GBB80DYFD
GBB80DYFD
    SULLINS
    SMD,P=1.27mm
    CONN EDGE DUAL FMALE 160POS .050
GBB80DYFD 数据手册
8 7 4 5 6 REVISIONS PART NUMBER CODING _ _ B _ _ DYF_ - S_ _ _ _ MATERIAL (INSULATOR/CONTACT) F E R = BLACK, PPS/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS G = BLACK, PA9T/PHOSPHOR BRONZE OPERATING TEMP: -65°C TO +125°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS A = BLACK, PPS/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS J = BLACK, PA9T/BERYLLIUM COPPER OPERATING TEMP: -65°C TO +150°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS *F = BLACK, PPS/SPINODAL OPERATING TEMP: -65°C TO +200°C PROCESSING TEMP: 260°C MAX FOR 20 SECONDS (CONSULT FACTORY FOR SPECIAL SOLDERING GUIDELINES) * AVAILABLE IN 'M' PLATING ONLY 2X REV. ECO. NO F 4448 DESCRIPTION DATE MODIFICATION CODE H 4626 UPDATE NOTE 11 (WAS '500 CYCLES') 2/13/2023 MM OMIT FOR STANDARD, EX: 'GCB15DYFD' OTHER S# FOR MOLDED KEY OPTION (SEE DRAWING C13556 FOR S#, G & H DIMENSIONS) J 4668 REMOVE 'X' MATERIAL 5/11/2023 JH CHANGE SMT BEND & INCREASE CONTACT SURFACE RADIUS BIGGER, ADDED 'X' MATERIAL 12/12/2022 BY JH F MOUNTING STYLE NUMBER OF POSITIONS (CONTACTS PER ROW) D= N= T= R= FLUSH MOUNTING (PAGE 1) NO MOUNTING EARS (PAGE 2) FLUSH MOUNTING, WITH THREADED INSERTS (PAGE 2) METAL BOARDLOCKS (PAGE 2) PLATING E ALL PLATINGS ARE LEAD FREE AND HAVE .000050" NICKEL UNDERPLATE CONTACT SURFACE TERMINATION B = .000010" GOLD .000100" PURE TIN, MATTE C = .000030" GOLD .000100" PURE TIN, MATTE M = .000030" GOLD .000010" GOLD OVERALL 1ST POSITION INDICATOR D 1 2 3 E D B A D .075 1.91 SEE NOTE 13 .125 3.18 THRU .016 .41 .050 1.27 TYP +.13 +.005 .370 9.40 - .015 - .38 C C A .029 .74 .300 7.62 INSERTION DEPTH .144 3.66 C .610 15.49 .250 6.35 .010[0.25] A .060 1.52 B A 2X .100±.025 2.54±.64 _ _B_ _DYFD NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING 2. CONTACT MATERIAL: SEE PART NUMBER CODING 3. PLATING: SEE PART NUMBER CODING 4. OPERATING TEMPERATURE: SEE PART NUMBER CODING 5. PROCESSING TEMP: SEE PART NUMBER CODING 6. UL FLAMMABILITY RATING: 94V-0 7. OPERATING VOLTAGE: 300 VAC 8. CURRENT RATING: 1 AMP 9. CONTACT RESISTANCE: 30 MILLI OHMS MAX 10. INSULATION RESISTANCE: 5000 MEGA OHM 11. DURABILITY: 5000 CYCLES MINIMUM 12. CONNECTOR IDENTIFICATION: THE PART SHALL BE MARKED WITH A PART NUMBER AND LOT CODE 13. BOARD THICKNESS ACCOMMODATED: .062 .008[1.57 0.20] 