SFM210-LPPE-S38-SC-BK 数据手册
8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
DESCRIPTION
DATE
BY
A
1910
INITIAL RELEASE
2/5/2009
JH
F
F
E
E
PIN 1
(C MOUNTING)
A
2.00 .079
B
2.00 .079
PIN 1
0.30 .012
1.00 .039
1.40 .055
3.60 .142
1.50 .059
0.60 .024
D
(NOT REQ'D FOR USE
AS TOP ENTRY)
SFM210-LP_E-S_ _-SC-BK
(STANDARD)
(NOT REQ'D FOR USE
AS TOP ENTRY)
2.00 .079
D
A
0.60 .024
B
0.30 .012
0.60 .024
RECOMMENDED PCB LAYOUT
1.00 .039
2.00 .079
3.60 .142
1.50 .059
C
C
1.40 .055
PIN 1
SFM210-LP_E-S_ _-SD-BK
(OPPOSITE BEND, APPLICABLE ON EVEN PIN COUNTS)
PIN 1
(D MOUNTING)
0.60 .024
0.70 .028
2.10 .083
B
A
2.20 .087
0.10 [.004]
B
1.00 .039
NOTES:
A
1. INSULATOR MATERIAL: L.C.P, UL 94V-0, BLACK COLOR.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 1 AMP.
02-20, 0.20mm MAX.
5. INSULATOR RESISTANCE: 1000 MEGA OHMS MIN.
21-50, 0.30mm MAX.
6. CONTACT RESISTANCE: 20 MILLI OHMS MAX.
7. DIELECTRIC WITHSTANDING: AC 300V.
8. OPERATING TEMPERATURE: -40° C TO +125° C.
9. PROCESSING TEMP.: 260° C FOR 10 SECS MAX.
(INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR.
HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS
APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED
INDICATED TEMPERATURE AND TIME.)
10. FOR TOP/BOTTOM ENTRY.
11. CONSULT FACTORY FOR THE MATE IF BEING USED AS BOTTOM ENTRY.
8
7
6
5
0.10 .004
2.90 .114
UNLESS OTHERWISE SPECIFIED:
Pb
DIMENSIONS ARE IN MM[INCHES]
TOLERANCES:
ANGULAR: 5
.X= .30 [.012]
.XX= .20 [.008]
.XXX= .10 [.004]
SURFACE FINISH: 63 Ra
REMOVE ALL BURRS AND SHARP EDGES .010 MAX
RoHS COMPLIANT
4
DRAWN
NAME
2/05/09
JH
THE INFORMATION HEREIN CONTAINS
PROPIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT DESCRIPTION
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
PART NUMBER
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
HEADER, FEMALE 1mm CC, 1 ROW, SMT
SFM210-LP_E-S_ _-S_-BK
SIZE DWG. NO.
C
INTERPRET DIMENSIONS AND GEOMETRIC
TOLERANCING
PER: ANSI Y14.5M-1994
3
DATE
REV
11198
SCALE: 16:1
2
A
SHEET 1 OF 1
1
FILE NAME: C:\Documents and Settings\jhsieh\Desktop\JH PDM WIP\11198, SFM210-LP_E-S_ _-S_-BK PRINT: 3/6/2009
A
SFM210-LPPE-S38-SC-BK 价格&库存
很抱歉,暂时无法提供与“SFM210-LPPE-S38-SC-BK”相匹配的价格&库存,您可以联系我们找货
