GDLX-SMT-S-88-50
GDLX-SMT-S-88-50
    KYCON
    SMD
    模块化连接器 - 插孔 8p8c(RJ45,以太网) 90°角(直角) 屏蔽
GDLX-SMT-S-88-50 数据手册
2.67 3.10±0.20 Materials and Finish 15.86 Housing MaterialHight Temp material UL 94V-0 Rated Color: Black 2.35±0.20 1234 5678 Reflow Process Compatible Contact MaterialPhosphor Bronze 13.19 0.10+0.15 -0.10 Contact Plating OptionsStandard: 0.0001" Nickel Plating, Selective Plating Gold Flash on Contact Area tin on termination end 50: 0.0001" Nickel Plating, Selective Plating 0.000050" Gold on Contact Area to Comply with FCC Requirements Under No. 47 C.F.R. Part 68, Subpart F tin on termination end 0.50 KYCON, Inc. 305 Digital Drive, Morgan Hill, CA 95037 (408)494-0330 17.78 18.34 11.43 5.07 3.05 Electrical Characteristics 8.89 1.27 Current Rating1.0 Amps 8 1 2.57 Voltage Rating125V DC Insulation Resistance500 Megohms Min. 0.76 Dielectric Withstanding Voltage1000V rms, 60Hz 12.70 2xØ3.25 Contact Resistance20 milliohms Max. Operating Temperature-40°C to +85°C Durability Rating500 mating cycles min. 3.05 11.43 Part Number GDLX-SMT-S-88 GDLX-SMT-S-88-50 2xØ1.60 15.75 Contact Area Plating Finish Tolerances Recommended PCB Layout Gold Flash (standard) R (Top View) 50u" Gold (50 option) REV. DATE DESCRIPTION REV. BY CHK. BY DRAWN BY DATE A2 A3 A4 A5 B1 B2 05/03/10 11/06/13 04/16/15 05/23/17 04/02/19 06/29/21 ECO #10-020 ECO #13-084 ECO #15-001 ECO #17-014 ECO #19-024 ECO #21-007 S. Vien W. Cook H. MA H. MA G. Serrato C. Kelleher H. MA H. MA C. Furumasu C. Furumasu D. Shehan N/A R. Aguirre 05/19/05 UNITS mm GDLX-SMT-S-88 RoHS COMPLIANT R E134345 Shielded Right Ang. Mod. Jack RoHS Compliant,Surface Mount, 8 pos. 8 contact C US LR78160 X.X ± 0.25 X.XX ± 0.15 Unless Stated Otherwise
GDLX-SMT-S-88-50 价格&库存
很抱歉,暂时无法提供与“GDLX-SMT-S-88-50”相匹配的价格&库存,您可以联系我们找货
GDLX-SMT-S-88-50
  • 1+18.314431+2.29072
  • 10+15.5916410+1.95016
  • 25+14.6121225+1.82764
  • 50+13.9145250+1.74039
  • 120+13.07950120+1.63595
  • 360+12.10352360+1.51388
  • 600+11.67503600+1.46028
  • 1080+11.200941080+1.40098
  • 2520+10.551262520+1.31972
库存:109
