries with dust cover 16 ½” 100090 100389 1 entry with dust cover 16 ½” 100070 100369 2 entries 21 ¾” — — 1 entry 21 ¾” — 100347 2 entries with dust cover 21 ¾” — — 1 entry with dust cover 21 ¾” — — High Profile Surface Mount Base with Single Lever 2 entries 21 ¾” 700062 700612 1 entry 21 ¾” 700052 700602 2 entries with dust cover 21 ¾” 700162 700652 1 entry with dust cover 21 ¾” 700152 700642 2 entries 29 1” — 700614 1 entry 29 1” 700054 700604 2 entries with dust cover 29 1” — 700654 1 entry with dust cover 29 1” — 700644 2 entries 36 1¼” — — 1 entry 36 1¼” — — 2 entries with dust cover 36 1¼” — — 1 entry with dust cover 36 1¼” — — Cable Coupler Hood with Single Lever 13.5 ½” 100140 — 16 ½” 100240 100469 21 ¾” — 700422 29 1” — — High Profile Cable Coupler Hood with Single Lever 21 ¾” 700102 700424 29 1” 700104 700426 Complete with a PG SKINTOP® HB 16 HB 24 HB 48 Gray Black Metal MS-SC — — 100809 — — — — — 101219 101119 — — — — — 101550 101560 101570 53015030 53015040 53015050 53015060 53015070 53015080 53015330 53015340 53015350 53015360 53015370 53015380 52015700 52015740 52015750 52015760 52015765 52015766 53112230 53112240 53112250 53112260 53112270 — 700942 700944 701444 701446 — — 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 — — 100829 100929 — — — — 101139 101239 — — — — — 101580 101590 101600 53015030 53015040 53015050 53015060 53015070 53015080 53015330 53015340 53015350 53015360 53015370 53015380 52015700 52015740 52015750 52015760 52015765 52015766 53112230 53112240 53112250 53112260 53112270 — 701042 701044 701544 701546 — — 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 10072900 10073900 — 10102900 10103900 — 10161000 10152500 10152000 — — — — — — — — — — — — — — — — 100759 100749 100789 100769 — — — — 101059 101049 101099 101079 — — — — — — — — 53015040 53015040 53015040 53015040 53015050 53015050 53015050 53015050 53015340 53015340 53015340 53015340 53015350 53015350 53015350 53015350 52015740 52015740 52015740 52015740 52015750 52015750 52015750 52015750 53112240 53112240 53112240 53112240 53112240 53112250 53112250 53112250 701112 701102 701152 701142 701114 701104 701154 701144 — — — — 701612 701602 701652 701642 701614 701604 701654 701644 — — — — — — — — 101660 101650 101682 101670 101661 101651 101681 101671 53015050 53015050 53015050 53015050 53015060 53015060 53015060 53015060 53015070 53015070 53015070 53015070 53015350 53015350 53015350 53015350 53015360 53015360 53015360 53015360 53015370 53015370 53015370 53015370 52015750 52015750 52015750 52015750 52015760 52015760 52015760 52015760 52015765 52015765 52015765 52015765 53112250 53112250 53112250 53112250 52015760 52015760 52015760 52015760 53112270 53112270 53112270 53112270 — — 100869 — — — 101279 101179 — — — — 53015030 53015040 53015050 53015060 53015330 53015340 53015350 53015360 52015700 52015740 52015750 52015760 53112230 53112240 53112250 53112260 70092200 70092400 701424 701426 — - 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 For NPT parts: add “NP” to the end of 6-digit part numbers or replace the last two digits of an 8-digit part number with “NP”. Metric parts are also available. 290 EPIC® connectors mate with SKINTOP® glands without locknuts. Use of tapered (NPT) threads is not recommended with EPIC® rectangular connectors, unless a thread sealant is used. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Reference Rectangular Connector Inserts Quick Select Summary: Housings EPIC® HB Series Housings with Double Levers on Base EPIC® HB Series Rectangular Connectors PG Description NPT HB 10 HB 16 Top Entry Hood with Double Lever Bolts 16 ½” 100400 — 21 ¾” 100401 100800 29 1” — 100900 36 1¼” — — Top Entry High Profile Hood with Double Lever Bolts 21 ¾” 700504 701002 29 1” 700506 701004 Side Entry Hood with Double Lever Bolts 16 ½” 100420 — 21 ¾” 100421C0 100820 29 1” — 100920 Side Entry High Profile Hood with Double Lever Bolts 21 ¾” 700524 701022 29 1” 700526 701024 Panel Mount Base with Double Levers — — 100320C0 100720C0 Surface Mount Base with Double Levers 2 entries 16 ½” 100350 — 1 entry 16 ½” 100340 — 2 entries 21 ¾” — 100750 1 entry 21 ¾” — 100740 2 entries 29 1” — — 1 entry 29 1” — — High Profile Surface Mount Base with Double Levers 2 entries 21 ¾” 700362 700862 1 entry 21 ¾” 700352 700852 2 entries 29 1” 700364 700864 1 entry 29 1” 700354 700854 Cable Coupler Hood with Double Levers 16 ½” 100460 — 21 ¾” 700402 100860 29 1” — 100960C0 High Profile Cable Coupler Hood with Double Levers 21 ¾” 700404R — 29 1” 700406 700904 Complete with a PG SKINTOP® HB 24 HB 32 Gray Black Metal MS-SC — 101210 101110 — — 101330 101340 — 53015040 53015050 53015060 53015070 53015340 53015350 53015360 53015370 52015740 52015750 52015760 52015765 53112240 53112250 53112260 53112270 701504 701506 — — 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 — 101130 101230 — 101350 101360 53015040 53015050 53015060 53015340 53015350 53015360 52015740 52015750 52015760 53112240 53112250 53112260 701524 701526 — — 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 101020C0 101320C0 — — — — — — 101050 101040 — — — — — — 101380 101370 53015040 53015040 53015050 53015050 53015060 53015060 53015340 53015340 53015350 53015350 53015360 53015360 52015740 52015740 52015750 52015750 52015760 52015760 53112240 53112240 53112250 53112250 53112260 53112260 701362 701352 701364 701354 — — — — 53015050 53015050 53015060 53015060 53015350 53015350 53015360 53015360 52015750 52015750 52015760 52015760 53112250 53112250 53112260 53112260 — 101270 101170 — 101390 101395 53015040 53015050 53015060 53015340 53015350 53015360 52015740 52015750 52015760 53112240 53112250 53112260 701404R 701406 — — 53015050 53015060 53015350 53015360 52015750 52015760 53112250 53112260 For NPT parts: add “NP” to the end of 6-digit part numbers or replace the last two digits of an 8-digit part number with “NP”. Metric parts are also available. EPIC® connectors mate with SKINTOP® glands without locknuts. Use of tapered (NPT) threads is not recommended with EPIC® rectangular connectors, unless a thread sealant is used. EPIC® HA 3/4 Rectangular Connectors with Single Lever on Base Rectangular Hoods PG with cable gland Material PG Zinc Die Cast 11 Black Plastic 11 Gray Plastic 11 NPT Top Entry Side Entry Surface Mount Bases & Cable Coupler Hoods NPT without cable gland Top Entry ½” 10426500 10427500 105121NP ½” 10426700 10620600 104255NP ½” 10426400 10427100 104260NP PG with cable gland Panel Mount Bases NPT without cable gland Side Entry Base Coupler Base 105123NP 104273NP 104270NP 10424500 — 10424200 10429500 10620300 10429100 105127NP — 104240NP Coupler Standard Angled With Cover 105129NP 10422500 10423500 44429015 104292NP 10422200 10423100 104290NP 10422000 10423000 - Complete with a SKINTOP® PG 11 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com Gray Black Metal 53015020 53015320 52015720 MS-SC 53112220 291 EPIC® Rectangular Connector Inserts Reference Quick Select Summary: Housings EPIC® HA Series Connectors with Single Lever on Base EPIC® HA Series Rectangular Connectors Description PG NPT Top Entry Hood with Single Lever Bolts 13.5 ½” 16 ½” 21 ¾” 29 1” 36 1¼” 42 — Side Entry Hood with Single Lever Bolts 16 ½” 21 ¾” 29 1” 36 1¼” 42 — Panel Mount Base with Single Lever without dust cover — — with dust cover — — with dust cover, no bolts — — Description PG NPT Surface Mount Base with Single Lever 2 entries 16 ½” 1 entry 16 ½” 2 entries 21 ¾” 1 entry 21 ¾” 2 entries 29 1” 1 entry 29 1” 2 entries with dust cover 29 1” 1 entry with dust cover 29 1” 2 entries 36 1¼” 1 entry 36 1¼” 2 entries with dust cover 36 1¼” 1 entry with dust cover 36 1¼” Description PG NPT Cable Coupler Hood with Single Lever 13.5 ½” 16 ½” 29 1” Complete with a PG SKINTOP® HA 10 Standard HA 10 High Profile HA 16 Standard HA 16 High Profile HA 64 Gray Black Metal MS-SC 104460 104461 — — — — — 704602 704604 — — — — 105650 105652 — — — — 704902 704904 — — — — — — 101550HA 101560HA 101570HA 53015030 53015040 53015050 53015060 53015070 53015080 53015330 53015340 53015350 53015360 53015370 53015380 52015800 52015810 52015820 52015830 52015831 52015832 53112230 53112240 53112250 53112260 53112270 — 104450 104455 — — — 704622 704624 — — — 105640 105645 — — — 704922 704924 — — — — — 101580HA 101590HA 101600HA 53015040 53015050 53015060 53015070 53015080 53015340 53015350 53015360 53015370 53015380 52015810 52015820 52015830 52015831 52015832 53112240 53112250 53112260 53112270 — 104420C0 704440C0 — — — — 104620C0 704740C0 — — — — 101610HA 101525HA 101520HA — — — — — — — — — — — — HA 10 HA 10 with cover HA 16 HA 16 with cover HA 64 Gray Black Metal MS-SC 104501 104481 104500 104480 — — — — — — — — 704562 704552 704564 704554 — — — — — — — — 105681 105671 105680 105670 — — — — — — — — 704862 704852 — 704854 — — — — — — — — — — — — 101660HA 101650HA 101680HA 101670HA 101661HA 101651HA 101681HA 101671HA 53015040 53015040 53015050 53015050 53015060 53015060 53015060 53015060 53015070 53015070 53015070 53015070 53015340 53015340 53015350 53015350 53015360 53015360 53015360 53015360 53015370 53015370 53015370 53015370 52015810 52015810 52015820 52015820 52015830 52015830 52015830 52015830 52015831 52015831 52015831 52015831 53112240 53112240 53112250 53112250 53112260 53112260 53112260 53112260 53112270 53112270 53112270 53112270 HA 10 Standard HA 10 High Profile HA 16 Standard HA 16 High Profile HA 64 Gray Black Metal MS-SC 104390 704500 — — — 704504 — 105630 — — 704802 704804 — — — 53015030 53015040 53015050 53015330 53015340 53015350 52015800 52015810 52015820 