DCP4P051007GD4KSSD
DCP4P051007GD4KSSD
    WIMA
    DIP4
    10 µF 薄膜电容器 1100V(1.1kV) 聚丙烯(PP),金属化 径向 - 4 引线
DCP4P051007GD4KSSD 数据手册
® WIMA DC-LINK MKP 4 Metallized Polypropylene (PP) - Capacitors for DC-Link Applications. Capacitances from 1.0 F to 400 F. Rated Voltages from 400 VDC to 1500 VDC. Special Features Electrical Data O Capacitances up to 400 F O High volume/capacitance ratio O Excellent self-healing properties O Very low dissipation factor O High reliability O 2-pin, 4-pin or plate contact configuration O AEC-Q200 qualified O According to RoHS 2015/863/EU Typical Applications As intermediate circuit capacitor e.g. in high power converter technology, power supplies, solar inverters, e-mobility (battery chargers, motor drives & power train) etc. Construction Dielectric: Polypropylene (PP) film Capacitor electrodes: Vacuum-deposited Internal construction: Capacitance range: 1 F to 400 F (intermediate values on request) Rated voltages: 400 VDC, 500 VDC, 600 VDC, 800 VDC, 900 VDC, 1100 VDC, 1300 VDC, 1500 VDC Capacitance tolerances: ±20%, ±10%, ±5% Operating temperature range: –55° C to +105° C (hot spot including self-heating) Climatic test category: 55/085/56 in accordance with IEC Insulation resistance at +20° C:  30 000 sec (MΩ x F) Measuring voltage: 100 V/1 min. Dielectric absorption: 0.05 % Voltage and current derating: A derating factor of 1.35% per K must be applied from +85° C for DC voltages and from +70° C for AC currents (Irms). Additionally a derating factor of 4.5% per K must be applied from +85° C for AC currents (Irms) Reliability: Operational life 100 000 hours (Ur and 70° C) Failure rate 0 (0.5 x Ur and 40° C) Plastic film Vacuum-deposited electrode Metal contact layer (schoopage)  = CN [F] x Ur [V]   10 000 10 000 <    25 000 25 000 <    50 000 50 000 <  100 000  > 100 000 PCM Packing < < < < <  2  5 10 20 30 fit fit fit fit fit Dissipation factors at +20° C: tan  x 10-4 Termination Encapsulation: Solvent-resistant, flame-retardant plastic case with epoxy resin seal, UL 94 V-0 Terminations: Tinned wire or plates. Marking: Colour: Red. Marking: Black. 0 Test voltage:   500 VDC: 1.5 Ur, 2sec   500 VDC: 1.2 Ur, 2sec Specific dissipation: Box size Specific dissipation in Watts per K W x H x L in mm above the ambient temperature 9 x 19 x 31.5 11 x 21 x 31.5 13 x 24 x 31.5 15 x 26 x 31.5 17 x 29 x 31.5 17 x 34.5 x 31.5 20 x 39.5 x 31.5 13 x 24 x 41.5 15 x 26 x 41.5 17 x 29 x 41.5 19 x 32 x 41.5 20 x 39.5 x 41.5 24 x 45.5 x 41.5 28 x 38 x 41.5 31 x 46 x 41.5 35 x 50 x 41.5 40 x 55 x 41.5 25 x 45 x 57 30 x 45 x 57 35 x 50 x 57 45 x 55 x 57 45 x 65 x 57 0.021 0.025 0.030 0.034 0.039 0.044 0.053 0.037 0.042 0.048 0.054 0.065 0.080 0.076 0.092 0.106 0.123 0.102 0.113 0.132 0.164 0.184 For further details and graphs please refer to Technical Information. 400 VDC 500 VDC 600 VDC 800 VDC 900 VDC 1100 VDC 1300 VDC 1500 VDC 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 27.5 15 160 15 130 12 120 10  90 10  80 10  60  7  50  7  40 37.5 60 350 30 240 21 150 18 170 16 150 14 100 12  90 12  90 52.5 80 550 80 460 40 300 35 250 31 200 30 170 23 150 23 150 Maximum pulse rise time: max. pulse rise time V/sec at TA < 40° C PCM 400 VDC 500 VDC 600 VDC 800 VDC 900 VDC 1100 VDC 1300 VDC 1500 VDC 27.5 11 15 27 29 35 43 50 59 37.5 8 10 19 21 22 29 35 41 52.5 5 7 13 15 18 21 25 29 04.23 Packing units at the end of the catalogue 129 ® WIMA DC-LINK MKP 4 Continuation General Data Capacitance W H L   1 F   2 „   3 „   4 „   5 „   7 „  10 F   15 „   20 „   22 „   25 „  9  9  9  9  9  9 11 13 15 17 17 15 17 17 20 19 20 20 24 24 24 28 31 31 35 35 25 40 25 40 30 40 30 35 45 45 45 45 45 45 45 19 19 19 19 19 19 21 24 26 29 29 26 34.5 29 39.5 32 39.5 39.5 45.5 45.5 45.5 38 46 46 50 50 45 55 45 55 45 55 45 50 55 55 55 65 65 65 65 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 41.5 31.5 41.5 31.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 57 41.5 57 41.5 57 41.5 57 57 57 57 57 57 57 57 57   30 „   40 „   50   60   70   80   90 „ „ „ „ „ 100 120 140 150 „ „ „ F 160 „ 180 „ 200 „ 220 250 270 300 330 350 370 400 „ „ „ „ „ „ „ „ 400 VDC (70° C) / 300 VDC (85° C) / 220 VDC (105° C) Part number PCM** Pin IS Irms*(10 kHz)* ESR (10 kHz)* A A mΩ 27.5 2   11  1 238.7 DCP4G041006A_ _ _ _ _ _ 27.5 2   22  1.5 119.4 DCP4G042006A_ _ _ _ _ _ 27.5 2   33  1.5  79.6 DCP4G043006A_ _ _ _ _ _ 27.5 2   44  2  59.7 DCP4G044006A_ _ _ _ _ _ 27.5 2   55  2  47.7 DCP4G045006A_ _ _ _ _ _ 27.5 2   77  2.5  34.1 DCP4G047006A_ _ _ _ _ _ 27.5 2/4  110  3.5  23.9 DCP4G051006B_ _ _ _ _ _ 27.5 2/4  165  4.5  15.9 DCP4G051506D_ _ _ _ _ _ 27.5 2/4  220  5.5  11.9 DCP4G052006F_ _ _ _ _ _ 27.5 2/4  242  6   9.8 DCP4G052206G_ _ _ _ _ _ 27.5 2/4  275  7   8.6 DCP4G052506G_ _ _ _ _ _ 37.5 2/4  200  6.5  10 DCP4G052507D_ _ _ _ _ _ 27.5 2/4  330  8   7.2 DCP4G053006I_ _ _ _ _ _ 37.5 2/4  240  7.5   8.5 DCP4G053007E_ _ _ _ _ _ 27.5 2/4  440 10   5.4 DCP4G054006J_ _ _ _ _ _ 37.5 2/4  320  9.5   6 DCP4G054007F_ _ _ _ _ _ 37.5 2/4  400 11   5.4 DCP4G055007G_ _ _ _ _ _ 37.5 2/4  480 11.5   4.8 DCP4G056007G_ _ _ _ _ _ 37.5 2/4  560 13   4.7 DCP4G057007H_ _ _ _ _ _ 37.5 2/4  640 14   4.1 DCP4G058007H_ _ _ _ _ _ 37.5 2/4  720 15   3.6 DCP4G059007H_ _ _ _ _ _ 37.5 2/4  720 15   3.6 DCP4G059007L _ _ _ _ _ _ 37.5 2/4  800 18   2.8 DCP4G061007I_ _ _ _ _ _ 37.5 2/4  960 20   2.3 DCP4G061207I_ _ _ _ _ _ 37.5 2/4 1120 22.5   2.1 DCP4G061407J_ _ _ _ _ _ 