AS5047U-HTSM
AS5047U-HTSM
    AMSOSRAM(艾迈斯半导体)
    TSSOP14
    霍尔效应 传感器 旋转位置 外磁铁,不含 鸥翼
AS5047U-HTSM 数据手册
Product Document Published by ams OSRAM Group AS5047U 14-Bit On-Axis Magnetic Rotary Position Sensor with Up to 14-Bit Binary Incremental Pulse Count General Description The AS5047U is a high-resolution rotary position sensor for fast absolute angle measurement over a full 360-degree range. This new position sensor is equipped with a revolutionary integrated dynamic angle error compensation (DAEC™) with almost 0 latency at higher rotational speed. For increased signal quality at lower rotational speed, the dynamic filter system (DFS™) reduces transition noise. The robust design of the device suppresses the influence of any homogenous external stray magnetic field. A standard 4-wire SPI serial interface with a CRC protection allows a host microcontroller to read 14-bit absolute angle position data from the AS5047U and to program non-volatile settings without a dedicated programmer. Incremental movements are indicated on a set of ABI signals with a maximum resolution of 16989 steps / 4096 pulses per revolution. Brushless DC (BLDC) motors are controlled through a standard UVW commutation interface with a programmable number of pole pairs from 1 to 7. The absolute angle position is also provided as PWM-encoded output signal. AS5047U are single die sensors and are available in a TSSOP14 Package. Ordering Information and Content Guide appear at end of datasheet. Key Benefits & Features The benefits and features of this device are listed below: Figure 1: Added Value of Using the AS5047U Benefits Features • Easy to use – saving costs on DSP • DAEC ™ Dynamic angle error compensation • DFS ™ Dynamic filter system • Higher durability and lower system costs (no shield needed) • Magnetic stray field immunity • Versatile choice of the interface • Independent output interfaces: SPI, ABI, UVW, PWM ams Datasheet [v1-01] 2020-Dec-16 Page 1 Document Feedback AS5047U − General Description Applications The AS5047U supports BLDC motor commutation for the most challenging industrial applications such as: • Factory automation • Building automation • Robotics • PMSM (permanent magnet synchronous motor) • Stepper motor closed loop • Optical encoder replacement Block Diagram The functional blocks of the AS5047U are shown below: Figure 2: AS5047U Block Diagram VDD3V3 Volatile Memory CSn CLK MISO MOSI SPI OTP VDD LDO P2ram_err or CRC ABI OffCompN otFinished Cordic Overflow 14-Bit ADC AFE CORDIC Adaptive Filter Interpolator DAEC UVW 14-Bit ADC A B I/PWM U V W/PWM Hall sensor array AGC Oscillator WDTST PWM AGCwarning AS5047U GND Page 2 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Pin Assignment Pin Assignment Figure 3: TSSOP-14 Pin Assignment 1 14 I/PWM CLK 2 13 GND MISO 3 12 VDD3V3 MOSI 4 11 VDD TEST 5 10 U B 6 9 V A 7 8 W/PWM AS547U CSn Figure 4: AS5047U Pin Description Pin Number Pin Name 1 CSn Digital input(1) SPI chip select (active low)(2) 2 CLK Digital input(1) SPI clock(3) 3 MISO Digital output SPI master data input, slave output(4) 4 MOSI Digital input(1) SPI master data output, slave input(3) 5 TEST 6 B Digital output Incremental signal B(5) 7 A Digital output Incremental signal A(5) 8 W/PWM Digital output Commutation signal W or PWM-encoded output(5) 9 V Digital output Commutation signal V(5) 10 U Digital output Commutation signal U(5) 11 VDD Power supply 5V power supply voltage for on-chip regulator ams Datasheet [v1-01] 2020-Dec-16 Pin Type Description Test pin (connect to ground) Page 3 Document Feedback AS5047U − Pin Assignment Pin Number Pin Name Pin Type Description 12 VDD3V3 Power supply 3.3V on-chip low-dropout (LDO) output. Requires an external decoupling capacitor (1μF) 13 GND Power supply Ground 14 I/PWM Digital output Incremental signal I (index) or PWM(5) Note(s): 1. Floating state of a digital input is not allowed. 2. If SPI is not used, a pull-up resistor on CSn is required. 3. If SPI is not used, a pull-down resistor on CLK and MOSI is required. 4. If SPI is not used, the pin MISO can be left open. 5. If ABI, UVW or PWM is not used, the pins can be left open. Page 4 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Absolute Maximum Ratings Stresses beyond those listed under Absolute Maximum Ratings Absolute Maximum Ratings may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated under Operational Conditions is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Figure 5: Absolute Maximum Ratings Symbol Parameter Min Max Units Comments Electrical Parameters VDD5 DC Supply Voltage at VDD pin -0.3 7.0 V Not operational VDD3 DC Supply Voltage at VDD3V3 pin -0.3 5.0 V Not operational VSS DC Supply Voltage at GND pin -0.3 0.3 V Vin Input Pin Voltage VDD+0.3 V Iscr Input Current (latch-up immunity) 100 mA -100 AEC-Q100-004 Total Power Dissipation PT Total Power Dissipation (all supplies and outputs) 150 mW Electrostatic Discharge ESDHBM Electrostatic Discharge HBM ±2 kV AEC-Q100-002 Temperature Ranges and Storage Conditions TAMB Operating Temperature Range TaProg -40 150 °C Ambient temperature Programming Temperature 5 45 °C Programming @ room temperature (25°C ± 20°C) TSTRG Storage Temperature Range -55 150 °C TBODY Package Body Temperature 260 °C RHNC Relative Humidity (non-condensing) 85 % MSL Moisture Sensitivity Level ams Datasheet [v1-01] 2020-Dec-16 5 3 IPC/JEDEC J-STD-020 Represents a maximum floor lifetime of 168h Page 5 Document Feedback AS5047U − Electrical Characteristics Electrical Characteristics All in this datasheet defined tolerances for external components need to be assured over the whole operation conditions range and also over lifetime. Overall condition: T AMB= -40°C to 150°C components spec; unless otherwise noted. Figure 6: Operational Conditions Symbol Parameter Conditions Min Typ Max Units VDD5 Positive supply voltage 5.0V operation mode 4.5 5.0 5.5 V Positive supply voltage 3.3V operation mode; from -40°C to 150°C (NOISESET bit has to set) 3.0 3.3 3.6 V Positive supply voltage Supply voltage required for programming in 3.3V operation 3.3 3.5 V Regulated voltage Voltage at VDD3V3 pin if VDD ≠ VDD3V3 3.2 3.6 V 16 mA VDD3V3 VDD_Burn VREG IDD Supply current VIH High-level input voltage VIL Low-level input voltage VOH High-level output voltage VOL Low-level output voltage C_L 3.4 0.7 × VDD V 0.3 × VDD VDD - 0.5 V V VSS + 0.4 V 50 pF I_Out_5V Output current 5 V operation(1) 4 mA I_Out_3V Output current 3 V operation(1) 2 mA Note(s): 1. Only applicable for digital output pins