14. INSERTION FORCE: 6 OZ MAX PER CONTACT PAIR WHEN USING A .062[1.57] TEST BLADE INTERNAL INSPECTION TO BE PER SULLINS WORK INSTRUCTION WI-8.6-03 15. WITHDRAWAL FORCE: 1/2 OZ MIN PER CONTACT PAIR USING .062[1.57] TEST BLADE 16. MODIFICATION: SEE PART NUMBER CODING 8 7 6 5 SECTION A-A B CUSTOMER COPY Pb RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 01/06/09 TT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 3 2 _ _B_ _DYF_ CAGE CODE 54453 SCALE: 2:1 4 A EDGECARD, .050" CC, HP, SMT DWG. NO. C11422 REV J SHEET 1 OF 3 1 FILE NAME: C11422, _ _B_ _DYF_-OMIT, S_ _ _ _ MOLDED KEY 8 7 4 5 6 1 2 3 D 2X #4-40 THREADED INSERTS F F C E E _ _B_ _DYFT _ _B_ _DYFN D D .040 1.02 TYP MAX .050 1.27 TYP .315 8.00 MIN C .134±.015 3.40±.38 C .630 16.00 2X .125 3.18 FOR 'D' OR 'T' MOUNTING .185 4.70 MAX 2X .096 2.44 FOR 'R' MOUNTING C 2X BOARD LOCK A F F _ _B_ _DYFR D PCB LAYOUT RECOMMENDED B B CUSTOMER COPY Pb A RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 01/06/09 TT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 7 6 5 4 3 2 _ _B_ _DYF_ CAGE CODE 54453 SCALE: 2:1 8 A EDGECARD, .050" CC, HP, SMT DWG. NO. C11422 REV J SHEET 2 OF 3 1 FILE NAME: C11422, _ _B_ _DYF_-OMIT, S_ _ _ _ MOLDED KEY 8 NO OF POS. 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 PART NUMBER F E D C _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _B05DYF_ _B06DYF_ _B07DYF_ _B08DYF_ _B09DYF_ _B10DYF_ _B11DYF_ _B12DYF_ _B13DYF_ _B14DYF_ _B15DYF_ _B16DYF_ _B17DYF_ _B18DYF_ _B19DYF_ _B20DYF_ _B21DYF_ _B22DYF_ _B23DYF_ _B24DYF_ _B25DYF_ _B26DYF_ _B27DYF_ _B28DYF_ _B29DYF_ _B30DYF_ _B31DYF_ _B32DYF_ _B33DYF_ _B34DYF_ _B35DYF_ _B36DYF_ _B37DYF_ _B38DYF_ _B39DYF_ _B40DYF_ _B41DYF_ _B42DYF_ _B43DYF_ _B44DYF_ _B45DYF_ _B46DYF_ _B47DYF_ _B48DYF_ _B49DYF_ _B50DYF_ _B51DYF_ _B52DYF_ _B53DYF_ _B54DYF_ _B55DYF_ _B56DYF_ _B57DYF_ _B58DYF_ _B59DYF_ _B60DYF_ _B61DYF_ _B62DYF_ 7 A±.005[0.13] IN MM 0.200 5.08 0.250 6.35 0.300 7.62 0.350 8.89 0.400 10.16 0.450 11.43 0.500 12.7 0.550 13.97 0.600 15.24 0.650 16.51 0.700 17.78 0.750 19.05 0.800 20.32 0.850 21.59 0.900 22.86 0.950 24.13 1.000 25.4 1.050 26.67 1.100 27.94 1.150 29.21 1.200 30.48 1.250 31.75 1.300 33.02 1.350 34.29 1.400 35.56 1.450 36.83 1.500 38.1 1.550 39.37 1.600 40.64 1.650 41.91 1.700 43.18 1.750 44.45 1.800 45.72 1.850 46.99 1.900 48.26 1.950 49.53 2.000 50.8 2.050 52.07 2.100 53.34 2.150 54.61 2.200 55.88 