37.5 2/4 1200 23   2 DCP4G061507J_ _ _ _ _ _ 52.5 4  750 20   2.6 DCP4G061509D_ _ _ _ _ _ 37.5 2/4 1280 24.5   2 DCP4G061607K_ _ _ _ _ _ 52.5 4  800 21   2.3 DCP4G061609D_ _ _ _ _ _ 37.5 2/4 1440 26   1.8 DCP4G061807K_ _ _ _ _ _ 52.5 4  900 23.5   2 DCP4G061809E_ _ _ _ _ _ 37.5 2/4 1600 27.5   1.6 DCP4G062007K_ _ _ _ _ _ 52.5 4 1000 25   1.8 DCP4G062009E_ _ _ _ _ _ 52.5 4 1100 27   1.8 DCP4G062209F_ _ _ _ _ _ 52.5 4 1250 32   1.6 DCP4G062509H_ _ _ _ _ _ 52.5 4 1350 33.5   1.5 DCP4G062709H_ _ _ _ _ _ 52.5 4 1500 35   1.3 DCP4G063009H_ _ _ _ _ _ 52.5 4 1650 37   1.2 DCP4G063309J_ _ _ _ _ _ 52.5 4 1750 40   1.1 DCP4G063509J_ _ _ _ _ _ 52.5 4 1850 41.5   1.1 DCP4G063709J_ _ _ _ _ _ 52.5 4 2000 43   1 DCP4G064009J_ _ _ _ _ _   * General guide   * Permissible Irms at 10° C internal temperature rise (general guide) ** PCM = Printed circuit module = pin spacing Dims. in mm. Part number completion: Version code: 2-pin = 4-pin = Tolerance: 20 % = 10 % =   5 % = Packing: bulk = Pin length: 6-2 = D2 D4 M K J S SD Taped version see page 157. Rights reserved to amend design data without prior notification. 04.23 Continuation page 131 130 ® WIMA DC-LINK MKP 4 Continuation General Data Capacitance W H L   1 F   2 „   3 „   4 „   5 „   7 „   8 „  10 F   12 „   15 „  9  9  9  9  9 11 13 13 15 17 15 17 17 17 20 20 19 20 20 20 24 28 24 28 31 31 31 35 35 25 40 30 40 35 35 45 45 45 45 45 45 19 19 19 19 19 21 24 24 26 29 26 29 34.5 29 39.5 39.5 32 39.5 39.5 39.5 45.5 38 45.5 38 46 46 46 50 50 45 55 45 55 50 50 55 55 55 55 65 65 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 41.5 31.5 31.5 41.5 31.5 31.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 57 41.5 57 41.5 57 57 57 57 57 57 57 57   18 „   20 „   22 „   25 „   30   35   40   50 „ „ „ „   55 „   60 „   70 „   80 „   90 „ 100 F 120 „ 130 140 150 160 180 200 210 220 240 „ „ „ „ „ „ „ „ „ 500 VDC (70° C) / 400 VDC (85° C) / 290 VDC (105° C) Part number PCM** Pin IS Irms*(10 kHz)* ESR (10 kHz)* A A mΩ 27.5 2  15  1 238.7 DCP4H141006A_ _ _ _ _ _ 27.5 2  30  1.5 119.4 DCP4H142006A_ _ _ _ _ _ 27.5 2  45  1.5  79.6 DCP4H143006A_ _ _ _ _ _ 27.5 2  60  1.8  63.7 DCP4H144006A_ _ _ _ _ _ 27.5 2  75  2.5  47.7 DCP4H145006A_ _ _ _ _ _ 27.5 2/4 105  3  34.1 DCP4H147006B_ _ _ _ _ _ 27.5 2/4 120  3  29.8 DCP4H148006D_ _ _ _ _ _ 27.5 2/4 150  4  23.9 DCP4H151006D_ _ _ _ _ _ 27.5 2/4 180  4  19.9 DCP4H151206F_ _ _ _ _ _ 27.5 2/4 225  5  15.9 DCP4H151506G_ _ _ _ _ _ 37.5 2/4 150  4.3  22.3 DCP4H151507D_ _ _ _ _ _ 27.5 2/4 270  6   9.5 DCP4H151806G_ _ _ _ _ _ 27.5 2/4 300  6  11.9 DCP4H152006I_ _ _ _ _ _ 37.5 2/4 200  5.4  16.8 DCP4H152007E_ _ _ _ _ _ 27.5 2/4 330  7  10.9 DCP4H152206J_ _ _ _ _ _ 27.5 2/4 375  7.5   9.5 DCP4H152506J_ _ _ _ _ _ 37.5 2/4 250  6.3  13.4 DCP4H152507F_ _ _ _ _ _ 37.5 2/4 300  9   7.9 DCP4H153007G_ _ _ _ _ _ 37.5 2/4 350  8.5   9.1 DCP4H153507G_ _ _ _ _ _ 37.5 2/4 400 10   5.7 DCP4H154007G_ _ _ _ _ _ 37.5 2/4 500 13   4.8 DCP4H155007H_ _ _ _ _ _ 37.5 2/4 500 13   4.8 DCP4H155007L_ _ _ _ _ _ 37.5 2/4 550 14   4 DCP4H155507H_ _ _ _ _ _ 37.5 2/4 550 14   4 DCP4H155507L_ _ _ _ _ _ 37.5 2/4 600 14   4.7 DCP4H156007I_ _ _ _ _ _ 37.5 2/4 700 16.5   3.9 DCP4H157007I_ _ _ _ _ _ 37.5 2/4 800 17.5   3.4 DCP4H158007I_ _ _ _ _ _ 37.5 2/4 900 DCP4H159007J_ _ _ _ _ _ 19   3 37.5 2/4 1000 20   2.7 DCP4H161007J_ _ _ _ _ _ 52.5 4  700 14.3   5 DCP4H161009D_ _ _ _ _ _ 37.5 2/4 1200 22.5   2.7 DCP4H161207K_ _ _ _ _ _ 52.5 4  840 16.5   4.2 DCP4H161209E_ _ _ _ _ _ 37.5 2/4 1300 23   2.4 DCP4H161307K_ _ _ _ _ _ 52.5 4  980 21.5   2.8 DCP4H161409F_ _ _ _ _ _   2.7 DCP4H161509F_ _ _ _ _ _ 52.5 4 1050 22.5 52.5 4 1120 25.5   2.5 DCP4H161609H_ _ _ _ _ _ 52.5 4 1260 27   2.2 DCP4H161809H_ _ _ _ _ _ 52.5 4 1400 28.5   2 DCP4H162009H_ _ _ _ _ _ 52.5 4 1470 29.5   1.9 DCP4H162109H_ _ _ _ _ _ 52.5 4 1540 32   1.8 DCP4H162209J_ _ _ _ _ _ 52.5 4 1680 33.5   1.7 DCP4H162409J_ _ _ _ _ _   * General guide   * Permissible Irms at 10° C internal temperature rise (general guide) Part number completion: ** PCM = Printed circuit module = pin spacing Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 Dims. in mm. = = = = = = = D2 D4 M K J S SD Taped version see page 157. Rights reserved to amend design data without prior notification. 04.23 Continuation page 132 131 ® WIMA DC-LINK MKP 4 Continuation General Data Capacitance W H L   1 F   2 „   3 „   4 „   5 „   7 „   8 „  10 F  9  9  9 11 13 15 15 17 13 17 17 17 20 20 19 20 20 24 24 28 31 31 35 35 25 40 30 40 30 35 45 45 45 45 19 19 19 21 24 26 26 29 24 29 34.5 29 39.5 39.5 32 39.5 39.5 45.5 45.5 38 46 46 50 50 45 55 45 55 45 50 55 65 65 65 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 41.5 31.5 31.5 41.5 31.5 31.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 57 41.5 57 41.5 57 57 57 57 57 57   18 „   20 „   22   25   30   35 „ „ „ „   40   45   50   60 „ „ „ „   70 „   80 „   90 „ 100 F 120 „ 140 „ 150 „ 2-pin version   * General guide   * Permissible Irms at 10° C internal temperature rise (general guide) PCM Ø d 27.5 0.8 37.5 1 ** PCM = Printed circuit module = pin spacing W PCM b Dims. in mm. pin Part number completion: Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 = = = = = = = D2 D4 M K J S SD 4-pin version Taped version see page 157. pin Rights reserved to amend design data without prior notification. 