3570-1331-051
    COMUS
    SIP
    RELAY REED SIP SPST .5A 5V
3570-1331-051 数据手册
Relays Part Number: 3570 1331 General Purpose SIP - 1 Form A Product Data Sheet PICTURE FEATURES • SIP 1 Form A - 10 W molded dry reed relays • Low cost switching solutions. • Industry standard package. • Optional internal coil suppression diode. • 5, 12 and 24 volt coils available. • UL File E358613 ® ORDERING INFORMATION Series Coil 05 3570.1331. 12 24 SCHEMATIC Options 1 = no diode 3 = with diode Part Number Example: 3570.1331.xxx 3570.1331.051 = 5 volt coil, no diode 1 + _ 2 3 4 DIMENSIONS IDENTIFIES PIN #1 0.20 (5.08) 0.030 (0.8) 0.748 (19.0) 0.303 (7.70) 1 2 3 4 0.125 (3.18) 0.02 (0.50) 0.009 (0.25) 0.20 (5.08) Drawings not to scale. All dimensions in inches (mm) nominal. As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone: (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 Belgium: + 32 (0)12 390400 - Comus Europe Ltd (Assemtech) UK: +44 (0) 1255 862236 - Germany: +49 (0)911 923 15 943 - Netherlands: +31(0)45 54 39 345 - India: +(91) (44) 43219090 ©2015 Copyright Comus International, 454 Allwood Road, Clifton NJ 07012, USA 1 / 2015 An ISO 9001 Certified Company Relays Part Number: 3570 1331 General Purpose SIP - 1 Form A Product Data Sheet COIL DATA-STANDARD TYPE 1 FORM A (at 20˚C) NOMINAL COIL VOLTAGE (VDC) NOMINAL COIL RESISTANCE ±10% (Ω) MAX OPERATE VOLTAGE (VDC) MIN RELEASE VOLTAGE (VDC) MAX COIL VOLTAGE (VDC) 5 500 3.75 0.4 7 12 1000 9 1 16 24 2000 18 2 32 CONTACT RATING Max Switching Power 10 W Max Switching Voltage 150 VDC Max Switching Current 0.5 A Max Carry Current 1A SPECIFICATION Contact Resistance (Initial) MAX 200 mΩ Operate Time - including bounce (Typical) 0.35 ms (At Nominal Voltage) Release Time (Typical) 0.5 ms Insulation Resistance @ 100V, 20°C, 40% RH (MIN) 1010 Ω Dielectric Strength (MIN) Between Open Contacts 200 V DC / peak AC Between Coil to Contacts 1500 V DC / peak AC Capacitance Between Open Contacts (Typical) 0.5 pF Vibration 20G Shock 50G Operating Temperature -40° +85°C Storage Temperature -40° +100°C Life Expectancy at Specified Load (Typical) 100 x 106 ops (1 VDC, 10mA) As part of the company policy of continued product improvement, specifications may change without notice. Our sales office will be pleased to help you with the latest information on this product range and the details of our full design and manufacturing service. All products are supplied to our standard conditions of sale unless otherwise agreed in writing. Phone: (1) 973 777 6900 www.comus-intl.com Fax: (1) 973 777 8405 Belgium: + 32 (0)12 390400 - Comus Europe Ltd (Assemtech) UK: +44 (0) 1255 862236 - Germany: +49 (0)911 923 15 943 - Netherlands: +31(0)45 54 39 345 - India: +(91) (44) 43219090 ©2015 Copyright Comus International, 454 Allwood Road, Clifton NJ 07012, USA 1 / 2015 An ISO 9001 Certified Company
3570-1331-051 价格&库存
很抱歉,暂时无法提供与“3570-1331-051”相匹配的价格&库存,您可以联系我们找货