2.250 57.15 2.300 58.42 2.350 59.69 2.400 60.96 2.450 62.23 2.500 63.5 2.550 64.77 2.600 66.04 2.650 67.31 2.700 68.58 2.750 69.85 2.800 71.12 2.850 72.39 2.900 73.66 2.950 74.93 3.000 76.2 3.050 77.47 B±.005[0.13] IN MM 0.300 7.62 0.350 8.89 0.400 10.16 0.450 11.43 0.500 12.70 0.550 13.97 0.600 15.24 0.650 16.51 0.700 17.78 0.750 19.05 0.800 20.32 0.850 21.59 0.900 22.86 0.950 24.13 1.000 25.40 1.050 26.67 1.100 27.94 1.150 29.21 1.200 30.48 1.250 31.75 1.300 33.02 1.350 34.29 1.400 35.56 1.450 36.83 1.500 38.10 1.550 39.37 1.600 40.64 1.650 41.91 1.700 43.18 1.750 44.45 1.800 45.72 1.850 46.99 1.900 48.26 1.950 49.53 2.000 50.80 2.050 52.07 2.100 53.34 2.150 54.61 2.200 55.88 2.250 57.15 2.300 58.42 2.350 59.69 2.400 60.96 2.450 62.23 2.500 63.50 2.550 64.77 2.600 66.04 2.650 67.31 2.700 68.58 2.750 69.85 2.800 71.12 2.850 72.39 2.900 73.66 2.950 74.93 3.000 76.20 3.050 77.47 3.100 78.74 3.150 80.01 4 5 6 C±.015[0.38] IN MM 0.490 12.45 0.540 13.72 0.590 14.99 0.640 16.26 0.690 17.53 0.740 18.80 0.790 20.07 0.840 21.34 0.890 22.61 0.940 23.88 0.990 25.15 1.040 26.42 1.090 27.69 1.140 28.96 1.190 30.23 1.240 31.50 1.290 32.77 1.340 34.04 1.390 35.31 1.440 36.58 1.490 37.85 1.540 39.12 1.590 40.39 1.640 41.66 1.690 42.93 1.740 44.20 1.790 45.47 1.840 46.74 1.890 48.01 1.940 49.28 1.990 50.55 2.040 51.82 2.090 53.09 2.140 54.36 2.190 55.63 2.240 56.90 2.290 58.17 2.340 59.44 2.390 60.71 2.440 61.98 2.490 63.25 2.540 64.52 2.590 65.79 2.640 67.06 2.690 68.33 2.740 69.60 2.790 70.87 2.840 72.14 2.890 73.41 2.940 74.68 2.990 75.95 3.040 77.22 3.090 78.49 3.140 79.76 3.190 81.03 3.240 82.30 3.290 83.57 3.340 84.84 D±.010[0.25] IN MM 0.776 19.71 0.826 20.98 0.876 22.25 0.926 23.52 0.976 24.79 1.026 26.06 1.076 27.33 1.126 28.60 1.176 29.87 1.226 31.14 1.276 32.41 1.326 33.68 1.376 34.95 1.426 36.22 1.476 37.49 1.526 38.76 1.576 40.03 1.626 41.30 1.676 42.57 1.726 43.84 1.776 45.11 1.826 46.38 1.876 47.65 1.926 48.92 1.976 50.19 2.026 51.46 2.076 52.73 2.126 54.00 2.176 55.27 2.226 56.54 2.276 57.81 2.326 59.08 2.376 60.35 2.426 61.62 2.476 62.89 2.526 64.16 2.576 65.43 2.626 66.70 2.676 67.97 2.726 69.24 2.776 70.51 2.826 71.78 2.876 73.05 2.926 74.32 2.976 75.59 3.026 76.86 3.076 78.13 3.126 79.40 3.176 80.67 3.226 81.94 3.276 83.21 3.326 84.48 3.376 85.75 3.426 87.02 3.476 88.29 3.526 89.56 3.576 90.83 3.626 92.10 E±.020[0.51] IN MM 1.090 27.69 