53112230 53112240 53112250 For NPT parts: add “NP” to the end of 6-digit part numbers or replace the last two digits of an 8-digit part number with “NP”. Metric parts are also available. EPIC® connectors mate with SKINTOP® glands without locknuts. Use of tapered (NPT) threads is not recommended with EPIC® rectangular connectors, unless a thread sealant is used. EPIC® HA Series Connectors with Double Levers on Base EPIC® HA Series Rectangular Connectors Description PG NPT HA 32 Top Entry Hood with Double Lever Bolts 21 ¾” 105820 29 1” 105830 Side Entry Hood with Double Lever Bolts 21 ¾” 105760 29 1” 105770 Panel Mount Base with Double Levers — — 104720C0 Surface Mount Base with Double Levers 2 entries with dust cover 21 ¾” 104820 1 entry with dust cover 21 ¾” 104740 2 entries with dust cover 29 1” 104821 1 entry with dust cover 29 1” 104741 Cable Coupler Hood with Double Levers 21 ¾” 105880 29 1” 105885 Complete with a PG SKINTOP® HA 48 Gray Black Metal MS-SC — 106318 53015050 53015060 53015350 53015360 52015820 52015830 53112250 53112260 — 106308 53015050 53015060 53015350 53015360 52015820 52015830 53112250 53112260 106255C0 — — — — — — 106348 106338 53015050 53015050 53015060 53015060 53015350 53015350 53015360 53015360 52015820 52015820 52015830 52015830 53112250 53112250 53112260 53112260 — — 53015050 53015060 53015350 53015360 52015820 52015830 53112250 53112260 For NPT parts: add “NP” to the end of 6-digit part numbers or replace EPIC® connectors mate with SKINTOP® glands the last two digits of an 8-digit part number with “NP”. without locknuts. Use of tapered (NPT) threads is not Metric parts are also available. recommended with EPIC® rectangular connectors, unless a thread sealant is used. 292 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Reference Rectangular Connector Inserts Diagrams: Hoods & Bases EPIC® HA 3/4 Top Entry Hood; Single Lever Bolts EPIC® HA 3/4 Side Entry Hood; Single Lever Bolts EPIC® HA 3/4 Panel Mount Base; Single Lever EPIC® HA 3/4 Surface Mount Base; Single Lever EPIC® HA 3/4 Angled Panel Mount Base; Single Lever EPIC® HA/HB Top & Side Entry Hoods; Single Lever Bolts EPIC® HA 3/4 Cable Coupler Hood; Single Lever HA/HB Hood Dimension (mm) B B1 C Series A HA 10 HA 16 HA 64 HB 6 HB 10 HB 16 HB 24 HB 48 29.5 29.5 90 43 43 43 43 90 53.3 58.3 105 52 52 61 61 105 67.3 72.3 — 72 72 76 76 — 63 79 132 60 73 93.3 120 132 D 73 89 152 74.8 90 110 137 152 EPIC® HA/HB Cable Coupler Hood; Single Lever Series A B HA 10 HA 16 HB 6 HB 10 HB 16 HB 24 36.5 36.5 44 50 50 50 29.5 29.5 43 43 43 43 HA/HB Hood Dimension (mm) C C1 D 48 53 54.8 54.8 63.5 63.5 62 67 74.8 74.8 78.8 78.8 74.4 90.4 74.8 91 111 138 E F 71.4 87.8 70 88.5 109.5 136.5 63 79 60 73 93.3 120 EPIC® HA/HB Panel Mount Base; Single Lever Series HA 10 HA 16 HA 64 HB 6 HB 10 HB 16 HB 24 HB 48 A B C D E 36.5 36.5 105 44 50 50 50 105 17.5 17.5 70 32 32 32 32 70 29.5 29.5 90 43 43 43 43 90 25 25 30 25 25 25 25 30 25 25 39.5 27.8 27.8 27.8 27.8 39.5 HA/HB Hood Dimension (mm) F G H 42 42 56.5 44.8 44.8 44.8 44.8 56.5 74.4 90.4 152 74.8 91 111 138 152 71.4 87.5 139.5 70 88.5 109.5 136.5 139.5 I J K L M 63 79 132 60 73 93.3 120 132 70 86 148 70 83 103 130 148 81 96 165 80 93 113 140 165 3.5 3.5 10 4 4 4 4 10 3.6 3.6 7 4.3 4.3 4.3 4.3 7 EPIC® HA/HB Surface Mount Base; Single Lever Series A B C D E F HA/HB Hood Dimension (mm) F1 G G1 H I J HA 10 36.5 40 29.5 50 25 57 — 74 — 74.4 71.4 63 HA 16 36.5 40 29.5 50 25 57 — 74 — 90.4 87.8 79 HA 64 105 106 90 120 30 100 — 117 — 152 139.5 132 HB 6 44 40 43 52 25 54 74 71 91 74.8 70 60 HB 10 50 40 43 52 25 57 74 74 91 91 88.5 73 HB 16 50 45 43 57 25 64 84 81 101 111 109.5 93 HB 24 50 45 43 57 25 64 84 81 101 138 136.5 120 HB 48 105 106 90 120 30 100 — 117 — 152 139.5 132 * M dimension for HB 6, 10, 16 & 24 is 4.5mm (standard profile) or 6mm (high profile). 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com K L M N 48 64 111 70 82 105 132 111 80 96 132 84 94 117 144 132 3.5 3.5 12 * * * * 12 4.5 4.5 6.5 5.5 5.5 5.5 5.5 6.5 293 EPIC® Rectangular Connector Inserts Reference Diagrams: Hoods & Bases EPIC® HA & HB Series Connectors with Double Levers on Base HA/HB Top & Side Entry Hoods with Double Lever Bolts HA/HB Hood Dimension (mm) C C1 D Series A B HA 32 HA 48 HB 10 HB 16 HB 24 HB 32 56 79 43 43 43 79 67.8 89.5 55 55 55 89.5 75 95 52 61 61 95 — — 72 76 76 — E 49.6 64.5 27 47.5 74 64.5 82 93.5 73 93.3 120 93.5 HA/HB Panel Mount Base with Double Levers Series HA 32 HA 48 HB 10 HB 16 HB 24 HB 32 A B C D 67.8 93.8 55 55 55 93.8 66 87.8 53 53 53 87.8 42 65 32 32 32 65 56 79 43 43 42 79 HA/HB Hood Dimension (mm) E F G H 25.4 30.3 27.8 27.8 27.8 30.3 124.5 136.5 116 136.5 163 136.5 49.6 64.5 27 47.5 74 64.5 82 93.5 73 93.3 120 93.5 I J K L 92 110 83 103 130 110 102 124 93 113 140 124 4 5 4 4 4 5 4.3 5.5 4.3 4.3 4.3 5.5 HA/HB Surface Base with Double Levers Series HA 32 HA 48 HB 10 HB 16 HB 24 HB 32 A B C D E 67.8 93.8 55 55 55 93.8 66 87.8 53 53 53 87.8 46 67 40 45 45 67 56 79 43 43 43 79 57 81 54 57 57 81 HA/HB Hood Dimension (mm) F F1 G 75 72 57 64 64 72 — — 74 84 84 — H 124.5 49.6 136.5 64.5 116 27 136.5 47.5 163 74 136.5 64.5 I J K L 82 82 73 93 120 93.5 94 94 82 105 132 112 106 106 94 117 144 124.5 4 5 * * * 5 * L dimension for HB3 10, 16 & 24 is 4.5mm (standard profile) or 6mm (high profile). HA/HB Panel Mount Base Cut-Outs HA/HB Cable Coupler Hood with Double Levers Series A B HA 32 HB 10 HB 16 HB 24 HB 32 67.8 55 55 55 93.8 66 53 53 53 87.8 294 HA/HB Hood Dimension (mm) C D D1 E 56 43 43 43 79 76.5 54.8 63.6 63.6 97 — 74.8 78.8 78.8 — 124.5 116 136.5 163 136.5 F G 82 73 93.3 120 93.5 49.6 27 47.5 74 64.5 Series HA 3/4 HA 10 HA 16 HA 32 HA 48 HA 64 HB 6 HB 10 HB 16 HB 24 HB 32 HB 48 A 30 70 86 92 110 148 70 83 103 130 110 148 HA/HB Cut—Out Dimension (mm) B C D — 17.5 17.5 42 65 70 32 32 32 32 65 70 21 57.5 73.7 74.2 85.5 117 52.2 65.2 85.5 112.2 85.5 117 21 24 24 48.4 71 82 35 35 35 35 71 82 E 3.3 3.6 3.6 4.3 5.5 7 4.3 4.3 4.3 4.3 5.5 7 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBE Series Rectangular Connector Inserts EPIC® HBE Series EPIC® HBE series inserts provide reliable termination and performance in the vast majority of medium power and control applications. Methods of termination include screw, crimp, and “spring” cage clamp. Technical Data Number of Contacts: 6, 10, 16, 24, 32, 48 (+PE) Temperature Range: - Short-term: -40°C to +100°C up to +125°C Pollution Level: 3 Dimensioning Transient: 6 kV Mating Cycles: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service in excess of 500 cycles is possible at rated voltage and current* Screw Termination: Rated Voltage: - UL: - CSA: - IEC: 600V 600V 500V Rated Current: - UL: - CSA: - IEC: 16A 16A 16A Wire Size: 20 - 14 AWG (0.5 - 2.5 mm2) Contact Material: Silver-plated copper alloy Contact Resistance: < 2 mΩ Crimp Termination: Rated Voltage: - UL: - CSA: - IEC: 600V 600V 500V Rated Current: - UL: - CSA: - IEC: 16A 16A 16A Wire Size: 20 - 12 AWG (0.5 - 4 mm2) Contact Material: Silver- or gold-plated copper alloy Contact Resistance: < 2 mΩ Cage Clamp Termination: Rated Voltage: - UL: - CSA: - IEC: 600V 600V 500V Rated Current: - UL: - CSA: - IEC: 16A 16A 16A Wire Size: 20 - 14 AWG (0.5 - 2.5 mm2) Contact Material: Silver-plated copper alloy Contact Resistance: 1.5 - 4 mΩ * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 295 EPIC® Rectangular Connector Inserts HBE Series EPIC® HBE Inserts: Derating Curves EPIC® HBE Screw-Terminated 16 AWG (1.5 mm2) EPIC® HBE Screw-Terminated 14 AWG (2.5 mm2) EPIC® HBE Crimp-Terminated 16 AWG (1.5 mm2) EPIC® HBE Crimp-Terminated 14 AWG (2.5 mm2) EPIC® HBE Cage Clamp 16 AWG (1.5 mm2) EPIC® HBE Cage Clamp 14 AWG (2.5 mm2) 296 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBE Series Rectangular Connector Inserts EPIC® HBE 6 Inserts Screw-Terminated View from Cable Side Crimp-Terminated Crimp contacts sold separately, see below All dimensions are in mm. Screwless Cage Clamp Compatible Housing HB 6: page 369 Approvals Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Crimp-Terminated: Machined Contacts Screwless Spring Cage Clamp Plug Receptacle 10190000 10190100 10180000 10400000 10191000 10191100 10181000 10401000 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Gold Contacts Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 Part number = 1 contact, sold in bags of 100 Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 For removal of contacts, use a slotted screwdriver. No special tool is necessary. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 297 EPIC® Rectangular Connector Inserts HBE Series EPIC® HBE 10 Inserts Screw-Terminated View from Cable Side Crimp-Terminated Crimp contacts sold separately, see below All dimensions are in mm. Screwless Cage Clamp Compatible Housing HB 10: page 372 Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Crimp-Terminated: Machined Contacts Screwless Cage Clamp Plug Receptacle 10192000 10192100 10182000 10400100 10193000 10193100 10183000 10401100 Approvals Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 Part number = 1 contact, sold in bags of 100 Gold Contacts Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation For removal of contacts, use a slotted screwdriver. No special tool is necessary. Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 298 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBE Series Rectangular Connector Inserts EPIC® HBE 16 Inserts Screw-Terminated View from Cable Side Crimp-Terminated Crimp contacts sold separately, see below All dimensions are in mm. Screwless Cage Clamp Compatible Housing HB 16: page 378 Approvals Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Crimp-Terminated: Machined Contacts Screwless Cage Clamp Plug Receptacle 10194000 10194100 10184000 10400200 10195000 10195100 10185000 10401200 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Gold Contacts Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 Part number = 1 contact, sold in bags of 100 Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 For removal of contacts, use a slotted screwdriver. No special tool is necessary. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 299 EPIC® Rectangular Connector Inserts HBE Series EPIC® HBE 16 Inserts Terminal Block Receptacle View from Cable Side All dimensions are in mm. Description Terminal Block: Right Ground Terminal Block: Left Ground Receptacle 70315100 70314100 Compatible Housing Approvals HB 16 Panel Mount: page 379 • T erminal block inserts only fit into HBE panel mount bases. •O  ne terminal block insert mates with one screw-terminated insert. EPIC® HBE 24 Inserts Terminal Block Receptacle View from Cable Side All dimensions are in mm. Description Terminal Block: Right Ground Terminal Block: Left Ground Receptacle Compatible Housing 70317100 70316100 HB 24 Panel Mount: page 385 Approvals • T erminal block inserts only fit into HBE panel mount bases. •O  ne terminal block insert mates with one screw-terminated insert. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 300 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBE Series Rectangular Connector Inserts EPIC® HBE 24 Inserts Screw-Terminated View from Cable Side Crimp-Terminated Crimp contacts sold separately, see below All dimensions are in mm. Screwless Cage Clamp Compatible Housing HB 24: page 384 Approvals Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Crimp-Terminated: Machined Contacts Screwless Cage Clamp Plug Receptacle 10196000 10196100 10186000 10400300 10197000 10197100 10187000 10401300 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Gold Contacts Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 Part number = 1 contact, sold in bags of 100 Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 For removal of contacts, use a slotted screwdriver. No special tool is necessary. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 301 EPIC® Rectangular Connector Inserts HBE Series EPIC® HBE 32 Inserts Screw-Terminated View from Cable Side Crimp-Terminated Crimp contacts sold separately, see below All dimensions are in mm. Screwless Spring Cage Clamp Compatible Housing HB 32: page 390 Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Crimp-Terminated: Machined Contacts Screwless Cage Clamp Contacts Plug Receptacle #1 - 16 10194000 10195000 #17 - 32 10202000 10203000 #1 - 16 10194100 10195100 #17 - 32 10202100 10203100 #1 - 16 10184000 10185000 #17 - 32 10184200 10185200 #1 - 16 10400200 10401200 #17 - 32 10400400 10401400 Approvals Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 Part number = 1 contact, sold in bags of 100 Gold Contacts Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation For removal of contacts, use a slotted screwdriver. No special tool is necessary. Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 302 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBE Series Rectangular Connector Inserts EPIC® HBE 48 Inserts Screw-Terminated View from Cable Side Crimp-Terminated Crimp contacts sold separately, see below All dimensions are in mm. Screwless Spring Cage Clamp Compatible Housing HB 48: page 392 Description Screw-Terminated with Wire Protection Approvals Screw-Terminated without Wire Protection Crimp-Terminated: Machined Contacts Screwless Cage Clamp Contacts Plug Receptacle #1 - 24 #25 - 48 #1 - 24 #25 - 48 #1 - 24 #25 - 48 #1 - 24 #25 - 48 10196000 10204000 10196100 10204100 10186000 10186200 10400300 10400500 10197000 10205000 10197100 10205100 10187000 10187200 10401300 10401500 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Gold Contacts Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 Part number = 1 contact, sold in bags of 100 Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 For removal of contacts, use a slotted screwdriver. No special tool is necessary. Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 303 EPIC® Rectangular Connector Inserts HA Series EPIC® HA Series Similar to the HBE series inserts but more compact, EPIC® HA series inserts are used whenever space is limited. EPIC® HA 3/4 inserts and housings provide the smallest possible footprint in a 10A power connector. HA 10 - 48 inserts are unique because of their shortened ground straps, which still allow for a wire cross-section up to 2.5 mm2. HA 3 - 48 screw-terminated inserts fit into EPIC® HA series housings. A modified EPIC® HB 48 housing can fit 64 contacts. Technical Data Number of Contacts: 3, 4, 10, 16, 32, 48, 64 (+PE) Temperature Range: - Short-term: -40°C to +100°C up to +125°C Pollution Level: 3 Dimensioning Transient: 4 kV Mating Cycles: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service up to 500 cycles is possible at rated voltage and current* Test Voltage: 4 kV Rated Voltage: - UL: - CSA: - IEC: - EPIC® HA 3/4: - EPIC® HA 10 - 64: - SEV: 600V 600V 400V 250V 250V Rated Current: - UL: - EPIC® HA 3/4: - EPIC® HA 10 - 64: - CSA: - EPIC® HA 3/4: - EPIC® HA 10 - 64: - IEC: - EPIC® HA 3/4: - EPIC® HA 10 - 64: - SEV: 10A 14A 10A 16A 10A 16A 16A Wire Size: - EPIC® HA 3/4: - solid or stranded wire with ferrule: 20 - 14 AWG (0.5 - 2.5 mm2) - EPIC® HA 10 - 64: - solid or stranded wire with ferrule: 20 - 14 AWG (0.5 - 2.5 mm2) - for stranded wire without ferrule: 18 - 14 AWG (0.75 - 2.5 mm2) (requires insert with wire protection) Contact Material: Silver-plated copper alloy Contact Resistance: 1.5 - 4 mΩ * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. EPIC® HA Inserts: Derating Curves EPIC® HA Screw-Terminated 16 AWG (1.5 mm2) 304 EPIC® HA Screw-Terminated 14 AWG (2.5 mm2) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HA Series Rectangular Connector Inserts EPIC® HA 3 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Approvals CompatibleComplete Housing the Installation HAHB: 3/4: page page 400 Description Coding Pin: 10451400 Screw-Terminated Plug Receptacle 10420000 10421000 EPIC® HA 4 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Approvals CompatibleComplete Housing the Installation HAHB: 3/4: page page 400 Description Coding Pin: 10451400 Screw-Terminated Plug Receptacle 10431000 10432000 EPIC® HA 10 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Approvals Compatible Housing HA 10: page 402 Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Plug Receptacle 10440100 10440000 10441100 10441000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 305 EPIC® Rectangular Connector Inserts HA Series EPIC® HA 16 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Plug Receptacle 10530000 10532000 10531000 10533000 Compatible Housing Approvals HA 16: page 404 EPIC® HA 32 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Contacts Plug Receptacle #1 - 16 #17 - 32 #1 - 16 #17 - 32 10530000 10540000 10532000 10542000 10531000 10541000 10533000 10543000 Compatible Housing Approvals HA 32: page 406 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 306 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HA Series Rectangular Connector Inserts EPIC® HA 48 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Approvals Compatible Housing HA 48: page 408 Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Contacts Plug Receptacle #1 - 16 #17 - 32 #33 - 48 #1 - 16 #17 - 32 #33 - 48 10530000 10540000 10540100 10532000 10542000 10542100 10531000 10541000 10541100 10533000 10543000 10543100 EPIC® HA 64 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Approvals Compatible Housing HA 64: page 409 Description Screw-Terminated with Wire Protection Contacts Plug #1 - 16 10530000 #17 - 32 10540000 #33 - 48 10540100 #49 - 64 105300LE64 Receptacle 10531000 10541000 10541100 105310LE64 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 307 EPIC® Rectangular Connector Inserts HQ Series EPIC® HQ Series The EPIC® HQ 5 insert fills the gap between the smallest configuration EPIC® HA and EPIC® HD connector inserts. It provides more contacts (5+PE) in the same housing space as the EPIC® HA 3 and HA 4 inserts, with a higher current capability than the EPIC® HD 7 and HE 8 inserts (16A vs. 10A). It is ideal for applications in the transportation and automotive industries, and in many other industrial applications. Technical Data Number of Contacts: 5 (+PE) Test Voltage: 4 kV Temperature Range: - Short-term: -40°C to +100°C up to +125°C Rated Voltage: - UL/CSA: - IEC: 600V 400V Rated Current: - UL/CSA: 16A Wire Size: 20 - 14 AWG (0.5 - 2.5 mm2) Pollution Level: 3 Mating Cycles: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service up to 500 cycles is possible at rated voltage and current* Contact Material: Silver- or gold-plated copper alloy Contact Resistance: ≤ 2 mΩ * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. EPIC® HQ Inserts: Derating Curves EPIC® HQ Crimp-Terminated 16 AWG (1.5 mm2) EPIC® HQ Crimp-Terminated 14 AWG (2.5 mm2) Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 308 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HQ Series Rectangular Connector Inserts EPIC® HQ 5 Inserts Crimp-Terminated Contacts sold separately, see below All dimensions are in mm. View from Cable Side Approvals Compatible Complete the Housing Installation HA 3/4: page 400 HB: page Description