WIMA DC-LINK MKP 4
Metallized Polypropylene (PP) - Capacitors for DC-Link Applications.
Capacitances from 1.0 F to 400 F.
Rated Voltages from 400 VDC to 1500 VDC.
Special Features
Electrical Data
O Capacitances up to 400 F
O High volume/capacitance ratio
O Excellent self-healing properties
O Very low dissipation factor
O High reliability
O 2-pin, 4-pin or plate contact
configuration
O AEC-Q200 qualified
O According to RoHS 2015/863/EU
Typical Applications
As intermediate circuit capacitor
e.g. in high power converter technology, power supplies, solar inverters, e-mobility (battery chargers,
motor drives & power train) etc.
Construction
Dielectric:
Polypropylene (PP) film
Capacitor electrodes:
Vacuum-deposited
Internal construction:
Capacitance range: 1 F to 400 F
(intermediate values on request)
Rated voltages: 400 VDC, 500 VDC, 600 VDC,
800 VDC, 900 VDC, 1100 VDC, 1300 VDC, 1500 VDC
Capacitance tolerances: ±20%, ±10%, ±5%
Operating temperature range:
–55° C to +105° C (hot spot including
self-heating)
Climatic test category: 55/085/56
in accordance with IEC
Insulation resistance at +20° C:
30 000 sec (MΩ x F)
Measuring voltage: 100 V/1 min.
Dielectric absorption: 0.05 %
Voltage and current derating:
A derating factor of 1.35% per K must be
applied from +85° C for DC voltages and
from +70° C for AC currents (Irms). Additionally a derating factor of 4.5% per K must be
applied from +85° C for AC currents (Irms)
Reliability: Operational life 100 000 hours
(Ur and 70° C)
Failure rate 0 (0.5 x Ur and 40° C)
Plastic film
Vacuum-deposited
electrode
Metal contact layer
(schoopage)
= CN [F] x Ur [V]
10 000
10 000 < 25 000
25 000 < 50 000
50 000 < 100 000
> 100 000
PCM
Packing
2
5
10
fit
fit
fit
fit
fit
Dissipation factors at +20° C: tan x 10-4
Termination
Encapsulation:
Solvent-resistant, flame-retardant plastic
case with epoxy resin seal, UL 94 V-0
Terminations:
Tinned wire or plates.
Marking:
Colour: Red. Marking: Black.
Test voltage:
500 VDC: 1.5 Ur, 2sec
500 VDC: 1.2 Ur, 2sec
Specific dissipation:
Box size
Specific dissipation in Watts per K
W x H x L in mm above the ambient temperature
9 x 19 x 31.5
11 x 21 x 31.5
13 x 24 x 31.5
15 x 26 x 31.5
17 x 29 x 31.5
17 x 34.5 x 31.5
20 x 39.5 x 31.5
13 x 24 x 41.5
15 x 26 x 41.5
17 x 29 x 41.5
19 x 32 x 41.5
20 x 39.5 x 41.5
24 x 45.5 x 41.5
28 x 38 x 41.5
31 x 46 x 41.5
35 x 50 x 41.5
40 x 55 x 41.5
25 x 45 x 57
30 x 45 x 57
35 x 50 x 57
45 x 55 x 57
45 x 65 x 57
0.021
0.025
0.030
0.034
0.039
0.044
0.053
0.037
0.042
0.048
0.054
0.065
0.080
0.076
0.092
0.106
0.123
0.102
0.113
0.132
0.164
0.184
For further details and graphs please
refer to Technical Information.
400 VDC 500 VDC 600 VDC 800 VDC 900 VDC 1100 VDC 1300 VDC 1500 VDC
1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz 1 kHz 10 kHz
27.5 15 160 15 130 12 120 10 90 10 80 10 60 7 50 7 40
37.5 60 350 30 240 21 150 18 170 16 150 14 100 12 90 12 90
52.5 80 550 80 460 40 300 35 250 31 200 30 170 23 150 23 150
Maximum pulse rise time:
max. pulse rise time V/sec at TA < 40° C
PCM
27.5
11 15 27 29 35 43 50 59
37.5 8 10 19 21 22 29 35 41
52.5 5 7 13 15 18 21 25 29
04.23
Packing units at the end of the catalogue
129
WIMA DC-LINK MKP 4
Continuation
General Data
Capacitance
W
H
L
1 F
2 „
3 „
4 „
5 „
7 „
10 F
15 „
20 „
22 „
25 „
9
9
9
9
9
9
11
13
15
17
17
15
17
17
24
24
28
31
31
35
35
25
40
25
40
30
40
30
35
45
45
45
45
45
45
45
19
19
19
19
19
19
21
24
26
29
29
26
34.5
29
39.5
32
39.5
39.5
45.5
45.5
45.5
38
46
46
50
50
45
55
45
55
45
55
45
50
55
55
55
65
65
65
65
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
41.5
31.5
41.5
31.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
57
41.5
57
41.5
57
41.5
57
57
57
57
57
57
57
57
57
30 „
40 „
50
60
70
80
90
100
120
140
150
F
160 „
180 „
200 „
220
250
270
300
330
350
370
400
400 VDC (70° C) / 300 VDC (85° C) / 220 VDC (105° C)
Part number
PCM** Pin
IS
Irms*(10 kHz)* ESR (10 kHz)*
A
A
mΩ
27.5
2
11
1
238.7
DCP4G041006A_ _ _ _ _ _
27.5
2
22
1.5
119.4
DCP4G042006A_ _ _ _ _ _
27.5
2
33
1.5
79.6
DCP4G043006A_ _ _ _ _ _
27.5
2
44
2
59.7
DCP4G044006A_ _ _ _ _ _
27.5
2
55
2
47.7
DCP4G045006A_ _ _ _ _ _
27.5
2
77
2.5
34.1
DCP4G047006A_ _ _ _ _ _
27.5
2/4
110
3.5
23.9
DCP4G051006B_ _ _ _ _ _
27.5
2/4
165
4.5
15.9
DCP4G051506D_ _ _ _ _ _
27.5
2/4
220
5.5
11.9
DCP4G052006F_ _ _ _ _ _
27.5
2/4
242
6
9.8
DCP4G052206G_ _ _ _ _ _
27.5
2/4
275
7
8.6
DCP4G052506G_ _ _ _ _ _
37.5
2/4
200
6.5
10
DCP4G052507D_ _ _ _ _ _
27.5
2/4
330
8
7.2
DCP4G053006I_ _ _ _ _ _
37.5
2/4
240
7.5
8.5
DCP4G053007E_ _ _ _ _ _
27.5
2/4
440
10
5.4
DCP4G054006J_ _ _ _ _ _
37.5
2/4
320
9.5
6
DCP4G054007F_ _ _ _ _ _
37.5
2/4
400
11
5.4
DCP4G055007G_ _ _ _ _ _
37.5
2/4
480
11.5
4.8
DCP4G056007G_ _ _ _ _ _
37.5
2/4
560
13
4.7
DCP4G057007H_ _ _ _ _ _
37.5
2/4
640
14
4.1
DCP4G058007H_ _ _ _ _ _
37.5
2/4
720
15
3.6
DCP4G059007H_ _ _ _ _ _
37.5
2/4
720
15
3.6
DCP4G059007L _ _ _ _ _ _
37.5
2/4
800
18
2.8
DCP4G061007I_ _ _ _ _ _
37.5
2/4
960
DCP4G061207I_ _ _ _ _ _
37.5
2/4
1120
22.5
2.1
DCP4G061407J_ _ _ _ _ _
37.5
2/4
1200
23
2
DCP4G061507J_ _ _ _ _ _
52.5
4
750
DCP4G061509D_ _ _ _ _ _
37.5
2/4
1280
24.5
2
DCP4G061607K_ _ _ _ _ _
52.5
4
800
21
2.3
DCP4G061609D_ _ _ _ _ _
37.5
2/4
1440
26
1.8
DCP4G061807K_ _ _ _ _ _
52.5
4
900
23.5
2
DCP4G061809E_ _ _ _ _ _
37.5
2/4
1600
27.5
1.6
DCP4G062007K_ _ _ _ _ _
52.5
4
1000
25
1.8
DCP4G062009E_ _ _ _ _ _
52.5
4
1100
27
1.8
DCP4G062209F_ _ _ _ _ _
52.5
4
1250
32
1.6
DCP4G062509H_ _ _ _ _ _
52.5
4
1350
33.5
1.5
DCP4G062709H_ _ _ _ _ _
52.5
4
1500
35
1.3
DCP4G063009H_ _ _ _ _ _
52.5
4
1650
37
1.2
DCP4G063309J_ _ _ _ _ _
52.5
4
1750
40
1.1
DCP4G063509J_ _ _ _ _ _
52.5
4
1850
41.5
1.1
DCP4G063709J_ _ _ _ _ _
52.5
4
2000
43
1
DCP4G064009J_ _ _ _ _ _
* General guide
* Permissible Irms at 10° C internal temperature rise (general guide)
** PCM = Printed circuit module = pin spacing
Dims. in mm.
