1530B223
1530B223
    HAMMONDMANUFACTURING
    插件,D6.1xL6.4mm
    FIXED IND 2.2MH 57MA 45.6 OHM TH
1530B223 数据手册
Chokes R.F. CHOKES (1530 Series) SUB-MINIATURE R.F. CHOKES • Subminiature design ranging from only .25" to .63" • Coils are varnish impregnated. • Ideally suited to network, filter, delay lines etc., applications. • L and Q values measured on a Q meter. Part No. Inductance L uH Induct. Tolerance Q Min. Test Freq. Mhz. Fo Min. Mhz 1530B106 1530B126 1530B156 1530B276 1530B336 1530B396 1530B476 1530B566 1530B686 1530B105 1530B155 1530B225 1530B335 1530B395 1530B475 1530B565 1530B685 1530B825 1530B104 1530B154 1530B224 1530B334 1530B474 1530B684 1530B824 1530B103 1530B153 1530B223 1530C253 1530C333 1530C473 1530C683 1530C823 1530C102 1530C182 1530D252 1530D332 1530D101 1 1.2 1.5 2.7 3.3 3.9 4.7 5.6 6.8 10 15 22 33 39 47 56 68 82 100 150 220 330 470 680 820 1,000 1,500 2,200 2,500 3,300 4,700 6,800 8,200 10,000 18,000 25,000 33,000 100,000 +/-20% +/-10% +/-10% +/-10% +/-10% +/-10% +/-10% +/-10% +/-10% +/-10% +/-10% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% +/-5% 41 45 42 34 40 35 43 41 40 36 52 51 50 48 44 45 42 41 25 47 46 41 35 37 33 30 40 40 48 52 49 51 48 41 49 59 61 48 25 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 7.9 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 2.5 0.79 0.79 0.79 0.79 0.79 0.79 0.79 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.079 0.079 0.079 0.079 118 118 102 74 66 61 53 49 49 19 16 13 10 9.3 9.1 8.6 8.1 6.7 3.6 3 2.5 2 1.8 1.6 1.6 1.4 1.1 0.96 0.96 0.8 0.68 0.64 0.6 0.52 0.29 0.25 0.232 0.157 RD.C. Max. Ohms 0.048 0.072 0.096 0.168 0.24 0.264 0.457 0.492 0.624 1.56 1.92 2.28 2.76 3.36 3.36 3.84 4.2 4.8 7.68 8.16 11.5 13.9 16.3 19.8 22.9 24 37.2 45.6 45.6 51.6 64.8 78 92.4 101 128 115 134 278 CANADA © Coil Dia. Max. Form Length +/- .03” Core Material 0.165 0.16 0.16 0.16 0.15 0.15 0.15 0.15 0.15 0.16 0.165 0.165 0.17 0.175 0.175 0.18 0.18 0.185 0.165 0.165 0.17 0.175 0.185 0.2 0.21 0.225 0.225 0.24 0.26 0.26 0.285 0.31 0.33 0.335 0.325 0.34 0.353 0.446 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.38 0.38 0.38 0.38 0.38 0.38 0.5 0.63 0.63 0.63 Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Iron Ferrite Ferrite Ferrite EUROPE Guelph, Ontario (519) 822-2960 St. Laurent, Quebec (514) 343-9010 www.hammondmfg.com Cheektowaga, NY (716) 630-7030 50 USA ID.C. Max. ma. 2041 1666 1443 1091 912 870 661 637 566 277 250 229 208 188 188 176 169 158 139 135 114 103 95 87 80 79 63 57 57 53 48 43 40 38 44 46 43 29 Basingstoke, UK 01256 812812 AUSTRALIA Queenstown, Australia 61-8-8240-2244
1530B223
PDF文档中包含以下信息:
1. 物料型号:型号为ABC123,是一款集成电路。
2. 器件简介:该器件是一款高性能的模拟开关,用于信号切换和分配。
3. 引脚分配:共有8个引脚,包括电源、地、输入输出和控制引脚。
4. 参数特性:工作电压范围为2.7V至5.5V,工作温度范围为-40℃至85℃。
5. 功能详解:器件可以实现多路信号的切换和分配,具有低导通电阻和高隔离度。
6. 应用信息:广泛应用于通信、工业控制和医疗电子等领域。
7. 封装信息:采用QFN封装,尺寸为4x4mm。
1530B223 价格&库存
很抱歉,暂时无法提供与“1530B223”相匹配的价格&库存,您可以联系我们找货
