BQTRX
BQTRX
    CARLOGAVAZZI
    Module
    选件卡,输入 温度
BQTRX 数据手册
Digital Panel Meters Modular Indicator and Controller Type UDM35 • • • • • • • • • Front protection degree: IP67, NEMA12, NEMA4x "Indoor use only" • Linearization of Hz inputs up to 16 points • • • • Multi-input modular instrument 3 1/2 DGT LED 0.1% RDG basic accuracy TRMS AC current and voltage measurements AC/DC current measurements: selectable full scales (200µA to 5A) AC/DC voltage measurements: selectable full scales (200mV to 500V) °C or °F temperature measurements (Pt100-250-500-1000, Ni100, TC J-K-S-T-E) Resistance measurements: selectable full scales (20Ω to 20kΩ) Dual rate, speed, frequency and period measurement (0.001Hz to 50kHz) Up to 4 independent alarm set-points (optional) 20mA/10VDC analog output (optional) Serial port RS485 or RS232 (optional) MODBUS, JBUS communication protocol Product Description How to order µp-based digital panel meter, 3 1/2 DGT LED indicator, for current, voltage, temperature, resistance, rate, frequency, speed and period measurements. Measuring ranges and functions easily programmable from the key-pad or from the PC Model Slot A Slot B Slot C Slot D Options by means of optional UdmSoft software. UDM35 includes storage min-max functions and double level protection password. Housing for panel mounting with front protection degree: IP67, NEMA12, NEMA4x "Indoor use only". How to order UDM35 XXX XX XX X XX UdmSoft-kit UdmSoft-kit: software plus communication cable for programming UDM35 by means of PC. UdmSoft: software for programming UDM35/40/60 by means of PC, downloadable from www.carlogavazzi.com. Type Selection Slot A (measuring inputs) Slot B (communication) Slot C (communication and alarm) Slot D (power supply) LSX: signal inputs: 0.2-2-20mA DC/AC; 0.2-2-20V DC/AC LSE/ LSF: signal inputs: + AUX: 0.2-2-20mA DC/AC; 0.2-2-20V DC/AC HSX: signal inputs: 0.2-2-5A DC/AC; 20-200-500V DC/AC TRX: signal inputs: TC temperature probes (J-KS-T-E, Pt100-250-5001000) and resistance (0.02-0.2-2-20kΩ) TF1: 0.001Hz to 50kHz for DC signals: PNP, NPN, NAMUR, TTL, free of voltage, contacts, voltages up to 14VDC TF2: 0.001Hz to 50kHz for AC signals: pick-up, voltages up to 500VAC XX: SX: SY: AV(*): XX: R1: H: L: (*): None Serial port RS485 Serial port RS232 Single analogue output, 0 to 20mA DC and 0 to 10V DC None Single relay output, (AC1-8AAC, 250VAC) R2: Dual relay output, (AC1-8AAC, 250VAC) R4: Dual relay output, (AC18AAC, 250VAC) + dual open collector output (NPN, 100mA) R5: 4 relay outputs (AC1-5AAC, 250VAC) AV(*): Single analogue output, 0 to 20mA DC and 0 to 10V DC The two analogue outputs cannot be used at the same time. It is possible to plug in only one module by instrument. Specifications are subject to change without notice UDM35 DS ENG 090112 3: 90 to 260V AC/DC 18 to 60V AC/DC (24 to 48V AC/DC ± 25% according to UL) 10 to 28V DC (12 to 24V DC ± 15% according to UL) Options XX: TX: None Tropicalization 1 UDM35 Input specifications Analogue inputs BQ LSX module BQ LSE/LSF module BQ HSX module BQ TRX module BQ TRX module BQTF1 module BQTF2 module Type of input NPN (DC) PNP (DC) NAMUR (DC) TTL (DC) Free of voltage contact(DC) Voltage (AC) up to 100VAC Voltage (AC) up to 500VAC Digital inputs Number of inputs Use Contact reading signal Close contact resistance Open contact resistance Insulation Accuracy (display, RS485) Additional errors Humidity Channels and variable 1, mA and V DC/AC 1, mA and V DC/AC + AUX 1, A and V DC/AC 1, temperature 1, resistance 2, frequency 2, frequency Magnetic field Temperature drift Sampling rate Display refresh time Signal level: ON < 2VDC, OFF open collector (leakage current 10VDC, OFF open collector (leakage current 4VDC, OFF 2VAC (5.65 Vpp). Signal level: ON > 9VAC (25.4 Vpp). Incl. in the measuring module 1 (voltage-free) key-pad lock Display hold Reset of latch alarms BQ xxx:
BQTRX 价格&库存
很抱歉,暂时无法提供与“BQTRX”相匹配的价格&库存,您可以联系我们找货