1.140 28.96 1.190 30.23 1.240 31.50 1.290 32.77 1.340 34.04 1.390 35.31 1.440 36.58 1.490 37.85 1.540 39.12 1.590 40.39 1.640 41.66 1.690 42.93 1.740 44.20 1.790 45.47 1.840 46.74 1.890 48.01 1.940 49.28 1.990 50.55 2.040 51.82 2.090 53.09 2.140 54.36 2.190 55.63 2.240 56.90 2.290 58.17 2.340 59.44 2.390 60.71 2.440 61.98 2.490 63.25 2.540 64.52 2.590 65.79 2.640 67.06 2.690 68.33 2.740 69.60 2.790 70.87 2.840 72.14 2.890 73.41 2.940 74.68 2.990 75.95 3.040 77.22 3.090 78.49 3.140 79.76 3.190 81.03 3.240 82.30 3.290 83.57 3.340 84.84 3.390 86.11 3.440 87.38 3.490 88.65 3.540 89.92 3.590 91.19 3.640 92.46 3.690 93.73 3.740 95.00 3.790 96.27 3.840 97.54 3.890 98.81 3.940 100.08 .026±.002 .66±.05 MOLDED KEY IN POSITION F±.010[0.25] IN MM 0.350 8.89 0.400 10.16 0.450 11.43 0.500 12.70 0.550 13.97 0.600 15.24 0.650 16.51 0.700 17.78 0.750 19.05 0.800 20.32 0.850 21.59 0.900 22.86 0.950 24.13 1.000 25.40 1.050 26.67 1.100 27.94 1.150 29.21 1.200 30.48 1.250 31.75 1.300 33.02 1.350 34.29 1.400 35.56 1.450 36.83 1.500 38.10 1.550 39.37 1.600 40.64 1.650 41.91 1.700 43.18 1.750 44.45 1.800 45.72 1.850 46.99 1.900 48.26 1.950 49.53 2.000 50.80 2.050 52.07 2.100 53.34 2.150 54.61 2.200 55.88 2.250 57.15 2.300 58.42 2.350 59.69 2.400 60.96 2.450 62.23 2.500 63.50 2.550 64.77 2.600 66.04 2.650 67.31 2.700 68.58 2.750 69.85 2.800 71.12 2.850 72.39 2.900 73.66 2.950 74.93 3.000 76.20 3.050 77.47 3.100 78.74 3.150 80.01 3.200 81.28 PART NUMBER _ _B63DYF_ _ _B64DYF_ _ _B65DYF_ _ _B66DYF_ _ _B67DYF_ _ _B68DYF_ _ _B69DYF_ _ _B70DYF_ _ _B71DYF_ _ _B72DYF_ _ _B73DYF_ _ _B74DYF_ _ _B75DYF_ _ _B76DYF_ _ _B77DYF_ _ _B78DYF_ _ _B79DYF_ _ _B80DYF_ _ _B81DYF_ _ _B82DYF_ _ _B83DYF_ _ _B84DYF_ _ _B85DYF_ _ _B86DYF_ _ _B87DYF_ _ _B88DYF_ _ _B89DYF_ _ _B90DYF_ _ _B91DYF_ _ _B92DYF_ _ _B93DYF_ _ _B94DYF_ _ _B95DYF_ _ _B96DYF_ _ _B97DYF_ _ _B98DYF_ _ _B99DYF_ _ _B100DYF_ _ _B101DYF_ _ _B102DYF_ _ _B103DYF_ _ _B104DYF_ _ _B105DYF_ _ _B106DYF_ _ _B107DYF_ _ _B108DYF_ _ _B109DYF_ _ _B110DYF_ _ _B111DYF_ _ _B112DYF_ _ _B113DYF_ _ _B114DYF_ _ _B115DYF_ _ _B116DYF_ _ _B117DYF_ _ _B118DYF_ _ _B119DYF_ _ _B120DYF_ A±.005[0.13] IN MM 3.100 78.74 3.150 80.01 3.200 81.28 3.250 82.55 3.300 83.82 3.350 85.09 3.400 86.36 3.450 87.63 3.500 88.90 3.550 90.17 3.600 91.44 3.650 92.71 3.700 93.98 3.750 95.25 3.800 96.52 3.850 97.79 3.900 99.06 3.950 100.33 4.000 101.60 4.050 102.87 4.100 104.14 