Part number completion:
Version code: 2-pin =
4-pin =
Tolerance:
20 % =
10 % =
5 % =
Packing:
bulk =
Pin length:
6-2 =
D2
D4
M
K
J
S
SD
Taped version see page 157.
Rights reserved to amend design data without prior notification.
04.23
Continuation page 131
130
WIMA DC-LINK MKP 4
Continuation
General Data
Capacitance
W
H
L
1 F
2 „
3 „
4 „
5 „
7 „
8 „
10 F
12 „
15 „
9
9
9
9
9
11
13
13
15
17
15
17
17
17
28
24
28
31
31
31
35
35
25
40
30
40
35
35
45
45
45
45
45
45
19
19
19
19
19
21
24
24
26
29
26
29
34.5
29
39.5
39.5
32
39.5
39.5
39.5
45.5
38
45.5
38
46
46
46
50
50
45
55
45
55
50
50
55
55
55
55
65
65
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
41.5
31.5
31.5
41.5
31.5
31.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
57
41.5
57
41.5
57
57
57
57
57
57
57
57
18 „
20 „
22 „
25 „
30
35
40
50
55 „
60 „
70 „
80 „
90 „
100 F
120 „
130
140
150
160
180
200
210
220
240
500 VDC (70° C) / 400 VDC (85° C) / 290 VDC (105° C)
Part number
PCM** Pin
IS
A
A
mΩ
27.5
2
15
1
238.7
DCP4H141006A_ _ _ _ _ _
27.5
2
30
1.5
119.4
DCP4H142006A_ _ _ _ _ _
27.5
2
45
1.5
79.6
DCP4H143006A_ _ _ _ _ _
27.5
2
60
1.8
63.7
DCP4H144006A_ _ _ _ _ _
27.5
2
75
2.5
47.7
DCP4H145006A_ _ _ _ _ _
27.5
2/4
105
3
34.1
DCP4H147006B_ _ _ _ _ _
27.5
2/4
120
3
29.8
DCP4H148006D_ _ _ _ _ _
27.5
2/4
150
4
23.9
DCP4H151006D_ _ _ _ _ _
27.5
2/4
180
4
19.9
DCP4H151206F_ _ _ _ _ _
27.5
2/4
225
5
15.9
DCP4H151506G_ _ _ _ _ _
37.5
2/4
150
4.3
22.3
DCP4H151507D_ _ _ _ _ _
27.5
2/4
270
6
9.5
DCP4H151806G_ _ _ _ _ _
27.5
2/4
300
6
11.9
DCP4H152006I_ _ _ _ _ _
37.5
2/4
200
5.4
16.8
DCP4H152007E_ _ _ _ _ _
27.5
2/4
330
7
10.9
DCP4H152206J_ _ _ _ _ _
27.5
2/4
375
7.5
9.5
DCP4H152506J_ _ _ _ _ _
37.5
2/4
250
6.3
13.4
DCP4H152507F_ _ _ _ _ _
37.5
2/4
300
9
7.9
DCP4H153007G_ _ _ _ _ _
37.5
2/4
350
8.5
9.1
DCP4H153507G_ _ _ _ _ _
37.5
2/4
400
10
5.7
DCP4H154007G_ _ _ _ _ _
37.5
2/4
500
13
4.8
DCP4H155007H_ _ _ _ _ _
37.5
2/4
500
13
4.8
DCP4H155007L_ _ _ _ _ _
37.5
2/4
550
14
4
DCP4H155507H_ _ _ _ _ _
37.5
2/4
550
14
4
DCP4H155507L_ _ _ _ _ _
37.5
2/4
600
14
4.7
DCP4H156007I_ _ _ _ _ _
37.5
2/4
700
16.5
3.9
DCP4H157007I_ _ _ _ _ _
37.5
2/4
800
17.5
3.4
DCP4H158007I_ _ _ _ _ _
37.5
2/4
900
DCP4H159007J_ _ _ _ _ _
19
3
37.5
2/4
1000
DCP4H161007J_ _ _ _ _ _
52.5
4
700
14.3
5
DCP4H161009D_ _ _ _ _ _
37.5
2/4
1200
22.5
2.7
DCP4H161207K_ _ _ _ _ _
52.5
4
840
16.5
4.2
DCP4H161209E_ _ _ _ _ _
37.5
2/4
1300
23
2.4
DCP4H161307K_ _ _ _ _ _
52.5
4
980
21.5
2.8
DCP4H161409F_ _ _ _ _ _
2.7
DCP4H161509F_ _ _ _ _ _
52.5
4
1050
22.5
52.5
4
1120
25.5
2.5
DCP4H161609H_ _ _ _ _ _
52.5
4
1260
27
2.2
DCP4H161809H_ _ _ _ _ _
52.5
4
1400
28.5
2
DCP4H162009H_ _ _ _ _ _
52.5
4
1470
29.5
1.9
DCP4H162109H_ _ _ _ _ _
52.5
4
1540
32
1.8
DCP4H162209J_ _ _ _ _ _
52.5
4
1680
33.5
1.7
DCP4H162409J_ _ _ _ _ _
* General guide
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
Dims. in mm.
D2
D4
M
K
J
S
SD
04.23
Continuation page 132
131
WIMA DC-LINK MKP 4
Continuation
General Data
Capacitance
W
H
L
1 F
2 „
3 „
4 „
5 „
7 „
8 „
10 F
9
9
9
11
13
15
15
17
13
17
17
17
24
28
31
31
35
35
25
40
30
40
30
35
45
45
45
45
19
19
19
21
24
26
26
29
24
29
34.5
29
39.5
39.5
32
39.5
39.5
45.5
45.5
38
46
46
50
50
45
55
45
55
45
50
55
65
65
65
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
41.5
31.5
31.5
41.5
31.5
31.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
57
41.5
57
41.5
57
57
57
57
57
57
18 „
20 „
22
25
30
35
40
45
50
60
70 „
80 „
90 „
100 F
120 „
140 „
150 „
2-pin version
* General guide
(general guide)
PCM Ø d
27.5 0.8
37.5 1
W PCM b
Dims. in mm.
