KUSBEX-ASFS1N-B30
KUSBEX-ASFS1N-B30
    KYCON
    插件
    USB连接器 4P SMD 端口数:1 额定电流:1.5A 额定电压:30V 工作温度:-40℃~+105℃
KUSBEX-ASFS1N-B30 数据手册
2D Drawing IGES STEP 3D PDF Solder Profile CofC RoHS Compliant CofC REACH Compliant UL Plastic File Certificate of Origin Check Stock Request a Sample Send Us An Email Generated Part Number KUSBEX-ASFS1N-B Part Number Builder LR78160 KUSBEX UNIVERSAL SERIAL BUS: KUSBEX Series Fully Shielded Right Angle USB ASFS1N Type B Color Option Series KUSBEX - Fully Shielded Right Angle USB (NEW DESIGN) Product Features Meets USB 2.0 Specifications Compatible with Many Computer Peripherals A and B Types Available Supports Hot Plugging Contact Area with Gold Plating CSA/NRTL Certified File No. LR78160 UL File No. E134345 Performance Specifications Materials and Finish Insulator PBT Thermoplastic, UL 94V-0 Rated, Black or White Color Contacts Phosphor Bronze Contact Plating Gold over Nickel on Contacts, Tin over Nickel on Termination End Shell Brass, Nickel or Tin Plating, See Spec. Electrical Characteristics Series Type ASFS1N - A Type Fully Shielded Receptacle BSFS1N - B Type Fully Shielded Receptacle Insulator Color Option B - Black W - White Contact Kycon for other options KUSBEX Series Dimensions in mm KUSBEX-ASFS1N Rated Voltage: 30V AC Rated Current: 1A Contact Resistance: 20 milliohms Max Insulation Resistance: 1000 Megohms Min. Dielectric Withstanding Voltage: 750V AC For 1 Minute Operating Temperature: See Drawing Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 1116
KUSBEX-ASFS1N-B30 价格&库存
很抱歉,暂时无法提供与“KUSBEX-ASFS1N-B30”相匹配的价格&库存,您可以联系我们找货
KUSBEX-ASFS1N-B30
  • 1+8.859001+1.14830