132 c pin c Ø d c 11 27.5 5 0.8 0.4 13 27.5  7.5 0.8 0.4 15 27.5  7.5 0.8 0.4 17 27.5 10   0.8 0.4 20 27.5 12.5 0.8 0.4 19 37.5 10   1 0.4 20 37.5 12.5 1 0.4 24 37.5 12.5 1 0.4 28 37.5 10   1 0.4 31 37.5 20   1 0.4 35 37.5 20   1 0.4 40 37.5 20   1 0.4 25 52.5 12.5 1.2 0.8 30 52.5 20   1.2 0.8 35 52.5 20   1.2 0.8 45 52.5 20   1.2 0.8 Continuation page 133 04.23   12 „   15 „ 600 VDC (70° C) / 450 VDC (85° C) / 320 VDC (105° C) Part number PCM** Pin IS Irms*(10 kHz)* ESR (10 kHz)* A A mΩ 27.5 2   27  1.5 106.9 DCP4I041006A_ _ _ _ _ _ 27.5 2   54  2 56 DCP4I042006A_ _ _ _ _ _ 27.5 2   81  2.5 35.6 DCP4I043006A_ _ _ _ _ _ 27.5 2/4  108  3 26.7 DCP4I044006B_ _ _ _ _ _ 27.5 2/4  135  3.5 22 DCP4I045006D_ _ _ _ _ _ 27.5 2/4  189  4.5 16 DCP4I047006F_ _ _ _ _ _ 27.5 2/4  216  5 13.4 DCP4I048006F_ _ _ _ _ _ 27.5 2/4  270  6 11 DCP4I051006G_ _ _ _ _ _ 37.5 2/4  190  5 17.6 DCP4I051007C_ _ _ _ _ _ 27.5 2/4  324  6.5  8.9 DCP4I051206G_ _ _ _ _ _ 27.5 2/4  405  8  7 DCP4I051506I_ _ _ _ _ _ 37.5 2/4  285  6.5 11.8 DCP4I051507E_ _ _ _ _ _ 27.5 2/2  486  9.5  5.9 DCP4I051806J_ _ _ _ _ _ 27.5 2/4  540 10  5.3 DCP4I052006J_ _ _ _ _ _ 37.5 2/4  380 10.5  4.9 DCP4I052007F_ _ _ _ _ _ 37.5 2/4  418 11  5.4 DCP4I052207G_ _ _ _ _ _ 37.5 2/4  475 11.5  5 DCP4I052507G_ _ _ _ _ _ 37.5 2/4  570 14  4.1 DCP4I053007H_ _ _ _ _ _ 37.5 2/4  665 14.5  3.8 DCP4I053507H_ _ _ _ _ _ 37.5 2/4  665 14.5  3.8 DCP4I053507L_ _ _ _ _ _ 37.5 2/4  760 16.5  3.3 DCP4I054007I_ _ _ _ _ _ 37.5 2/4  855 17  3.2 DCP4I054507I_ _ _ _ _ _ 37.5 2/4  950 19  2.9 DCP4I055007J_ _ _ _ _ _ 37.5 2/4 1140 17.5  3.4 DCP4I056007J_ _ _ _ _ _ 52.5 2/4  780 14.5  4.9 DCP4I056009D_ _ _ _ _ _ 37.5 2/4 1330 20  3.1 DCP4I057007K_ _ _ _ _ _ 52.5 4  910 16.5  4.2 DCP4I057009E_ _ _ _ _ _ 37.5 2/4 1520 22  2.6 DCP4I058007K_ _ _ _ _ _ 52.5 4 1040 17.8  3.6 DCP4I058009E_ _ _ _ _ _ 52.5 4 1170 23.5  1.9 DCP4I059009F_ _ _ _ _ _ 52.5 4 1300 25  2.6 DCP4I061009H_ _ _ _ _ _ 52.5 4 1560 28  2.3 DCP4I061209J_ _ _ _ _ _ 52.5 4 1820 31  1.9 DCP4I061409J_ _ _ _ _ _ 52.5 4 1950 33  1.7 DCP4I061509J_ _ _ _ _ _ ® WIMA DC-LINK MKP 4 Continuation General Data Capacitance W H L   1 F   2 „   3 „   4 „   5 „   7 „   8 „  10 F  9  9 11 13 13 17 17 17 17 20 20 19 20 20 20 24 24 28 31 31 35 35 25 40 30 35 45 45 45 45 45 45 19 19 21 24 24 29 29 34.5 29 39.5 39.5 32 39.5 39.5 39.5 45.5 45.5 38 46 46 50 50 45 55 45 50 55 55 55 65 65 65 31.5 31.5 31.5 31.5 31.5 31.5 31.5 31.5 41.5 31.5 31.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 57 41.5 57 57 57 57 57 57 57 57   12 „   15 „   18   20   22   25   30 „ „ „ „ „   35   40   45   50 „ „ „ „   60 „   65 „   70 „   75 „   80 „   90 „ 100 F 115 „ 800 VDC (70° C) / 700 VDC (85° C) / 510 VDC (105° C) Part number PCM** Pin IS Irms*(10 kHz)* ESR (10 kHz)* A A mΩ 27.5 2   29  1.7 73.2 DCP4L041006A_ _ _ _ _ _ 27.5 2   58  2.5 36.6 DCP4L042006A_ _ _ _ _ _ 27.5 2/4   87  3 24.4 DCP4L043006B_ _ _ _ _ _ 27.5 2/4  116  4 18.3 DCP4L044006D_ _ _ _ _ _ 27.5 2/4  145  4.5 14.6 DCP4L045006D_ _ _ _ _ _ 27.5 2/4  203  6 10.5 DCP4L047006G_ _ _ _ _ _ 27.5 2/4  232  6.5  9.2 DCP4L048006G_ _ _ _ _ _ 27.5 2/4  290  8  7.3 DCP4L051006I_ _ _ _ _ _ 37.5 2/4  210  7.5  8.5 DCP4L051007E_ _ _ _ _ _ 27.5 2/4  348  9.5  6.1 DCP4L051206J_ _ _ _ _ _ 27.5 2/4  435  10.5  4.9 DCP4L051506J_ _ _ _ _ _ 37.5 2/4  315  8.5  7.5 DCP4L051507F_ _ _ _ _ _ 37.5 2/4  378  9.5  7.2 DCP4L051807G_ _ _ _ _ _ 37.5 2/4  420 10  6.2 DCP4L052007G_ _ _ _ _ _ 37.5 2/4  462 10.5  5.9 DCP4L052207G_ _ _ _ _ _ 37.5 2/4  525 12.5  5 DCP4L052507H_ _ _ _ _ _ 37.5 2/4  630 14  4.1 DCP4L053007H_ _ _ _ _ _ 37.5 2/4  630 14  4.1 DCP4L053007L_ _ _ _ _ _ 37.5 2/4  735 15.5  3.8 DCP4L053507I_ _ _ _ _ _ 37.5 2/4  840 16.5  3.3 DCP4L054007I_ _ _ _ _ _ 37.5 2/4  945 17.5  3.4 DCP4L054507J_ _ _ _ _ _ 37.5 2/4 1050 19  3 DCP4L055007J_ _ _ _ _ _ 52.5 4  750 18.5  3 DCP4L055009D_ _ _ _ _ _ 37.5 2/4 1260 21.5  2.7 DCP4L056007K_ _ _ _ _ _ 52.5 4  900 20.5  2.7 DCP4L056009E_ _ _ _ _ _ 52.5 4  975 22.5  2.2 DCP4L056509F_ _ _ _ _ _ 52.5 4 1050 23.5  3 DCP4L057009H_ _ _ _ _ _ 52.5 4 1125 24  2.9 DCP4L057509H_ _ _ _ _ _ 52.5 4 1200 24.5  3 DCP4L058009H_ _ _ _ _ _ 52.5 4 1350 25.5  2.5 DCP4L059009J_ _ _ _ _ _ 52.5 4 1500 26.5  2.3 DCP4L061009J_ _ _ _ _ _ 52.5 4 1725 28  2.1 DCP4L061159J_ _ _ _ _ _ 2-pin version   * General guide   * Permissible Irms at 10° C internal temperature rise (general guide) PCM Ø d 27.5 0.8 37.5 1 ** PCM = Printed circuit module = pin spacing W PCM b Ø d c Dims. in mm. pin Part number completion: Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 4-pin version = D2 = D4 =M =K =J =S = SD Taped version see page 157. 04.23 pin Rights reserved to amend design data without prior notification.. Continuation page 134 c pin c 11 27.5 5 0.8 0.4 13 27.5  7.5 0.8 0.4 15 27.5  7.5 0.8 0.4 17 27.5 10   0.8 0.4 20 27.5 12.5 0.8 0.4 19 37.5 10   1 0.4 20 37.5 12.5 1 0.4 24 37.5 12.5 1 0.4 28 37.5 10   1 0.4 31 37.5 20   1 0.4 35 37.5 20   1 0.4 40 37.5 20   1 0.4 25 52.5 12.5  1.2 0.8 30 52.5 20   1.2 0.8 35 52.5 20   1.2 0.8 45 52.5 20   1.2 0.8 133 ® WIMA DC-LINK MKP 4 Continuation General Data L 900 VDC (70° C) / 760 VDC (85° C) / 550 VDC (105° C) PCM** Pin IS Irms*(10 kHz)* ESR (10 kHz)* A A mΩ Part number Capacitance W H   1 F   2 „  9 11 19 21 31.5 27.5 31.5 27.5 2 2/4   35   70  2  2.5 66.1 44 DCP4N041006A_ _ _ _ _ _ DCP4N042006B_ _ _ _ _ _   3 „ 13 24 31.5 27.5 2/4  105  4 22 DCP4N043006D_ _ _ _ _ _   4 „ 13 24 31.5 27.5 2/4  140  4.5 16.5 DCP4N044006D_ _ _ _ _ _   5 „ 17 29 31.5 27.5 2/4  175  4.5 18 DCP4N045006G_ _ _ _ _ _   7 „   8 „ 17 17 29 34.5 31.5 27.5 31.5 27.5 2/4 2/4  245  280  6.5  7.5 9.4 8.3 DCP4N047006G_ _ _ _ _ _ DCP4N048006I_ _ _ _ _ _  10 F 20 19 39.5 32 31.5 27.5 41.5 37.5 2/4 2/4  350  220 10  9  5.3  6.7 DCP4N051006J_ _ _ _ _ _ DCP4N051007F_ _ _ _ _ _   15 „ 20 39.5 41.5 37.5 2/4  330 10.5  5.8 DCP4N051507G_ _ _ _ _ _   20 „ 24 45.5 41.5 37.5 2/4  440 13  4.8 DCP4N052007H_ _ _ _ _ _ 28 38 41.5 37.5 2/4  440 13  4.8 DCP4N052007L_ _ _ _ _ _   22 „   25 „   30 „   35 „   40 „ 24 45.5 41.5 37.5 2/4  484 14  4.1 DCP4N052207H_ _ _ _ _ _ 28 38 41.5 37.5 2/4  484 14  4.1 DCP4N052207L_ _ _ _ _ _ 31 46 41.5 37.5 2/4  550 15.5  3.8 DCP4N052507I_ _ _ _ _ _ 2/4  660 16.5  3.4 DCP4N053007I_ _ _ _ _ _ 4  540 15  4.5 DCP4N053009D_ _ _ _ _ _ 2/4  770 18  3.2 DCP4N053507J_ _ _ _ _ _ 4  630 16  4 DCP4N053509D_ _ _ _ _ _ 31 46 41.5 37.5 25 45 57 35 50 41.5 37.5 25 45 57 52.5 52.5 40 55 41.5 37.5 30 45 57 52.5 2/4  880 19.5  3.2 DCP4N054007K_ _ _ _ _ _ 4  720 18  3.5 DCP4N054009E_ _ _ _ _ _   50 „ 35 50 57 52.5 4  900 22  3.3 DCP4N055009F_ _ _ _ _ _   60 „ 45 55 57 52.5 4 1080 23  3 DCP4N056009H_ _ _ _ _ _   70 „   80 „ 45 45 65 65 57 57 52.5 52.5 4 4 1260 1440 24.5 25.5  3.3  2.8 DCP4N057009J_ _ _ _ _ _ DCP4N058009J_ _ _ _ _ _   * General guide   * Permissible Irms at 10° C internal temperature rise (general guide) ** PCM = Printed circuit module = pin spacing Dims. in mm. Part number completion: Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 = D2 = D4 =M =K =J =S = SD Taped version see page 157. Rights reserved to amend design data without prior notification. 04.23 Continuation page 135 134 ® WIMA DC-LINK MKP 4 Continuation General Data Capacitance W H L   1   2   3   4   5   7  9 13 15 17 17 20 19 20 20 24 24 28 31 35 25 35 25 40 30 35 35 35 45 45 45 19 24 26 29 34.5 39.5 32 39.5 39.5 45.5 45.5 38 46 50 45 50 45 55 45 50 50 50 55 65 65 31.5 31.5 31.5 31.5 31.5 31.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 57 41.5 57 41.5 57 57 57 57 57 57 57 Capacitance W H L F 11 15 17 17 20 19 20 24 24 28 31 25 35 25 40 30 40 35 35 45 45 45 21 26 29 34.5 39.5 32 39.5 45.5 45.5 38 46 45 50 45 55 45 55 50 50 55 65 65 31.5 31.5 31.5 31.5 31.5 41.5 41.5 41.5 41.5 41.5 41.5 57 41.5 57 41.5 57 41.5 57 57 57 57 57 F „ „ „ „ „   8 „  10 F   12 „   15 „   18 „   20 „   22 „   25 „   30   35   40   45   50   60   1   2   3   4   5 „ „ „ „ „ „ „ „ „ „   7 „   8 „  10 F   15 „   18 „   20 „   22 „   25   30   35   40 „ „ „ „ 1100 VDC (70° C) / 920 VDC (85° C) / 670 VDC (105° PCM** Pin IS Irms*(10 kHz)* ESR (10 kHz)* A A mΩ 27.5 2   43  2 86 27.5 2/4   86  4 19 27.5 2/4  129  5 13.6 27.5 2/4  172  6 10.8 27.5 2/4  215  7.5  7.8 27.5 2/4  301  9  6.5 37.5 2/4  203  7.5 10 37.5 2/4  232  8 10 37.5 2/4  290  9.5  7.2 37.5 2/4  348 11  6.6 37.5 2/4  435 12  5.6 37.5 2/4  435 12  5.6 37.5 2/4  522 13.5  5 37.5 2/4  580 15  4.7 52.5 4  420 14.5  4.9 37.5 2/4  638 15.5  4.4 52.5 4  462 15  4.5 37.5 2/4  725 16.5  4.6 52.5 4  525 16  4.4 52.5 4  630 17.5  4.4 52.5 4  735 18  4 52.5 4  840 18  4.3 52.5 4  945 20  4.1 52.5 4 1050 21  4.1 52.5 4 1260 23  3.5 C) 1300 VDC (70° C) / 1100 VDC (85° C) / 800 VDC (105° IS PCM** Pin Irms*(10 kHz)* ESR (10 kHz)* A A MΩ 27.5 2/4   50  2.5 40 27.5 2/4  100  4.5 16.8 27.5 2/4  150  6 10.8 27.5 2/4  200  6.5 10.4 27.5 2/4  250  7.5  9.4 37.5 2/4  175  7 11 37.5 2/4  245  8 10 37.5 2/4  280  9  9.9 37.5 2/4  350 10.5  7.2 37.5 2/4  350 10.5  7.2  4.8 37.5 2/4  525 14 52.5 4  375 13  6 37.5 2/4  630 15.5  4.4 52.5 4  450 14.5  4.9 37.5 2/4  700 17.5  4 52.5 4  500 16  4.4 37.5 2/4  770 18  3.8 52.5 4  550 17.5  4.3 52.5 4  625 19  3.6 52.5 4  750 20  4 52.5 4  875 21  4.1 52.5 4 1000 22  3.7 C) Part number DCP4P041006A_ _ _ _ _ _ DCP4P042006D_ _ _ _ _ _ DCP4P043006F_ _ _ _ _ _ DCP4P044006G_ _ _ _ _ _ DCP4P045006I_ _ _ _ _ _ DCP4P047006J_ _ _ _ _ _ DCP4P047007F_ _ _ _ _ _ DCP4P048007G_ _ _ _ _ _ DCP4P051007G_ _ _ _ _ _ DCP4P051207H_ _ _ _ _ _ DCP4P051507H_ _ _ _ _ _ DCP4P051507L_ _ _ _ _ _ DCP4P051807I_ _ _ _ _ _ DCP4P052007J_ _ _ _ _ _ DCP4P052009D_ _ _ _ _ _ DCP4P052207J_ _ _ _ _ _ DCP4P052209D_ _ _ _ _ _ DCP4P052507K_ _ _ _ _ _ DCP4P052509E_ _ _ _ _ _ DCP4P053009F_ _ _ _ _ _ DCP4P053509F_ _ _ _ _ _ DCP4P054009F_ _ _ _ _ _ DCP4P054509H_ _ _ _ _ _ DCP4P055009J_ _ _ _ _ _ DCP4P056009J_ _ _ _ _ _ Part number DCP4R241006B_ _ _ _ _ _ DCP4R242006F_ _ _ _ _ _ DCP4R243006G_ _ _ _ _ _ DCP4R244006I_ _ _ _ _ _ DCP4R245006J_ _ _ _ _ _ DCP4R245007F_ _ _ _ _ _ DCP4R247007G_ _ _ _ _ _ DCP4R248007H_ _ _ _ _ _ DCP4R251007H_ _ _ _ _ _ DCP4R251007L_ _ _ _ _ _ DCP4R251507I_ _ _ _ _ _ DCP4R251509D_ _ _ _ _ _ DCP4R251807J_ _ _ _ _ _ DCP4R251809D_ _ _ _ _ _ DCP4R252007K_ _ _ _ _ _ DCP4R252009E_ _ _ _ _ _ DCP4R252207K_ _ _ _ _ _ DCP4R252209F_ _ _ _ _ _ DCP4R252509F_ _ _ _ _ _ DCP4R253009H_ _ _ _ _ _ DCP4R253509J_ _ _ _ _ _ DCP4R254009J_ _ _ _ _ _   * General guide ** PCM = Printed circuit module = pin spacing   * Permissible Irms at 10° C internal temperature rise (general guide) 04.23 Dims. in mm. Rights reserved to amend design data without prior notification. Continuation page 136 135 ® WIMA DC-LINK MKP 4 Continuation General Data Capacitance W H L   1   2   3   4   5   7 13 17 19 20 20 24 28 31 31 35 25 40 30 35 35 45 45 45 24 29 32 39.5 39.5 45.5 38 46 46 50 45 55 45 50 50 55 55 65 31.5 31.