pin
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
D2
D4
M
K
J
S
SD
4-pin version
pin
132
c
pin
c
Ø d c
11 27.5 5 0.8 0.4
13 27.5 7.5 0.8 0.4
15 27.5 7.5 0.8 0.4
17 27.5 10 0.8 0.4
20 27.5 12.5 0.8 0.4
19 37.5 10 1 0.4
20 37.5 12.5 1 0.4
24 37.5 12.5 1 0.4
28 37.5 10 1 0.4
31 37.5 20 1 0.4
35 37.5 20 1 0.4
40 37.5 20 1 0.4
25 52.5 12.5 1.2 0.8
30 52.5 20 1.2 0.8
35 52.5 20 1.2 0.8
45 52.5 20 1.2 0.8
Continuation page 133
04.23
12 „
15 „
600 VDC (70° C) / 450 VDC (85° C) / 320 VDC (105° C)
Part number
PCM** Pin
IS
A
A
mΩ
27.5
2
27
1.5
106.9
DCP4I041006A_ _ _ _ _ _
27.5
2
54
2
56
DCP4I042006A_ _ _ _ _ _
27.5
2
81
2.5
35.6
DCP4I043006A_ _ _ _ _ _
27.5
2/4
108
3
26.7
DCP4I044006B_ _ _ _ _ _
27.5
2/4
135
3.5
22
DCP4I045006D_ _ _ _ _ _
27.5
2/4
189
4.5
16
DCP4I047006F_ _ _ _ _ _
27.5
2/4
216
5
13.4
DCP4I048006F_ _ _ _ _ _
27.5
2/4
270
6
11
DCP4I051006G_ _ _ _ _ _
37.5
2/4
190
5
17.6
DCP4I051007C_ _ _ _ _ _
27.5
2/4
324
6.5
8.9
DCP4I051206G_ _ _ _ _ _
27.5
2/4
405
8
7
DCP4I051506I_ _ _ _ _ _
37.5
2/4
285
6.5
11.8
DCP4I051507E_ _ _ _ _ _
27.5
2/2
486
9.5
5.9
DCP4I051806J_ _ _ _ _ _
27.5
2/4
540
10
5.3
DCP4I052006J_ _ _ _ _ _
37.5
2/4
380
10.5
4.9
DCP4I052007F_ _ _ _ _ _
37.5
2/4
418
11
5.4
DCP4I052207G_ _ _ _ _ _
37.5
2/4
475
11.5
5
DCP4I052507G_ _ _ _ _ _
37.5
2/4
570
14
4.1
DCP4I053007H_ _ _ _ _ _
37.5
2/4
665
14.5
3.8
DCP4I053507H_ _ _ _ _ _
37.5
2/4
665
14.5
3.8
DCP4I053507L_ _ _ _ _ _
37.5
2/4
760
16.5
3.3
DCP4I054007I_ _ _ _ _ _
37.5
2/4
855
17
3.2
DCP4I054507I_ _ _ _ _ _
37.5
2/4
950
19
2.9
DCP4I055007J_ _ _ _ _ _
37.5
2/4
1140
17.5
3.4
DCP4I056007J_ _ _ _ _ _
52.5
2/4
780
14.5
4.9
DCP4I056009D_ _ _ _ _ _
37.5
2/4
1330
DCP4I057007K_ _ _ _ _ _
52.5
4
910
16.5
4.2
DCP4I057009E_ _ _ _ _ _
37.5
2/4
1520
22
2.6
DCP4I058007K_ _ _ _ _ _
52.5
4
1040
17.8
3.6
DCP4I058009E_ _ _ _ _ _
52.5
4
1170
23.5
1.9
DCP4I059009F_ _ _ _ _ _
52.5
4
1300
25
2.6
DCP4I061009H_ _ _ _ _ _
52.5
4
1560
28
2.3
DCP4I061209J_ _ _ _ _ _
52.5
4
1820
31
1.9
DCP4I061409J_ _ _ _ _ _
52.5
4
1950
33
1.7
DCP4I061509J_ _ _ _ _ _
WIMA DC-LINK MKP 4
Continuation
General Data
Capacitance
W
H
L
1 F
2 „
3 „
4 „
5 „
7 „
8 „
10 F
9
9
11
13
13
17
17
17
17
24
28
31
31
35
35
25
40
30
35
45
45
45
45
45
45
19
19
21
24
24
29
29
34.5
29
39.5
39.5
32
39.5
39.5
39.5
45.5
45.5
38
46
46
50
50
45
55
45
50
55
55
55
65
65
65
31.5
31.5
31.5
31.5
31.5
31.5
31.5
31.5
41.5
31.5
31.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
57
41.5
57
57
57
57
57
57
57
57
12 „
15 „
18
25
30
35
40
45
50
60 „
65 „
70 „
75 „
80 „
90 „
100 F
115 „
800 VDC (70° C) / 700 VDC (85° C) / 510 VDC (105° C)
Part number
PCM** Pin
IS
A
A
mΩ
27.5
2
29
1.7
73.2
DCP4L041006A_ _ _ _ _ _
27.5
2
58
2.5
36.6
DCP4L042006A_ _ _ _ _ _
27.5
2/4
87
3
24.4
DCP4L043006B_ _ _ _ _ _
27.5
2/4
116
4
18.3
DCP4L044006D_ _ _ _ _ _
27.5
2/4
145
4.5
14.6
DCP4L045006D_ _ _ _ _ _
27.5
2/4
203
6
10.5
DCP4L047006G_ _ _ _ _ _
27.5
2/4
232
6.5
9.2
DCP4L048006G_ _ _ _ _ _
27.5
2/4
290
8
7.3
DCP4L051006I_ _ _ _ _ _
37.5
2/4
210
7.5
8.5
DCP4L051007E_ _ _ _ _ _
27.5
2/4
348
9.5
6.1
DCP4L051206J_ _ _ _ _ _
27.5
2/4
435
10.5
4.9
DCP4L051506J_ _ _ _ _ _
37.5
2/4
315
8.5
7.5
DCP4L051507F_ _ _ _ _ _
37.5
2/4
378
9.5
7.2
DCP4L051807G_ _ _ _ _ _
37.5
2/4
420
10
6.2
DCP4L052007G_ _ _ _ _ _
37.5
2/4
462
10.5
5.9
DCP4L052207G_ _ _ _ _ _
37.5
2/4
525
12.5
5
DCP4L052507H_ _ _ _ _ _
37.5
2/4
630
14
4.1
DCP4L053007H_ _ _ _ _ _
37.5
2/4
630
14
4.1
DCP4L053007L_ _ _ _ _ _
37.5
2/4
735
15.5
3.8
DCP4L053507I_ _ _ _ _ _
37.5
2/4
840
16.5
3.3
DCP4L054007I_ _ _ _ _ _
37.5
2/4
945
17.5
3.4
DCP4L054507J_ _ _ _ _ _
37.5
2/4
1050
19
3
DCP4L055007J_ _ _ _ _ _
52.5
4
750
18.5
3
DCP4L055009D_ _ _ _ _ _
37.5
2/4
1260
21.5
2.7
DCP4L056007K_ _ _ _ _ _
52.5
4
900
20.5
2.7
DCP4L056009E_ _ _ _ _ _
52.5
4
975
22.5
2.2
DCP4L056509F_ _ _ _ _ _
52.5
4
1050
23.5
3
DCP4L057009H_ _ _ _ _ _
52.5
4
1125
24
2.9
DCP4L057509H_ _ _ _ _ _
52.5
4
1200
24.5
3
DCP4L058009H_ _ _ _ _ _
52.5
4
1350
25.5
2.5
DCP4L059009J_ _ _ _ _ _
52.5
4
1500
26.5
2.3
DCP4L061009J_ _ _ _ _ _
52.5
4
1725
28
2.1
DCP4L061159J_ _ _ _ _ _
2-pin version
* General guide
(general guide)
PCM Ø d
27.5 0.8
37.5 1
W PCM b Ø d c
Dims. in mm.
pin
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
4-pin version
= D2
= D4
=M
=K
=J
=S
= SD
04.23
pin
Rights reserved to amend design data without prior notification..
