IP232912-1
IP232912-1
    DBUNLIMITED
    插件,D=23.8mm
    压电 蜂鸣器 指示灯,内部驱动 12 V 8mA 2.9kHz 95dB @ 12V,10cm 通孔 PC 引脚
IP232912-1 数据手册
Insert Graphics Specifications Description Value Unit Technology Piezo Resonant Frequency 2,900 (Hz) Rated Voltage 12 (V) SPL @ 10cm 95 (dBA) Tone Mount Type Voltage Range Max Rated Current Housing Material 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S Single Thru-hole 3 ~ 20 8 (V) (mA) NORYL Operating Temperature -20 ~ +85 °C Storage Temperature -20 ~ +85 °C 6 (g) Weight Revision History Notes Piezo Indicator Drawn by Date Checked by Date Approved by Date A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 IP232912-1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited Sheet 1 of 1
IP232912-1 价格&库存
很抱歉,暂时无法提供与“IP232912-1”相匹配的价格&库存,您可以联系我们找货
