TE122405-6
TE122405-6
    DBUNLIMITED
    插件,D=12mm
    机电元件 蜂鸣器 传感器,外部驱动 5 V 40mA 2.4kHz 85dB @ 5V,10cm 通孔 PC 引脚
TE122405-6 数据手册
4 3 2 1 Part Number: DRAWN TE122405-6 12/19/2016 CJ CHECKED 12/19/2016 P.D Description: Electro-Mechanical Transducer D APPROVED 12/19/2016 J.S This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Side View Top View Bottom View Ø12 ± 0.2 C D C 9 ± 0.2 6.5 ± 0.2 2 - Ø0.6 5.5 Wash Tab 1.5 B A B Items Specifications Conditions Sound Pressure Level 85 dB (@ 10cm) Resonant Frequency 2,400 Hz Rated Voltage 5 V Voltage Range 3~8 V Coil Resistance 47 Ω Max. Rated Current 40 mA Storage Temperature -40 ~ +85 °C NOTES Operating Temperature -30 ~ +75 °C 1) All dimensions are in mm unless otherwise noted REVISION HISTORY REV 1 DESCRIPTION DATE Released from Engineering 10/21/2013 J.S. Updated to new template 4/2/2018 C.E. 2) All tolerances are ± 0.5 mm unless otherwise noted Connection Method PC Pin Mount Type Thru-Hole Mount 3) All parts meet RoHS Housing Material NORYL 4) Subject to change or redrawn without notice Weight 2 4 APPROVED g 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
TE122405-6 价格&库存
很抱歉,暂时无法提供与“TE122405-6”相匹配的价格&库存,您可以联系我们找货