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 41.5 57 41.5 57 57 57 57 57 57 F „ „ „ „ „   8 „  10 F   12 „   15 „   18   20   22   25   30 „ „ „ „ „ 1500 VDC (70° C) / 1200 VDC (85° C) / 870 VDC (105° PCM** Pin IS Irms*(10 kHz)* ESR (10 kHz)* A A mΩ 27.5 2/4  59  3 33.3 27.5 2/4 118  5 15.6 37.5 2/4 123  6 15 37.5 2/4 164  7 13.3 37.5 2/4 205  8 10.2 37.5 2/4 287  9.5 8.9 37.5 2/4 287  9.5 8.4 37.5 2/4 328 11 7.6 37.5 2/4 410 12.5 5.9 37.5 2/4 492 14.5 5 52.5 4 348 14 5.2 37.5 2/4 615 17 4.3 52.5 4 435 16 4.4 52.5 4 522 17.5 4.3 52.5 4 580 18 4.1 52.5 4 638 20 4.1 52.5 4 725 20.5 3.9 52.5 4 870 21.5 4 C) Part number DCP4S041006D_ _ _ _ _ _ DCP4S042006G_ _ _ _ _ _ DCP4S043007F_ _ _ _ _ _ DCP4S044007G_ _ _ _ _ _ DCP4S045007G_ _ _ _ _ _ DCP4S047007H_ _ _ _ _ _ DCP4S047007L_ _ _ _ _ _ DCP4S048007I_ _ _ _ _ _ DCP4S051007I_ _ _ _ _ _ DCP4S051207J_ _ _ _ _ _ DCP4S051209D_ _ _ _ _ _ DCP4S051507K_ _ _ _ _ _ DCP4S051509E_ _ _ _ _ _ DCP4S051809F_ _ _ _ _ _ DCP4S052009F_ _ _ _ _ _ DCP4S052209H_ _ _ _ _ _ DCP4S052509H_ _ _ _ _ _ DCP4S053009J_ _ _ _ _ _ 2-pin version   * General guide   * Permissible Irms at 10° C internal temperature rise (general guide) PCM Ø d ** PCM = Printed circuit module = pin spacing 27.5 0.8 37.5 1 Dims. in mm. pin Part number completion: Version code: 2-pin 4-pin Tolerance: 20 % 10 %   5 % Packing: bulk Pin length: 6-2 = = = = = = = D2 D4 M K J S SD 4-pin version W PCM b Taped version see page 157. pin c pin c Plate versions page 140 Rights reserved to amend design data without prior notification. Ø d c 11 27.5 5 0.8 0.4 13 27.5   7.5 0.8 0.4 15 27.5   7.5 0.8 0.4 17 27.5 10   0.8 0.4 20 27.5 12.5 0.8 0.4 19 37.5 10   1 0.4 20 37.5 12.5 1 0.4 24 37.5 12.5 1 0.4 28 37.5 10   1 0.4 31 37.5 20   1 0.4 35 37.5 20   1 0.4 40 37.5 20   1 0.4 25 52.5 12.5 1.2 0.8 30 52.5 20   1.2 0.8 35 52.5 20   1.2 0.8 45 52.5 20   1.2 0.8 Example 04.23 Continuation page 137 136 ® WIMA DC-LINK MKP 4 Continuation 500 VDC Impedance change with frequency (general guide) 1 1 PCM 27.5 Z  PCM 37.5 Z  0.1 0.1 7 5 7 5 3 3 -- 104 3 5 7 105 106 12 0.001 104 3 5 7 105 106 f/Hz Irms A 22 µF 7 5 3 f/Hz 24 Irms A µF 30 µF -- 40 µF -- 50 µF -- 60 -- 16 0.001 F Permissible AC current in relation to frequency at  20° C internal temperature rise (general guide) 5µ 3 0.01 µF µF 22 -- 7 5 10 -- 0.01 40 Irms A 32 60 µF 180 µF 18 28 16 10 24 14 8 30 µF 12 10 µF 10 6 16 8 4 120 µF 20 12 6 PCM 27.5 2 4 2 0 0 102 2 5 103 2 5 104 2 5 f 105 Hz 102 600 VDC Impedance change with frequency (general guide) 2 103 5 2 5 104 5 f 105 Hz 2 PCM 52.5 8 PCM 37.5 4 0 102 1 2 103 5 2 5 104 1 PCM 37.5 PCM 52.5 Z  Z  0.1 7 5 7 5 3 3 0.01 0.01 µF 25 µF -- 30 µF -- 35 µF -- 45 -- 0.1 0.001 104 3 5 7 µF 80 0 µF F µ 12 40 -- - 1 - 3 7 5 -- 7 5 3 105 106 0.001 104 3 5 7 105 106 f/Hz Permissible AC current in relation to frequency at  20° C internal temperature rise (general guide) 5 f 105 Hz 2 f/Hz 24 Irms A 40 Irms A 32 45 µF 120 µF 18 28 16 14 24 12 20 10 16 8 PCM 37.5 6 4 80 µF 12 PCM 52.5 8 4 2 0 2 5 103 2 5 104 2 5 f 105 Hz 0 102 2 5 103 2 5 104 2 5 f 105 Hz 04.23 102 Continuation page 138 137 ® WIMA DC-LINK MKP 4 Continuation 800 VDC Impedance change with frequency (general guide) 1 1 1 PCM 27.5 PCM 37.5 PCM 52.5 Z  Z  Z  0.1 0.1 0.1 7 5 7 5 7 5 3 3 3 0.01 0.01 0.01 7 5 7 5 3 3 5 µF 3 5 7 105 106 0.001 104 3 5 7 3 105 106 f/Hz µF 50 0 µF -- 6 0 µF F -- 9 0 µ -- - 10 - 104 µF 20 µF -- 25 µF -- 30 -- 0.001 7 5 0.001 104 3 5 7 105 106 f/Hz f/Hz Permissible AC current in relation to frequency at  20° C internal temperature rise (general guide) 16 24 Irms A PCM 27.5 12 40 Irms A 32 Irms A 30 µF 25 µF 18 16 10 8 28 14 24 12 20 10 5 µF 6 12 PCM 37.5 6 4 2 0 0 102 2 5 103 2 5 104 2 5 f 105 Hz PCM 52.5 8 4 2 60 µF 16 8 4 100 µF 102 900 VDC Impedance change with frequency (general guide) 2 103 5 2 5 104 2 5 f 105 Hz 0 102 1 2 103 5 2 104 5 1 PCM 37.5 PCM 52.5 Z  Z  0.1 7 5 7 5 3 3 0.01 0.01 µF F 15 0 µ F -- - 2 25 µ - - 0.1 0.001 104 3 5 7 µF 50 µF F 70 µ ---- 80 3 7 5 -- 7 5 3 105 106 0.001 104 3 5 7 105 106 f/Hz Permissible AC current in relation to frequency at  20° C internal temperature rise (general guide) 5 f 105 Hz 2 f/Hz 24 40 Irms A 32 Irms A 25 µF 18 16 20 µF 14 80 µF 28 24 12 20 10 16 8 PCM 37.5 6 4 50 µF 12 PCM 52.5 8 4 2 0 2 5 103 2 5 104 2 5 f 105 Hz 0 102 2 5 103 2 5 104 2 5 f 105 Hz 04.23 102 138 Continuation page 139 ® WIMA DC-LINK MKP 4 Continuation 1100 VDC Impedance change with frequency (general guide) 1 1 1 PCM 27.5 PCM 37.5 PCM 52.5 Z  Z  Z  0.1 0.1 7 5 7 5 7 5 3 3 2 0.1 µF 3 -µF 60 3 30 40 3 µF 7 5 -- 3 0.01 20 µF 7 5 -- 7 5 -- 0.01 µF 5 F -- 7 µ -- 0.01 µF 0.001 104 3 5 7 105 106 0.001 104 3 5 7 105 106 f/Hz 0.001 104 3 5 7 105 106 f/Hz f/Hz Permissible AC current in relation to frequency at  20° C internal temperature rise (general guide) 24 16 Irms A PCM 27.5 12 40 Irms A 32 Irms A 18 7 µF 20 µF 16 10 5 µF 8 6 14 24 12 20 40 µF 10 16 30 µF 8 2 µF 4 12 6 8 PCM 37.5 4 2 0 0 2 103 5 2 5 104 102 5 f 105 Hz 2 2 103 5 2 5 104 5 f 105 Hz 2 PCM 52.5 4 2 102 60 µF 28 0 102 2 103 5 2 5 104 5 f 105 Hz 2 1300 VDC Impedance change with frequency (general guide) 1 1 1 PCM 37.5 PCM 27.5 Z  PCM 52.5 Z  Z  0.1 0.1 0.1 7 5 7 5 7 5 3 3 3 10 µF 0.01 0.01 µF µF 3 20 3 40 3 25 7 5 -- 7 5 -- 7 5 -- 5 µF 0.01 µF 0.001 104 3 5 7 105 106 0.001 104 3 5 7 105 106 0.001 104 3 5 7 105 106 f/Hz f/Hz f/Hz Permissible AC current in relation to frequency at  20° C internal temperature rise (general guide) 16 24 Irms A Irms A PCM 27.5 12 40 Irms A 32 PCM 37.5 28 16 10 24 14 8 PCM 