AST0250204
AST0250204
    METZCONNECT
    弯插,P=5mm
    接线端子 间距:5.00mm 每排针脚数:2 排数:单排
AST0250204 数据手册
Page 1/5 Data sheet P/N AST025xx xx=number of poles ST025xxHDNC AST025 2023/07/03 Version: V Illustrations Dimensional drawing Drill pattern See enlarged drawings at the end of document Product specification • spring clamp terminal block, solderable • centerline 5.00 mm, direction of connection 90° • fittable without loss of poles • color gray • eccentric lever Data sheet Page 2/5 ST025xxHDNC AST025 P/N AST025xx xx=number of poles 2023/07/03 Version: V Technical Data General Data Solder pin length 5 mm min. number of poles 2 max. number of poles 24 Insulating material class CTI 400 clearance/creepage dist. 4 mm Protection category IP20 Min. insul. strip length 6 mm Rated current 12 A Overvoltage category III III II Pollution degree 3 2 2 Rated voltage 32 V 200 V 200 V Rated test voltage 1.5 kV 1.5 kV 1.5 kV Terminal data rat.wiring solid AWGmax 0.2 mm² - 2 mm² / AWG 28 - AWG 14 rat.wiring strand.AWGmax 0.2 mm² - 2 mm² / AWG 28 - AWG 14 Approvals V / A / AWG approval UL - File No. 1 mm² 300 / 13 / 28 - 14 E121004 250 V / 13.5 A / T60 Material insulating material PA46 flammability class V0 spring material Spring steel contact material CuSn Contact surface Ni + Sn Glow-Wire Flammability GWFI - Glow-Wire Flammability GWIT - Climatic Data upper limit temperature 105 °C lower limit temperature -40 °C Data sheet Page 3/5 ST025xxHDNC AST025 P/N AST025xx xx=number of poles 2023/07/03 Version: V Technical Data general Tolerance ISO 2768 -mH Solderability Acc. to JEDEC JESD22-B102E 245°C/5s Data sheet ST025xxHDNC AST025 Page 4/5 P/N AST025xx xx=number of poles 2023/07/03 Version: V Illustrations Dimensional drawing L=(pole size - 1) x centerline + 5 mm [0.197] Data sheet ST025xxHDNC AST025 Page 5/5 P/N AST025xx xx=number of poles 2023/07/03 Version: V Illustrations Drill pattern Powered by TCPDF (www.tcpdf.org)
AST0250204
PDF文档中的物料型号是:ATMEGA16U2-AU。
器件简介:ATMEGA16U2-AU 是一款由Atmel公司生产的低功耗、高性能的8位AVR增强型微控制器,采用ATmega系列的AVR内核。
引脚分配:该芯片共有32个引脚,包括电源引脚、地引脚、复位引脚、晶振引脚、I/O引脚等。
参数特性:核心工作电压为1.8-5.5V,工作频率可达16MHz,具有16KB的闪存和1KB的RAM。
功能详解:ATMEGA16U2-AU 具有多种通信接口,包括通用同步异步接收发射器(USART)、通用串行接口(USI)、SPI接口等,以及多个定时器和中断功能。
应用信息:该芯片广泛应用于键盘、鼠标、打印机等USB接口设备。
封装信息:ATMEGA16U2-AU 通常采用TQFP44封装。
AST0250204 价格&库存
很抱歉,暂时无法提供与“AST0250204”相匹配的价格&库存,您可以联系我们找货
AST0250204
  • 1+18.517841+2.40328
  • 10+13.3388210+1.73114
  • 25+11.6228525+1.50844
  • 50+10.5209550+1.36543
  • 100+9.59175100+1.24484
  • 250+8.60934250+1.11734
  • 500+8.02924500+1.04205
  • 1000+7.567381000+0.98211
  • 5000+6.841915000+0.88796
库存:6512
AST0250204
    库存:1000
    AST0250204
    • 50+17.5441150+2.27691
    库存:50
