STDP4320BA
STDP4320BA
    KINETIC(芯凯)
    LFBGA172
    视频 分线器 IC I²C,SPI 172-LFBGA(12x12) 封装
STDP4320BA 数据手册
Datasheet Brief STDP4320 DisplayPort 1.2a Splitter Kinetic Technologies cannot assume responsibility for use of any circuitry other than circuitry entirely embodied in a Kinetic Technologies product. No intellectual property or circuit patent licenses are implied. Kinetic Technologies reserves the right to change the circuitry and specifications without notice at any time October 2021 – Revision 03c Page 1 of 4 Company Confidential Datasheet Brief STDP4320 Features • HDCP repeater with embedded keys • DisplayPort™ dual mode receiver • AUX to I2C bridge for EDID/MCCS pass through – DP 1.2a compliant – Link rate HBR2/HBR/RBR – Maps on DDC ports • Device configuration options – SST or MST (up to eight streams) – SPI Flash – 1, 2, or 4 lanes – I2C host interface – AUX CH 1 Mbps • Deep color support – HPD out – RGB/YCC (4:4:4) – 16-bit color – HDMI/DVI operation (3.2 Gbps link rate) – YCC (4:2:2) – 16-bit color – Functions as eDP and MyDP receiver • DisplayPort dual mode transmitters – Two transmitter ports – DP 1.2a compliant – Link rate HBR2/HBR/RBR – SST or MST (up to eight streams) – 1, 2, or 4 lanes – AUX CH 1 Mbps – HPD in – HDMI/DVI operation (3.2 Gbps link rate) with external level translator – Functions as eDP transmitter • SPDIF audio output – Two SPDIF port pins • Spread spectrum on DisplayPort interface for EMI reduction • Bandwidth – Video resolution up to 4K2K @ 60 Hz – Audio 7.1 Ch up to 192 kHz sample rate • Low power operation – Standby 30 mW • Package – 172 LFBGA (12 x 12 mm) • Power supply voltages – 3.3 V I/O; 1.2 V core Applications • Audio-video router for PC/notebooks, docking stations, hub, 4K2K TVs, daisy chain monitors, digital signage – 192 kHz/24 bits – Compressed/LPCM • Conversion from DP SST to TMDS format and vice versa October 2021 – Revision 03c Page 2 of 4 Company Confidential Datasheet Brief STDP4320 1. Description The STDP4320 is a high-speed DisplayPort dual mode splitter IC targeted for audio-video demultiplexing and routing in applications such as notebooks, docking stations, video hub, 4K2K TVs, daisy chainable monitors, digital signage, etc. It consists of one dual mode input port and two dual mode output ports configurable as either DisplayPort or HDMI/DVI. STDP4320 is a VESA DP Standard Ver. 1.2a compliant device that supports advanced features such as MST, HBR2, 3D formats and GTC assist. Designs based on STDP4320 have the flexibility to offer either DP or HDMI/DVI connectors on its end product to interface with legacy and new generation video sources and sinks. In addition, STDP4320based products with a DisplayPort output connector are DP++ compliant and work with any HDMI or single link DVI sink through a passive level translator (dongle). The STDP4320 uses Kinetic’s latest generation DisplayPort dual mode receiver and transmitter technology that supports both DisplayPort and TMDS signal formats. This device receives MST format up to eight audio-video streams, which can be further routed on either of the two outputs in any combination of eight streams depending on the capability of downstream sinks. This device can also replicate the incoming video streams on both output ports simultaneously, thus allowing cloning on two downstream sinks. For example, a 4K2K 60 Hz video input is replicated on two output ports simultaneously. The DisplayPort receiver and transmitters support HBR2 speed, a data rate of 5.4 Gbps per lane with a total bandwidth of 21.6 Gbps link rate. In HDMI mode, this device supports link rates up to 3.2 Gbps corresponding to a pixel rate of 300 MHz, adequate for supporting video resolution up to FHD 120 Hz with all 3D formats. The device is also capable of delivering deep color video up to 16-bits per color. The STDP4320 allows audio transport from the source to the desired audio rendering devices over the video output port or through an SPDIF port. The STDP4320 supports RGB and YCbCr colorimetric formats with color depth of 16, 12, 10, and 8 bits. The STDP4320 features the HDCP 1.3 content protection scheme with embedded keys for secure transmission of protected audio-video content. It also operates as an HDCP repeater for the downstream sinks. The DDC ports in the STDP4320 allow the upstream source to access EDID and transfer MCCS commands to downstream sinks when the physical ports are either HDMI or DVI type. If both the upstream source and downstream sinks are DP type, I2C transactions take place over the AUX CH. If one of them is a DP type and the other is either a HDMI or DVI type, STDP4320 converts the I2C over AUX message protocol to I2C commands and sends it on the DDC port. October 2021 – Revision 03c Page 3 of 4 Company Confidential Datasheet Brief STDP4320 The device has an on-chip microcontroller with SPI, UART, and I2C interface. The STDP4320 uses an external SPI Flash ROM for storing device configuration firmware. It has an I2C slave port for external host communication. Other system interface signals include general-purpose IO for source, sink communication, detection, monitoring, etc. When the downstream sink is disconnected, STDP4320 automatically turns off the inactive port for power saving purposes. 2. Application overview Figure 1. STDP4320 in video hub application SPI Flash Crystal Figure 2. STDP4320 in 4K2K TV application 3. Ordering information Table 1. Order codes Part Number Operating Temperature STDP4320-BA 0°C to +70°C October 2021 – Revision 03c Package 172 LFBGA (12 x 12 mm) Page 4 of 4 Company Confidential
STDP4320BA 价格&库存
很抱歉,暂时无法提供与“STDP4320BA”相匹配的价格&库存,您可以联系我们找货
