Modular timers
1 - 6 - 8 - 16 A
Building
automation
Elevators
and liſts
Automation for
blinds, grilles
and shutters
Hoists and
cranes
Panels for
electrical
distribution
Door and
gate openers
80
SЕRIES
Prices, features, specifications, capabilities, appearance and availability of our products and services are subject to change without notice.
FINDER assumes no responsibility for the presence of possible errors or insufficient information in this document.
In case of discrepancies between the printed and online versions, the latter prevails.
80
80 SERIES
Modular timers 16 A
SERIES
80.01
Multi-function and mono-function timer range
80.11
80.01 - Multi-function & multi-voltage
80.11 - On-delay, multi-voltage
• 17.5 mm wide
• Six time scales from 0.1 s to 24 h
• High input/output isolation
• 35 mm rail (EN 60715) mount
• “Blade + cross” - both flat blade and cross head
screw drivers can be used to adjust the range
and function selectors, the timing trimmer, and
to disengage the rail mounting clip
• New multi-voltage versions with “PWM clever”
technology
80.01 / 80.11
Screw terminal
• Multi-voltage
• Multi-function
• Multi-voltage
• Mono-function
AI: On-delay
DI: Interval
SW: Symmetrical flasher (starting pulse on)
BE: Off-delay with control signal
CE: On- and off-delay with control signal
DE: Interval with control signal on
AI: On-delay
For UL ratings see:
“General technical information” page V
Wiring diagram
(without control signal)
For outline drawing see page 9
Wiring diagram
(with control signal)
Wiring diagram
Contact specification
Contact configuration
Rated current/Maximum peak current
Rated voltage/
Maximum switching voltage
A
V AC
Rated load AC1
VA
1 CO (SPDT)
1 CO (SPDT)
16/30
16/30
250/400
250/400
4000
4000
Rated load AC15 (230 V AC)
VA
750
750
Single phase motor rating (230 V AC)
kW
0.55
0.55
A
16/0.3/0.12
16/0.3/0.12
mW (V/mA)
500 (10/5)
500 (10/5)
AgNi
AgNi
12…240
24…240
Breaking capacity DC1: 24/110/220 V
Minimum switching load
Standard contact material
I
Supply specification
Nominal voltage (UN)
Rated power AC/DC
Operating range
V AC (50/60 Hz)
V DC
12…240
24…240
VA (50 Hz)/W
很抱歉,暂时无法提供与“80.01.0.240.0000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+810.088311+105.18594
- 10+721.4213710+93.67298
- 25+688.8285225+89.44096
- 50+665.1379050+86.36485
- 100+642.25013100+83.39299