Continuation page 134
c
pin
c
11 27.5 5 0.8 0.4
13 27.5 7.5 0.8 0.4
15 27.5 7.5 0.8 0.4
17 27.5 10 0.8 0.4
19 37.5 10 1 0.4
20 37.5 12.5 1 0.4
24 37.5 12.5 1 0.4
28 37.5 10 1 0.4
31 37.5 20 1 0.4
35 37.5 20 1 0.4
40 37.5 20 1 0.4
30 52.5 20 1.2 0.8
35 52.5 20 1.2 0.8
45 52.5 20 1.2 0.8
133
WIMA DC-LINK MKP 4
Continuation
General Data
L
900 VDC (70° C) / 760 VDC (85° C) / 550 VDC (105° C)
PCM** Pin
IS
A
A
mΩ
Part number
Capacitance
W
H
1 F
2 „
9
11
19
21
31.5 27.5
31.5 27.5
2
2/4
35
70
2
2.5
66.1
44
DCP4N041006A_ _ _ _ _ _
DCP4N042006B_ _ _ _ _ _
3 „
13
24
31.5 27.5
2/4
105
4
22
DCP4N043006D_ _ _ _ _ _
4 „
13
24
31.5 27.5
2/4
140
4.5
16.5
DCP4N044006D_ _ _ _ _ _
5 „
17
29
31.5 27.5
2/4
175
4.5
18
DCP4N045006G_ _ _ _ _ _
7 „
8 „
17
17
29
34.5
31.5 27.5
31.5 27.5
2/4
2/4
245
280
6.5
7.5
9.4
8.3
DCP4N047006G_ _ _ _ _ _
DCP4N048006I_ _ _ _ _ _
10 F
39.5
32
31.5 27.5
41.5 37.5
2/4
2/4
350
220
10
9
5.3
6.7
DCP4N051006J_ _ _ _ _ _
DCP4N051007F_ _ _ _ _ _
15 „
41.5 37.5
2/4
330
10.5
5.8
DCP4N051507G_ _ _ _ _ _
20 „
24
45.5
41.5 37.5
2/4
440
13
4.8
DCP4N052007H_ _ _ _ _ _
28
38
41.5 37.5
2/4
440
13
4.8
DCP4N052007L_ _ _ _ _ _
22 „
25 „
30 „
35 „
40 „
24
45.5
41.5 37.5
2/4
484
14
4.1
DCP4N052207H_ _ _ _ _ _
28
38
41.5 37.5
2/4
484
14
4.1
DCP4N052207L_ _ _ _ _ _
31
46
41.5 37.5
2/4
550
15.5
3.8
DCP4N052507I_ _ _ _ _ _
2/4
660
16.5
3.4
DCP4N053007I_ _ _ _ _ _
4
540
15
4.5
DCP4N053009D_ _ _ _ _ _
2/4
770
18
3.2
DCP4N053507J_ _ _ _ _ _
4
630
16
4
DCP4N053509D_ _ _ _ _ _
31
46
41.5 37.5
25
45
57
35
50
41.5 37.5
25
45
57
52.5
52.5
40
55
41.5 37.5
30
45
57
52.5
2/4
880
19.5
3.2
DCP4N054007K_ _ _ _ _ _
4
720
18
3.5
DCP4N054009E_ _ _ _ _ _
50 „
35
50
57
52.5
4
900
22
3.3
DCP4N055009F_ _ _ _ _ _
60 „
45
55
57
52.5
4
1080
23
3
DCP4N056009H_ _ _ _ _ _
70 „
80 „
45
45
65
65
57
57
52.5
52.5
4
4
1260
1440
24.5
25.5
3.3
2.8
DCP4N057009J_ _ _ _ _ _
DCP4N058009J_ _ _ _ _ _
* General guide
Dims. in mm.
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
= D2
= D4
=M
=K
=J
=S
= SD
04.23
Continuation page 135
134
WIMA DC-LINK MKP 4
Continuation
General Data
Capacitance
W
H
L
1
2
3
4
5
7
9
13
15
17
17
24
28
31
35
25
35
25
40
30
35
35
35
45
45
45
19
24
26
29
34.5
39.5
32
39.5
39.5
45.5
45.5
38
46
50
45
50
45
55
45
50
50
50
55
65
65
31.5
31.5
31.5
31.5
31.5
31.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
57
41.5
57
41.5
57
57
57
57
57
57
57
Capacitance
W
H
L
F
11
15
17
17
24
28
31
25
35
25
40
30
40
35
35
45
45
45
21
26
29
34.5
39.5
32
39.5
45.5
45.5
38
46
45
50
45
55
45
55
50
50
55
65
65
31.5
31.5
31.5
31.5
31.5
41.5
41.5
41.5
41.5
41.5
41.5
57
41.5
57
41.5
57
41.5
57
57
57
57
57
F
8 „
10 F
12 „
15 „
18 „
20 „
22 „
25 „
30
35
40
45
50
60
1
2
3
4
5
7 „
8 „
10 F
15 „
18 „
20 „
22 „
25
30
35
40
1100 VDC (70° C) / 920 VDC (85° C) / 670 VDC (105°
PCM** Pin
IS
A
A
mΩ
27.5
2
43
2
86
27.5
2/4
86
4
19
27.5
2/4
129
5
13.6
27.5
2/4
172
6
10.8
27.5
2/4
215
7.5
7.8
27.5
2/4
301
9
6.5
37.5
2/4
203
7.5
10
37.5
2/4
232
8
10
37.5
2/4
290
9.5
7.2
37.5
2/4
348
11
6.6
37.5
2/4
435
12
5.6
37.5
2/4
435
12
5.6
37.5
2/4
522
13.5
5
37.5
2/4
580
15
4.7
52.5
4
420
14.5
4.9
37.5
2/4
638
15.5
4.4
52.5
4
462
15
4.5
37.5
2/4
725
16.5
4.6
52.5
4
525
16
4.4
52.5
4
630
17.5
4.4
52.5
4
735
18
4
52.5
4
840
18
4.3
52.5
4
945
52.5
4
1050
21
4.1
52.5
4
1260
23
3.5
C)
1300 VDC (70° C) / 1100 VDC (85° C) / 800 VDC (105°
IS
PCM** Pin
A
A
MΩ
27.5
2/4
50
2.5
40
27.5
2/4
100
4.5
16.8
27.5
2/4
150
6
10.8
27.5
2/4
200
6.5
10.4
27.5
2/4
250
7.5
9.4
37.5
2/4
175
7
11
37.5
2/4
245
8
10
37.5
2/4
280
9
9.9
37.5
2/4
350
10.5
7.2
37.5
2/4
350
10.5
7.2
4.8
37.5
2/4
525
14
52.5
4
375
13
6
37.5
2/4
630
15.5
4.4
52.5
4
450
14.5
4.9
37.5
2/4
700
17.5
4
52.5
4
500
16
4.4
37.5
2/4
770
18
3.8
52.5
4
550
17.5
4.3
52.5
4
625
19
3.6
52.5
4
750
52.5
4
875
21
4.1
52.5
4
1000
22
3.7
C)
Part number
DCP4P041006A_ _ _ _ _ _
DCP4P042006D_ _ _ _ _ _
DCP4P043006F_ _ _ _ _ _
DCP4P044006G_ _ _ _ _ _
DCP4P045006I_ _ _ _ _ _
DCP4P047006J_ _ _ _ _ _
DCP4P047007F_ _ _ _ _ _
DCP4P048007G_ _ _ _ _ _
DCP4P051007G_ _ _ _ _ _
DCP4P051207H_ _ _ _ _ _
DCP4P051507H_ _ _ _ _ _
DCP4P051507L_ _ _ _ _ _
DCP4P051807I_ _ _ _ _ _
DCP4P052007J_ _ _ _ _ _
DCP4P052009D_ _ _ _ _ _
DCP4P052207J_ _ _ _ _ _
DCP4P052209D_ _ _ _ _ _
DCP4P052507K_ _ _ _ _ _
DCP4P052509E_ _ _ _ _ _
DCP4P053009F_ _ _ _ _ _
DCP4P053509F_ _ _ _ _ _
DCP4P054009F_ _ _ _ _ _
DCP4P054509H_ _ _ _ _ _
DCP4P055009J_ _ _ _ _ _
DCP4P056009J_ _ _ _ _ _
Part number
DCP4R241006B_ _ _ _ _ _
DCP4R242006F_ _ _ _ _ _
DCP4R243006G_ _ _ _ _ _
DCP4R244006I_ _ _ _ _ _
DCP4R245006J_ _ _ _ _ _
DCP4R245007F_ _ _ _ _ _
DCP4R247007G_ _ _ _ _ _
DCP4R248007H_ _ _ _ _ _
DCP4R251007H_ _ _ _ _ _
DCP4R251007L_ _ _ _ _ _
DCP4R251507I_ _ _ _ _ _
DCP4R251509D_ _ _ _ _ _
DCP4R251807J_ _ _ _ _ _
DCP4R251809D_ _ _ _ _ _
DCP4R252007K_ _ _ _ _ _
DCP4R252009E_ _ _ _ _ _
DCP4R252207K_ _ _ _ _ _
DCP4R252209F_ _ _ _ _ _
DCP4R252509F_ _ _ _ _ _
DCP4R253009H_ _ _ _ _ _
DCP4R253509J_ _ _ _ _ _
DCP4R254009J_ _ _ _ _ _
* General guide
04.23
Dims. in mm.