52.5 18 12 F 5µ 10 6 16 8 4 25 µF 20 µF 20 10 µF 12 6 8 4 2 4 2 0 0 2 5 103 2 5 104 2 5 f 105 Hz 102 2 5 103 2 5 104 2 5 f 105 Hz 0 102 2 5 103 2 5 104 2 5 f 105 Hz 04.23 102 Continuation page 140 139 ® WIMA DC-LINK MKP 4 Continuation Plate versions L H 0.6 14 15 W c 0.15 7.50.8 H 15 20.8 H h 0.8 L 20.8 20.8 0.6 L d 0.6 12 W 0.15 c 0.15 6.10.1 12 0.15 14 19.5 d 0.8 e e a b c d h W f a b a Ø Version L 41.5 41.5 A1 A1.5 a b c h 0.5 0.5 0.5 0.8 17.5 17.5 28 28 7.5 7.5 W 0 3.5 Version L a c d e Ø 0.5 0.5 0.8 0.8 0.1 A1.6 41.5 18 A1.6.1 41.5 22 A1.6.2 41.5 23 6 10 10 Version 6.50.15 0.6 L 17 0.8 a b a b 0.5 41.5 41.5 41.5 41.5 41.5 36 46.5 33.5 39.5 31.5 41.5 31.5 41.5 36 46.5 d c c d e f h 7.5 13 13 13 7.5 W 8.4 8.4 6.1 6.1 8.4 0 0 3.5 0 3.5 L H 6.50.15 0.6 l 8.40.1 a b c 22 0.15 d h 0.5 0.15 0.8 0 3 0 Version L A3.9 41.5 A3.11 41.5 70.1 5.50.15 a c 0.6 12 22 0.15 0.15 a b c h 0.5 0.5 0.5 0.8 40.5 40.5 46.5 46.5 14.5 14.5 0 3 Version L A3.8 A3.8.1 A3.8.2 41.5 W 17 41.5 W 17 41.5 W 17 12 0.15 a c l 0.5 0.5 0.8 18 22 22 6 10 10 23 17.5 23 04.23 A3 41.5 17.5 27.5 7.5 15 A3.5 41.5 17.5 27.5 7.5 15 A3.12 41.5 17.5 30 7.5 16.5 d 14.5 22 7.5 22 14 18.75 14 22 14.5 22 H 6.10.1 0.5 A2 A2.4.1 A2.6.1 A2.6.2 A2.8 c h H 17 7 7 8 b 0.5 0.5 0.5 0.15 0.8 0.1 0.8 L W L h 0.8 21.5 16 18.5 13 18.5 13 a Version L 140 Continuation page 141 ® WIMA DC-LINK MKP 4 Continuation Plate versions L W H 20.8 0.6 Dims. in mm L W Version B H f 6 -1 b 120.15 d 0.5 a L PCM 31.5 41.5 28.5 38.5 b Version A4.9 A4.10 A4.2 A4 a L b 0.8 31.5 W 15 31.5 W 15 41.5 W 15 41.5 W 15 44 43 54 53 f d 0.8 0.8 0.1 47 59 57 69 4.5 6.1 4.5 6.1 57 69 67 79 PCM =PC Module at the pin exit points ( 0.4) b 0.15 Additional special versions can be realized. Please contact us with your specific needs. 8 8 9 x 19 x 31.5 D4 B8 1A 1H 1I 1J 1S 2A 2F 2J 2K 2M 3A 3G 3K 3L 3M 3N 3P 3Q 4A 4C 4L 4M B8 A1 A1.5 A1.6 A1.6.1 A1.6.2 A2 A2.4.1 A2.6.1 A2.6.2 A2.8 A3 A3.5 A3.8 A3.8.1 A3.8.2 A3.9 A3.11 A3.12 A4 A4.2 A4.9 A4.10 Size Code 4-pin WxHxL D2 Version code 2-pin Possible connecting respective plate versions - depending on box size 6A 11 x 21 x 31.5 6B 13 x 24 x 31.5 6D 15 x 26 x 31.5 6F 17 x 29 x 31.5 6G 17 x 34.5 x 31.5 6I 20 x 39.5 x 31.5 6J 13 x 24 x 41.5 7C 15 x 26 x 41.5 7D 17 x 29 x 41.5 7E 19 x 32 x 41.5 7F 20 x 39.5 x 41.5 7G 24 x 45.5 x 41.5 7H 28 x 38 x 41.5 7L 7I 35 x 50 x 41.5 7J 40 x 55 x 41.5 7K 04.23 31 x 46 x 41.5 141 ® Recommendation for Processing and Application of Through-Hole Capacitors Soldering Process Internal temperature of the capacitor must be kept as follows: Polyester: preheating: Tmax. T125° C soldering: Tmax. T135° C Polypropylene: preheating: Tmax. T100° C soldering: Tmax. T110° C Single wave soldering Soldering bath temperature: T P 260 ° C Dwell time: t P 5 sec Double wave soldering Soldering bath temperature: T P 260 ° C Dwell time: ∑t P 5 sec Due to different soldering processes and heat requirements the graphs are to be regarded as a recommendation only. WIMA Quality and Environmental Philosophy ISO 9001:2015 Certification ISO 9001:2015 is an international basic standard of quality assurance systems for all branches of industry. The approval according to ISO 9001:2015 of our factories certifies that organisation, equipment and monitoring of quality assurance in our factories correspond to internationally recognized standards. WIMA WPCS The WIMA Process Control System (WPCS) is a quality surveillance and optimization system developed by WIMA. WPCS is a major part of the quality-oriented WIMA production. Points of application during production process: All WIMA capacitors, irrespective of whether through-hole devices or SMD, are made of environmentally friendly materials. Neither during manufacture nor in the product itself any toxic substances are used, e.g. – Lead – PBB/PBDE – PCB – Arsenic – CFC – Cadmium – Hydrocarbon chloride – Mercury – Chromium 6+ – etc. We merely use pure, recyclable materials for packing our components, such as: ! ! ! ! carton cardboard adhesive tape made of paper polystyrene We almost completely refrain from using packing materials such as: ! adhesive tapes made of plastic ! metal clips RoHS Compliance According to the RoHS Directive 2015/863/EU as amended from time to time certain hazardous substances like e.g. lead, cadmium, mercury must not be used any longer in electronic equipment as of July 1st, 2006. For the sake of the environment WIMA has re-fraind from using such substances since years already. WIMA Kondensatoren sind bleifrei konform RoHS 2015/863/EU WIMA capacitors are lead free in accordance with RoHS 2015/863/EU Tape for lead-free WIMA capacitors DIN EN ISO 14001:2004 WIMA’s environmental management has been established in accordance with the guidelines of DIN EN ISO 14001:2004 to optimize the production processes with regard to energy and resources. 04.23 ! incoming material inspection ! metallization ! film inspection ! schoopage ! pre-healing ! pin attachment ! cast resin preparation/encapsu lation ! 