Coding Pin: 10436500 Crimp-Terminated: Machined Contacts Plug Receptacle 10431500 10432500 Machined Contacts 2.5 mm Diameter Contact Size mm 2 0.5 0.75 - 1.0 1.5 2.5 4.0 AWG 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Silver Contacts Pin Socket 7.3 — 11190000 11195000 7.3 1 11190100 11195100 7.3 2 11190200 11195200 7.3 3 11190300 11195300 7.3 — 11190400 11195400 Part number = 1 contact, sold in bags of 100 Gold Contacts Pin Socket 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Complete the Installation Crimp Tool: 11147000 Tool: Crimp Dies: 11147000 11147100 Crimp Dies: Locator: 11147100 11147200 Locator: Removal Tool: 11147200 111825000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 309 EPIC® Rectangular Connector Inserts STA Series EPIC® STA Series EPIC® STA series inserts with solid spring-designed contacts are used extensively in the construction of devices and in control units, laboratories, and withdrawable unit design. These inserts are available with screw or solder termination, and fit into EPIC® HA series housings. Technical Data Number of Contacts: 6, 14, 20, 40 Temperature Range: -40°C to +80°C Pollution Level: 2 Mating Cycles: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed Test Voltage: 1 kV Rated Voltage: - UL/CSA: - EPIC® STA 6 - 20: - IEC: - EPIC® STA 6 - 20: 48V Rated Current: - UL/CSA; IEC: - EPIC® STA 6 - 20: 10A Wire Size: - Solder termination: - Screw termination: up to 16 AWG (1.5 mm2) 20 - 16 AWG (0.5 - 1.5 mm2) Contact Material: Silver-plated copper alloy Contact Resistance: < 2 mΩ 60V EPIC® STA Inserts: Derating Curves EPIC® STA Screw-Terminated 18 AWG (1 mm2) 310 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® STA Series Rectangular Connector Inserts EPIC® STA 6 Inserts View from Cable Side Screw-Terminated All dimensions are in mm. Solder-Terminated Compatible Housing HA 3/4: page 400 Approvals Description Screw-Terminated Solder-Terminated Plug Receptacle 10488100 10487200 10486100 10485200 EPIC® STA 14 Inserts View from Cable Side Screw-Terminated All dimensions are in mm. Solder-Terminated Compatible Housing HA 10: page 402 Approvals Description Screw-Terminated Solder-Terminated Plug Receptacle 10493100 10492200 10491100 10490200 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 311 EPIC® Rectangular Connector Inserts STA Series EPIC® STA 20 Inserts Screw-Terminated View from Cable Side Solder-Terminated All dimensions are in mm. Compatible Housing HA 16: page 404 Description Screw-Terminated Solder-Terminated Plug Receptacle 10503100 10502200 10501100 10500200 Approvals EPIC ® STA 40 Inserts Screw-Terminated View from Cable Side Solder-Terminated x2 STA 20 inserts, use two part numbers. All dimensions are in mm. Compatible Housing HA 32: page 406 Description Screw-Terminated Solder-Terminated Plug Receptacle 10503100 (x2) 10502200 (x2) 10501100 (x2) 10500200 (x2) Approvals Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 312 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HEE Series Rectangular Connector Inserts EPIC® HEE Series The EPIC® HEE series of crimp-terminated inserts is a high-density companion to the popular EPIC® HBE series. Offering the same voltage and current ratings (600V AC; 16A), it provide a significant increase in contact density (a 67% - 100% increase) within the same footprint dimensions as an equivalent-sized HBE insert. EPIC® HEE inserts are ideal for applications in the automotive industry, and any other industrial application requiring high density contacts and immunity to vibration. Technical Data Number of Contacts: 10, 18, 32, 46, 64, 92 (+PE) Test Voltage: 6 kV Temperature Range: - Short-term: -40°C to +100°C up to +125°C Rated Voltage: - UL/CSA: - IEC: 600V 500V Pollution Level: 3 Mating Cycles: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service up to 500 cycles is possible at rated voltage and current* Rated Current: 16A Wire Size: 20 - 12 AWG (0.5 - 4 mm2) Contact Material: Silver- or gold-plated copper alloy Contact Resistance: ≤ 2 mΩ * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. EPIC® HEE Inserts: Derating Curves EPIC® HEE Crimp-Terminated 16 AWG (1.5 mm2) EPIC® HEE Crimp-Terminated 14 AWG (2.5 mm2) Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 313 EPIC® Rectangular Connector Inserts HEE Series EPIC® HEE 10 Inserts Crimp-Terminated View from Cable Side Contacts sold separately, see below Description Description Crimp-Terminated: Machined Contacts All dimensions are in mm. Plug Plug Receptacle Receptacle 10180400 10181400 Approvals Compatible Housing HB 6: page 369 EPIC® HEE 18 Inserts Crimp-Terminated View from Cable Side Contacts sold separately, see below Description Crimp-Terminated: Machined Contacts All dimensions are in mm. Approvals Compatible Housing Plug Receptacle 10182400 10183400 HB 10: page 372 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Pin Socket Pin Socket — 1 2 3 — 11190000 11190100 11190200 11190300 11190400 11195000 11195100 11195200 11195300 11195400 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — 7.3 7.3 7.3 7.3 7.3 Silver Contacts Gold Contacts Part number = 1 contact, sold in bags of 100 Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11182500 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 314 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HEE Series Rectangular Connector Inserts EPIC® HEE 32 Inserts Crimp-Terminated View from Cable Side Contacts sold separately, see below All dimensions are in mm. Approvals Compatible Housing Description HB 16: page 378 Crimp-Terminated: Machined Contacts Plug Receptacle 10184400 10185400 EPIC® HEE 46 Inserts View from Cable Side Crimp-Terminated Contacts sold separately, see below All dimensions are in mm. Approvals Compatible Housing Description HB 24: page 384 Crimp-Terminated: Machined Contacts Plug Receptacle 10186400 10187400 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Pin Socket Pin Socket — 1 2 3 — 11190000 11190100 11190200 11190300 11190400 11195000 11195100 11195200 11195300 11195400 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — 7.3 7.3 7.3 7.3 7.3 Silver Contacts Gold Contacts Part number = 1 contact, sold in bags of 100 Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11182500 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 315 EPIC® Rectangular Connector Inserts HEE Series EPIC® HEE 64 Inserts Crimp-Terminated View from Cable Side Contacts sold separately, see below Description Description Crimp-Terminated: Machined Contacts All dimensions are in mm. Contacts #1 - 32 #33 - 64 Plug Plug Receptacle Receptacle 10184400 10184500 Approvals Compatible Housing HB 32: page 390 10185400 10185500 EPIC® HEE 92 Inserts View from Cable Side Crimp-Terminated Contacts sold separately, see below Description Description Crimp-Terminated: Machined Contacts All dimensions are in mm. Contacts #1 - 46 #47 - 92 Plug Plug Receptacle Receptacle 10186400 10186500 Approvals Compatible Housing HB 48: page 392 10187400 10187500 Machined Contacts 2.5 mm Diameter Contact Size mm2 AWG 0.5 0.75 - 1.0 1.5 2.5 4.0 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 # of Marking Tracks Pin Socket Pin Socket — 1 2 3 — 11190000 11190100 11190200 11190300 11190400 11195000 11195100 11195200 11195300 11195400 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — 7.3 7.3 7.3 7.3 7.3 Silver Contacts Gold Contacts Part number = 1 contact, sold in bags of 100 Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11182500 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 316 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBS Series Rectangular Connector Inserts EPIC® HBS Series EPIC HBS series inserts are characterized by their higher current-carrying capacity: a little more than twice the capacity of the EPIC® HBE series. A secure electrical connection can be made by simple screw termination for cables up to 10 AWG. ® Technical Data Number of Contacts: 6, 12 (+PE) Test Voltage: 6 kV Temperature Range: - Short-term: -40°C to +100°C up to +125°C Rated Voltage: - UL/CSA: - IEC: 600V 500V Pollution Level: 3 Mating Cycles: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service up to 500 cycles is possible at rated voltage and current* Rated Current: - UL/CSA; IEC: 35A Wire Size: 20 - 10 AWG (0.5 - 6 mm2) Contact Material: Silver-plated copper alloy Contact Resistance: < 2 mΩ * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. EPIC® HBS Inserts: Derating Curves EPIC® HBS Screw-Terminated 10 AWG (6 mm2) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 317 EPIC® Rectangular Connector Inserts HBS Series EPIC® HBS 6 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Description Screw-Terminated Plug Receptacle 10170000 10171000 Compatible Housing Approvals HB 16: page 378 EPIC® HBS 12 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Description Screw-Terminated Contacts Plug Receptacle #1 - 6 #7 - 12 10170000 10170600 10171000 10171600 Compatible Housing Approvals HB 32: page 390 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 318 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBVE Series Rectangular Connector Inserts EPIC® HBVE Series EPIC HBVE series inserts handle higher voltage and are equipped with two switch contacts. These contacts “make” after the working contacts are engaged and “break” before the working contacts disengage. They can be wired as part of an electrical interlock circuit to ensure that power to the working contacts is turned off during connector mating and unmating. ® Technical Data Number of