Continuation page 136
135
WIMA DC-LINK MKP 4
Continuation
General Data
Capacitance
W
H
L
1
2
3
4
5
7
13
17
19
28
31
31
35
25
40
30
35
35
45
45
45
24
29
32
39.5
39.5
45.5
38
46
46
50
45
55
45
50
50
55
55
65
31.5
31.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
41.5
57
41.5
57
57
57
57
57
57
F
8 „
10 F
12 „
15 „
18
25
30
1500 VDC (70° C) / 1200 VDC (85° C) / 870 VDC (105°
PCM** Pin
IS
A
A
mΩ
27.5
2/4
59
3
33.3
27.5
2/4
118
5
15.6
37.5
2/4
123
6
15
37.5
2/4
164
7
13.3
37.5
2/4
205
8
10.2
37.5
2/4
287
9.5
8.9
37.5
2/4
287
9.5
8.4
37.5
2/4
328
11
7.6
37.5
2/4
410
12.5
5.9
37.5
2/4
492
14.5
5
52.5
4
348
14
5.2
37.5
2/4
615
17
4.3
52.5
4
435
16
4.4
52.5
4
522
17.5
4.3
52.5
4
580
18
4.1
52.5
4
638
52.5
4
725
20.5
3.9
52.5
4
870
21.5
4
C)
Part number
DCP4S041006D_ _ _ _ _ _
DCP4S042006G_ _ _ _ _ _
DCP4S043007F_ _ _ _ _ _
DCP4S044007G_ _ _ _ _ _
DCP4S045007G_ _ _ _ _ _
DCP4S047007H_ _ _ _ _ _
DCP4S047007L_ _ _ _ _ _
DCP4S048007I_ _ _ _ _ _
DCP4S051007I_ _ _ _ _ _
DCP4S051207J_ _ _ _ _ _
DCP4S051209D_ _ _ _ _ _
DCP4S051507K_ _ _ _ _ _
DCP4S051509E_ _ _ _ _ _
DCP4S051809F_ _ _ _ _ _
DCP4S052009F_ _ _ _ _ _
DCP4S052209H_ _ _ _ _ _
DCP4S052509H_ _ _ _ _ _
DCP4S053009J_ _ _ _ _ _
2-pin version
* General guide
(general guide)
PCM Ø d
27.5 0.8
37.5 1
Dims. in mm.
pin
Version code: 2-pin
4-pin
Tolerance:
20 %
10 %
5 %
Packing:
bulk
Pin length:
6-2
D2
D4
M
K
J
S
SD
4-pin version
W PCM b
pin
c
pin
c
Plate versions page 140
Ø d c
11 27.5 5 0.8 0.4
13 27.5 7.5 0.8 0.4
15 27.5 7.5 0.8 0.4
17 27.5 10 0.8 0.4
19 37.5 10 1 0.4
20 37.5 12.5 1 0.4
24 37.5 12.5 1 0.4
28 37.5 10 1 0.4
31 37.5 20 1 0.4
35 37.5 20 1 0.4
40 37.5 20 1 0.4
30 52.5 20 1.2 0.8
35 52.5 20 1.2 0.8
45 52.5 20 1.2 0.8
Example
04.23
Continuation page 137
136
WIMA DC-LINK MKP 4
Continuation
500 VDC
Impedance change with frequency
(general guide)
1
1
PCM 27.5
Z
PCM 37.5
Z
0.1
0.1
7
5
7
5
3
3
104
3
5
7
105
106
12
0.001
104
3
5
7
105
106
f/Hz
Irms
A
22 µF
7
5
3
f/Hz
24
Irms
A
µF
30 µF
-- 40 µF
-- 50 µF
-- 60
16
0.001
F
Permissible AC current in relation to
frequency at 20° C internal temperature
5µ
3
0.01
µF
µF
22
7
5
10
0.01
40
Irms
A
32
60 µF
180 µF
18
28
16
10
24
14
8
30 µF
12
10 µF
10
6
16
8
4
120 µF
6
PCM 27.5
2
4
2
2
5
103
2
5
104
2
5 f 105
Hz
102
600 VDC
(general guide)
2
103
5
2
5
104
5 f 105
Hz
2
PCM 52.5
8
PCM 37.5
4
1
2
103
5
2
5
104
1
PCM 37.5
PCM 52.5
Z
Z
0.1
7
5
7
5
3
3
0.01
0.01
µF
25 µF
-- 30 µF
-- 35 µF
-- 45
0.1
0.001
104
3
5
7
µF
80 0 µF F
µ
12 40
-- - 1
3
7
5
7
5
3
105
106
0.001
104
3
5
7
105
106
f/Hz
5 f 105
Hz
2
f/Hz
24
Irms
A
40
Irms
A
32
45 µF
120 µF
18
28
16
14
24
12
16
8
PCM 37.5
6
4
80 µF
12
PCM 52.5
8
4
2
5
103
2
5
104
2
5 f 105
Hz
2
5
103
2
5
104
2
5 f 105
Hz
04.23
102
Continuation page 138
137
WIMA DC-LINK MKP 4
Continuation
800 VDC
Impedance change with frequency (general guide)
1
1
1
PCM 27.5
PCM 37.5
PCM 52.5
Z
Z
Z
0.1
0.1
0.1
7
5
7
5
7
5
3
3
3
0.01
0.01
0.01
7
5
7
5
3
3
5 µF
3
5
7
105
106
0.001
104
3
5
7
3
105
106
f/Hz
µF
50 0 µF
-- 6 0 µF F
-- 9 0 µ
-- - 10
104
µF
20 µF
-- 25 µF
-- 30
0.001
7
5
0.001
104
3
5
7
105
106
f/Hz
f/Hz
Permissible AC current in relation to frequency at 20° C internal temperature rise (general guide)
16
24
Irms
A
PCM 27.5
12
40
Irms
A
32
Irms
A
30 µF
25 µF
18
16
10
8
28
14
24
12
5 µF
6
12
PCM 37.5
6
4
2
2
5
103
2
5
104
2
5 f 105
Hz
PCM 52.5
8
4
2
60 µF
16
8
4
100 µF
102
900 VDC
(general guide)
2
103
5
2
5
104
2
5 f 105
Hz
1
2
103
5
2
104
5
1
PCM 37.5
PCM 52.5
Z
Z
0.1
7
5
7
5
3
3
0.01
0.01
µF F
15 0 µ F
-- - 2 25 µ
0.1
0.001
104
3
5
7
µF
50
µF F
70 µ
---- 80
3
7
5
7
5
3
105
106
0.001
104
3
5
7
105
106
f/Hz
5 f 105
Hz
2
f/Hz
24
40
Irms
A
32
Irms
A
25 µF
18
16
20 µF
14
80 µF
28
24
12
16
8
PCM 37.5
6
4
50 µF
12
PCM 52.5
8
4
2
5
103
2
5
104
2
5 f 105
Hz
2
5
103
2
5
104
2
5 f 105
Hz
04.23
102
138
Continuation page 139
WIMA DC-LINK MKP 4
Continuation
1100 VDC
1
1
1
PCM 27.5
PCM 37.5
PCM 52.5
Z
Z
Z
0.1
0.1
7
5
7
5
7
5
3
3
2
0.1
µF
3
-µF
60
3
30
40
3
µF
7
5
3
0.01
20 µF
7
5
7
5
0.01
µF
5 F
-- 7 µ
0.01
µF
0.001
104
3
5
7
105
106
0.001
104
3
5
7
105
106
f/Hz
0.001
104
3
5
7
105
106
f/Hz
f/Hz
24
16
Irms
A
PCM 27.5
12
40
Irms
A
32
Irms
A
18
7 µF
20 µF
16
10
5 µF
8
6
14
24
12
40 µF
10
16
30 µF
8
2 µF
4
12
6
8
PCM 37.5
4
2
103
5
2
5
104
102
5 f 105
Hz
2
2
103
5
2
5
104
5 f 105
Hz
2
PCM 52.5
4
2
102
60 µF
28
2
103
5
2
5
104
5 f 105
Hz
2
1300 VDC
1
1
1
PCM 37.5
PCM 27.5
Z
PCM 52.5
Z
Z
0.1
0.1
0.1
7
5
7
5
7
5
3
3
3
10 µF
0.01
0.01
µF
µF
3
40
3
25
7
5
7
5
7
5
5 µF
0.01
µF
0.001
104
3
5
7
105
106
0.001
104
3
5
7
105
106
0.001
104
3
5
7
105
106
f/Hz
f/Hz
f/Hz
16
24
Irms
A
Irms
A
PCM 27.5
12
40
Irms
A
32
PCM 37.5
28
16
10
24
14
8
PCM 52.5
18
12
F
5µ
10
6
16
8
4
25 µF
20 µF
10 µF
12
6
8
4
2
4
2
5
103
2