I/PWM, A, B, U, V, W/PWM, MISO. Page 6 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Electrical Characteristics Magnetic Characteristics Figure 7: Magnetic Characteristics Symbol Bz Parameter Orthogonal Magnetic Field Strength Conditions Min Required orthogonal component of the magnetic field strength measured at the die surface along a circle of 1.1mm radius 35 Typ Max Unit 70 mT Note(s): 1. All datasheet parameters are still valid as long as AGC (Automatic Gain Control) stays in range. To ensure a proper function of the AGC regulation loop, readout of ERRFL register (0x0001) or AGC register (0x3FF9) is required. Sensor can work with lower magnetic input field which influences spec parameters in terms of noise and accuracy. In case the sensor will be used in application with wider z distance, please contact the support team for detailed information. System Specifications Figure 8: System Specifications Symbol Parameter RES Core and resolution on SPI RES_ABI Resolution of the ABI interface Conditions Min Typ Max 14 Programmable with register setting (ABIRES) 25 Units bit 4096 steps INLOPT @ 25°C Non-linearity, optimum placement of the magnet ±0.4 ±0.8 degree INLOPT+TEMP Non-linearity, optimum placement of magnet and temperature -40°C to 150°C ±0.6 ±1 degree INLDIS+TEMP Non-linearity @ displacement of magnet and temperature -40°C to 150°C Assuming N35H Magnet (D=8mm, H=3mm) 500μm displacement in x and y z-distance = 2000μm ±1.2 degree RMS output noise without filter (1 sigma) on SPI, ABI, PWM and UVW. Not tested, guaranteed by design Orthogonal component for the magnetic field within the specified range (Bz), NOISESET= 0 0.068 degree ONL ams Datasheet [v1-01] 2020-Dec-16 0.034 Page 7 Document Feedback AS5047U − Electrical Characteristics Symbol Parameter Conditions ONH RMS output noise without filter (1 sigma) on SPI, ABI, PWM and UVW. Not tested, guaranteed by design Orthogonal component for the magnetic field within the specified range (Bz), NOISESET = 1 tdelay System propagation delay –core Reading angle via SPI Residual system propagation delay after dynamic angle error correction Typ Max Units 0.041 0.082 degree 90 110 μs At ABI, UVW and SPI -1.9 1.9 μs trefresh Refresh time of DAEC output Refresh time at SPI(ANGLECOM), ABI, UVW 202 247 ns DAE1700 Dynamic angle error At 1700 rpm constant speed 0.02 degree DAEmax Dynamic angle error At 28000 rpm constant speed 0.32 degree 28000 rpm tdelay_DAEC MS Maximum speed Min 222 Reference magnet: N35H, 8mm diameter; 3mm thickness. Magnet in the Bz range. Page 8 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Timing Characteristics Timing Characteristics Figure 9: Timing Specifications Symbol tpon Parameter Power-on time ams Datasheet [v1-01] 2020-Dec-16 Conditions Guaranteed by design. Time between VDD > VDDmin and the first valid outcome Min Typ Max Units 10 ms Page 9 Document Feedback AS5047U − Detailed Description Detailed Description The AS5047U is a Hall-effect magnetic sensor using a CMOS technology. The Hall sensors convert the magnetic field component perpendicular to the surface of the chip into voltage. The signals from the Hall sensors are amplified and filtered by the analog front-end (AFE) before being converted by the analog-to-digital converter (ADC). The output of the ADC is processed by the hardwired CORDIC (coordinate rotation digital computer) block to compute the angle and magnitude of the magnetic vector. The intensity of the magnetic field (magnitude) used by the automatic gain control (AGC) to adjust the amplification level for compensation of the temperature and magnetic field variations. The AS5047U generates continuously the angle information, which can be requested by the different interfaces of the device. The internal 14-bit resolution is available by readout register via the SPI interface. The resolution on the ABI output can be programmed for 10 to 14 bits. The Dynamic Angle Error Compensation block corrects the calculated angle regarding latency by using a linear prediction calculation algorithm. At constant rotation speed the latency time is internally compensated by the AS5047U, reducing the dynamic angle error at the SPI, ABI and UVW outputs. The adaptive filter block is implemented after the compensation block and reduces the transition noise at low rotation speed. The stable information is available on SPI, ABI and UVW. AS5047U allows selecting between a UVW output interface and a PWM encoded interface on the W pin. The non-volatile settings in the AS5047U is programmed through the SPI interface without any dedicated programmer. The AS5047U can support high-speed application up to 28krpm. Page 10 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Power Management The AS5047U can be either powered from a 5.0V supply using the on-chip low-dropout regulator or from a 3.3V voltage supply. The LDO regulator is not intended to power any other loads, and it needs a 1μF capacitor to ground located close to chip for decoupling as shown in Figure 11. In 3.3.V operation, VDD and VREG shall connected together. In this configuration, normal noise performance (ONL) is available at reduced maximum temperature (125°C) by clearing NOISESET to 0. When NOISESET is set to 1, the full temperature range is available with reduced noise performance (ONH). Figure 10: Temperature Range and Output Noise Without Filtering in 3.3V and 5.0V Mode VDD (V) NOISESET Temperature Range (°C) RMS Output Noise (degree) 5.0 0 -40 to 150 0.068 3.3 0 -40 to 125 0.068 3.3 1 -40 to 150 0.082 Figure 11: 5.0V and 3.3V Power Supply Options 5.0V Operation VDD 3.3 V Operation VDD3V3 LDO 3.0 – 3.6V VDD VDD3V3 LDO 1uF 100nF 100nF GND GND AS547U ams Datasheet [v1-01] 2020-Dec-16 AS547U Page 11 Document Feedback AS5047U − Detailed Description Dynamic Angle Error Compensation The AS5047U uses 4 integrated Hall sensors which produce a voltage proportional to the orthogonal component of the magnetic field to the die. These voltage signals are amplified, filtered, and converted into the digital domain to allow the CORDIC digital block to calculate the angle of the magnetic vector. The propagation of these signals through the analog front-end and digital back-end generates a fixed delay between the time of measurement and the availability of the measured angle at the outputs. This latency generates a dynamic angle error represented by the product of the angular speed (ω) and the system propagation delay (t delay): (EQ1) DAE = ω x t delay The dynamic angle compensation