4.150 105.41 4.200 106.68 4.250 107.95 4.300 109.22 4.350 110.49 4.400 111.76 4.450 113.03 4.500 114.30 4.550 115.57 4.600 116.84 4.650 118.11 4.700 119.38 4.750 120.65 4.800 121.92 4.850 123.19 4.900 124.46 4.950 125.73 5.000 127.00 5.050 128.27 5.100 129.54 5.150 130.81 5.200 132.08 5.250 133.35 5.300 134.62 5.350 135.89 5.400 137.16 5.450 138.43 5.500 139.70 5.550 140.97 5.600 142.24 5.650 143.51 5.700 144.78 5.750 146.05 5.800 147.32 5.850 148.59 5.900 149.86 5.950 151.13 1 2 3 NO OF POS. 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 B±.005[0.13] IN MM 3.200 81.28 3.250 82.55 3.300 83.82 3.350 85.09 3.400 86.36 3.450 87.63 3.500 88.90 3.550 90.17 3.600 91.44 3.650 92.71 3.700 93.98 3.750 95.25 3.800 96.52 3.850 97.79 3.900 99.06 3.950 100.33 4.000 101.60 4.050 102.87 4.100 104.14 4.150 105.41 4.200 106.68 4.250 107.95 4.300 109.22 4.350 110.49 4.400 111.76 4.450 113.03 4.500 114.30 4.550 115.57 4.600 116.84 4.650 118.11 4.700 119.38 4.750 120.65 4.800 121.92 4.850 123.19 4.900 124.46 4.950 125.73 5.000 127.00 5.050 128.27 5.100 129.54 5.150 130.81 5.200 132.08 5.250 133.35 5.300 134.62 5.350 135.89 5.400 137.16 5.450 138.43 5.500 139.70 5.550 140.97 5.600 142.24 5.650 143.51 5.700 144.78 5.750 146.05 5.800 147.32 5.850 148.59 5.900 149.86 5.950 151.13 6.000 152.40 6.050 153.67 C±.015[0.38] IN MM 3.390 86.11 3.440 87.38 3.490 88.65 3.540 89.92 3.590 91.19 3.640 92.46 3.690 93.73 3.740 95.00 3.790 96.27 3.840 97.54 3.890 98.81 3.940 100.08 3.990 101.35 4.040 102.62 4.090 103.89 4.140 105.16 4.190 106.43 4.240 107.70 4.290 108.97 4.340 110.24 4.390 111.51 4.440 112.78 4.490 114.05 4.540 115.32 4.590 116.59 4.640 117.86 4.690 119.13 4.740 120.40 4.790 121.67 4.840 122.94 4.890 124.21 4.940 125.48 4.990 126.75 5.040 128.02 5.090 129.29 5.140 130.56 5.190 131.83 5.240 133.10 5.290 134.37 5.340 135.64 5.390 136.91 5.440 138.18 5.490 139.45 5.540 140.72 5.590 141.99 5.640 143.26 5.690 144.53 5.740 145.80 5.790 147.07 5.840 148.34 5.890 149.61 5.940 150.88 5.990 152.15 6.040 153.42 6.090 154.69 6.140 155.96 6.190 157.23 6.240 158.50 D±.010[0.25] IN MM 3.676 93.37 3.726 94.64 3.776 95.91 3.826 97.18 3.876 98.45 3.926 99.72 3.976 100.99 4.026 102.26 4.076 103.53 4.126 104.80 4.176 106.07 4.226 107.34 4.276 108.61 4.326 109.88 4.376 111.15 4.426 112.42 4.476 113.69 4.526 114.96 4.576 116.23 4.626 117.50 4.676 118.77 4.726 120.04 4.776 