100% final inspection ! Testing as per customer require ments WIMA Environmental Policy 15 ® Typical Dimensions for Taping Configuration Vh P P2 Diagram 1: PCM 2.5/5/7.5mm W W1 W0 H H1 W2 P1 D0 d P t F P0 H1 P P1 H P1 d d F P0 P2 Diagram 2: PCM 10/15 mm Diagram 3: PCM 22.5 and 27.5*mm *PCM 27.5 taping possible with two feed holes between components Designation Carrier tape width Dimensions for Radial Taping Symbol PCM 2.5 taping W P0 P2 F PCM 5 taping PCM 7.5 taping PCM 10 taping* PCM 15 taping* PCM 22.5 taping PCM 27.5 taping 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing for hot-sealing Hold-down tape width W0 6.0 6.0 12.0 12.0 12.0 12.0 12.0       adhesive tape       adhesive tape        adhesive tape        adhesive tape        adhesive tape        adhesive tape        adhesive tape Hole position W1 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 Hold-down tape position W2 Feed hole diameter D0 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 *38.1 ±1.5 or 50.8 ±1.5 P 12.7 ±1.0 12.7 ±1.0 12.7 ±1.0 25.4 ±1.0 25.4 ±1.0 38.1 ±1.5 0.5 to 3.0 max. 0.5 to 3.0 max. Pitch of component cumulative pitch Feed hole pitch P0 12.7  ±0.3 error max. 12.7 ±0.3 1.0 mm/20 pitch 0.5 to 3.0 max. cumulative pitch error max. 1.0 mm/20 pitch 12.7 ±0.3 0.5 to 3.0 max. cumulative pitch error max. 1.0 mm/20 pitch 12.7 ±0.3 cumulative pitch error max. 1.0 mm/20 pitch 0.5 to 3.0 max. 12.7 ±0.3 0.5 to 3.0 max. cumulative pitch error max. 1.0 mm/20 pitch 12.7 ±0.3 cumulative pitch error max. 1.0 mm/20 pitch 0.5 to 3.0 max. 12.7 ±0.3 cumulative pitch error max. 1.0 mm/20 pitch Feed hole centre to pin P1 5.1 ±0.5 3.85 ±0.7 2.6 ±0.7 7.7 ±0.7 5.2 ±0.7 7.8 ±0.7 5.3 ±0.7 Hole centre to component centre P2 6.35 ±1.3 6.35 ±1.3 6.35 ±1.3 12.7 ±1.3 12.7 ±1.3 19.05 ±1.3 19.05 ±1.3 Feed hole centre to bottom H▲ edge of the component 16.5 ±0.3 16.5 ±0.3 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 Feed hole centre to top H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H edge of the component 1 32.25 max. 32.25 max. 24.5 to 31.5 25.0 to 31.5 26.0 to 37.0 30.0 to 43.0 35.0 to 45.0 Pin spacing at +0.8 F 2.5 ±0.5 5.0 7.5 ±0.8 10.0 ±0.8 15 ±0.8 22.5 ±0.8 27.5 ±0.8 upper edge of carrier tape     –0.2 Pin diameter d Component alignment ∆h Total tape thickness t 0.4 ±0.05 0.5 ±0.05 ± 2.0 max. ± 2.0 max. $ +0.06 ± 3.0 max. ± 3.0 max. 04.23 +0.08 +0.08 ± 3.0 max. ± 3.0 max. ± 3.0 max. AMMO 52 ±2 max. REEL   Ø 360 max. B 58 ±2 or REEL ØØ 500 25 ±1  Ø 30 ±1 66 ±2 Unit ▲ +0.08 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 ROLL/AMMO Package ▲ 52 ±2 depending on Ø 360 max. (see also page 158) B REEL Ø 30 ±1 58 ±2 comp. dimensions  +0.06 0.5 ±0.05 or 0.6–0.05 $0.5 ±0.05 or 0.6 –0.05 0.8  –0.05 0.8  –0.05 0.8  –0.05 When ordering please specify dimension H and required packaging type. $ Diameter of pins see General Data.  54 ±2 B 60 ±2  68 ±2 depending on PCM and component dimensions see details page 159. Dims in mm. Please clarify customer-specific deviations with the manufacturer. * PCM 10 and PCM 15 can be crimped to PCM 7.5. Position of components according to PCM 7.5 (sketch 1). P0 = 12.7 or 15.0 is possible 157 ® Types of Tape Packaging of Capacitors for Automatic Radial Insertion O REEL Packaging 340 max.  30±1 25±1 360 max. 500 max. O AMMO Packaging 340 max. 370 max. O ROLL Packaging 34 0m ax. 50 max. 50 max. 70 max. . ax 0 m ax. 34 0 m 49 B BAR CODE (Labelling) Labelling of package units in plain text and with alphanumerical Bar Code BARCODE PDF417 BARCODE 2D Datamatrix ! WIMA supplier number ! Date code ! Customer‘s P/O number ! P/O line ! Customer‘s part number ! WIMA part number ! Quantity ! WIMA confirmation number ! Country of origin ! Customer name ! Handling unit number ! Week of delivery. In addition part description of article capacitance value rated voltage dimensions technical note capacitance tolerance packing connecting information 04.23 – – – – – – – – 158 ® Packing Quantities for Capacitors with Radial Pins in PCM 2.5 mm to 27.5 mm Size PCM 2.5 mm 5 mm 7.5 mm 10 mm 15 mm 22.5 mm 04.23 27.5 mm W  2.5  3  3.8  4.6  5.5  2.5  3  3.5  4.5  4.5  5  5.5  5.5  6.5  7.2  7.2  8.5  8.5 11  2.5  3  4  4.5  5  5.7  7.2  3  4  4  5  6  6  8  5  6  7  8  9  9 11  5  6  7  8.5 10.5 10.5 11  9 11 13 15 17 17 20 H  7  7.5  8.5  9 10  6.5  7.5  8.5  6  9.5 10  7 11.5  8  8.5 13 10 14 16  7  8.5  9  9.5 10.5 12.5 12.5  9  9  9.5 11 12 12.5 12 11 12.5 14 15 14 16 14 14 15 16.5 18.5 19 20.5 21 19 21 24 26 29 34.5 39.5 pcs. per packing unit REEL AMMO Ø 360 Ø 500 340 x 340 490 x 370 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 N O F I H J A C B D 2200 2500 – 2800 – 2000 2300 – 2300 – 1500 1800 – 1800 – 1200 1500 – 1500 –  900 1200 – 1200 – 2200 2500 – 2800 – 2000 2300 – 2300 – 1600 2000 – 2000 – 1300 1500 – 1500 – 1300 1500 – 1500 – 1100 1400 – 1400 – 1000 1200 – 1200 – 1000 1200 – 1200 –  800 1000 – 1000 –  700 1000 – 1000 –  700  950 – 1000 –  600  800 –  800 –  600  800 –  800 –  500  600 –  640 – – 2500 4400 2500 – – 2200 4300 2300 4150 – 1700 3200 1700 3000 – 1500 2900 1400 2700 – 1300 2500 1300 – – 1000 2200 1100 – –  900 1800 1000 – – 1100 2200 – 1900 –  900 1600 – 1450 –  900 1600 – 1400 –  700 1300 – 1100 –  550 1100 – 1000 –  550 1100 – 1000 –  400  800 –  740 –  600 1200 – 1150 –  500 1000 – 1000 –  450  900 –  850 –  400  800 –  740 –  350  700 –  650 –  350  700 –  650 –  300  600 –  540 – –  800 –  770 – –  700 –  640 – –  600 –  550 – –  480 –  450 – –  400 –  360 – –  400 –  360 – –  380 –  350 – – 460/340* – – – – 380/280* – – – –  300 – – – –  270 – – – – – – – – – – – – – – – – – ROLL bulk L Codes  4.6 0B  4.6 0C  4.6 0D  4.6 0E  4.6 0F  7.2 1A  7.2 1B  7.2 1C  7.2 1D  7.2 1E  7.2 1F  7.2 1G  7.2 1H  7.2 1I  7.2 1J  7.2 1K  7.2 1L  7.2 1M  7.2 1N 10 2A 10 2B 10 2C 10.3 2D 10.3 2E 10.3 2F 10.3 2G 13 3A 13 3C 13 3D 13 3F 13 3G 13 3H 13 3I 18 4B 18 4C 18 4D 18 4F 18 4H 18 4J 18 4M 26.5 5A 26.5 5B 26.5 5D 26.5 5F 26.5 5G 26.5 5H 26.5 5I 31.5 6A 31.5 6B 31.5 6D 31.5 6F 31.5 6G 31.5 6I 31.5 6J S 5000 5000 5000 5000 5000 5000 5000 5000 6000 4000 3500 4000 2500 2500 2500 2000 2000 1500 1000 5000 5000 4000 3500 3000 2000 1500 3000 3000 3000 3000 2400 2400 2000 2400 2000 1600 1200 1200  900 1000 1200 1000  760  500 594* 594* 561*  567*  459*  378*  324*  198*  198*   162* * for 2-inch transport pitches. * TPS (Tray-Packing-System). Plate versions may have different packing units. Samples and pre-production needs on request. Rights reserved to amend design data without prior notification. 