block calculates the current magnet rotation speed (ω) and multiplies it with the system propagation delay (t delay ) to determine the correction angle to reduce this error. At constant speed, the residual system propagation delay is t delay_DAEC. The angle represented on the PWM interface is not compensated by the Dynamic Angle Error Compensation algorithm. It is also possible to disable the Dynamic Angle Error Compensation with the DAECDIS setting. Disabling the Dynamic Angle Error Compensation gives a noise benefit of 0.016 degree rms. This setting can be advantageous for low speed (under 100 RPM) respectively static positioning applications. Adaptive Filter System The AS5047U uses an implemented adaptive filter system, which reduces the transition noise. The filter works dynamically depending on acceleration (positive and negative acceleration) of rotating system. It is able to match the right filter coefficients automatically. The filter coefficients (K value), which define also the limits in which the filters is acting, can be set in the OTP (K_min= 0x00 and K_max=0x00 by default).In addition, there is the possibility to turn off the filter in the OTP. Page 12 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Noise rms [degree] Figure 12: Noise vs K Values K_min 0 1 K_max 2 3 4 5 6 Filter coefficient (K values) For detailed application information please refer to the Application Note: AS5x47U_Adaptive_Filter. Figure 13: K Value Configuration K_min [LSB] Minimum K Value K_max [LSB] Maximum K Value 000 2 000 6 001 3 001 5 010 4 010 4 011 5 011 3 100 6 100 5 101 0 101 1 110 1 110 0 111 1 111 0 ams Datasheet [v1-01] 2020-Dec-16 Page 13 Document Feedback AS5047U − Detailed Description Figure 14: Adaptive Filter System Setting Symbol Parameter Min Typ Max Unit Notes 48 3059 Hz Depending on K setting in the OTP fcorner Corner frequency ONFdyn Noise during rotation 0.019 0.086 ° RMS noise (depending on the selected K setting) ONFstat Noise when stand still 0.011 0.084 ° Depending on K setting in the OTP Figure 15: Corner Frequency vs Noise K Value fcorner Filter corner frequency [Hz] ONFdyn Noise during rotation [degree] ONFstat Noise when stand still [degree] 0 48 0.019 0.011 1 97 0.028 0.017 2 194 0.036 0.032 3 387 0.048 0.044 4 773 0.062 0.059 5 1548 0.077 0.077 6 3095 0.086 0.084 Page 14 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Speed Measurements Rotation Speed Measurement The AS5047U features an average angular velocity calculation algorithm with 14-bit resolution. This angular velocity information is available over SPI and can be used without further averaging in the ECU. Figure 16: Angular Velocity Measurement Parameter Symbol Parameter Min Typ Velocity signal resolution VRes VRange Measurement range (default) VSens Velocity sensitivity (default) VError Velocity total error FCutoff Cut off frequency Max 14 bit -28000 28000 24.141 16.9 Unit 68.4 Notes Two's complement value rpm º/s/bit 14-bit resolution ±5 % Based on actual rotation speed 231 Hz Depending on K value (see adaptive filter system) Figure 17: Angular Velocity Measurement Filter Parameters Filter Setting Typ K=0 5.8 K=1 6 K=2 8.4 K=3 19.8 K=4 51.8 K=5 121.9 K=6 244.9 ams Datasheet [v1-01] 2020-Dec-16 Unit Notes °/s RMS noise Page 15 Document Feedback AS5047U − Detailed Description SPI Interface (Slave) The SPI interface shall connected to a host microcontroller (master) to read or write the volatile memory as well as to program the non-volatile OTP registers. The AS5047U SPI only supports slave operation mode. It communicates at clock rates up to 10 MHz. The AS5047U SPI uses mode=1 (CPOL=0, CPHA=1) to exchange data. As shown in Figure 18, a data transfer starts with the falling edge of CSn (CLK is low). The AS5047U samples MOSI data on the falling edge of CLK. SPI commands are executed at the end of the frame (rising edge of CSn). The bit order is MSB first. A CRC is protecting the SPI Data. SPI Timing The AS5047U SPI timing is shown in Figure 18. Figure 18: SPI Timing Diagram tCSn CSn (Input) tclk tL tclkH tclkL tH CLK (Input) tMISO tOZ MISO (Output) Data[23] Data[22] Data[0] tOZ tMOSI MOSI (Input) Page 16 Document Feedback Data[23] Data[22] Data[0] ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Figure 19: SPI Timing Parameter Description Min tL Time between CSn falling edge and CLK rising edge 350(1) ns tclk Serial clock period 100 ns tclkL Low period of serial clock 50 ns tclkH High period of serial clock 50 ns Time between last falling edge of CLK and rising edge of CSn tclk/2 ns tCSn High time of SS/ between two transmissions 350(1) ns tMOSI Data input valid to clock edge 20 ns tMISO CLK edge to data output valid 51 ns Time between CSn rising edge and MISO HiZ 10 ns tH tOZ Max Units Note(s): 1. Synchronization with the internal clock → 2 * tCLK_SYS + 10ns (tCLK_SYS is 9MHz typ). ams Datasheet [v1-01] 2020-Dec-16 Page 17 Document Feedback AS5047U − Detailed Description SPI Transaction AS5047U provides two different SPI transactions • 16-bit SPI frame without CRC (for high throughput) • 24-bit SPI frames with CRC • 32-bit SPI frames with CRC. The 32-bit SPI frames includes 8-bit PAD word. For high-throughput requirements, the AS5047U can handle 16-bit frames for read operations. This allows reading more than 400000 angle positions per second. Figure 20: 16-Bit SPI Frame CSn 15 14 13 MOSI 0 0 ADDR[13:0] R MSB LSB 15 14 13 MISO ER 0 RDATA[13:0] MSB LSB Figure 21: 16-Bit Command Frame Bit Name 15 0 Do not Care 14 R 1: Read 13:0 ADDR[13:0] Address Page 18 Document Feedback Description ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Figure 22: 16-Bit Data Frame Bit Name Description 15 Warning Bit ER 14 Error Bit 13:0 DATA[13:0] Data 24-Bit SPI frames and 32-Bit SPI frames have CRC for increased reliability of communication over the SPI. A wrong setting of the calculation / setting of the CRC causes a CRC error, which sets the CRCERR bit in the error flag register. Figure 23: 24-Bit SPI Frame CSn 23 MOSI 21 0 8 7 ADDR[13:0] 0 RW CRC-8 MSB LSB 23 22 21 MISO 8 7 ER RDATA[13:0] 0 CRC-8 MSB LSB Figure 24: 24-Bit Command Frame Bit Name 23 0 22 RW 0: Write 1: Read 21:8 ADDR[13:0] Address 7:0 CRC ams Datasheet [v1-01] 2020-Dec-16 Description Do not Care Calculated CRC Page 19 Document Feedback AS5047U − Detailed Description Figure 25: 24-Bit Data Frame Bit Name Description 23 Warning Bit ER 22 Error Bit 21:8 DATA[13:0] 7:0 CRC Data Calculated CRC The 32-Bit Frames have a PAD Word, which is applicable for operation in