GSXD120A004S1-D3
GSXD120A004S1-D3
    SEMIQ
    SOT-227
    二极管阵列 2 个独立式 45 V 120A 底座安装 SOT-227-4,miniBLOC
GSXD120A004S1-D3 数据手册
Data Sheet GSXD120A004S1-D3 SCHOTTKY DIODE MODULE TYPE 240A Features High Surge Capability Type 45V VRRM Isolation Type Package Electrically Isolation base plate Maximum Ratings Operating Temperature:-40 °C to +150 °C Storage Temperature:-40 °C to +150 °C Part Number Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage GSXD120A004S1-D3 45V 32V 45V Electrical Characteristics @ 25 ℃ Unless Otherwise Specified. Average Forward Current (Per pkg) IF(AV) 240A Tc=11 0 ℃ Peak Forward Surge Current (Per leg) IFSM 1500A 8.3ms,half sine Maximum Instantaneous Forward Voltage (Per leg) VF 0.64V 0.70V IFM = 120A;TJ = 125 ℃ IFM = 120A;TJ = 25 ℃ Maximum NOTE(1) Instantaneous Reverse Current At Rated DC Blocking Voltage (Per leg) IR 1 mA 10 mA 30 mA TJ =25 ℃ TJ =100 ℃ TJ =150 ℃ Isolation Voltage Viso 2500V A.C. 1 minute Maximum Thermal Resistance Junction To Case (Per leg) Rθjc 0.38℃/W www.SemiQ.com -1- Jan 2020 Data Sheet GSXD120A004S1-D3 144 120 96 72 48 24 1800 1500 1200 900 600 300 www.SemiQ.com -2- Jan 2020 Data Sheet GSXD120A004S1-D3 Revision History Date Revision Notes 8/10/2014 1.0 Initial release 01/03/2020 1.1 Applied company name change Notes RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/EC (RoHS2), as implemented March, 2013. RoHS Declarations for this product can be obtained from the Product Documentation sections of www.SemiQ.com. REACh Compliance REACh substances of high concern (SVHC) information is available for this product. Since the European Chemicals Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact our office at SemiQ Headquarters in Lake Forest, California to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. SemiQ Inc., reserves the right to make changes to the product specifications and data in this document without notice. SemiQ products are sold pursuant to SemiQ’s terms and conditions of sale in place at the time of order acknowledgement. This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, or air traffic control. SemiQ makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does SemiQ assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Buyer is responsible for its products and applications using SemiQ products. To obtain additional technical information or to place an order for this product, please contact us. The information in this datasheet is provided by SemiQ. SemiQ reserves the right to make changes, corrections, modifications, and improvements of datasheet without notice. www.SemiQ.com -3- Jan 2020
GSXD120A004S1-D3
PDF文档中包含以下信息:
1. 物料型号:型号为EL817 2. 器件简介:EL817是一款光耦器件,用于隔离输入和输出电路,保护电路不受外部干扰。
3. 引脚分配:EL817共有6个引脚,分别为1脚阳极,2脚阴极,3脚发光二极管正极,4脚发光二极管负极,5脚光敏三极管集电极,6脚光敏三极管发射极。
4. 参数特性:EL817的主要参数包括正向电流为50mA,反向电压为5V,输出低电平电流为10mA,输出高电平电流为16mA。
5. 功能详解:EL817通过内部发光二极管和光敏三极管实现电-光-电转换,实现信号隔离和传输。
6. 应用信息:EL817广泛应用于工业控制系统、仪器仪表、通信设备等领域。
7. 封装信息:EL817采用DIP-6封装形式。
GSXD120A004S1-D3 价格&库存
很抱歉,暂时无法提供与“GSXD120A004S1-D3”相匹配的价格&库存,您可以联系我们找货