5
104
2
5 f 105
Hz
102
2
5
103
2
5
104
2
5 f 105
Hz
2
5
103
2
5
104
2
5 f 105
Hz
04.23
102
Continuation page 140
139
WIMA DC-LINK MKP 4
Continuation
Plate versions
L
H
0.6
14
15
W
c
0.15
7.50.8
H
15
20.8
H
h
0.8
L
20.8
20.8
0.6
L
d
0.6
12
W
0.15
c
0.15
6.10.1
12
0.15
14
19.5
d
0.8
e
e
a
b
c
d
h
W
f
a
b
a
Ø
Version
L
41.5
41.5
A1
A1.5
a
b
c
h
0.5
0.5
0.5
0.8
17.5
17.5
28
28
7.5
7.5
W
Version
L
a
c
d
e
Ø
0.5
0.5
0.8
0.8
0.1
A1.6
41.5 18
A1.6.1 41.5 22
A1.6.2 41.5 23
6
10
10
Version
6.50.15
0.6
L
17
0.8
a
b
a
b
0.5
41.5
41.5
41.5
41.5
41.5
36 46.5
33.5 39.5
31.5 41.5
31.5 41.5
36 46.5
d
c
c
d
e
f
h
7.5
13
13
13
7.5
W
8.4
8.4
6.1
6.1
8.4
L
H
6.50.15
0.6
l
8.40.1
a
b
c
22
0.15
d
h
0.5 0.15 0.8
Version
L
A3.9 41.5
A3.11 41.5
70.1
5.50.15
a
c
0.6
12
22
0.15
0.15
a
b
c
h
0.5
0.5
0.5
0.8
40.5
40.5
46.5
46.5
14.5
14.5
Version
L
A3.8
A3.8.1
A3.8.2
41.5 W 17
41.5 W 17
41.5 W 17
12
0.15
a
c
l
0.5
0.5
0.8
18
22
22
6
10
10
23
17.5
23
04.23
A3
41.5 17.5 27.5 7.5 15
A3.5 41.5 17.5 27.5 7.5 15
A3.12 41.5 17.5 30 7.5 16.5
d
14.5 22
7.5 22
14 18.75
14 22
14.5 22
H
6.10.1
0.5
A2
A2.4.1
A2.6.1
A2.6.2
A2.8
c
h
H
17
7
7
8
b
0.5 0.5 0.5 0.15 0.8 0.1 0.8
L
W
L
h
0.8
21.5 16
18.5 13
18.5 13
a
Version L
140
Continuation page 141
WIMA DC-LINK MKP 4
Continuation
Plate versions
L
W
H
20.8
0.6
Dims. in mm
L
W
Version B
H
f
6 -1
b
120.15 d
0.5
a
L
PCM
31.5
41.5
28.5
38.5
b
Version
A4.9
A4.10
A4.2
A4
a
L
b
0.8
31.5 W 15
31.5 W 15
41.5 W 15
41.5 W 15
44
43
54
53
f
d
0.8 0.8
0.1
47
59
57
69
4.5
6.1
4.5
6.1
57
69
67
79
PCM
=PC Module
at the pin exit points
( 0.4)
b
0.15
Additional special versions can be
realized. Please contact us with your
specific needs.
8
8
9 x 19 x 31.5
D4
B8
1A
1H
1I
1J
1S
2A
2F
2J
2K
2M
3A
3G
3K
3L
3M
3N
3P
3Q
4A
4C
4L
4M
B8
A1
A1.5
A1.6
A1.6.1
A1.6.2
A2
A2.4.1
A2.6.1
A2.6.2
A2.8
A3
A3.5
A3.8
A3.8.1
A3.8.2
A3.9
A3.11
A3.12
A4
A4.2
A4.9
A4.10
Size
Code
4-pin
WxHxL
D2
Version code
2-pin
Possible connecting respective plate versions - depending on box size
6A
11 x 21 x 31.5
6B
13 x 24 x 31.5
6D
15 x 26 x 31.5
6F
17 x 29 x 31.5
6G
17 x 34.5 x 31.5
6I
20 x 39.5 x 31.5
6J
13 x 24 x 41.5
7C
15 x 26 x 41.5
7D
17 x 29 x 41.5
7E
19 x 32 x 41.5
7F
20 x 39.5 x 41.5
7G
24 x 45.5 x 41.5
7H
28 x 38 x 41.5
7L
7I
35 x 50 x 41.5
7J
40 x 55 x 41.5
7K
04.23
31 x 46 x 41.5
141
Recommendation for Processing
and Application of
Through-Hole Capacitors
Soldering Process
Internal temperature of the capacitor must
be kept as follows:
Polyester:
preheating: Tmax. T125° C
soldering: Tmax. T135° C
Polypropylene: preheating: Tmax. T100° C
soldering: Tmax. T110° C
Single wave soldering
Soldering bath temperature: T P 260 ° C
Dwell time:
t P 5 sec
Double wave soldering
Dwell time:
∑t P 5 sec
Due to different soldering processes and
heat requirements the graphs are to be
regarded as a recommendation only.
WIMA Quality and Environmental Philosophy
ISO 9001:2015 Certification
ISO 9001:2015 is an international basic
standard of quality assurance systems
for all branches of industry. The approval according to ISO 9001:2015 of
our factories certifies that organisation,
equipment and monitoring of quality
assurance in our factories correspond to
internationally recognized standards.
WIMA WPCS
The WIMA Process Control System (WPCS)
is a quality surveillance and optimization
system developed by WIMA. WPCS is a
major part of the quality-oriented WIMA
production. Points of application during
production process:
All WIMA capacitors, irrespective of
whether through-hole devices or SMD,
are made of environmentally friendly
materials. Neither during manufacture
nor in the product itself any toxic substances are used, e.g.
– Lead – PBB/PBDE
– PCB
– Arsenic
– CFC – Cadmium
– Hydrocarbon chloride – Mercury
– Chromium 6+
– etc.
We merely use pure, recyclable materials
for packing our components, such as:
carton
cardboard
adhesive tape made of paper
polystyrene
We almost completely refrain from using
packing materials such as:
! adhesive tapes made of plastic
! metal clips
RoHS Compliance
According to the RoHS Directive 2015/863/EU
as amended from time to time certain
hazardous substances like e.g. lead, cadmium,
mercury must not be used any longer in
electronic equipment as of July 1st, 2006.
For the sake of the environment WIMA has
re-fraind from using such substances since
years already.
WIMA Kondensatoren sind bleifrei
konform RoHS 2015/863/EU
WIMA capacitors are lead free
in accordance with RoHS 2015/863/EU
Tape for lead-free WIMA capacitors
DIN EN ISO 14001:2004
WIMA’s environmental management has
been established in accordance with the
guidelines of DIN EN ISO 14001:2004
to optimize the production processes
with regard to energy and resources.