daisy chain mode. Figure 26: 32-Bit SPI Frame CSn 31 MOSI 23 22 21 PAD[n-1:0] 0 8 7 ADDR[13:0] 0 RW CRC-8 MSB LSB 31 30 29 MISO 8 7 16 15 ER RDATA[13:0] CRC-8 0 PAD[n-1:0] MSB LSB Figure 27: 32-Bit Command Frame Bit Name 31:24 PAD PAD Number 23 0 Do Not care 22 RW 0: Write 1: Read 21:8 ADDR[13:0] Address 7:0 CRC Page 20 Document Feedback Description Calculated CRC ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Figure 28: 32-Bit Data Frame Bit Name 31 Description Warning Bit ER 30 Error Bit 29:16 RW 15:8 ADDR[13:0] 7:0 CRC Data Calculated CRC PAD Number The data sent on the MISO pin. The CRC is calculated by the AS5047U. If an error or a warning is detected in the previous SPI command frame, the Error/Warning bit is set high. The SPI read is synchronized on the rising edge of CSn and the data is transmitted on MISO with the next read command, as shown in Figure 29. Figure 29: SPI Read CSn MOSI MISO Command Command Command Command Read ADD[m] Read ADD[n] Read ADD[o] Read ADD[p] Data Data Data DATA (ADD[m]) DATA (ADD[n]) DATA (ADD[o]) Recommended CRC calculation see chapter CRC Checksum In an SPI write transaction, the write command frame is followed by a write data frame at MOSI. The write data frame consists of the new content of register which address is in the command frame. During the new content is transmitted on MOSI by the write data frame, the old content is send on MISO. At the next command on MOSI the actual content of the register is transmitted on MISO, as shown in Figure 30. ams Datasheet [v1-01] 2020-Dec-16 Page 21 Document Feedback AS5047U − Detailed Description Figure 30: SPI Write CSn Command MOSI Write ADD[n] Data to write into ADD[n] DATA (x) Data content ADD[n] MISO Command Write ADD[m] New Data content of ADD[n] DATA (ADD[n]) DATA (x) Data to write into ADD[m] DATA (y) Data content ADD[m] DATA (ADD[m]) Command Next command New Data content of ADD[m] DATA (y) PAD Word Any number of PAD [8*n-1:0] bits can precede the MOSI data. The PAD word is used to allocate the data on MISO to the correct device. Page 22 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description CRC Checksum For secure and reliable data transmission, the 24-bit and 32-bit frames have a CRC for verification of correct transmission. The CRC is calculated out of the payload of the SPI frame. For the 24-bit SPI frames, the CRC calculation is based on bits 23:8. For the 32-bit command frame (MOSI), the CRC calculation is based on bits 23:8 as well. For the 32-bit data frame (MISO), the CRC is calculated based on bits 31:16. The PAD Number in the 32-bit frame does not affect the CRC. The calculation of the CRC is based on Irreducible polynomial x^4+x^3+x^2+1. The initialization CRC = 0xC4 prevents that 0x000000 is a valid SPI command. This command would clear all sticky error flags. Figure 31: CRC Parameters ams Datasheet [v1-01] 2020-Dec-16 Name Value CRC width 8-bit Polynomial 0x1D Initial value 0xC4 Input reflected No Result reflected No Final XOR value 0xFF Page 23 Document Feedback AS5047U − Detailed Description Volatile Registers The volatile registers are shown in Figure 32. Each register has a 14-bit address. Figure 32: Volatile Memory Register Description Address Name Default Description 0x0000 NOP 0x0000 No operation 0x0001 ERRFL 0x0000 Error register 0x0003 PROG 0x0000 Programming register 0x3FF5 DIA 0xX3C2 or 0xXBC2 for 3.3V mode 0xX3C3 or 0xXBC3 for 5 V mode 0x3FF9 AGC 0x0000 AGC Value 0x3FFA Sin-data 0x0000 Raw digital sine channel data 0x3FFB Cos-data 0x0000 Raw digital cosine channel data 0x3FFC VEL 0x0000 Velocity 0x3FFD MAG 0x0000 CORDIC magnitude 0x3FFE ANGLEUNC 0x0000 Measured angle without dynamic angle error compensation 0x3FFF ANGLECOM 0x0000 Measured angle with dynamic angle error compensation 0x00D1 ECC_Checksum 0x0000 ECC checksum calculated based on actual register setting DIAGNOSTIC Figure 33: ERRFL (0x0001) Name Read/Write Bit Position CORDIC Overflow R 10 Reading the Overflow Bit of the CORDIC OffCompNotFi nished R 9 In case the flag is 1 the internal offset compensation is not finished Not used N/A 8 No function. Bit Setting: 0 WDTST R 7 Watchdog information. In case the flag sets to 1, the internal oscillator or the watchdog is not working correctly CRC error R 6 CRC error during SPI communication Page 24 Document Feedback Description ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Name Read/Write Bit Position Command_ error R 5 SPI invalid command received Framing error R 4 Framing if SPI communication wrong P2ram_error R 3 ECC has detected 2 uncorrectable errors in P2RAM in customer area P2ram_ warning R 2 ECC is correcting one bit of P2RAM in customer area 1 This flag sets to 1 in case the AGC Value reaches 255 LSB and the magnitude value is the half of the of the regulated magnitude value (between AGC = 0LSB and AGC = 255LSB) which is typical 4800LSB. 0 Agc-warning=1. The flag sets to 1 in case the AGC Value reaches 0LSB or 255LSB. The detailed information which level is reached can be found in the diagnostic register. MagHalf Agc-warning R R Description Reading the ERRFL register automatically clears its contents (ERRFL=0x0000). In case of an error flag, a read of the DIA register is mandatory. Figure 34: PROG (0x0003) Name Read/Write Bit Position Description PROGVER R/W 6 Program verify: Must be set to 1 for verifying the correctness of the OTP programming PROGOTP R/W 3 Start OTP programming cycle OTPREF R/W 2 Refreshes the non-volatile memory content with the OTP programmed content PROGEN R/W 0 Program OTP enable: Enables reading / writing the OTP memory The PROG register is used for programming the OTP memory. ams Datasheet [v1-01] 2020-Dec-16 Page 25 Document Feedback AS5047U − Detailed Description Figure 35: DIA(0x3FF5) Name Read/Write Bit Position Description SPI_cnt R 11:12 Not used N/A 10 No function. Bit Setting: 0 AGC_finished R 9 Initial AGC settling finished Off comp finished R 8 Error flag offset compensation finished SinOff_fin R 7 Sine offset compensation finished CosOff_fin R 6 Cosine offset compensation finished MagHalf_flag R 5 Error flag magnitude is below half of target value Comp_h R 4 Warning flag AGC high Comp_l R 3 Warning flag AGC low Cordic_overflow R 2 Error flag CORDIC overflow LoopsFinished R 1 All Magneto Core loops finished Vdd_mode R 0 VDD supply mode: 0: VDD 3.3 Mode 1: VDD 5.0 Mode SPI frame counter Figure 36: AGC(0x3FF9) Name Read/Write Bit Position AGC R 7:0 Name Read/Write Bit Position Vel R 13:0 Name Read/Write Bit Position Mag R 13:0 