Contacts: 3+2+PE, 6+2+PE, 10+2+PE Test Voltage: 6 kV Temperature Range: - Short-term: -40°C to +100°C up to +125°C Rated Voltage: - UL/CSA: - IEC: 600V 630V Rated Current: - UL/CSA; IEC: 16A Wire Size: 20 - 14 AWG (0.5 - 2.5 mm2) Pollution Level: 3 Mating Cycles: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service up to 500 cycles is possible at rated voltage and current* Contact Material: Silver-plated copper alloy Contact Resistance: < 2 mΩ * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. EPIC® HBVE Inserts: Derating Curves EPIC® HBVE Screw-Terminated 16 AWG (1.5 mm2) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HBVE Screw-Terminated 14 AWG (2.5 mm2) 319 EPIC® Rectangular Connector Inserts HBVE Series EPIC® HBVE 3 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Plug Receptacle 10210010 10210110 10211010 10211110 Compatible Housing Approvals HB 10: page 372 EPIC® HBVE 6 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Plug Receptacle 10239010 10239110 10240010 10240110 Compatible Housing Approvals HB 16: page 378 EPIC® HBVE 10 Inserts Screw-Terminated View from Cable Side All dimensions are in mm. Description Screw-Terminated with Wire Protection Screw-Terminated without Wire Protection Plug Receptacle 10270010 10270110 10271010 10271110 Compatible Housing Approvals HB 24: page 384 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 320 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD Series EPIC HD series inserts are designed for use in industries where large numbers of contacts are required and limited space is available. These high-density crimp inserts are available with stamped & formed or machined contacts and fit into EPIC® HA & HB series housings. ® Technical Data Number of Contacts: 7, 8, 15, 25, 40, 50, 64, 80, 128 (+PE) Temperature Range: - Short-term: -40°C to +100°C up to +125°C Pollution Level: 3 Mating Cycles: Test Voltage: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service up to 500 cycles is possible at rated voltage and current* 2.5 kV Rated Voltage: - IEC EPIC® HD 7 - 8: - Metal housing: - Plastic housing: - IEC EPIC® HD 15 - 128: - UL/CSA: 42V 250V 250V 250V Rated Current: - UL/CSA, IEC: 10A Wire Size: 26 - 14 AWG (0.14 - 2.5 mm2) Contact Material: Silver- or gold-plated copper alloy Contact Resistance: - EPIC® HD 40, 64 - 128 (machined contacts): < 2 mΩ < 3 mΩ * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. EPIC® HD Inserts: Derating Curves EPIC® HD Machined 14 AWG (2.5 mm2) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Stamped & Formed 14 AWG (2.5 mm2) 321 EPIC® Rectangular Connector Inserts HD Series EPIC® HD Inserts: Derating Curves EPIC® HD Machined 16 AWG (1.5 mm2) EPIC® HD Stamped & Formed 16 AGW (1.5 mm2) EPIC® HD Stamped & Formed 20 AWG (0.5 mm2) 322 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 7 Inserts Crimp-Terminated: Machined Contacts All dimensions are in mm. Contacts sold separately, see below View from Cable Side Approvals Compatible Housing Description HA 3/4: page 400 Crimp-Terminated: Machined Contacts Plug Receptacle 11250500 11251500 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 323 EPIC® Rectangular Connector Inserts HD Series EPIC® HD 7 Inserts Crimp-Terminated: Stamped & Formed Contacts All dimensions are in mm. Contacts sold separately, see below View from Cable Side Approvals Description Description Crimp-Terminated: Stamped & Formed Contacts Plug Plug Receptacle Receptacle 11250000 11251000 Compatible Housing HA 3/4: page 400 Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 AWG Stripping Length (mm) 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size mm 1 part number = 1 contact, sold in bags of 100 or 1 reel 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 Bag of 100: Silver Bag of 100: Gold Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Gold Left-hand Feed Pin Socket 11240500 — — 11230500 — — Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 324 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 8 Inserts Crimp-Terminated: Machined Contacts All dimensions are in mm. Contacts sold separately, see below View from Cable Side Approvals Compatible Housing Description HA 3/4: page 400 Crimp-Terminated: Machined Contacts Plug Receptacle 11252500 11253500 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: Tool Crimp 11147000 Crimp Dies: Dies Crimp 11147100 Locator Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 325 EPIC® Rectangular Connector Inserts HD Series EPIC® HD 15 Inserts Crimp-Terminated: Machined Contacts Contacts sold separately, see below All dimensions are in mm. View from Cable Side Approvals Description Crimp-Terminated: Machined Contacts Plug Receptacle 11283200 11282200 Compatible Housing HA 10: page 402 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 326 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 15 Inserts Crimp-Terminated: Stamped & Formed Contacts Contacts sold separately, see below All dimensions are in mm. View from Cable Side Approvals Compatible Housing Description HA 10: page 402 Crimp-Terminated: Stamped & Formed Contacts Plug Receptacle 11255000 11256000 Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 mm2 AWG Stripping Length (mm) 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size Bag of 100: Silver Bag of 100: Gold Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Gold Left-hand Feed Pin Socket 11240500 — — 11230500 — — 1 part number = 1 contact, sold in bags of 100 or 1 reel Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 327 EPIC® Rectangular Connector Inserts HD Series EPIC­® HD 25 Inserts Crimp-Terminated: Machined Contacts Contacts sold separately, see below All dimensions are in mm. View from Cable Side Approvals Description Crimp-Terminated: Machined Contacts Plug Receptacle 11283300 11282300 Compatible Housing HA 16: page 404 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 328 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 25 Inserts Crimp-Terminated: Stamped & Formed Contacts Contacts sold separately, see below All dimensions are in mm. View from Cable Side Approvals Compatible Housing Description HA 16: page 404 Crimp-Terminated: Stamped & Formed Contacts Plug Receptacle 11260000 11261000 Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 mm2 AWG Stripping Length (mm) 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size Bag of 100: Silver Bag of 100: Gold Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Gold Left-hand Feed Pin Socket 11240500 — — 11230500 — — 1 part number = 1 contact, sold in bags of 100 or 1 reel Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 329 EPIC® Rectangular Connector Inserts HD Series EPIC­® HD 40 Inserts Crimp-Terminated: Machined Contacts All dimensions are in mm. Contacts sold separately, see below View from Cable Side Approvals Description Crimp-Terminated: Machined Contacts Plug Receptacle 11265200 11266200 Compatible Housing HB 16: page 378 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 330 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 40 Inserts Crimp-Terminated: Stamped & Formed Contacts All dimensions are in mm. Contacts sold separately, see below View from Cable Side Approvals Compatible Housing Description HB 16: page 378 Crimp-Terminated: Stamped & Formed Contacts Plug Receptacle 11265000 11266000 Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 mm2 AWG Stripping Length (mm) 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size Bag of 100: Silver Bag of 100: Gold Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Gold Left-hand Feed Pin Socket 11240500 — — 11230500 — — 1 part number = 1 contact, sold in bags of 100 or 1 reel Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 331 EPIC® Rectangular Connector Inserts HD Series EPIC­® HD 50 Inserts Crimp-Terminated: Machined Contacts x2 HD 25 inserts, use two part numbers Contacts sold separately, see below All dimensions are in mm. View from Cable Side Approvals Description Crimp-Terminated: Machined Contacts Plug Receptacle 11283300 (x2) 11282300 (x2) Compatible Housing HA 32: page 406 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 332 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 50 Inserts Crimp-Terminated: Stamped & Formed Contacts x2 HD 25 inserts, use two part numbers Contacts sold separately, see below All dimensions are in mm. View from Cable Side Approvals Compatible Housing Description HA 32: page 406 Crimp-Terminated: Stamped & Formed Contacts Plug Receptacle 11260000 (x2) 11261000 (x2) Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 mm2 AWG Stripping Length (mm) 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size Bag of 100: Silver Bag of 100: Gold Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Gold Left-hand Feed Pin Socket 11240500 — — 11230500 — — 1 part number = 1 contact, sold in bags of 100 or 1 reel Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 333 EPIC® Rectangular Connector Inserts HD Series EPIC­® HD 64 Inserts Crimp-Terminated: Machined Contacts All dimensions are in mm. Contacts sold separately, see below View from Cable Side Approvals Description Crimp-Terminated: Machined Contacts Plug Receptacle 11272000 11273000 Compatible Housing HB 24: page 384 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 334 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 64 Inserts Crimp-Terminated: Stamped & Formed Contacts All dimensions are in mm. Contacts sold separately, see below View from Cable Side Approvals Compatible Housing Description HB 24: page 384 