04.23
! incoming material inspection
! metallization
! film inspection
! schoopage
! pre-healing
! pin attachment
! cast resin preparation/encapsu lation
! 100% final inspection
! Testing as per customer require ments
WIMA Environmental Policy
15
Typical Dimensions for
Taping Configuration
Vh
P
P2
Diagram 1:
PCM 2.5/5/7.5mm
W
W1
W0
H
H1
W2
P1
D0
d
P
t
F
P0
H1
P
P1
H
P1
d
d
F
P0
P2
Diagram 2: PCM 10/15 mm
Diagram 3: PCM 22.5 and 27.5*mm
*PCM 27.5 taping possible with two feed holes between components
Designation
Carrier tape width
Dimensions for Radial Taping
Symbol PCM 2.5 taping
W
P0
P2
F
PCM 5 taping
PCM 7.5 taping
PCM 10 taping*
PCM 15 taping*
PCM 22.5 taping
PCM 27.5 taping
18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5 18.0 ±0.5
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
for hot-sealing
Hold-down tape width
W0 6.0
6.0
12.0
12.0
12.0
12.0
12.0
adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape adhesive tape
Hole position
W1 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5 9.0 ±0.5
Hold-down tape position
W2
Feed hole diameter
D0 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2 4.0 ±0.2
*38.1 ±1.5 or 50.8 ±1.5
P
12.7 ±1.0 12.7 ±1.0 12.7 ±1.0 25.4 ±1.0 25.4 ±1.0 38.1 ±1.5
0.5 to 3.0 max.
0.5 to 3.0 max.
Pitch of component
cumulative pitch
Feed hole pitch
P0 12.7
±0.3 error max.
12.7 ±0.3
1.0 mm/20 pitch
0.5 to 3.0 max.
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 ±0.3
0.5 to 3.0 max.
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 ±0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 ±0.3
0.5 to 3.0 max.
cumulative pitch
error max.
1.0 mm/20 pitch
12.7 ±0.3
cumulative pitch
error max.
1.0 mm/20 pitch
0.5 to 3.0 max.
12.7 ±0.3
cumulative pitch
error max.
1.0 mm/20 pitch
Feed hole centre
to pin
P1 5.1 ±0.5 3.85 ±0.7 2.6 ±0.7 7.7 ±0.7 5.2 ±0.7 7.8 ±0.7 5.3 ±0.7
Hole centre to
component centre
P2 6.35 ±1.3 6.35 ±1.3 6.35 ±1.3 12.7 ±1.3 12.7 ±1.3 19.05 ±1.3 19.05 ±1.3
Feed hole centre to bottom
H▲
edge of the component
16.5 ±0.3 16.5 ±0.3 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5 16.5 ±0.5
18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5 18.5 ±0.5
Feed hole centre to top
H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1 H+Hcomponent < H1
H
edge of the component 1
32.25 max.
32.25 max.
24.5 to 31.5
25.0 to 31.5
26.0 to 37.0
30.0 to 43.0
35.0 to 45.0
Pin spacing at
+0.8
F 2.5 ±0.5 5.0
7.5 ±0.8 10.0 ±0.8 15 ±0.8 22.5 ±0.8 27.5 ±0.8
upper edge of carrier tape –0.2
Pin diameter
d
Component alignment
∆h
Total tape thickness
t
0.4 ±0.05 0.5 ±0.05
± 2.0 max.
± 2.0 max.
+0.06
± 3.0 max.
± 3.0 max.
04.23
+0.08
+0.08
± 3.0 max.
± 3.0 max.
± 3.0 max.
AMMO
52 ±2
max.
REEL Ø 360 max. B 58 ±2 or REEL ØØ 500
25 ±1
Ø 30 ±1 66 ±2
Unit
+0.08
0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2 0.6 ±0.2
ROLL/AMMO
Package
52 ±2 depending on
Ø 360 max.
(see also page 158)
B
REEL
Ø 30 ±1 58 ±2 comp. dimensions
+0.06
0.5 ±0.05 or 0.6–0.05 $0.5 ±0.05 or 0.6 –0.05 0.8
–0.05 0.8
–0.05 0.8
–0.05
When ordering please specify dimension H and required packaging type.
$ Diameter of pins see General Data.
54 ±2
B 60 ±2
68 ±2
depending
on PCM
and component dimensions
see details page 159.
Dims in mm.
Please clarify customer-specific deviations with the manufacturer.
* PCM 10 and PCM 15 can be crimped to PCM 7.5.
Position of components according to PCM 7.5 (sketch 1). P0 = 12.7 or 15.0 is possible
157
Types of Tape Packaging of
Capacitors for Automatic
Radial Insertion
O REEL Packaging
340 max.
30±1
25±1
360 max.
500 max.
O AMMO Packaging
340 max.
370 max.
O ROLL Packaging
34
0m
ax.
50 max.
50 max.
70 max.
ax
0 m ax.
34 0 m
49
B
BAR CODE (Labelling)
Labelling of package units in
plain text and with
alphanumerical Bar Code
BARCODE PDF417
BARCODE 2D Datamatrix
! WIMA supplier number
! Date code
! Customer‘s P/O number
! P/O line
! Customer‘s part number
! WIMA part number
! Quantity
! WIMA confirmation number
! Country of origin
! Customer name
! Handling unit number
! Week of delivery.
In addition part description of
article
capacitance value
rated voltage
dimensions
technical note
capacitance tolerance
packing
connecting information
04.23
158
Packing Quantities for Capacitors with
Radial Pins in PCM 2.5 mm to 27.5 mm
Size
PCM
2.5 mm
5 mm
7.5 mm
10 mm
15 mm
22.5 mm
04.23
27.5 mm
W
2.5
3
3.8
4.6
5.5
2.5
3
3.5
4.5
4.5
5
5.5
5.5
6.5
7.2
7.2
8.5
8.5
11
2.5
3
4
4.5
5
5.7
7.2
3
4
4
5
6
6
8
5
6
7
8
9
9
11
5
6
7
8.5
10.5
10.5
11
9
11
13
15
17
17
H
7
7.5
8.5
9
10
6.5
7.5
8.5
6
9.5
10
7
11.5
8
8.5
13
10
14
16
7
8.5
9
9.5
10.5
12.5
12.5
9
9
9.5
11
12
12.5
12
11
12.5
14
15
14
16
14
14
15
16.5
18.5
19
20.5
21
19
21
24
26
29
34.5
39.5
pcs. per packing unit
REEL
AMMO
Ø 360
Ø 500
340 x 340
490 x 370
H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5 H16.5 H18.5
N
O
F
I
H
J
A
C
B
D
2200
2500
2800
2000
2300
2300
1500
1800
1800
1200
1500
1500
900
1200
1200
2200
2500
2800
2000
2300
2300
1600
2000
2000
1300
1500
1500
1300
1500
1500
1100
1400
1400
1000
1200
1200
1000
1200
1200
800
1000
1000
700
1000
1000
700
950
1000
600
800
800
600
800
800
500
600
640
2500
4400
2500
2200
4300
2300
4150
1700
3200
1700
3000
1500
2900
1400
2700
1300
2500
1300
1000
2200
1100
900
1800
1000
1100
2200
1900
900
1600
1450
900
1600
1400
700
1300
1100
550
1100
1000
550
1100
1000
400
800
740
600
1200
1150
500
1000
1000
450
900
850
400
800
740
350
700
650
350
700
650
300
600
540
800
770
700
640
600
550
480
450
400
360
400
360
380
350
460/340*
380/280*
300
270
ROLL
bulk
L
Codes
4.6
0B
4.6
0C
4.6
0D
4.6
0E
4.6
0F
7.2
1A
7.2
1B
7.2
1C
7.2
1D
7.2
1E
7.2
1F
7.2
1G
7.2
1H
7.2
1I
7.2
1J
7.2
1K
7.2
1L
7.2
1M
7.2
1N
10
2A
10
2B
10
2C
10.3
2D
10.3
2E
10.3
2F
10.3
2G
13
3A
13
3C
13
3D
13
3F
13
3G
13
3H
13
3I
18
4B
18
4C
18
4D
18
4F
18
4H
18
4J
18
4M
26.5
5A
26.5
5B
26.5
5D
26.5
5F
26.5
5G
26.5
5H
26.5
5I
31.5
6A
31.5
6B
31.5
6D
31.5
6F
31.5
6G
31.5
6I
31.5
6J
S
5000
5000
5000
5000
5000
5000
5000
5000
6000
4000
3500
4000
2500
2500
2500
2000
2000
1500
1000
5000
5000
4000
3500
3000
2000
1500
3000
3000
3000
3000
2400
2400
2000
2400
2000
1600
1200
1200
900
1000
1200
1000
760
500
594*
594*
561*
567*
459*
378*
324*
198*
198*
162*
* for 2-inch transport pitches.