Description 8-Bit AGC value Figure 37: VEL(0x3FFC) Description Velocity value (14-bit signed integer) Figure 38: MAG (0x3FFD) Page 26 Document Feedback Description CORDIC magnitude information ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Figure 39: ANGLEUNC (0x3FFE) Name Read/Write Bit Position ANGLEUNC R 13:0 Description Angle information without dynamic angle error compensation Figure 40: ECC_s (0x3FD0) Name Read/Write Bit Position ECC_s R 6:0 Name Read/Write Bit Position ANGLECOM R 13:0 Description Calculated ECC checksum Figure 41: ANGLECOM(0x3FFF) Description Angle information with dynamic angle error compensation Non-Volatile Registers (OTP) The OTP (One-Time Programmable) memory is used to store the absolute zero position of the sensor and the customer settings permanently in the sensor IC. SPI write/read access is possible several times for all non-volatile registers (soft write). Soft written register content will be lost after a hardware reset. The programming itself can be done just once. Therefore the content of the non-volatile registers is stored permanently in the sensor. The register content is still present after a hardware reset and cannot be overwritten. For a correct function of the sensor the OTP programming is not required. If no configuration or programming is done, the non-volatile registers are in the default state 0x0000. Figure 42: Non-Volatile Register Table Address Name Default 0x0015 DISABLE 0x0000 Outputs and filter disable register 0x0016 ZPOSM 0x0000 Zero position MSB 0x0017 ZPOSL 0x0000 Zero position LSB/ MAG diagnostic 0x0018 SETTINGS1 0x0000 Custom setting register 1 ams Datasheet [v1-01] 2020-Dec-16 Description Page 27 Document Feedback AS5047U − Detailed Description Address Name Default Description 0x0019 SETTINGS2 0x0000 Custom setting register 2 0x001A SETTINGS3 0x0000 Custom setting register 3 0x001B ECC 0x0000 ECC Settings Figure 43: DISABLE (0x0015) Description Name Read/Write/Program Bit Position UVW_off RW 0 0: Normal mode (default) 1: Switch UVW output off (tristate) ABI_off RW 1 0: Normal mode (default) 1: Switch ABI output off (tristate) na RW 2:5 FILTER_disable RW 6 Default=0 0: Filter enabled (default) 1: Filter disabled Figure 44: ZPOSM (0x0016) Name Read/Write/Program Bit Position ZPOSM R/W/P 7:0 Description 8 most significant bits of the zero position Figure 45: ZPOSL (0x0017) Name Read/Write/Program Bit Position Description ZPOSL R/W/P 5:0 6 least significant bits of the zero position Dia1_en R/W/P 6 Default=0; only applicable for automotive version AS5147U Dia2_en R/W/P 7 Default=0; only applicable for automotive version AS5147U Page 28 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Figure 46: SETTINGS1 (0x0018) Name Read/Write/Program Bit Position Description K_max R/W/P 2:0 K max for adaptive filter setting K_min R/W/P 5:3 K min for adaptive filter setting Dia3_en R/W/P 6 Default=0; not applicable Dia4_en R/W/P 7 Default=0; not applicable Figure 47: SETTINGS2 (0x0019) Name Read/Write/Program Bit Position Description IWIDTH R/W/P 0 0: 3 pulses 1: 1 pulses NOISESET R/W/P 1 Noise setting for 3.3V operation at 150°C DIR R/W/P 2 Rotation direction UVW_ABI R/W/P 3 Defines the PWM output (0=ABI is operating, W is used as PWM) (1=UVW is operating, I is used as PWM) DAECDIS R/W/P 4 Disable dynamic angle error compensation (0=DAE compensation ON, 1=DAE compensation OFF) ABI_DEC R/W/P 5 ABI setting to decimal count Data_select R/W/P 6 This bit defines which data can be read from address 16383dec (3FFFhex) 0-> ANGLECOM 1-> ANGLEUNC PWMon R/W/P 7 Enables PWM (setting of UVW_ABI bit necessary) ams Datasheet [v1-01] 2020-Dec-16 Page 29 Document Feedback AS5047U − Detailed Description Figure 48: SETTINGS3 (0x001A) Name Read/Write/Program Bit Position Description UVWPP R/W/P 2:0 UVW number of pole pairs HYS R/W/P 4:3 Hysteresis ABIRES R/W/P 7:5 Resolution of ABI Figure 49: ECC (0x001B) Name Read/Write/ Program Bit Position ECC_chsum R/W/P 6:0 ECC_en R/W/P 7 Page 30 Document Feedback Description ECC checksum Enables ECC ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description ABI Incremental Interface The AS5047U can send the angle position to the host microcontroller through an incremental interface. This interface is available simultaneously with the other interfaces. By default, the incremental interface is set to work at a 12-bit resolution which corresponds to 4096 steps per revolution or 1024 pulses per revolution (ppr). This resolution can be changed with the OTP bits ABIRES. The phase shift between the A and B signals indicates the rotation direction: clockwise (A leads, B follows) or counterclockwise (B leads, A follows). During the start-up time, after power on to the chip, all three ABI signals are high. The DIR bit can be used to invert the sense of the rotation direction. The IWIDTH setting programs the width of the index pulse from 3 LSB (default) to 1 LSB. Figure 50: ABI Signals A B I Steps N-7 N-6 N-5 N-4 N-3 N-2 N-1 0 1 2 3 Clockwise rotation 4 5 6 7 8 7 6 5 4 3 2 1 0 N-1 N-2 N-3 N-4 Counter-clockwise rotation N= 16384 for 14-Bit resolution, N = 4096 for 12-bit resolution and N = 1024 for 10-bit resolution.. The Figure 50 shows the ABI signal flow if the magnet rotates in clockwise direction and counter-clockwise direction (DIR=0). The rotation direction of the magnet is defined as clockwise (DIR=0) when the view is from the topside of AS5047U. ams Datasheet [v1-01] 2020-Dec-16 Page 31 Document Feedback AS5047U − Detailed Description Figure 51: ABI Settings ABIRES [LSB] SETTINGS3 (0x001A) ABI_DEC SETTINGS2 (0x0019) ABI_Pulses ABI Resolution [LSB] 100 0 4096 16384 011 0 2048 8192 000 0 1024 4096 (default value) 001 0 512 2048 010 0 256 1024 000 1 1000 4000 001 1 500 2000 010 1 400 1600 011 1 300 1200 100 1 200 800 101 1 100 400 110 1 50 200 111 1 25 100 Page 32 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description UVW Commutation Interface The AS5047U can emulate the UVW signals generated by the three discrete Hall switches commonly used in BLDC motors. The UVWPP field in the SETTINGS3 register selects the number of pole pairs of the motor (from 1 to 7 pole pairs). The UVW signals are generated based on14-bit core resolution. During the start-up time, after power on of the chip, the UVW signals are low. Figure 52: UVW Signals U V W angle 0° 60° 120° 180° 240° Clockwise rotation 300° 360° 360° 300° 240° 180° 120° 60° 0° Counter-clockwise rotation The Figure 52 shows the UVW signal flow if the magnet rotates in clockwise