Crimp-Terminated: Stamped & Formed Contacts Plug Receptacle 11270000 11271000 Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 mm2 AWG Stripping Length (mm) 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size Bag of 100: Silver Bag of 100: Gold Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Gold Left-hand Feed Pin Socket 11240500 — — 11230500 — — 1 part number = 1 contact, sold in bags of 100 or 1 reel Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 335 EPIC® Rectangular Connector Inserts HD Series EPIC­® HD 80 Inserts Crimp-Terminated: Machined Contacts All dimensions are in mm. x2 HD 40 inserts, use two part numbers Contacts sold separately, see below View from Cable Side Approvals Description Crimp-Terminated: Machined Contacts Plug Receptacle 11265200 (x2) 11266200 (x2) Compatible Housing HB 32: page 390 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 336 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 80 Inserts Crimp-Terminated: Stamped & Formed Contacts All dimensions are in mm. x2 HD 40 inserts, use two part numbers Contacts sold separately, see below View from Cable Side Approvals Compatible Housing Description HB 32: page 390 Crimp-Terminated: Stamped & Formed Contacts Plug Receptacle 11265000 (x2) 11266000 (x2) Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 mm2 AWG Stripping Length (mm) 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size Bag of 100: Silver Bag of 100: Gold Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Gold Left-hand Feed Pin Socket 11240500 — — 11230500 — — 1 part number = 1 contact, sold in bags of 100 or 1 reel Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 337 EPIC® Rectangular Connector Inserts HD Series EPIC­® HD 128 Inserts Crimp-Terminated: Machined Contacts All dimensions are in mm. x2 HD 64 inserts, use two part numbers Contacts sold separately, see below View from Cable Side Approvals Description Crimp-Terminated: Machined Contacts Plug Receptacle 11272000 (x2) 11273000 (x2) Compatible Housing HB 48: page 392 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 338 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HD Series Rectangular Connector Inserts EPIC® HD 128 Inserts Crimp-Terminated: Stamped & Formed Contacts All dimensions are in mm. x2 HD 64 inserts, use two part numbers Contacts sold separately, see below View from Cable Side Approvals Compatible Housing Description HB 48: page 392 Plug Crimp-Terminated: Stamped & Formed Contacts 1127000 (x2) Receptacle 1127100 (x2) Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 mm2 AWG Stripping Length (mm) 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size Bag of 100: Silver Bag of 100: Gold Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Gold Left-hand Feed Pin Socket 11240500 — — 11230500 — — 1 part number = 1 contact, sold in bags of 100 or 1 reel Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 339 EPIC® Rectangular Connector Inserts HDD Series EPIC® HDD Series EPIC® HDD series inserts offer the highest possible machined contact density in a compact insert design. With more contacts available in a single insert, smaller connector housings can be used to provide significant panel space savings. Technical Data Number of Contacts: 24, 42, 72, 108, 144, 216 (+PE) Temperature Range: - Short-term: -40°C to +100°C up to +125°C Pollution Level: 2 Mating Cycles: Test Voltage: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service up to 500 cycles is possible at rated voltage and current* Rated Voltage: - UL/CSA: - IEC: 600V 250V Rated Current: - UL: 8.5A - CSA: 10A - IEC: 10A Wire Size: 26 - 14 AWG (0.14 - 2.5 mm2) Contact Material: Silver- or gold-plated copper alloy Contact Resistance: < 3 mΩ 2.5 kV * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. EPIC® HDD Inserts: Derating Curves EPIC® HDD Crimp-Terminated 16 AWG (1.5 mm2) EPIC® HDD Crimp-Terminated 14 AWG (2.5 mm2) Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 340 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HDD Series Rectangular Connector Inserts EPIC® HDD 24 Inserts Crimp-Terminated View from Cable Side Contacts sold separately, see below All dimensions are in mm. Approvals Compatible Housing Description HB 6: page 369 Crimp-Terminated: Machined Contacts Plug Receptacle 11285000 11286000 EPIC® HDD 42 Inserts Crimp-Terminated View from Cable Side Contacts sold separately, see below All dimensions are in mm. Approvals Compatible Housing Description HB 10: page 372 Crimp-Terminated: Machined Contacts Plug Receptacle 11285100 11286100 Machined Contacts 1.6 mm Diameter mm2 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 1 part number = 1 contact, sold in bags of 100 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 341 EPIC® Rectangular Connector Inserts HDD Series EPIC® HDD 72 Inserts Crimp-Terminated View from Cable Side Contacts sold separately, see below All dimensions are in mm. Description Crimp-Terminated: Machined Contacts Plug Receptacle 11285200 11286200 Approvals Compatible Housing HB 16: page 378 EPIC® HDD 108 Inserts View from Cable Side Crimp-Terminated Contacts sold separately, see below Description Crimp-Terminated: Machined Contacts All dimensions are in mm. Plug Receptacle 11285300 11286300 Approvals Compatible Housing HB 24: page 384 Machined Contacts 1.6 mm Diameter mm2 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size Silver Contacts Gold Contacts Complete the Installation 1 part number = 1 contact, sold in bags of 100 Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 342 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® HDD Series Rectangular Connector Inserts EPIC® HDD 144 Inserts Crimp-Terminated View from Cable Side Contacts sold separately, see below All dimensions are in mm. Approvals Compatible Housing Description HB 32: page 390 Crimp-Terminated: Machined Contacts Contacts Plug Receptacle #1 - 72 #73 - 144 11285200 11285400 11286200 11286400 EPIC® HDD 216 Inserts View from Cable Side Crimp-Terminated Contacts sold separately, see below All dimensions are in mm. Approvals Compatible Housing Description HB 48: page 392 Crimp-Terminated: Machined Contacts Contacts Plug Receptacle #1 - 108 #109 - 216 11285300 11285500 11286300 11286500 Machined Contacts 1.6 mm Diameter mm2 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 1 part number = 1 contact, sold in bags of 100 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 343 EPIC® Rectangular Connector Inserts MC Series EPIC® MC Series The EPIC® MC modular series connector can be custom-configured to meet application requirements by combining a variety of standard plug-and-play modules within various size support frames. Configurations include contacts for power and control, thermocouple contacts, data modules for PROFIBUS and Ethernet, and pneumatic modules. Technical Data Number of Contacts: 2 - 208 (+PE) Temperature Range: - Short-term: -40°C to +100°C up to +125°C Pollution Level: 3 Mating Cycles: Rated Voltage: - UL/CSA: - IEC: - Per DIN EN 61984:2008 Service Life Test: Tested to 100 cycles and passed - Per Contact Thermal Test: Useful service up to 500 cycles is possible at rated voltage and current* Rated Current: - UL/CSA: 4 - 82A - IEC: 1 - 82A Wire Size: - Screw termination: 8 - 4 AWG (10 - 25 mm2) - Crimp termination: 30 - 8 AWG (0.06 - 10 mm2) - Cage clamp: 20 - 14 AWG (0.5 - 2.5 mm2) Contact Material: Silver- or gold-plated copper alloy Contact Resistance: < 1 mΩ - < 5 mΩ Dimension Transient: 1.5 - 8 kV, depending on module 100 - 600V 30 - 1000V * In dry, non-conductive, non-corrosive environments when protected in a housing rated at least IP54 and disconnected for cycling and maintenance only. EPIC® MC Inserts: Derating Curves EPIC® MC 2 Module 12 - 4 AWG (4 - 25 mm2) 344 EPIC® MC 3 Module: Machined 10 AWG (6 mm2) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC Inserts: Derating Curves EPIC® MC 3 Module: Machined 8 AWG (10 mm2) EPIC® MC 3 High Voltage Module 10 AWG (6 mm2) EPIC® MC 3 High Voltage Module 8 AWG (10 mm2) EPIC® MC 4 Module: Machined 14 AWG (2.5 mm2) EPIC® MC 4 Module: Machined 12 AWG (4 mm2) EPIC® MC 4 Module: Cage Clamp 20 AWG (0.5 mm2) EPIC® MC 5 Module: Machined 14 AWG (2.5 mm2) EPIC® MC 5 Module: Machined 12 AWG (4 mm2) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 345 EPIC® Rectangular Connector Inserts MC Series EPIC® MC Inserts: Derating Curves 346 EPIC® MC 5 Module: Stamped & Formed 16 AWG (1.5 mm2) EPIC® MC 5 Module: Stamped & Formed 14 AWG (2.5 mm2) EPIC® MC 10 Module: Machined 20 AWG (0.5 mm2) EPIC® MC 10 Module: Machined 16 AWG (1.5 mm2) EPIC® MC 10 Module: Stamped & Formed 20 AWG (0.5 mm2) EPIC® MC 10 Module: Stamped & Formed 16 AWG (1.5 mm2) EPIC® MC 20 Module: Stamped & Formed 24 AWG (0.25 mm2) EPIC® MC 20 Module: Stamped & Formed 20 AWG (0.5 mm2) 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC Series Selection Charts Choose the Correct Modules Modules Plug Receptacle Rated Voltage 2 Contact Module: 2 Working Contacts 2 Contact Module: 1 Working Contact + 1 Ground 3 Contact Coax Module 3 Contact Module 3 Contact Module: High Voltage 4 Contact HE Module 4+PE Contact Module: High Voltage 5 Contact Module 10 Contact Module: Machined Contacts 10 Contact Module: Stamped & Formed Contacts 20 Contact Module Dummy Module 4 Contact Cage Clamp Module PROFIBUS DP Module Ethernet Module: RJ45 Connectors + 4 Power Contacts Universal Bus Modules Pneumatic Module: 1 Contact with 2.5 mm Hose Diameter Pneumatic Module: 1 Contact with 4.0 mm Hose Diameter Pneumatic Module: 2 Contacts with 2.5 mm Hose