IE123103-1
IE123103-1
    DBUNLIMITED
    插件,D=12mm
    机电元件 蜂鸣器 指示灯,内部驱动 3 V 30mA 3.1kHz 通孔 PC 引脚
IE123103-1 数据手册
Specifications Description Technology Resonant Frequency Value Unit Electro-Mechanical 3,100 (Hz) Rated Voltage 3 (V) SPL @ 10cm 83 (dBA) Tone Mount Type Voltage Range Max Rated Current Housing Material Revision History Version Description Date Approved 1 Released from Engineering 10/21/2013 J.S 1) All dimensions are in mm unless otherwise noted 2) All parts meet RoHS Single Thru Hole 2~5 30 (V) (mA) NORYL Operating Temperature -30 ~ +70 °C Storage Temperature -40 ~ +85 °C 2 (g) Weight Notes Drawn by Date Checked by Date Approved by Date A.B. 10/21/2013 C.E. 10/21/2013 J.S 10/21/2013 Electro-Mechanical Indicator IE123103-1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. sales@dbunlimitedco.com | www.dbunlimitedco.com ©2013, DB Unlimited Sheet 1 of 1
IE123103-1 价格&库存
很抱歉,暂时无法提供与“IE123103-1”相匹配的价格&库存,您可以联系我们找货
IE123103-1
    • 1+9.03960
    • 200+3.49920
    • 500+3.38040
    • 1000+3.31560