direction and counter-clockwise direction (DIR=0). The rotation direction of the magnet is defined as clockwise (DIR=0) when the view is from the topside of AS5047U. With the bit DIR, it is possible to invert the rotation direction. ams Datasheet [v1-01] 2020-Dec-16 Page 33 Document Feedback AS5047U − Detailed Description Figure 53: UVW Settings Page 34 Document Feedback UVWPP [LSB] Pole Pairs 000 1pp (default) 001 2pp 010 3pp 011 4pp 100 5pp 101 6pp 110 7pp 111 7pp ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description PWM The PWM can be enabled with the bit setting PWMon. The PWM encoded signal is displayed on the pin W or the pin I. The bit setting UVW_ABI defines which output is used as PWM. The PWM output consists of a frame of 4119 PWM clock periods, as shown in Figure 54. The PWM frame has the following sections: • 12 PWM clock periods for INIT • 4 PWM clock periods for error detection • 4095 PWM clock periods of data • 8 PWM clock periods low The angle is represented in the data part of the frame with a 12-bit resolution. One PWM clock period represents 0.088 degree and has a typical duration of 444 ns. If the embedded diagnostic of the AS5047U detects any error the PWM interface displays only 12 clock periods high (0.3% duty-cycle). Respectively the 4 clocks for error detection are forced to low. Figure 54: Pulse Width Modulation Encoded Signal 4 clock 12 clock periods periods high Error detection ams Datasheet [v1-01] 2020-Dec-16 4089 4090 4091 4092 4093 4094 4095 Error detection 1 2 3 4 5 6 7 8 INIT frame 4095 clock periods data 8 clock periods low time Page 35 Document Feedback AS5047U − Detailed Description Hysteresis Incremental Output Hysteresis A hysteresis is introduced to avoid flickering at incremental outputs at a stationary magnet position. In case of a rotational direction change, the incremental outputs have a hysteresis, which can be set in the SETTINGS3 register by HYSt-bits. Regardless of the programmed incremental resolution, the hysteresis always corresponds to the highest resolution of 11-bit Figure 55: Hysteresis Settings HYS Hysteresis LSB Hysteresis Degree 00 1 0.17° 01 2 0.35° 10 3 0.52° 11 0 0 Default For constant rotational directions, every magnet position change is indicated at the incremental outputs (see Figure 56). If for example the magnet turns clockwise from position “x+3“ to “x+4“, the incremental output would also indicate this position accordingly. A change of the magnet’s rotational direction back to position “x+3“means, that the incremental output still remains unchanged for the duration of 2 LSB, until position “x+2“ is reached. Following this direction, the incremental outputs will again be updated with every change of the magnet position. Page 36 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Detailed Description Figure 56: Hysteresis Incremental output indication X +4 Hysteresis: 2 LSB X +3 X +2 X +1 X X X +1 X +2 X +3 X +4 X +5 Magnet position Clockwise direction Counter clockwise direction Automatic Gain Control (AGC) and CORDIC Magnitude The AS5047U uses AGC to compensate for variations in the magnetic field strength due to changes of temperature, air gap between the chip and the magnet, and demagnetization of the magnet. The automatic gain control value can be read in the AGC field of the AGC register. Within the specified input magnetic field strength (Bz), the Automatic Gain Control keeps the CORDIC magnitude value (MAG) constant. If magnetic field strength is out of specifications, the AGC has its limits reached and the Agc-warning bit is set. When the magnetic field strength is decreasing more then AGC can control, the CORDIC magnitude is also decreasing. If the CORDIC magnitude decreases lower than half of the target magnet, the error flag MagHalf_flag is set. ams Datasheet [v1-01] 2020-Dec-16 Page 37 Document Feedback AS5047U − Detailed Description ECC The ECC (Error Code Correction) is a mechanism which protects the customer settings. The ECC protection is active whenever ECC_en=1. ECC_en is the error corrected counterpart of the P2RAM bit en and is found in register ECC_STATUS. Whenever a bit error occurs, this is reported by the status register ERRFL [2:3]. Single bit errors are corrected immediately and do not influence the correct operation of the sensor. If either a single or double errors are detected, the next SPI MISO frame will report this to the software by setting flags error=1 (double bit error) or warning=1 (single bit error). Warning and error are sticky flags, which guarantees that spurious P2RAM errors are certainly reported. The ECC Protection is activated with the following steps: • Writing uses data into the register and set ECC_en to high. • Reading ECC_s from register 0x3FD0 and set the value into ECC_chsum. Do not overwrite the ECC_en • Programming the part. Page 38 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Application Information Application Information Burn and Verification of the OTP Memory Figure 57: Minimum Programming Diagram for the AS5047U with 5V Supply Voltage VDD during programming 4.5 – 5.5V VDD I CLK GND MISO MOSI Programmer TEST B A AS5047U CSn VDD3V VDD U V 100nF 1μF W GND Note(s): 1. In terms of EMC and for remote application, additional circuits are necessary. ams Datasheet [v1-01] 2020-Dec-16 Page 39 Document Feedback AS5047U − Application Information Figure 58: Minimum Programming Diagram for the AS5047U with 3.3V Supply Voltage VDD during programming: 3.3V – 3.5V VDD CSn I CLK GND MOSI Programmer TEST B A VDD3V AS5047U MISO VDD U V 100nF W GND Note(s): 1. In terms of EMC and for remote application, additional circuits are necessary. Page 40 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Application Information Figure 59: Programming Parameter Symbol Parameter Conditions Min TaProg Programming temperature Programming @ Room Temperature (25°C ± 20°C) VDD Positive supply voltage 5 V operation mode. Supply voltage during programming 4.5 VDD Positive supply voltage 3.3 V operation mode. Supply voltage during programming 3.3 IProg Current for programming Max current during OTP burn procedure. Typ 5 5 Max Units 45 °C 5.5 V 3.5 V 100 mA Note(s): 1. Programming parameter valid for AS5047U. Step-by-Step Procedure to Permanently Program the Non-Volatile Memory (OTP): The programming can either be performed in 5V operation using the internal LDO (1μF on regulator output pin), or in 3V Operation but using a supply voltage between 3.3V and 3.5V. 1. Power on cycle 2. Write the