RP1A23D10
RP1A23D10
    CARLOGAVAZZI
    SIP-4
    固态 SPST-NO(1 Form A) 4-SIP
RP1A23D10 数据手册
 RP1A..D10, RP1B..D10 1-phase PCB mount solid state relays Main features • AC Solid State Relay for PCB mounting • Zero switching or instant-on • Rated operational current: 10 AACrms (25 AACrms with forced air cooling) • Rated operational voltage: Up to 480 VACrms • Surface mount technology • Control voltage: 4 to 32 VDC • Opto-isolation: > 4000 VACrms • Blocking voltage: Up to 1000 Vp • Non-repetitive surge current: Up to 250 Ap Description The RP1..D10 is an SSR series for socket- or PCBmounting, providing an ideal interface between logic controls and AC loads. The RP1..D10 is designed for resistive and inductive loads up to 480VACrms. The integral heatsink allows switching of a high current in this compact package. Opto-isolation and load switching are performed by individual components, providing higher reliability. This relay can also drive high AC53a loads up to 7 AACrms. The Solid State technology used can withstand peak voltages of 1000V, making the RP1..D10 series suitable to drive AC loads such as loaded induction motors. Applications These relays can be used to switch heaters, motors, lights, valves or solenoids. Main functions • Zero cross or Instant on AC switching • Ratings up to 480 VACrms, 10 AACrms (25 AACrms with forced air cooling) • 4-32 VDC control voltage (3-32 VDC for RP1.23D10) 21/04/2017 RP1A..D10, RP1B..D10 DS ENG Carlo Gavazzi LTD 1 RP1A..D10, RP1B..D10  References Order code RP1 D10 Enter the code entering the corresponding option instead of Code R P 1 Option A B 23 40 48 - D 10 Description Notes Solid State Relay (PCB) Number of poles Switching mode: zero switching Switching mode: instant-On switching Rated operational voltage: 230 VACrms Rated operational voltage: 400 VACrms Rated operational voltage: 480 VACrms Control voltage: 4 to 32 VDC Rated operational current: 10AACrms 3 to 32 VDC for RP1.23D10 Selection guide Rated operational voltage Blocking voltage Control voltage 230 VACrms 400 VACrms 480 VACrms 650 Vp 850 Vp 1000 Vp 3 to 32 VDC 4 to 32 VDC 4 to 32 VDC Rated operational current 10 AACrms RP1A23D10 RP1A40D10 RP1A48D10 CARLO GAVAZZI compatible components Purpose Component name/code DIN adaptors RPM2 21/04/2017 RP1A..D10, RP1B..D10 DS ENG Notes DIN adaptor 600V with LED Note that when the RP..10 is mounted on DIN rail (vertical mounting), a derating factor has to be applied. Carlo Gavazzi LTD 2 RP1A..D10, RP1B..D10  Features General Material Weight Isolation: input to output Black Epoxy coating Approx. 40 g 4 kVACrms Dimensions 11 M 22 mm 18 mm 9M 3M 4M 22 mm 37 mm 43 mm M = 2.54 mm = 1/10 “ 21/04/2017 RP1A..D10, RP1B..D10 DS ENG Carlo Gavazzi LTD 3 RP1A..D10, RP1B..D10  Performance Mains supply Operational voltage range RP1A RP1B Operational frequency range Blocking voltage Zero voltage turn-on RP1.23D10 RP1.40D10 RP1.48D10 12 - 265 VACrms 12 - 265 VACrms 20 - 440 VACrms 12 - 440 VACrms 45 - 65 Hz < 850 Vp < 10 VACrms 20 - 530 VACrms 12 - 530 VACrms < 650 Vp < 1000 Vp Outputs Rated operational current AC 51 @ Ta = 25°C AC 53a @ Ta = 25°C Min. operational load current Power factor Rep. overload current t=1 s Non-rep. surge current t=20 ms Off-state leakage current @ rated voltage and frequency I2t for fusing t=10 ms Critical dV/dt off state min. On-state voltage drop @ rated current 10 AACrms 7 AACrms 10 mAACrms > 0.5 16 AACrms 250 Ap < 3 mAACrms 340 A2s 1000 V/μs < 1.5 VACrms Inputs Control voltage RP1.23D10 RP1.40D10, RP1.48D10 Pick-up voltage RP1.23D10 RP1.40D10, RP1.48D10 Drop-out voltage Max. input curent RP1A..D10 RP1B..D10 Max. reverse voltage Response time pick-up RP1A..D10 RP1A..D10 @ Vin 5VDC Response time drop-out RP1B..D10 RP1B..D10 @ Vin 5VDC 21/04/2017 RP1A..D10, RP1B..D10 DS ENG 3-32 VDC 4-32 VDC 2.8 VDC 3.8 VDC 1.2 VDC 10 mA 17 mA 32 VDC ≤ 1/2 cycle ≤ 200 μs ≤ 1/2 cycle ≤ 1/2 cycle Carlo Gavazzi LTD 4 RP1A..D10, RP1B..D10  Derating curve Load current [AACrms] Load current [AACrms] 12 30 10 25 8 20 6 15 4 10 2.5ACrms 2.5 AACrms 2 0 12AACrms 5 0 20 30 40 50 60 70 80 20 Surrounding Surroundingtemperature temperature[¡C] ˚C Fig. 1 Convection cooling 30 40 50 60 70 80 Surrounding temperature [°C] Fig. 2 Forced air cooling at 15m3/h Derating curve is used for finding max. load current at an elevated ambient temperature. Note: the above indicated current ratings apply only for the RP..10 mounted with fins in the vertical orientation to allow airflow through the heatsink fins. For other mounting orientations please consult your Carlo Gavazzi Sales representative. Thermal data Operating temperature Storage temperature -30° to +80°C (-22° to +176°F) -40° to +100°C (-40° to +212°F) Compatibility and conformity Standards compliance LVD: EN 60947-4-3 EMCD: EN 61000-6-2, EN 61000-6-4 UL508 C22.2 No. 14-13 Approvals 21/04/2017 RP1A..D10, RP1B..D10 DS ENG Carlo Gavazzi LTD 5  RP1A..D10, RP1B..D10 Electromagnetic compatibility (EMC) - immunity EN/IEC 61000-4-2 Electrostatic discharge (ESD) 8 kV air discharge, 4 kV contact (PC1) EN/IEC 61000-4-3 10 V/m, from 80 MHz to 1 GHz (PC1) Radiated radio frequency 10 V/m, from 1.4 to 2 GHz (PC1) 10 V/m, from 2 to 2.7 GHz (PC1) EN/IEC 61000-4-4 Electrical fast transient (burst) Output: 2 kV, 5 kHz (PC2) Input: 1 kV, 5 kHz (PC2) EN/IEC 61000-4-6 Conducted radio frequency 10V/m, from 0.15 to 80 MHz (PC1) EN/IEC 61000-4-5 Output, line to line: 1 kV (PC2) Electrical surge Output, line to earth: 1 kV (PC2)1 Input, line to line: 500 V (PC2)2 Input, line to earth: 500 V (PC2)2 EN/IEC 61000-4-11 0% for 0.5, 1 cycle (PC2) Voltage dips 40% for 10 cycles (PC2) 70% for 25 cycles (PC2) EN/IEC 61000-4-11 Voltage Interruptions 0% for 5000ms (PC2) Electromagnetic compatibility (EMC) - emissions Radio interference field emisEN/IEC 55011 sion (radiated) Class A: from 30 to 1000 MHz From 0.15 to 30 MHz EN/IEC 55011 Radio interference voltage Class A (industrial) with filter capacitor across the Mains supply emissions (conducted) EN/IEC 60947-4-3 Class A (no filtering needed) Note: • Performance Criteria 1 (PC1): no degradation of performance or loss of function is allowed when the product is operated as intended. • Performance Criteria 2 (PC2): during the test, degradation of performance or partial loss of function is allowed. However when the test is complete the product should return operating as intended by itself. • Performance Criteria 3 (PC3): temporary loss of function is allowed, provided the function can be restored by manual operation of the controls. • Control input lines must be installed together to maintain products' susceptability to Radio Frequency interference. • 1 A suppression device, such as a varistor, needs to be connected across the output terminals L1, T1 for immunity against higher voltage levels. • 2 A suppression device, such as a transil, needs to be connected across the control terminals A1, A2 for immunity against higher voltage levels. 21/04/2017 RP1A..D10, RP1B..D10 DS ENG Carlo Gavazzi LTD 6 RP1A..D10, RP1B..D10  Functional diagram (+) 3 1 REGULATION ZC Control input * IO 2 (-) 4 ZC - Zero Crossing IO - Instant On * The varistor is not included in the solid state relay. Connecting a varistor across terminals 1-2 helps protect the solid state relay against damages by over-voltage Connection specifications Terminals Terminals soldering temperature Copper alloy, tin-plated max. 300°C for 5 seconds COPYRIGHT ©2017 Content subject to change. Download the PDF: www.productselection.net 21/04/2017 RP1A..D10, RP1B..D10 DS ENG Carlo Gavazzi LTD 7
RP1A23D10 价格&库存
很抱歉,暂时无法提供与“RP1A23D10”相匹配的价格&库存,您可以联系我们找货
RP1A23D10
    • 1+426.68640
    • 200+170.25120
    • 500+164.57040
    • 1000+161.75160