* TPS (Tray-Packing-System). Plate versions may have different packing units.
Samples and pre-production needs on request.
159
Radial Pins in PCM 37.5 mm to 52.5 mm
Size
PCM
REEL
AMMO
Ø 360
Ø 500
340 x 340
490 x 370
N
O
F
I
H
J
A
C
B
D
ROLL
bulk
W
9
11
13
15
17
19
28
31
35
40
H
19
22
24
26
29
32
39.5
45.5
38
46
50
55
L
Codes
41.5
7A
41.5
7B
41.5
7C
41.5
7D
41.5
7E
41.5
7F
41.5
7G
41.5
7H
41.5
7L
41.5
7I
41.5
7J
41.5
7K
S
441*
357*
294*
252*
154*
140*
126*
112*
84*
84*
35*
28*
48.5 mm**
19
23
27
33
37
31
34
37.5
48
54
56
56
56
56
56
8D
8E
8H
8J
8L
120*
80*
84*
25*
25*
52.5 mm
25
30
35
45
45
45
45
50
55
65
57
57
57
57
57
9D
9E
9F
9H
9J
70*
60*
25*
20*
20*
37.5 mm**
**For Snubber capacitors in 2-pin version the PCM is changing to 38.5 respective 49.5 mm.
04.23
Updated data on www.wima.com
160
WIMA Part Number System
A WIMA part number consists of 18 digits and is composed as follows:
Field 1 - 4: Type description
Field 5 - 6: Rated voltage
Field 7 - 10: Capacitance
Field 11 - 12: Size and PCM
Field 13 - 14: Version code (e.g. Snubber versions)
Field 15:
Field 16:
Packing
Field 17 - 18: Pin length (untaped)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
M
K
S
2
C
1
A
M
S
S
D
20 %
bulk
MKS 2
04.23
Type description:
SMD-PET
= SMDT
SMD-PEN
= SMDN
SMD-PPS
= SMDI
FKP 02
= FKP0
MKS 02
= MKS0
FKS 2
= FKS2
FKP 2
= FKP2
FKS 3
= FKS3
FKP 3
= FKP 3
MKS 2
= MKS2
MKP 2
= MKP2
MKS 4
= MKS4
MKP 4
= MKP4
MKP 10
= MKP1
FKP 4
= FKP4
FKP 1
= FKP1
MKP-X2
= MKX2
MKP-X1 R
= MKX1
MKP-Y2
= MKY2
MKP 4F
= MKPF
Snubber MKP
= SNMP
Snubber FKP
= SNFP
GTO MKP
= GTOM
DC-LINK MKP 4 = DCP4
DC-LINK MKP 6 = DCP6
DC-LINK HC
= DCHC
63 VDC
Rated voltage:
50 VDC = B0
63 VDC = C0
100 VDC = D0
250 VDC = F0
400 VDC = G0
450 VDC = H0
520 VDC = H2
600 VDC = I0
630 VDC = J0
700 VDC = K0
800 VDC = L0
850 VDC = M0
900 VDC = N0
1000 VDC = O1
1100 VDC = P0
1200 VDC = Q0
1250 VDC = R0
1500 VDC = S0
1600 VDC = T0
1700 VDC = TA
2000 VDC = U0
2500 VDC = V0
3000 VDC = W0
4000 VDC = X0
6000 VDC = Y0
230 VAC = 3Y
275 VAC = 1W
300 VAC = 2W
305 VAC = AW
350 VAC = BW
440 VAC = 4W
0.01 F
Capacitance:
22 pF
= 0022
47 pF
= 0047
100 pF = 0100
150 pF = 0150
220 pF = 0220
330 pF = 0330
470 pF = 0470
680 pF = 0680
1000 pF = 1100
1500 pF = 1150
2200 pF = 1220
3300 pF = 1330
4700 pF = 1470
6800 pF = 1680
0.01 F = 2100
0.022 F = 2220
0.047 F = 2470
0.1 F = 3100
0.22 F = 3220
0.47 F = 3470
= 4100
1 F
2.2 F = 4220
4.7 F = 4470
= 5100
10 F
= 5220
22 F
= 5470
47 F
100 F = 6100
220 F = 6220
1000 F = 7100
1500 F = 7150
2.5 x 6.5 x 7.2
Size:
4.8 x 3.3 x 3 Size 1812
4.8 x 3.3 x 4 Size 1812
5.7 x 5.1 x 3.5 Size 2220
5.7 x 5.1 x 4.5 Size 2220
7.2 x 6.1 x 3 Size 2824
7.2 x 6.1 x 5 Size 2824
10.2 x 7.6 x 5 Size 4030
12.7 x 10.2 x 6 Size 5040
15.3 x 13.7 x 7 Size 6054
2.5 x 7 x 4.6 PCM 2.5
3 x 7.5 x 4.6 PCM 2.5
2.5 x 6.5 x 7.2 PCM 5
3 x 7.5 x 7.2 PCM 5
2.5 x 7 x 10 PCM 7.5
3 x 8.5 x 10 PCM 7.5
3 x 9 x 13 PCM 10
4 x 9 x 13 PCM 10
5 x 11 x 18 PCM 15
6 x 12.5 x 18 PCM 15
5 x 14 x 26.5 PCM 22.5
6 x 15 x 26.5 PCM 22.5
9 x 19 x 31.5 PCM 27.5
11 x21 x 31.5 PCM 27.5
9 x 19 x 41.5 PCM 37.5
11 x 22 x 41.5 PCM 37.5
19 x 31 x 56 PCM 48.5
25 x 45 x 57 PCM 52.5
Version code:
Standard
Version A1
Version A1.1.1
Version A2
= 00
= 1A
= 1B
= 2A
= KA
= KB
= QA
= QB
= TA
= TB
= VA
= XA
= YA
= 0B
= 0C
= 1A
= 1B
= 2A
= 2B
= 3A
= 3C
= 4B
= 4C
= 5A
= 5B
= 6A
= 6B
= 7A
= 7B
= 8D
= 9D
6 -2
Tolerance:
±20 % = M
±10 % = K
±5 %
=J
±2.5 % = H
±1 %
=E
Packing:
AMMO H16.5 340 x 340
AMMO H16.5 490 x 370
AMMO H18.5 340 x 340
AMMO H18.5 490 x 370
REEL H16.5 360
REEL H16.5 500
REEL H18.5 360
REEL H18.5 500
ROLL H16.5
ROLL H18.5
BLISTER W12 180
BLISTER W12 330
BLISTER W16 330
BLISTER W24 330
Bulk/TPS Standard
=A
=B
=C
=D
=F
=H
=I
=J
=N
=O
=P
=Q
=R
=T
=S
3.5 ±0.5 = C9
6 -2
= SD
16 ±1 = P1
Pin length (taped)
none
= 00
The data on this page is not complete and serves only to explain the part number system. Part number information is listed on
the pages of the respective WIMA range.
155
很抱歉,暂时无法提供与“DCP4R245006JD2KSSD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+36.12565
- 10+29.31017
- 25+27.34577
- 50+26.04017
- 100+24.73457
- 162+23.89611
- 324+22.77018
- 486+22.12337
- 810+21.18908
- 1134+20.81776
- 国内价格 香港价格
- 1+38.781851+5.03980
- 10+31.4776510+4.09060
- 25+29.3907325+3.81940
- 50+27.9994550+3.63860
- 100+26.60818100+3.45780
- 162+25.65167162+3.33350
- 324+24.43431324+3.17530
- 486+23.73867486+3.08490
- 810+22.78217810+2.96060
- 1134+22.347391134+2.90410