SETTINGS1 and SETTINGS2 and SETTINGS3 registers with the Custom settings for this application 3. Place the magnet at the desired zero position 4. Read out the measured angle from the ANGLECOM register 5. Write ANGLECOM [5:0] into the ZPOSL register and ANGLECOM[13:6] into the ZPOSM register 6. Read reg(0x0016) to reg(0x001A) 7. Set ECC_en in Register ECC to 1 (ECC protection enabled) 8. Read ECC_s (0x3FD0) to get the correct ECC key 9. Write ECC_s key into ECC register 10. Read reg(0x0016) to reg(0x001B) → read register step1 11. Comparison of written content (settings and angle) with content of read register step1 12. If point 11 is correct, enable OTP read / write by setting PROGEN = 1 in the PROG register 13. Start the OTP burn procedure by setting PROGOTP = 1 in the PROG register 14. Read the PROG register until it reads 0x0001 (Programming procedure complete) ams Datasheet [v1-01] 2020-Dec-16 Page 41 Document Feedback AS5047U − Application Information 15. Clear the memory content by writing 0x00 in the whole non-volatile memory 16. Set the PROGVER = 1 to set the Guard band for the guard band test.1 17. Refresh the non-volatile memory content with the OTP content by setting OTPREF = 1 18. Read reg(0x0016) to reg(0x001B) → read register step2 19. Comparison of written content (settings and angle) with content of read register step2. If a deviation in the comparison occurs, the guard band test was not successful. Reprogramming is not allowed! Mandatory: guard band test 20. New power on cycle. 21. Read reg(0x0016) to Reg(0x001B) → read register step3 22. Comparison of written content (settings and angle) with content of read register step3. If a deviation in the comparison occurs, the power on test was not successful. Reprogramming is not allowed! 23. If point 18 is correct, the programming was successful. 1. Guard band test: Restricted to temperature range: 25 °C ± 20 °C Right after the programming procedure (max. 1 hour with same conditions 25°C ± 20 °C), same VDD voltage. The guard band test is only for the verification of the burned OTP fuses during the programming sequence. A use of the guard band in other cases is not allowed. Page 42 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Application Information Figure 60: OTP Memory Burn and Verification Flowchart Read Reg(0x0003) Power on cycle Read OTP_CTRL START FAIL Write DISABLE,SETTINGS1, SETTINGS2 and SETTINGS3 register Turn magnet to the prospective Zero Position Read ANGLECOM Reg(0x0003)==0x01 OTP burning procedure complete if Reg(0x0003)==0x01 Write Reg(0x0015)=0x00 Reg(0x0016)=0x00 Reg(0x0017)=0x00 Reg(0x0018)=0x00 Reg(0x0019)=0x00 Reg(0x001A)=0x00 Reg(0x001B)=0x00 Clear memory Read Reg(0x3FFF) Write Reg(0x0003)=0x40 Set Guardband Write Write Reg(0x0003)=0x04 Refresh memory with OTP content Write Reg(0x0015) Reg(0x0018) Reg(0x0019) Reg(0x001A) Set magnet to the zero position Write Angle into ZPOSL Reg(0x0017(5:0))=Reg(0x3FFF(5:0)) and ZPOSM Reg(0x0016(7:0))=Reg(0x3FFF(13:6)) Read Reg(0x0015) to Reg(0x001A) Write ECC_EN Read Reg(0x0015) Reg(0x0016) Reg(0x0017) Reg(0x0018) Reg(0x0019) Reg(0x001A) Reg(0x001B) Read Reg(0x0015) Reg(0x0016) Reg(0x0017) Reg(0x0018) Reg(0x0019) Reg(0x001A) Write Reg(0x001B)=0x80 Verify 3 Read ECC Value Write ECC (do not overwrite ECC-en) Read Registers step 1 (DISABLE,SETTINGS1, SETTINGS2, SETTINGS3, ZPOSM, ZPOSL and ECC) Comparison of written content (DISABLE,SETTINGS1, SETTINGS2, SETTINGS3, ZPOSM, ZPOSL and ECC) with Read Register step 1 read content Read Register step 2 Read Reg(0x3FD0) PASS Write Reg(0x001B) Power-on Reset Read Reg(0x0015) Reg(0x0016) Reg(0x0017) Reg(0x0018) Reg(0x0019) Reg(0x001A) Reg(0x001B) Read Reg(0x0015) Reg(0x0016) Reg(0x0017) Reg(0x0018) Reg(0x0016) Verify 1 FAIL Verify 4 FAIL Read Register step 3 FAIL PASS PASS END Unlock OTP area for burning (PROGEN=1) Write Reg(0x0003)=0x01 Start OTP burning procedure (PROGOTP=1) Write Reg(0x0003)=0x08 Correct programming and verification. Comparison of written content (DISABLE,SETTINGS1, SETTINGS2, SETTINGS3, ZPOSM, ZPOSL and ECC) with content of Read Register step 2. Mandatory Guardband-Test Comparison of written content (DISABLE,SETTINGS1, SETTINGS2, SETTINGS3, ZPOSM, ZPOSL and ECC) with content of Read Register step 3 END Wrong programming. Reprogramming not allowed! Note(s): 1. Device with wrong programming must not be used. Scrapping mandatory. ams Datasheet [v1-01] 2020-Dec-16 Page 43 Document Feedback AS5047U − Application Information Circuit Diagram Figure 61: Minimum Circuit Diagram for the AS5047U VDD during programming 4.5 – 5.5V VDD I CLK GND MISO MOSI Programmer TEST A AS5047U CSn B VDD3V VDD U V 100nF 1μF W GND Note(s): 1. In terms of EMC and for remote application, additional protection circuit is necessary. Page 44 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Package Drawings & Markings Package Drawings & Markings Figure 62: Package Outline Drawing AS5047U RoHS Green Symbol Min Nom Max Symbol Min Nom Max A - - 1.20 R 0.09 - - A1 0.05 - 0.15 R1 0.09 - - A2 0.80 1.00 1.05 S 0.20 - - b 0.19 - 0.30 Θ1 0º - 8º c 0.09 - 0.20 Θ2 - 12 REF - D 4.90 5.00 5.10 Θ3 - 12 REF - E - 6.40 BSC - aaa - 0.10 - E1 4.30 4.40 4.50 bbb - 0.10 - e - 0.65 BSC - ccc - 0.05 - L 0.45 0.60 0.75 ddd - 0.20 - L1 - 1.00 REF - N 14 Note(s): 1. Dimensioning and tolerancing conform to ASME Y14.5M - 1994. 2. All dimensions are in millimeters. Angles are in degrees. 3. N is the total number of terminals. ams Datasheet [v1-01] 2020-Dec-16 Page 45 Document Feedback AS5047U − Package Drawings & Markings Figure 63: AS5047U Package Marking AS5047U YYWWMZZ @ Figure 64: Packaging Code YY Last two digits of the manufacturing year Page 46 Document Feedback WW Manufacturing week M Plant identifier ZZ Free choice / traceability code @ Sublot identifier ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Mechanical Data Mechanical Data Figure 65: TSSOP14 Die Placement and Hall Array Position Hall radius 0.306±0.100 3.200±0.235 2.130±0.235 0.236±0.100 0.694±0.150 Note(s): 1. Dimensions are in mm. 2. The Hall array center is located in the center of the IC package. Hall array radius is 1.1mm. 3. Die thickness is 203μm nominal. ams Datasheet [v1-01] 2020-Dec-16 Page 47 Document Feedback AS5047U − Ordering & Contact Information Ordering & Contact Information Figure 66: Ordering Information Ordering Code Package Marking Delivery Form Delivery Quantity AS5047U-HTSM TSSOP14 AS5047U 7” Tape & Reel in dry pack 500 pcs/reel AS5047U-HTST TSSOP14 AS5047U 13” Tape & Reel in dry pack 