Diameter Pneumatic Module: 2 Contacts with 4.0 mm Hose Diameter 10344100 10344600 10399200 10382000 10399800 10399000 10383200 10382200 10382400 10383400 10383600 10399400 10399600 10390400 10344300 10390600 44424004 44424006 44424008 44424010 10345100 10345600 10399300 10382100 10399900 10399100 10383300 10382300 10382500 10383500 10383700 10399500 10399700 10390500 10345300 10390700 44424005 44424007 44424009 44424011 1000V 1000V 250V 630V 1000V 630V 1000V 400V 250V 250V 100V — 400V 30V 600V 30V 145psi 145psi 145psi 145psi Rated Current Removal Tool Page 82A 82A — 40A 50A 25A 16A 20A 10A 10A 4A — 14A 1A 10A 1A — — — — — — X X X — X X X X X X X — X — X X X X 348 348 349 350 351 352 353 354 355 356 357 358 358 358 359 359 360 360 360 360 Choose the Correct Frame Frames Frame for 2 Modules Frame for 3 Modules Frame for 5 Modules Frame for 7 Modules Frame for 10 Modules Frame for 14 Modules For Plugs For Receptacles Corresponding Housing Page 10381000 10381200 10381400 10381600 10381400 (x2) 10381600 (x2) 10381100 10381300 10381500 10381700 10381500 (x2) 10381700 (x2) HB 6 HB 10 HB 16 HB 24 HB 32 HB 48 360 360 361 361 362 362 Modules snap into frames. Note: Color of components may be different than shown. EPIC® MC Module Removal Tool The EPIC® MC module removal tool is used to lift built-in modules out of the module frames. Approvals Part Number 11171200 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 347 EPIC® Rectangular Connector Inserts MC Series EPIC® MC 2 Modules 2 Working Contacts; 1 Working Contact + 1 Ground All dimensions are in mm. Approvals Application Advantage Description 2 Working Contacts 1 Working Contact + 1 Ground Plug Receptacle 10344100 10344600 10345100 10345600 •M  odule can be inserted into the standard EPIC® modular frames •M  odules can be inserted or removed from the frame without a tool, due to snap hooks •S  crew contact modules can be wired easily with a standard screwdriver • F lexibility of the modular series allows the arrangement of modules to fit requirements •M  odule takes up two slots in the modular frame •H  igh current modules require the usage of high profile EPIC® HB 16 & 24 housings Technical Data Temperature Range: Mating Cycles: -40°C to + 100°C 100 (higher mating cycles depending on the application) Rated Voltage: 1000V Rated Current: 82A Termination: Screw Wire Size: 8 - 4 AWG (10 - 25 mm2) Contact Material: Brass; 2µ nickel & 2 - 3µ silver Contact Resistance: 1.5 - 4 mΩ Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 348 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC 3 Coax Modules Solder/Crimp-Terminated Contacts sold separately, see below Plug Receptacle All dimensions are in mm. Approvals Technical Data Cable Size: RG 58 Temperature Range: -40°C to +100°C Rated Voltage: 250V Description Solder/Crimp-Terminated: Coax Contacts Plug Receptacle 10399200 10399300 Impedance: 50 Ω Coax Contacts Solder/Crimp Termination Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147130 Removal Tool: 11171100 Size Pin Socket RG 58 11214200 11219200 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 349 EPIC® Rectangular Connector Inserts MC Series EPIC® MC 3 Modules Crimp-Terminated Contacts sold separately, see below Plug Receptacle All dimensions are in mm. Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 630V Rated Current: 40A Description Crimp-Terminated: Machined Contacts Plug Receptacle 10382000 10382100 Machined Contacts 3.6 mm Diameter Complete the Installation Crimp Tool: 11147000 Locator: 11147210 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) Pin Socket 16 14 12 10 8 10 10 10 10 10 1121070C 1121060C 1121000C 1121010C 1121020C 1121570C 1121560C 1121500C 1121510C 1121520C Contact Size mm 2 1.5 2.5 4.0 6.0 10.0 Crimp Dies: 1.5 - 2.5 mm2:11147110 4.0 - 10 mm2:11147120 Removal Tool: 11171100 Silver Contacts Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 350 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC 3 High Voltage Modules Crimp-Terminated Contacts sold separately, see below Plug Receptacle All dimensions are in mm. Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 1000V Rated Current: 50A Description Crimp-Terminated: Machined Contacts Plug Receptacle 10399800 10399900 Machined Contacts 3.6 mm Diameter Complete the Installation Crimp Tool: 11147000 Locator: 11147210 Crimp Dies: 1.5 - 2.5 mm2:11147110 4.0 - 10 mm2:11147120 Removal Tool: 11171100 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) Pin Socket 16 14 12 10 8 10 10 10 10 10 1121070C 1121060C 1121000C 1121010C 1121020C 1121570C 1121560C 1121500C 1121510C 1121520C Contact Size mm 2 1.5 2.5 4.0 6.0 10.0 Silver Contacts Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 351 EPIC® Rectangular Connector Inserts MC Series EPIC® MC 4 HE Modules Crimp-Terminated Contacts sold separately, see below Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 630V Rated Current: 25A Description Crimp-Terminated: Machined Contacts Plug Receptacle 10399000 10399100 Machined Contacts 2.5 mm Diameter Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11182500 1 part number = 1 contact, sold in bags of 100 Contact Size mm 2 0.5 0.75 - 1.0 1.5 2.5 4.0 AWG 20 18 16 14 12 Stripping Length (mm) Pin Socket 7.4 7.4 7.4 7.4 7.4 7.3 7.3 7.3 7.3 7.3 # of Marking Tracks Pin Socket Pin Socket — 1 2 3 — 11190000 11190100 11190200 11190300 11190400 11195000 11195100 11195200 11195300 11195400 11192000 11192100 11192200 — — 11197000 11197100 11197200 — — Silver Contacts Gold Contacts Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 352 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC 4+PE High Voltage Modules Crimp-Terminated Contacts sold separately, see below Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 1000V Rated Current: 16A Description Crimp-Terminated: Stamped & Formed Contacts Plug Receptacle 10383200 10383300 Stamped & Formed Contacts 2.5 mm Diameter Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Crimp Dies: 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: 11153500 Removal Tool: 11160000 Crimp Dies for Reel: 0.5 - 1.5 mm2:11153700 1.5 - 2.5 mm2:11153800 1 part number = 1 contact, sold in bags of 100 or 1 reel Reel of 100: Silver Reel of 200: Silver mm2 Contact Size AWG Pin Silver Contacts Socket Pin Socket Pin Socket 0.5 - 1.5 1.5 - 2.5 20 - 16 16 - 14 11201000 11202000 11205000 11206000 — 11208500 — 11209500 11208000 — 11209000 — Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 353 EPIC® Rectangular Connector Inserts MC Series EPIC® MC 5 High Voltage Modules Crimp-Terminated Contacts sold separately, see below Plug Receptacle All dimensions are in mm. Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 400V Rated Current: 20A Description Crimp-Terminated: Machined Contacts Plug Receptacle 10382200 10382300 Machined Contacts 2.5 mm Diameter Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11171000 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket 20 18 16 14 12 7.8 7.8 7.8 7.8 7.8 — 1 2 3 — 1121300C 1121310C 1121320C 1121330C 1121340C 1121800C 1121810C 1121820C 1121830C 1121840C Contact Size mm 2 0.5 0.75 - 1.0 1.5 2.5 4.0 Silver Contacts Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 354 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC 10 Modules Crimp-Terminated: Machined Contacts Contacts sold separately, see below Receptacle Plug All dimensions are in mm. Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 250V Rated Current: 10A Description Crimp-Terminated: Machined Contacts Plug Receptacle 10382400 10382500 Machined Contacts 1.6 mm Diameter 1 part number = 1 contact, sold in bags of 100 AWG Stripping Length (mm) # of Marking Tracks Pin Socket Pin Socket 26 - 22 20 18 16 14 8 8 8 8 5.8 1 2 3 4 5 13162000 13162100 13162200 13162300 13162400 13163000 13163100 13163200 13163300 13163400 13162500 13162600 13162700 13162800 13162900 13163500 13163600 13163700 13163800 13163900 Contact Size mm 2 0.14 - 0.37 0.5 0.75 - 1.0 1.5 2.5 Silver Contacts Gold Contacts Complete the Installation Crimp Tool: 11147000 Crimp Dies: 11147100 Locator: 11147200 Removal Tool: 11161000 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 355 EPIC® Rectangular Connector Inserts MC Series EPIC® MC 10 Modules Crimp-Terminated: Stamped & Formed Contacts Contacts sold separately, see below Plug Receptacle All dimensions are in mm. Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 250V Rated Current: 10A Description Crimp-Terminated: Stamped & Formed Contacts Plug Receptacle 10383400 10383500 Stamped & Formed Contacts 1.6 mm Diameter AWG Stripping Length (mm) Pin Socket Pin Socket 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 11241100 11221000 11223500 11231100 11236100 11228500 11243100 11221300 — 11233100 11238100 — Contact Size mm 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 AWG Stripping Length (mm) 26 - 20 20 - 16 16 - 14 2.5 - 0.5 3.5 - 0.5 3.5 - 0.5 Contact Size mm 1 part number = 1 contact, sold in bags of 100 or 1 reel 2 0.14 - 0.5 0.5 - 1.5 1.5 - 2.5 Silver Contacts Gold Contacts Reel of 2000: Silver Right-hand Feed Pin Socket 11240000 11220000 — 11230000 11235000 — Reel of 2000: Gold Right-hand Feed Pin Socket — 11220100 — — 11235200 — Reel of 100: Silver Left-hand Feed Pin Socket — — 11223000 — — 11228000 Reel of 2000: Silver Left-hand Feed Pin Socket 11240400 11226000 11222700 11230400 11226500 11227700 Reel of 200: Silver Left-hand Feed Pin Socket 11240700 11220700 — 11230700 11235700 — Reel of 2000: Silver Left-hand Feed Pin Socket 11230500 — — 11240500 — — Complete the Installation Crimp Tool: 11147000 Locator: 11147300 Removal Tool: 11161000 Crimp Dies: 0.14 - 0.5 mm2:11147170 0.5 - 1.5 mm2:11147180 1.5 - 2.5 mm2:11147190 Crimp Tool for Reel: (includes tool, die, & locator) 0.14 - 0.5 mm2:11147004 0.5 - 1.5 mm2:11147005 1.5 - 2.5 mm2:11147006 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 356 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC 20 Modules Crimp-Terminated Contacts sold separately, see below Plug Receptacle All dimensions are in mm. Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 100V Description Crimp-Terminated Rated Current: 4A Plug Receptacle 10383600 10383700 Stamped & Formed Contacts 1.0 mm Diameter Complete the Installation Crimp Tool: 11158400 mm2 AWG* Stripping Length (mm) 0.08 - 0.2 0.2 - 0.52 28 - 26 26 - 20 2.5 +0.5 2.5 +0.5 Contact Size Removal Tool: 11132500 Reel of 500: Gold Left-hand Feed Pin Socket 44429013 44429014 * AWG conversion is approximate. 44429009 44429010 1 part number = 1 reel Stamped & Formed Contacts For Thermocouple Applications 1.0 mm Diameter Material Polarity Color Code AWG Stripping Length (mm) 24 - 20 24 - 20 24 - 20 24 - 20 2.5 - 0.5 2.5 - 0.5 2.5 - 0.5 2.5 - 0.5 Chromel Iron Alumel Constantan (+) (+) (-) (-) White Black Green Yellow Contact Size mm 2 0.25 - 0.52 0.25 - 0.52 0.25 - 0.52 0.25 - 0.52 Strips of 25 Contacts: Type K Pin Socket TC-CH-P — TC-AL-P — TC-CH-S — TC-AL-S — Strips of 25 Contacts: Type J Pin Socket — TC-IR-P — TC-CO-P Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com — TC-IR-S — TC-CO-S 1 part number = 1 contact 357 EPIC® Rectangular Connector Inserts MC Series EPIC® MC Dummy Modules Dummy Module, No Contacts Plug Receptacle All dimensions are in mm. Description Dummy Module: No Contacts Plug Receptacle 10399400 10399500 EPIC® MC Cage Clamp Modules 4 Contacts Plug Receptacle All dimensions are in mm. Approvals Technical Data Temperature Range: -40°C to +100°C Rated Voltage: 400V Description Cage Clamp Plug Receptacle 10399600 10399700 Rated Current: 14A Wire Size: 20 - 14 AWG (0.5 - 2.5 mm2) EPIC® MC PROFIBUS DP Modules 2 Contacts + Shield Mount in High Profile housings only. Approvals Technical Data Temperature Range: -20°C to +85°C Rated Voltage: 30V Description PROFIBUS DP Plug Receptacle 10390400 10390500 Rated Current: 1A Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 358 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC Ethernet Module RJ45 Connectors + 4 Power Contacts RJ45 connector not included. Application Advantage •O  ccupies two module positions in frame. • Uses standard HD Series machined crimp contacts for power, see page 288. Approvals Description Module RJ45 Connector Plug Receptacle 10344300 CE6326 10345300 — Technical Data Number of Contacts: 8 Temperature Range: -20°C to +85°C Complete the Installation Rated Voltage: - Power contacts: 600V RJ45 Connector: CE6326 Rated Current: - Power contacts: 10A RJ 45 Crimp Tool: CE5092 Termination: IDC CAT.5 (26 - 24 AWG) EPIC® MC Universal Bus Modules Screw-Terminated Mount in High Profile housings only. Approvals Description 4 Contacts + Shield Plug Receptacle 10390600 10390700 Technical Data Temperature Range: -20°C to +85°C Rated Voltage: 30V Wire Size: 28 - 16 AWG (0.08 - 1.5 mm2) Max. Transfer Rate: 1.5 MB/sec (bus feed-through) Rated Current: 1A Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 359 EPIC® Rectangular Connector Inserts MC Series EPIC® MC Pneumatic Modules Application Advantage • F or compressed air hoses with inner diameters of 2.5 mm or 4 mm and a maximum outer diameter of 8 mm. • T ypically used with 4 x 2.5 mm or 6 x 4 mm metric tubing. These modules are used for easy and fast connection of compressed air hoses. Applications include machine building, mini pneumatics, measurement, and control technology. Hose Diameter 1 Port 2.5 mm 4.0 mm 2 Ports 2.5 mm 4.0 mm Receptacle (plus built-in valve) Plug Approvals Technical Data Number of Ports: 1, 2 44424004 44424006 44424005 44424007 Max. Air Pressure: 10 bar (145 psi) 44424008 44424010 44424009 44424011 Temperature Range: -20°C to +100°C EPIC® MC 2 Module Frames Holds 2 Modules All dimensions are in mm. Description 2 Module Frame Plug Receptacle 10381000 10381100 Compatible Housing Approvals HB 6: page 369 EPIC® MC 3 Module Frames Holds 3 Modules All dimensions are in mm. Description 3 Module Frame Plug Receptacle 10381200 10381300 Compatible Housing Approvals HB 10: page 372 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 360 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® MC Series Rectangular Connector Inserts EPIC® MC 5 Module Frame Holds 5 Modules All dimensions are in mm. Approvals Compatible Housing HB 16: page 378 Description 5 Module Frame Plug Receptacle 10381400 10381500 EPIC® MC 7 Module Frame Holds 7 Modules All dimensions are in mm. Approvals Compatible Housing HB 24: page 384 Description 7 Module Frame Plug Receptacle 10381600 10381700 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 361 EPIC® Rectangular Connector Inserts MC Series EPIC® MC 10 Module Frames Holds 10 Modules All dimensions are in mm. x2 MC 5 frames, use two part numbers Approvals Description 10 Module Frame Plug Receptacle 10381400 (x2) 10381500 (x2) Compatible Housing HB 32: page 390 EPIC® MC 14 Module Frames Hold 14 Modules All dimensions are in mm. x2 MC 7 frames, use two part numbers Approvals Description 14 Module Frame Plug Receptacle 10381600 (x2) 10381700 (x2) Compatible Housing HB 48: page 392 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 362 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Mixed Power Series Rectangular Connector Inserts EPIC® Mixed Power Series EPIC Mixed Power series inserts provide a combination of power contacts (up to 80A) and control contacts (up to 16A) in a single insert package. This can save valuable panel space by allowing one connector to do the job of two. These inserts fit into EPIC® HB series housings. ® Technical Data Number of Contacts: 4 power + 0, 2, 8 signal Contact Material: Hard silver-plated copper alloy Temperature Range: Contact Resistance: - Principal contacts: - Auxiliary contacts: -40°C to +125°C Pollution Level: 3 Test Voltage: - 4 power + 0 signal: - 4 power + 2 signal: - 4 power + 8 signal: < 0.3 mΩ < 1 mΩ Insulation Group: C 6 kV 6 kV / 4 kV 4 kV Rated Voltage: - UL/CSA: 600V Wire Size: - Screw termination: - Power contacts: up to 6 AWG (16 mm2) - Signal contacts: up to 14 AWG (2.5 mm2) Molding Material: Fiberglass-reinforced thermoplastic resin DIN VDE 0110/02.79: - Principal contacts: - 4+0 & 4+2: - 4+8: - Auxiliary contacts: 80A, 690 - 830V 80A, 400 - 475V 16A, 400 - 475V DIN VDE 0110/01.89: - Principal contacts: - 4+0 & 4+2: - 4+8: - Auxiliary contacts: 80A, 690V 80A, 400V 16A, 400V Approvals: UL: File #E115072 CSA: File #LR82270 EPIC® Mixed Power Inserts: Derating Curves EPIC® Mixed Power: 4 Power + 0 Signal 12 - 6 AWG (4 - 16 mm2) Power + 0 Signal EPIC® Mixed Power: 4 Power + 2 Signal 12 AWG (4 mm2) Power + 18 AWG (1 mm2) Signal Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 363 EPIC® Rectangular Connector Inserts Mixed Power Series EPIC® Mixed Power Inserts: Derating Curves EPIC® Mixed Power: 4 Power + 2 Signal 8 AWG (10 mm2) Power + 16 AWG (1.5 mm2) Signal EPIC® Mixed Power: 4 Power + 2 Signal 6 AWG (10 mm2) Power + 14 AWG (2.5 mm2) Signal EPIC® Mixed Power: 4 Power + 8 Signal 12 AWG (4 mm2) Power + 18 AWG (1 mm2) Signal EPIC® Mixed Power: 4 Power + 8 Signal 10 AWG (6 mm2) Power + 18 AWG (1 mm2) Signal EPIC® Mixed Power: 4 Power + 8 Signal 8 AWG (10 mm2) Power + 16 AWG (1.5 mm2) Signal EPIC® Mixed Power: 4 Power + 8 Signal 6 AWG (16 mm2) Power + 14 AWG (2.5 mm2) Signal Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 364 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com EPIC® Mixed Power Series Rectangular Connector Inserts EPIC® Mixed Power Inserts 4 Power + 0 Signal View from Cable Side All dimensions are in mm. Approvals Compatible Housing HB 16: page 378 Description 4 Power + 0 Signal Plug Receptacle MP/M400 MP/F400 EPIC® Mixed Power Inserts 4 Power + 2 Signal View from Cable Side All dimensions are in mm. Approvals Compatible Housing HB 16: page 378 Description 4 Power + 2 Signal Plug Receptacle MP/M402 MP/F402 EPIC® Mixed Power Inserts 4 Power + 8 Signal View from Cable Side All dimensions are in mm. Approvals Compatible Housing HB 24: page 384 Description 4 Power + 8 Signal Plug Receptacle 11/2408 11/1408 Photographs are not to scale and are not true representations of the products in question. For current information go to our website. If not otherwise specified, all values relating to the product are nominal values. 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com 365 EPIC® RECTANGULAR CONNECTOR HOUSINGS Rectangular Connector Housings Reference EPIC® Rectangular Housings Overview 367 SKINTOP® Overview 368 Complete Your Installation with a SKINTOP® Strain Relief EPIC® HB Series EPIC® HB 6 Housings 369 EPIC® HB 10 Housings 372 EPIC® HB 16 Housings 378 EPIC® HB 24 Housings 384 EPIC® HB 32 Housings 390 EPIC® HB 48 Housings 392 EPIC® ULTRA HB Series EPIC® ULTRA HB Housings Overview 394 EPIC® ULTRA HB 6 Housings 394 EPIC® ULTRA HB 10 Housings 396 EPIC® ULTRA HB 16 Housings 397 EPIC® ULTRA HB 24 Housings 398 EPIC® HA Series 366 EPIC® HA Housings Overview 399 EPIC® HA 3/4 Housings 400 EPIC® HA 10 Housings 402 EPIC® HA 16 Housings 404 EPIC® HA 32 Housings 406 EPIC® HA 48 Housings 408 EPIC® HA 64 Housings 409 800-774-3539 •  www.lappusa.com • www.lappcanada.com • www.lappmexico.com
10381300 价格&库存
很抱歉,暂时无法提供与“10381300”相匹配的价格&库存,您可以联系我们找货