121.31 4.826 122.58 4.876 123.85 4.926 125.12 4.976 126.39 5.026 127.66 5.076 128.93 5.126 130.20 5.176 131.47 5.226 132.74 5.276 134.01 5.326 135.28 5.376 136.55 5.426 137.82 5.476 139.09 5.526 140.36 5.576 141.63 5.626 142.90 5.676 144.17 5.726 145.44 5.776 146.71 5.826 147.98 5.876 149.25 5.926 150.52 5.976 151.79 6.026 153.06 E±.020[0.51] IN MM 3.990 101.35 4.040 102.62 4.090 103.89 4.140 105.16 4.190 106.43 4.240 107.70 4.290 108.97 4.340 110.24 4.390 111.51 4.440 112.78 4.490 114.05 4.540 115.32 4.590 116.59 4.640 117.86 4.690 119.13 4.740 120.40 4.790 121.67 4.840 122.94 4.890 124.21 4.940 125.48 4.990 126.75 5.040 128.02 5.090 129.29 5.140 130.56 5.190 131.83 5.240 133.10 5.290 134.37 5.340 135.64 5.390 136.91 5.440 138.18 5.490 139.45 5.540 140.72 5.590 141.99 5.640 143.26 5.690 144.53 5.740 145.80 5.790 147.07 5.840 148.34 5.890 149.61 5.940 150.88 5.990 152.15 6.040 153.42 6.090 154.69 6.140 155.96 6.190 157.23 6.240 158.50 6.290 159.77 6.340 161.04 N OR R MOUNTING ONLY F±.010[0.25] IN MM 3.250 82.55 3.300 83.82 3.350 85.09 3.400 86.36 3.450 87.63 3.500 88.90 3.550 90.17 3.600 91.44 3.650 92.71 3.700 93.98 3.750 95.25 3.800 96.52 3.850 97.79 3.900 99.06 3.950 100.33 4.000 101.60 4.050 102.87 4.100 104.14 4.150 105.41 4.200 106.68 4.250 107.95 4.300 109.22 4.350 110.49 4.400 111.76 4.450 113.03 4.500 114.30 4.550 115.57 4.600 116.84 4.650 118.11 4.700 119.38 4.750 120.65 4.800 121.92 4.850 123.19 4.900 124.46 4.950 125.73 5.000 127.00 5.050 128.27 5.100 129.54 5.150 130.81 5.200 132.08 5.250 133.35 5.300 134.62 5.350 135.89 5.400 137.16 5.450 138.43 5.500 139.70 5.550 140.97 5.600 142.24 5.650 143.51 5.700 144.78 5.750 146.05 5.800 147.32 5.850 148.59 5.900 149.86 5.950 151.13 6.000 152.40 6.050 153.67 6.100 154.94 F E D C .024±.002 .61±.05 MOLDED KEY BETWEEN POSITIONS B B H G CUSTOMER COPY Pb A ('D' MOUNTING AS SHOWN FOR EXAMPLE) RoHS COMPLIANT UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 01/06/09 TT TOLERANCES: ANGULAR: 1 DECIMALS .XX= .02 [.5] .XXX= .005 [.13] .XXXX= .0005 [.013] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE PART NUMBER SIZE C 7 6 5 4 3 2 _ _B_ _DYF_ CAGE CODE 54453 SCALE: 2:1 8 A EDGECARD, .050" CC, HP, SMT DWG. NO. C11422 REV J SHEET 3 OF 3 1 FILE NAME: C11422, _ _B_ _DYF_-OMIT, S_ _ _ _ MOLDED KEY
GBB80DYFD 价格&库存
很抱歉,暂时无法提供与“GBB80DYFD”相匹配的价格&库存,您可以联系我们找货
GBB80DYFD
  • 10+139.1513510+18.00295