159 ® Packing Quantities for Capacitors with Radial Pins in PCM 37.5 mm to 52.5 mm Size PCM pcs. per packing unit REEL AMMO Ø 360 Ø 500 340 x 340 490 x 370 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 N O F I H J A C B D – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – – ROLL bulk W  9 11 13 15 17 19 20 24 28 31 35 40 H 19 22 24 26 29 32 39.5 45.5 38 46 50 55 L Codes 41.5 7A 41.5 7B 41.5 7C 41.5 7D 41.5 7E 41.5 7F 41.5 7G 41.5 7H 41.5 7L 41.5 7I 41.5 7J 41.5 7K S 441* 357* 294* 252* 154* 140* 126* 112*  84*  84*  35*  28* 48.5 mm** 19 23 27 33 37 31 34 37.5 48 54 56 56 56 56 56 8D 8E 8H 8J 8L 120*  80*  84*  25*  25* – – – – – – – – – – – – – – – – – – – – – – – – – 52.5 mm 25 30 35 45 45 45 45 50 55 65 57 57 57 57 57 9D 9E 9F 9H 9J  70*  60*  25*  20*  20* – – – – – – – – – – – – – – – – – – – – – – – – – 37.5 mm** * TPS (Tray-Packing-System). Plate versions may have different packing units. **For Snubber capacitors in 2-pin version the PCM is changing to 38.5 respective 49.5 mm. Samples and pre-production needs on request. Rights reserved to amend design data without prior notification. 04.23 Updated data on www.wima.com 160 ® WIMA Part Number System A WIMA part number consists of 18 digits and is composed as follows: Field   1 -   4: Type description Field   5 -   6: Rated voltage Field   7 - 10: Capacitance Field 11 - 12: Size and PCM Field 13 - 14: Version code (e.g. Snubber versions) Field 15: Capacitance tolerance Field 16: Packing Field 17 - 18: Pin length (untaped) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 M K S 2 C 0 2 1 0 0 1 A 0 0 M S S D 20 % bulk MKS 2 04.23 Type description: SMD-PET = SMDT SMD-PEN = SMDN SMD-PPS = SMDI FKP 02 = FKP0 MKS 02 = MKS0 FKS 2 = FKS2 FKP 2 = FKP2 FKS 3 = FKS3 FKP 3 = FKP 3 MKS 2 = MKS2 MKP 2 = MKP2 MKS 4 = MKS4 MKP 4 = MKP4 MKP 10 = MKP1 FKP 4 = FKP4 FKP 1 = FKP1 MKP-X2 = MKX2 MKP-X1 R = MKX1 MKP-Y2 = MKY2 MKP 4F = MKPF Snubber MKP = SNMP Snubber FKP = SNFP GTO MKP = GTOM DC-LINK MKP 4 = DCP4 DC-LINK MKP 6 = DCP6 DC-LINK HC = DCHC 63 VDC Rated voltage: 50 VDC = B0 63 VDC = C0 100 VDC = D0 250 VDC = F0 400 VDC = G0 450 VDC = H0 520 VDC = H2 600 VDC = I0 630 VDC = J0 700 VDC = K0 800 VDC = L0 850 VDC = M0 900 VDC = N0 1000 VDC = O1 1100 VDC = P0 1200 VDC = Q0 1250 VDC = R0 1500 VDC = S0 1600 VDC = T0 1700 VDC = TA 2000 VDC = U0 2500 VDC = V0 3000 VDC = W0 4000 VDC = X0 6000 VDC = Y0 230 VAC = 3Y 275 VAC = 1W 300 VAC = 2W 305 VAC = AW 350 VAC = BW 440 VAC = 4W ... 0.01 F Capacitance: 22 pF = 0022 47 pF = 0047 100 pF = 0100 150 pF = 0150 220 pF = 0220 330 pF = 0330 470 pF = 0470 680 pF = 0680 1000 pF = 1100 1500 pF = 1150 2200 pF = 1220 3300 pF = 1330 4700 pF = 1470 6800 pF = 1680 0.01 F = 2100 0.022 F = 2220 0.047 F = 2470 0.1 F = 3100 0.22 F = 3220 0.47 F = 3470 = 4100 1 F 2.2 F = 4220 4.7 F = 4470 = 5100 10 F = 5220 22 F = 5470 47 F 100 F = 6100 220 F = 6220 1000 F = 7100 1500 F = 7150 ... 2.5 x 6.5 x 7.2 Size: 4.8 x 3.3 x 3 Size 1812 4.8 x 3.3 x 4 Size 1812 5.7 x 5.1 x 3.5 Size 2220 5.7 x 5.1 x 4.5 Size 2220 7.2 x 6.1 x 3 Size 2824 7.2 x 6.1 x 5 Size 2824 10.2 x 7.6 x 5 Size 4030 12.7 x 10.2 x 6 Size 5040 15.3 x 13.7 x 7 Size 6054 2.5 x 7 x 4.6 PCM 2.5 3 x 7.5 x 4.6 PCM 2.5 2.5 x 6.5 x 7.2 PCM 5 3 x 7.5 x 7.2 PCM 5 2.5 x 7 x 10 PCM 7.5 3 x 8.5 x 10 PCM 7.5 3 x 9 x 13 PCM 10 4 x 9 x 13 PCM 10 5 x 11 x 18 PCM 15 6 x 12.5 x 18 PCM 15 5 x 14 x 26.5 PCM 22.5 6 x 15 x 26.5 PCM 22.5 9 x 19 x 31.5 PCM 27.5 11 x21 x 31.5 PCM 27.5 9 x 19 x 41.5 PCM 37.5 11 x 22 x 41.5 PCM 37.5 19 x 31 x 56 PCM 48.5 25 x 45 x 57 PCM 52.5 ... Version code: Standard Version A1 Version A1.1.1 Version A2 ... = 00 = 1A = 1B = 2A - = KA = KB = QA = QB = TA = TB = VA = XA = YA = 0B = 0C = 1A = 1B = 2A = 2B = 3A = 3C = 4B = 4C = 5A = 5B = 6A = 6B = 7A = 7B = 8D = 9D 6 -2 Tolerance: ±20 % = M ±10 % = K ±5 % =J ±2.5 % = H ±1 % =E ... Packing: AMMO H16.5 340 x 340 AMMO H16.5 490 x 370 AMMO H18.5 340 x 340 AMMO H18.5 490 x 370 REEL H16.5 360 REEL H16.5 500 REEL H18.5 360 REEL H18.5 500 ROLL H16.5 ROLL H18.5 BLISTER W12 180 BLISTER W12 330 BLISTER W16 330 BLISTER W24 330 Bulk/TPS Standard ... =A =B =C =D =F =H =I =J =N =O =P =Q =R =T =S Pin length (untaped) 3.5 ±0.5 = C9 6 -2 = SD 16 ±1 = P1 ... Pin length (taped) none = 00 The data on this page is not complete and serves only to explain the part number system. Part number information is listed on the pages of the respective WIMA range. 155
DCP4P051007GD4KSSD 价格&库存
很抱歉,暂时无法提供与“DCP4P051007GD4KSSD”相匹配的价格&库存,您可以联系我们找货
DCP4P051007GD4KSSD
  • 1+66.396181+8.58936
  • 10+49.3379910+6.38263
  • 50+42.5384550+5.50300
  • 126+39.81772126+5.15103
  • 504+36.85464504+4.76771
  • 1008+35.752641008+4.62515
  • 2520+34.588142520+4.47451
库存:4066