4500 pcs/reel Buy our products or get free samples online at: www.ams.com/Products Technical Support is available at: www.ams.com/Technical-Support Provide feedback about this document at: www.ams.com/Document-Feedback For further information and requests, e-mail us at: ams_sales@ams.com For sales offices, distributors and representatives, please visit: www.ams.com/Contact Headquarters ams AG Tobelbader Strasse 30 8141 Premstaetten Austria, Europe Tel: +43 (0) 3136 500 0 Website: www.ams.com Page 48 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − RoHS Compliant & ams Green Statement RoHS Compliant & ams Green Statement RoHS: The term RoHS compliant means that ams AG products fully comply with current RoHS directives. Our semiconductor products do not contain any chemicals for all 6 substance categories plus additional 4 substance categories (per amendment EU 2015/863), including the requirement that lead not exceed 0.1% by weight in homogeneous materials. Where designed to be soldered at high temperatures, RoHS compliant products are suitable for use in specified lead-free processes. ams Green (RoHS compliant and no Sb/Br/Cl): ams Green defines that in addition to RoHS compliance, our products are free of Bromine (Br) and Antimony (Sb) based flame retardants (Br or Sb do not exceed 0.1% by weight in homogeneous material) and do not contain Chlorine (Cl not exceed 0.1% by weight in homogeneous material). Important Information: The information provided in this statement represents ams AG knowledge and belief as of the date that it is provided. ams AG bases its knowledge and belief on information provided by third parties, and makes no representation or warranty as to the accuracy of such information. Efforts are underway to better integrate information from third parties. ams AG has taken and continues to take reasonable steps to provide representative and accurate information but may not have conducted destructive testing or chemical analysis on incoming materials and chemicals. ams AG and ams AG suppliers consider certain information to be proprietary, and thus CAS numbers and other limited information may not be available for release. ams Datasheet [v1-01] 2020-Dec-16 Page 49 Document Feedback AS5047U − Copyrights & Disclaimer Copyrights & Disclaimer Copyright ams AG, Tobelbader Strasse 30, 8141 Premstaetten, Austria-Europe. Trademarks Registered. All rights reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the copyright owner. Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its General Terms of Trade. ams AG makes no warranty, express, statutory, implied, or by description regarding the information set forth herein. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing by ams AG for each application. This product is provided by ams AG “AS IS” and any express or implied warranties, including, but not limited to the implied warranties of merchantability and fitness for a particular purpose are disclaimed. ams AG shall not be liable to recipient or any third party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other services. The Hardware was developed in the domain of SEooC (Safety Element out of Context) using ams best system know how. The final system or target application is not known to ams AG. This implies, that ams AG does not guarantee for a system functional safety concept. The final responsibility for achieving a certain ASIL (Automotive Safety Integrity Level) in the target application is the responsibility of the system integrator. Page 50 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Document Status Document Status Document Status Product Preview Preliminary Datasheet Datasheet Datasheet (discontinued) ams Datasheet [v1-01] 2020-Dec-16 Product Status Definition Pre-Development Information in this datasheet is based on product ideas in the planning phase of development. All specifications are design goals without any warranty and are subject to change without notice Pre-Production Information in this datasheet is based on products in the design, validation or qualification phase of development. The performance and parameters shown in this document are preliminary without any warranty and are subject to change without notice Production Information in this datasheet is based on products in ramp-up to full production or full production which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade Discontinued Information in this datasheet is based on products which conform to specifications in accordance with the terms of ams AG standard warranty as given in the General Terms of Trade, but these products have been superseded and should not be used for new designs Page 51 Document Feedback AS5047U − Revision Information Revision Information Changes from 1-00 (2018-Oct-30) to current revision 1-01 (2020-Dec-16) Page Updated Figure 2 2 Updated Figure 7 and added notes under it 7 Updated Figure 19 17 Updated CRC Checksum and added Figure 31 23 Updated Figure 46 29 Updated Hysteresis and added Figure 55 and 56 36 Updated Figure 57 39 Updated Figure 58 40 Updated notes under Figure 65 47 Note(s): 1. Page and figure numbers for the previous version may differ from page and figure numbers in the current revision. 2. Correction of typographical errors is not explicitly mentioned. Page 52 Document Feedback ams Datasheet [v1-01] 2020-Dec-16 AS5047U − Content Guide Content Guide ams Datasheet [v1-01] 2020-Dec-16 1 1 2 2 General Description Key Benefits & Features Applications Block Diagram 3 5 Pin Assignment Absolute Maximum Ratings 6 7 7 Electrical Characteristics Magnetic Characteristics System Specifications 9 Timing Characteristics 10 11 12 12 15 15 16 16 18 22 23 24 27 31 33 35 36 36 37 38 Detailed Description Power Management Dynamic Angle Error Compensation Adaptive Filter System Speed Measurements Rotation Speed Measurement SPI Interface (Slave) SPI Timing SPI Transaction PAD Word CRC Checksum Volatile Registers Non-Volatile Registers (OTP) ABI Incremental Interface UVW Commutation Interface PWM Hysteresis Incremental Output Hysteresis Automatic Gain Control (AGC) and CORDIC Magnitude ECC 39 39 41 44 Application Information Burn and Verification of the OTP Memory Step-by-Step Procedure to Permanently Program the Non-Volatile Memory (OTP): Circuit Diagram 45 47 48 49 50 51 52 Package Drawings & Markings Mechanical Data Ordering & Contact Information RoHS Compliant & ams Green Statement Copyrights & Disclaimer Document Status Revision Information Page 53 Document Feedback
